[MOAB-dev] r3243 - MOAB/trunk
Tim Tautges
tautges at mcs.anl.gov
Mon Oct 26 11:52:48 CDT 2009
Hi Brandon (and others),
Any time you add functionality to the interface or change something major in its behavior, you need to add a unit
test that verifies things work correctly. Most of the time those tests are in MBTest.cpp, though there are other
smaller unit test programs around too. If you're uncertain where they should go, just ask.
- tim
bmsmith6 at wisc.edu wrote:
> Author: bmsmith
> Date: 2009-10-26 10:42:27 -0500 (Mon, 26 Oct 2009)
> New Revision: 3243
> Modified:
> MOAB/trunk/MBCore.cpp
> MOAB/trunk/MBCore.hpp
> MOAB/trunk/MBInterface.hpp
> Log:
> Add interface function to change the options of a meshset.
> Modified: MOAB/trunk/MBCore.cpp
> --- MOAB/trunk/MBCore.cpp 2009-10-26 14:36:13 UTC (rev 3242)
> +++ MOAB/trunk/MBCore.cpp 2009-10-26 15:42:27 UTC (rev 3243)
> @@ -2436,6 +2436,17 @@
> return MB_SUCCESS;
> +MBErrorCode MBCore::set_meshset_options( const MBEntityHandle ms_handle,
> + const unsigned int options)
> + MBMeshSet* set = get_mesh_set( sequence_manager(), ms_handle );
> + if (!set)
> + return MB_ENTITY_NOT_FOUND;
> + return set->set_flags(options, ms_handle, a_entity_factory());
> MBErrorCode MBCore::clear_meshset( const MBEntityHandle *ms_handles,
> const int num_meshsets)
> Modified: MOAB/trunk/MBCore.hpp
> --- MOAB/trunk/MBCore.hpp 2009-10-26 14:36:13 UTC (rev 3242)
> +++ MOAB/trunk/MBCore.hpp 2009-10-26 15:42:27 UTC (rev 3243)
> @@ -845,6 +845,10 @@
> virtual MBErrorCode get_meshset_options(const MBEntityHandle ms_handle,
> unsigned int& options) const;
> + //! set the options of a mesh set
> + virtual MBErrorCode set_meshset_options(const MBEntityHandle ms_handle,
> + const unsigned int options);
> //! subtracts meshset2 from meshset1 - modifies meshset1
> virtual MBErrorCode subtract_meshset(MBEntityHandle meshset1,
> const MBEntityHandle meshset2);
> Modified: MOAB/trunk/MBInterface.hpp
> --- MOAB/trunk/MBInterface.hpp 2009-10-26 14:36:13 UTC (rev 3242)
> +++ MOAB/trunk/MBInterface.hpp 2009-10-26 15:42:27 UTC (rev 3243)
> @@ -1316,6 +1316,14 @@
> unsigned int& options) const = 0;
> + //! Set the options of a mesh set
> + /** Set the options of a mesh set.
> + \param ms_handle Handle for meshset whose options are being changed
> + \param options Bit mask of options to be used
> + const unsigned int options) = 0;
> //! Subtract meshsets
> /** Subtract <em>meshset2</em> from <em>meshset1</em>, placing the results in meshset1.
> \param meshset1 Mesh set being subtracted from, also used to pass back result
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
