[MOAB-dev] Error removing entity sets from entity sets
James Porter
jvporter at wisc.edu
Tue Oct 20 17:37:48 CDT 2009
I noticed this bug when running the PyTAPS tests on iMesh. It seems that
if you 1) add entity set A to entity set B, and then 2) remove A from B,
calling iMesh_isEntSetContained(mesh, B, A, ...); still returns true,
when it should be returning false. Attached is some C code that shows
the error in action.
- Jim
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20091020/08e9a721/attachment.c>
