[MOAB-dev] r3370 - MOAB/trunk
    kraftche at cae.wisc.edu
    Wed Nov 18 15:09:38 CST 2009
Author: kraftche
Date: 2009-11-18 15:09:38 -0600 (Wed, 18 Nov 2009)
New Revision: 3370
Modified:
   MOAB/trunk/MBCore.cpp
   MOAB/trunk/MBCore.hpp
   MOAB/trunk/MBInterface.hpp
Log:
change private MBCore::get_vertices into public range-range version of get_connectivity
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp	2009-11-18 02:31:34 UTC (rev 3369)
+++ MOAB/trunk/MBCore.cpp	2009-11-18 21:09:38 UTC (rev 3370)
@@ -1242,8 +1242,9 @@
     return MB_FAILURE;
-MBErrorCode MBCore::get_vertices( const MBRange& from_entities,
-                                  MBRange& adj_entities )
+MBErrorCode MBCore::get_connectivity( const MBRange& from_entities,
+                                      MBRange& adj_entities,
+                                      bool corners_only ) const
   const size_t DEFAULT_MAX_BLOCKS_SIZE = 4000;
   const size_t MAX_OUTER_ITERATIONS = 100;
@@ -1271,23 +1272,12 @@
     remaining -= count;
     temp_vec.clear();
     for (size_t j = 0; j < count; ++i, ++j) {
-      tmp_result = get_connectivity( *i, conn, conn_len, false, &storage );
+      tmp_result = get_connectivity( *i, conn, conn_len, corners_only, &storage );
       if (MB_SUCCESS != tmp_result) {
         result = tmp_result;
         continue;
-      if (TYPE_FROM_HANDLE(*i) == MBPOLYHEDRON) {
-        storage.clear();
-        tmp_result = get_connectivity( conn, conn_len, storage );
-        if (MB_SUCCESS != tmp_result) {
-          result = tmp_result;
-          continue;
-        conn_len = storage.size();
-        conn = &storage[0];
       const size_t oldsize = temp_vec.size();
       temp_vec.resize( oldsize + conn_len );
       memcpy( &temp_vec[oldsize], conn, sizeof(MBEntityHandle)*conn_len );
@@ -1307,6 +1297,32 @@
   return result;
+MBErrorCode MBCore::get_vertices( const MBRange& from_entities,
+                                  MBRange& vertices )
+  MBRange range;
+  MBErrorCode rval = get_connectivity( from_entities, range );
+    // If input contained polyhedra, connectivity will contain faces.
+    // Get vertices from faces.
+  if (MB_SUCCESS == rval && !range.all_of_dimension(0)) {
+    MBRange::iterator it = range.upper_bound(MBVERTEX);
+    MBRange polygons;
+    polygons.merge( it, range.end() );
+    range.erase( it, range.end() );
+    rval = get_connectivity( polygons, range );
+  if (MB_SUCCESS != rval)
+    return rval;
+  if (vertices.empty())
+    vertices.swap( range );
+  else
+    vertices.merge( range );
+  return MB_SUCCESS;
 MBErrorCode MBCore::get_adjacencies(const MBRange &from_entities,
                                       const int to_dimension,
                                       const bool create_if_missing,
Modified: MOAB/trunk/MBCore.hpp
--- MOAB/trunk/MBCore.hpp	2009-11-18 02:31:34 UTC (rev 3369)
+++ MOAB/trunk/MBCore.hpp	2009-11-18 21:09:38 UTC (rev 3370)
@@ -212,6 +212,13 @@
                                         const int num_handles,
                                         MBRange &connectivity,
                                         bool topological_connectivity = false) const;
+    //! Gets the connectivity for elements
+    /** Same as vector-based version except range is returned (unordered!)
+  virtual MBErrorCode get_connectivity( const MBRange& entity_handles,
+                                        MBRange &connectivity,
+                                        bool topological_connectivity = false) const;
     //! Gets a pointer to constant connectivity data of <em>entity_handle</em>
       /** Sets <em>number_nodes</em> equal to the number of nodes of the <em>
Modified: MOAB/trunk/MBInterface.hpp
--- MOAB/trunk/MBInterface.hpp	2009-11-18 02:31:34 UTC (rev 3369)
+++ MOAB/trunk/MBInterface.hpp	2009-11-18 21:09:38 UTC (rev 3370)
@@ -426,6 +426,13 @@
                                         bool topological_connectivity = false) const =0;
+                                        bool topological_connectivity = false) const =0;
     //! Gets the connectivity for a vector of elements
     /** Corner vertices or all vertices (including higher-order nodes, if any) are returned.
