[MOAB-dev] Question about getting entities with tag data
Paul Wilson
wilsonp at engr.wisc.edu
Tue Aug 18 13:19:27 CDT 2009
Jason Kraftcheck wrote:
> Paul Wilson wrote:
>> Hi there,
>> I have been digging through the interface and I can't seem to find a
>> function that will return an MBRange of entities formed by matching a
>> single tag against a set of tag values. As far as I can tell,
>> get_entities_by_type_and_tag will return an MBRange of entities
>> formed by matching N tags against N corresponding values, but will
>> not match 1 tag against M values.
>> Is there such a function? If not, is there a recommended way to
>> resolve this?
> You can call the existing function m times, passing the
> MBInterface::UNITE flag (or INTERSECT if that's what you want.) Or
> pass in m copies of the tag handle.
>> My first attempt was to get each entity one at a time, but that is
>> extremely slow. Perhaps better to get the tag data for all possible
>> entities and then throw out the ones that are not needed?
> MOAB's search of tag values is O(n). If you need something faster,
> you'll have to construct your own map or hash table from value to handle.
That's what I did - got all tag values, put it into
map<tag_value,MBEntityHandle> and used STL algorithms to achieve what I
needed.
Paul
Paul P H Wilson UW-Madison Engineering Physics
Associate Professor 419 Engineering Research Bldg
wilsonp at engr.wisc.edu 1500 Engineering Dr
608/263-0807 fax:608/263-4499 Madison, WI 53706
http://www.cae.wisc.edu/~wilsonp http://www.engr.wisc.edu/ep
My calendar
http://www.google.com/calendar/embed?src=paul@nagus-wilson.net
Contributing to the joy and improvement
of all those around me
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20090818/7e80f7d3/attachment.bin>
