[MOAB-dev] Problems with ReadCGM
Steve Jackson
sjackson at cae.wisc.edu
Mon Oct 26 17:50:36 CDT 2009
I have an issue with ReadCGM that's been puzzling me for a couple of
days. Perhaps someone on this list can help me determine the problem.
Below is a simple program that loads an acis .sat geometry into MOAB.
When MOAB is compiled with an acis-based CGM, the code below works
fine. However, when MOAB is compiled against a cubit-based CGM, the
code below fails.
> #include "MBCore.hpp"
> #include <iostream>
> int main(){
> MBErrorCode rval;
> MBEntityHandle file_set;
> MBCore* MBI = new MBCore();
> rval = MBI->load_file("geom.sat", file_set, "", NULL, 0, 0);
> if (MB_SUCCESS != rval) {
> std::cerr << "Couldn't read file. " << std::endl;
> return rval;
> return 0;
The initial failure occurs in ReadCGM::load_file, at line 393 of
ReadCGM.cpp. The first call to gqe->get_graphics() produces an error
message (below) and returns failure. This in turn causes
ReadCGM::load_file() to fail.
The error message produced within the get_graphics() call is:
> ERROR: In AcisQueryEngine::get_Body
> Body is not a BodyACIS.
Note that get_graphics() is being called with a Curve object, not a
Body.
The error happens predictably and seems to occur with any .sat file I
provide. My CGM is built against Cubit 10.22, and MOAB is the latest
revision from SVN. I also tried compiling MOAB with svn revision
3005, just before the last major revision to ReadCGM.cpp, but got the
same error.
Has anyone encountered this issue before?
~S
