[MOAB-dev] r3056 - in MOAB/trunk: parallel test
tautges at mcs.anl.gov tautges at mcs.anl.gov
Thu Jul 23 15:13:21 CDT 2009
Author: tautges
Date: 2009-07-23 15:13:21 -0500 (Thu, 23 Jul 2009)
New Revision: 3056
Modified:
   MOAB/trunk/parallel/MBParallelComm.cpp
   MOAB/trunk/parallel/MBParallelComm.hpp
   MOAB/trunk/parallel/pcomm_unit.cpp
   MOAB/trunk/test/64bricks_512hex.h5m
Log:
Fixing some remaining bugs in interface exchange and parallel
ghosting.  ALL parallel tests done for "make check" now work, except
for some of the iMeshP functions.  I still see some errors with some
other files, will track those down next.
parallel/pcomm_unit: added ability to serially test for more general
  cases (allow input of distrib flag, instead of hardcoding it); also
  now points to source directory if using out-of-source build
parallel/MBParallelComm:
- reserve MAX_SHARING_PROCS spaces in buffer and proc vectors; this
works around a bug, where, when the vector was resized due to adding
another processor as a result of ghost communication, some pointers
into the old vector became stale; this results in a maximum of
2*MAX_SHARING_PROCS*sizeof(std::vector<MBEntityHandle>) wasted space
on a processor, which is ok for now.
- make init function to call from both constructors
- got rid of unused myBuffers vector
- added a few asserts to make sure we weren't trying to unpack -1 ints
- adjusted list_entities argument processing for consistency with
MBCore behavior
- changed get_sharing_data and made another variant of same, that is
able to perform booleans on results, e.g. give me the processors
sharing all these entities; substituted some repeated code doing this
type of evaluation with call to this function
- added tag_iface_entities function, to correctly tag the non-vertex
entities in interface sets according to the pstatus of the interface
set; this is done after exchanging ghost cells call returns, rather
than during the function itself, because some entities previously
though to be interface ents are removed during that process
- fixed a few memory leaks and uninitialized variables
- for interface sets, assign at least part of the shared handles tag
to reflect local handle of set
- broke up consistency checking tests, and saved strings indicating
reason for failed checks, for individual entities, and repeats these
reasons in output when consistency check fails
- when DEBUG_COMM is defined, use barriers at the end of major rounds
of communication during ghost exchange
test/64bricks_512hex.h5m: changing, in case this was generated while
HDF5 wasn't working (probably not, but just to be safe).
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp	2009-07-23 18:04:18 UTC (rev 3055)
+++ MOAB/trunk/parallel/MBParallelComm.cpp	2009-07-23 20:13:21 UTC (rev 3056)
@@ -18,6 +18,7 @@
 #include <iostream>
 #include <sstream>
 #include <algorithm>
+#include <functional>
 #include <numeric>
 #define MIN(a,b) (a < b ? a : b)
@@ -172,22 +173,8 @@
           sharedhTag(0), sharedhsTag(0), pstatusTag(0), ifaceSetsTag(0),
           partitionTag(0), globalPartCount(-1), partitioningSet(0)
-  myBuffer.resize(INITIAL_BUFF_SIZE);
-  tagServer = dynamic_cast<MBCore*>(mbImpl)->tag_server();
-  sequenceManager = dynamic_cast<MBCore*>(mbImpl)->sequence_manager();
-  int flag = 1;
-  int retval = MPI_Initialized(&flag);
-  if (MPI_SUCCESS != retval || !flag) {
-    int argc = 0;
-    char **argv = NULL;
-      // mpi not initialized yet - initialize here
-    retval = MPI_Init(&argc, &argv);
-  pcommID = add_pcomm(this);
+  initialize();
   if (id)
     *id = pcommID;
@@ -201,7 +188,23 @@
-  myBuffer.swap(tmp_buff);
+  initialize();
+  if (id)
+    *id = pcommID;
+MBParallelComm::~MBParallelComm()
+  remove_pcomm(this);
+void MBParallelComm::initialize()
+  tagServer = dynamic_cast<MBCore*>(mbImpl)->tag_server();
+  sequenceManager = dynamic_cast<MBCore*>(mbImpl)->sequence_manager();
+    // initialize MPI, if necessary
   int flag = 1;
@@ -212,16 +215,14 @@
+    // reserve space for vectors
