[MOAB-dev] Question about getting entities with tag data
    Paul Wilson
    wilsonp at engr.wisc.edu
    Mon Aug 17 23:27:57 CDT 2009
Hi there,
I have been digging through the interface and I can't seem to find a
function that will return an MBRange of entities formed by matching a
single tag against a set of tag values.  As far as I can tell,
get_entities_by_type_and_tag will return an MBRange of entities formed
by matching N tags against N corresponding values, but will not match 1
tag against M values.
Is there such a function?  If not, is there a recommended way to resolve
this?  My first attempt was to get each entity one at a time, but that
is extremely slow.  Perhaps better to get the tag data for all possible
entities and then throw out the ones that are not needed?
Paul
Paul P H Wilson                  UW-Madison Engineering Physics
Associate Professor               419 Engineering Research Bldg
wilsonp at engr.wisc.edu                       1500 Engineering Dr
608/263-0807 fax:608/263-4499                 Madison, WI 53706
http://www.cae.wisc.edu/~wilsonp    http://www.engr.wisc.edu/ep
                       My calendar
http://www.google.com/calendar/embed?src=paul@nagus-wilson.net
          Contributing to the joy and improvement
                  of all those around me
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20090817/69c0e4f2/attachment.bin>
