[MOAB-dev] Question about getting entities with tag data
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Tue Aug 18 09:15:59 CDT 2009
Paul Wilson wrote:
> Hi there,
> I have been digging through the interface and I can't seem to find a
> function that will return an MBRange of entities formed by matching a
> single tag against a set of tag values.  As far as I can tell,
> get_entities_by_type_and_tag will return an MBRange of entities formed
> by matching N tags against N corresponding values, but will not match 1
> tag against M values.
> Is there such a function?  If not, is there a recommended way to resolve
> this?
You can call the existing function m times, passing the
MBInterface::UNITE flag (or INTERSECT if that's what you want.)  Or pass
in m copies of the tag handle.
> My first attempt was to get each entity one at a time, but that
> is extremely slow.  Perhaps better to get the tag data for all possible
> entities and then throw out the ones that are not needed?
MOAB's search of tag values is O(n).  If you need something faster,
you'll have to construct your own map or hash table from value to handle.
- jason