+  buffProcs.reserve(MAX_SHARING_PROCS);
+  ownerSBuffs.reserve(MAX_SHARING_PROCS);
+  ghostRBuffs.reserve(MAX_SHARING_PROCS);
-  if (id)
-    *id = pcommID;
-MBParallelComm::~MBParallelComm()
-  remove_pcomm(this);
 int MBParallelComm::add_pcomm(MBParallelComm *pc)
     // add this pcomm to instance tag
@@ -575,8 +576,6 @@
                                           std::vector<unsigned int> &L2p,
                                           MBRange &new_ents)
-  if (myBuffer.capacity() == 0) return MB_FAILURE;
 #ifdef DEBUG_PACKING
     unsigned char *tmp_buff = buff_ptr;
 #endif
@@ -1260,6 +1259,7 @@
       if (store_remote_handles) {
           // pointers to other procs/handles
         UNPACK_INT(buff_save, num_ps);
+        assert("Shouldn't ever be fewer than 1 procs here." && 0 < num_ps);
         UNPACK_INTS(buff_save, &ps[0], num_ps);
         UNPACK_EH(buff_save, &hs[0], num_ps);
@@ -1498,7 +1498,7 @@
     return MB_SUCCESS;
-  else if (NULL == ents || 0 == num_ents) {
+  else if (NULL == ents && 0 != num_ents) {
     return list_entities(sharedEnts);
@@ -1509,10 +1509,11 @@
   MBErrorCode result;
   for (int i = 0; i < num_ents; i++) {
+    result = mbImpl->list_entities(ents+i, 1);
     result = get_sharing_data(ents[i], tmp_procs, tmp_handles, pstat, num_ps);
     RRA("Failed to get sharing data.");
-    result = mbImpl->list_entities(ents+i, 1);
     std::cout << "Pstatus: ";
     if (!num_ps)
       std::cout << "local " << std::endl;
@@ -1706,7 +1707,55 @@
   return MB_SUCCESS;
-MBErrorCode MBParallelComm::get_sharing_data(MBEntityHandle entity,
+MBErrorCode MBParallelComm::get_sharing_data(const MBRange &entities,
+                                             std::set<int> &procs,
+                                             int operation)
+    // get the union or intersection of sharing data for multiple entities
+  MBErrorCode result;
+  int sp2[MAX_SHARING_PROCS];
+  int num_ps;
+  unsigned char pstat;
+  std::set<int> tmp_procs;
+  procs.clear();
+  for (MBRange::const_iterator rit = entities.begin(); rit != entities.end(); rit++) {
+      // get sharing procs
+    result = get_sharing_data(*rit, sp2, NULL, pstat, num_ps);
+    RRA("Problem getting sharing data in get_sharing_data.");
+    if (!(pstat & PSTATUS_SHARED) && MBInterface::INTERSECT == operation) {
+      procs.clear();
+      return MB_SUCCESS;
+    if (rit == entities.begin()) {
+      std::copy(sp2, sp2+num_ps, std::inserter(procs, procs.begin()));
+    else {
+      std::sort(sp2, sp2+num_ps);
+      tmp_procs.clear();
+      if (MBInterface::UNION == operation)
+        std::set_union(procs.begin(), procs.end(),
+                       sp2, sp2+num_ps, std::inserter(tmp_procs, tmp_procs.end()));
+      else if (MBInterface::INTERSECT == operation)
+        std::set_intersection(procs.begin(), procs.end(),
+      else {
+        assert("Unknown operation." && false);
+        return MB_FAILURE;
+      procs.swap(tmp_procs);
+    if (MBInterface::INTERSECT == operation && procs.empty())
+MBErrorCode MBParallelComm::get_sharing_data(const MBEntityHandle entity,
                                              int *ps,
                                              MBEntityHandle *hs,
                                              unsigned char &pstat,
@@ -2723,10 +2772,6 @@
   result = exchange_ghost_cells(-1, -1, 0, true, true);
   RRA("Trouble resolving shared entity remote handles.");
-    // now set the shared/interface tag on non-vertex entities on interface
-  result = tag_iface_entities();
-  RRA("Failed to tag iface entities.");
     // now build parent/child links for interface sets
   result = create_iface_pc_links();
   RRA("Trouble creating interface parent/child links.");
@@ -2763,7 +2808,7 @@
   std::vector<MBRange> verts(np);
   int tot_verts = 0;
-  unsigned int p, i, j, v, vtot;
+  unsigned int p, i, j, v;
   MBErrorCode rval;
   for (p = 0; p < np; p++) {
     MBSkinner skinner(pc[p]->get_moab());
@@ -2805,7 +2850,7 @@
