[MOAB-dev] MOAB build on windows
    tautges at mcs.anl.gov
    Wed Aug 19 14:47:52 CDT 2009
Forwarding to Moab-dev...
- tim
On Aug 17, 2009, at 1:28 PM, Alfred von Loebbecke <vonloebbecke at pa.nrl.navy.mil
 > wrote:
> Hi Tim,
> I've been trying to build MOAB under Visual Studio 2005 under
> windows XP
> and was hoping you might be able to point me in the right direction.
> Specifically I'm using the /clr:oldsyntax switch, as it says its
> needed. I'm also using
> exception handling /EHa, since /EHs is apparently incompatible with /
> clr:oldsyntax.
> Now suddenly I'm getting a bunch of syntax errors and unexpected
> tokens. Have you come across this
> by any chance? Any tips would be great. thanks and regards,
> Alfred
