[MOAB-dev] r3241 - MOAB/trunk
bmsmith6 at wisc.edu
Thu Oct 22 12:13:58 CDT 2009
Author: bmsmith
Date: 2009-10-22 12:13:57 -0500 (Thu, 22 Oct 2009)
New Revision: 3241
Modified:
MOAB/trunk/AEntityFactory.cpp
MOAB/trunk/MBAdaptiveKDTree.cpp
MOAB/trunk/ReadCGM.cpp
Log:
Undo previous commit to the wrong repo
Modified: MOAB/trunk/AEntityFactory.cpp
--- MOAB/trunk/AEntityFactory.cpp 2009-10-22 16:51:06 UTC (rev 3240)
+++ MOAB/trunk/AEntityFactory.cpp 2009-10-22 17:13:57 UTC (rev 3241)
@@ -31,8 +31,6 @@
#include <algorithm>
#include <set>
-#include <iostream> // brandon
MBErrorCode AEntityFactory::get_vertices( MBEntityHandle h,
const MBEntityHandle*& vect_out,
int& count_out,
@@ -586,7 +584,6 @@
bool create_if_missing,
std::vector<MBEntityHandle> &adjacent_entities)
- //std::cout << "mVertElemAdj=" << mVertElemAdj << std::endl;
MBEntityType ent_type = TYPE_FROM_HANDLE(entity);
if (ent_type == MBMAXTYPE) return MB_TYPE_OUT_OF_RANGE;
Modified: MOAB/trunk/MBAdaptiveKDTree.cpp
--- MOAB/trunk/MBAdaptiveKDTree.cpp 2009-10-22 16:51:06 UTC (rev 3240)
+++ MOAB/trunk/MBAdaptiveKDTree.cpp 2009-10-22 17:13:57 UTC (rev 3241)
@@ -1491,11 +1491,9 @@
return rval;
// test that point is inside tree
- // Brandon: add a tolerance
- double tol = 0.001;
- if (point[0] < result.box_min()[0]-tol || point[0] > result.box_max()[0]+tol ||
- point[1] < result.box_min()[1]-tol || point[1] > result.box_max()[1]+tol ||
- point[2] < result.box_min()[2]-tol || point[2] > result.box_max()[2]+tol)
+ if (point[0] < result.box_min()[0] || point[0] > result.box_max()[0] ||
+ point[1] < result.box_min()[1] || point[1] > result.box_max()[1] ||
+ point[2] < result.box_min()[2] || point[2] > result.box_max()[2])
return MB_ENTITY_NOT_FOUND;
// initialize iterator at tree root
Modified: MOAB/trunk/ReadCGM.cpp
--- MOAB/trunk/ReadCGM.cpp 2009-10-22 16:51:06 UTC (rev 3240)
+++ MOAB/trunk/ReadCGM.cpp 2009-10-22 17:13:57 UTC (rev 3241)
@@ -191,8 +191,7 @@
for (int i = entlist.size(); i--; ) {
RefEntity* ent = entlist.get_and_step();
MBEntityHandle handle;
- rval = mdbImpl->create_meshset( dim == 1 ? MESHSET_ORDERED | MESHSET_TRACK_OWNER :
- MESHSET_SET | MESHSET_TRACK_OWNER, handle );
+ rval = mdbImpl->create_meshset( dim == 1 ? MESHSET_ORDERED : MESHSET_SET, handle );
if (MB_SUCCESS != rval)
return rval;
