[MOAB-dev] r3243 - MOAB/trunk
bmsmith6 at wisc.edu
Mon Oct 26 10:42:27 CDT 2009
Author: bmsmith
Date: 2009-10-26 10:42:27 -0500 (Mon, 26 Oct 2009)
New Revision: 3243
Modified:
MOAB/trunk/MBCore.cpp
MOAB/trunk/MBCore.hpp
MOAB/trunk/MBInterface.hpp
Log:
Add interface function to change the options of a meshset.
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2009-10-26 14:36:13 UTC (rev 3242)
+++ MOAB/trunk/MBCore.cpp 2009-10-26 15:42:27 UTC (rev 3243)
@@ -2436,6 +2436,17 @@
return MB_SUCCESS;
+MBErrorCode MBCore::set_meshset_options( const MBEntityHandle ms_handle,
+ const unsigned int options)
+ MBMeshSet* set = get_mesh_set( sequence_manager(), ms_handle );
+ if (!set)
+ return MB_ENTITY_NOT_FOUND;
+ return set->set_flags(options, ms_handle, a_entity_factory());
MBErrorCode MBCore::clear_meshset( const MBEntityHandle *ms_handles,
const int num_meshsets)
Modified: MOAB/trunk/MBCore.hpp
--- MOAB/trunk/MBCore.hpp 2009-10-26 14:36:13 UTC (rev 3242)
+++ MOAB/trunk/MBCore.hpp 2009-10-26 15:42:27 UTC (rev 3243)
@@ -845,6 +845,10 @@
virtual MBErrorCode get_meshset_options(const MBEntityHandle ms_handle,
unsigned int& options) const;
+ //! set the options of a mesh set
+ virtual MBErrorCode set_meshset_options(const MBEntityHandle ms_handle,
+ const unsigned int options);
//! subtracts meshset2 from meshset1 - modifies meshset1
virtual MBErrorCode subtract_meshset(MBEntityHandle meshset1,
const MBEntityHandle meshset2);
Modified: MOAB/trunk/MBInterface.hpp
--- MOAB/trunk/MBInterface.hpp 2009-10-26 14:36:13 UTC (rev 3242)
+++ MOAB/trunk/MBInterface.hpp 2009-10-26 15:42:27 UTC (rev 3243)
@@ -1316,6 +1316,14 @@
unsigned int& options) const = 0;
+ //! Set the options of a mesh set
+ /** Set the options of a mesh set.
+ \param ms_handle Handle for meshset whose options are being changed
+ \param options Bit mask of options to be used
+ const unsigned int options) = 0;
//! Subtract meshsets
/** Subtract <em>meshset2</em> from <em>meshset1</em>, placing the results in meshset1.
\param meshset1 Mesh set being subtracted from, also used to pass back result
