[MOAB-dev] variable-length arrays
Jason Kraftcheck
kraftche at cae.wisc.edu
Tue Nov 17 16:01:13 CST 2009
After reading Jed's reply, I tried a few simple timing tests. The
variable-size stack offset when using VLAs seems to result in worse
performance than a much safer stack/heap combined approach such as:
void foo( int n ) {
int fixed_array[100];
std::vector<int> dyn_array;
int* array = fixed_array;
if (n > sizeof(fixed_array)/sizeof(int)) {
dyn_array.resize(n);
array = &dyn_array[0];
And this solution is amiable to encapsulation in a template class, unlike
VLAs. So it appears that it is best to continue to avoid the use of VLAs.
- jason
Jason Kraftcheck wrote:
> Beginning with the C99 standard, the C language has had support for
> automatic-duration variable-length arrays. For example:
> void foo( int n ) {
> int array[n]; // 'n' is *not* a constant
> No C++ standard incorporates this feature yet. However, given that a) it is
> common for much code to be shared between C and C++ compilers from the same
> vendor, b) this feature has been in the C standard for a decade, and c) this
> feature will be included in the next C++ standard, it seems likely that many
> C++ compilers support this feature now (e.g The Gnu compiler does.)
> It is possible to get the same functionality in c++ using std::vector
> (except for arrays of bool, and assuming the time to zero the memory isn't
> significant). However, std::vector allocates storage on the heap while a
> automatic array will (typically) be allocated on the stack. For a few cases
> involving tight loops where the performance with heap allocation is
> unacceptable, it would be nice to be able to use var-len auto arrays.
> We have not this feature anywhere in MOAB or CGM so far because of possible
> portability issues. Does anyone have any experience with using
> variable-length automatic arrays in C++ code that is built on diverse systems?
> - jason
"A foolish consistency is the hobgoblin of little minds" - Ralph Waldo Emerson
