[MOAB-dev] r3237 - MOAB/trunk/tools/iMesh
kraftche at cae.wisc.edu
Tue Oct 20 18:27:57 CDT 2009
Author: kraftche
Date: 2009-10-20 18:27:56 -0500 (Tue, 20 Oct 2009)
New Revision: 3237
Modified:
MOAB/trunk/tools/iMesh/testc_cbind.c
Log:
add regressesion test for bug found by Jim
Modified: MOAB/trunk/tools/iMesh/testc_cbind.c
--- MOAB/trunk/tools/iMesh/testc_cbind.c 2009-10-20 22:18:24 UTC (rev 3236)
+++ MOAB/trunk/tools/iMesh/testc_cbind.c 2009-10-20 23:27:56 UTC (rev 3237)
@@ -2065,6 +2065,39 @@
&& tag_delete_success);
+int set_remove_contained_regression( iMesh_Instance mesh )
+ int err,contained;
+ iBase_EntitySetHandle set,sub;
+ iMesh_createEntSet(mesh,0,&set,&err);
+ if (iBase_SUCCESS != err) return 0;
+ iMesh_createEntSet(mesh,1,&sub,&err);
+ iMesh_addEntSet(mesh,sub,set,&err);
+ iMesh_isEntSetContained(mesh,set,sub,&contained,&err);
+ if (!contained) {
+ fprintf(stderr,"isEntSetContained returned false for contained set\n");
+ return 0;
+ iMesh_rmvEntSet(mesh,sub,set,&err);
+ if (contained) {
+ fprintf(stderr,"isEntSetContained returned true for removed set\n");
+ return 0;
+ return 1;
int main( int argc, char *argv[] )
/* Check command line arg */
@@ -2184,6 +2217,15 @@
number_tests++;
printf("\n");
+ /* regression test for remove/contained bug */
+ printf(" set_remove_contained_regression: ");
+ result = set_remove_contained_regression(mesh);
+ handle_error_code(result, &number_tests_failed,
+ &number_tests_not_implemented,
+ &number_tests_successful);
+ number_tests++;
+ printf("\n");
/* summary */
printf("\nTSTT TEST SUMMARY: \n");