   buffer sort_buffer;
-  buffer_init(&sort_buffer, vtot);
+  buffer_init(&sort_buffer, tot_verts);
   tuple_list_sort(&shared_ents, 0, &sort_buffer);
   buffer_free(&sort_buffer);
@@ -2843,6 +2888,8 @@
     rval = pc[p]->get_interface_procs(psets, true);
     if (MB_SUCCESS != rval) return rval;
+  tuple_list_free(&shared_ents);
   return MB_SUCCESS;
@@ -2852,6 +2899,7 @@
   MBErrorCode result = MB_SUCCESS;
   MBRange iface_ents, tmp_ents, rmv_ents;
   std::vector<unsigned char> pstat;
+  unsigned char set_pstat;
   MBRange::iterator rit2;
   unsigned int i;
@@ -2862,13 +2910,35 @@
     RRA("Couldn't get iface set contents.");
     pstat.resize(iface_ents.size());
     result = mbImpl->tag_get_data(pstatus_tag(), iface_ents, &pstat[0]);
-    RRA("Couldn't get pstatus values.");
+    RRA("Couldn't get pstatus values for set ents.");
+    result = mbImpl->tag_get_data(pstatus_tag(), &(*rit), 1, &set_pstat);
+    RRA("Couldn't get pstatus values for set.");
     rmv_ents.clear();
     for (rit2 = iface_ents.begin(), i = 0; rit2 != iface_ents.end(); rit2++, i++) {
-      if (!(pstat[i] & PSTATUS_INTERFACE)) rmv_ents.insert(*rit2);
+      if (!(pstat[i] & PSTATUS_INTERFACE)) {
+        rmv_ents.insert(*rit2);
+        pstat[i] = 0x0;
     result = mbImpl->remove_entities(*rit, rmv_ents);
     RRA("Couldn't remove entities from set.");
+    if (!(set_pstat & PSTATUS_NOT_OWNED)) continue;
+      // if we're here, we need to set the notowned status on (remaining) set contents
+      // remove rmv_ents from the contents list
+    iface_ents = subtract(iface_ents, rmv_ents);
+      // compress the pstat vector (removing 0x0's)
+    std::remove_if(pstat.begin(), pstat.end(),
+                   std::bind2nd(std::equal_to<unsigned char>(), 0x0));
+      // fold the not_owned bit into remaining values
+    unsigned int sz = iface_ents.size();
+    for (i = 0; i < sz; i++)
+      pstat[i] |= PSTATUS_NOT_OWNED;
+      // set the tag on the entities
+    result = mbImpl->tag_set_data(pstatus_tag(), iface_ents, &pstat[0]);
+    RRA("Couldn't set pstatus values for set ents.");
   return MB_SUCCESS;
@@ -2987,6 +3057,7 @@
   if (proc_nranges.empty()) return MB_SUCCESS;
   int proc_ids[MAX_SHARING_PROCS];
+  MBEntityHandle proc_handles[MAX_SHARING_PROCS];
   MBTag sharedp_tag, sharedps_tag, sharedh_tag, sharedhs_tag, pstatus_tag;
   MBErrorCode result = get_shared_proc_tags(sharedp_tag, sharedps_tag,
@@ -3009,15 +3080,25 @@
     result = mbImpl->add_entities(new_set, mit->second);
     RRA("Failed to add entities to interface set.");
       // tag set with the proc rank(s)
-    if (mit->first.size() == 1)
+    if (mit->first.size() == 1) {
       result = mbImpl->tag_set_data(sharedp_tag, &new_set, 1,
                                     &(mit->first)[0]);
+      proc_handles[0] = 0;
+      result = mbImpl->tag_set_data(sharedh_tag, &new_set, 1,
+                                    proc_handles);
     else {
       // pad tag data out to MAX_SHARING_PROCS with -1
       assert( mit->first.size() <= MAX_SHARING_PROCS );
       std::copy( mit->first.begin(), mit->first.end(), proc_ids );
-      std::fill( proc_ids + mit->first.size(), proc_ids + MAX_SHARING_PROCS - mit->first.size(), -1 );
+      std::fill( proc_ids + mit->first.size(), proc_ids + MAX_SHARING_PROCS, -1 );
       result = mbImpl->tag_set_data(sharedps_tag, &new_set, 1, proc_ids );
+      unsigned int ind = std::find(proc_ids, proc_ids+mit->first.size(), procConfig.proc_rank())
+          - proc_ids;
+      assert(ind < mit->first.size());
+      std::fill( proc_handles + mit->first.size(), proc_handles + MAX_SHARING_PROCS, 0);
+      proc_handles[ind] = new_set;
+      result = mbImpl->tag_set_data(sharedhs_tag, &new_set, 1, proc_handles);
     RRA("Failed to tag interface set with procs.");
@@ -3116,15 +3197,11 @@
                                             std::map<std::vector<int>, MBRange> &proc_nranges)
     // set sharing procs tags on other skin ents
-  MBTag sharedp_tag, sharedps_tag, sharedh_tag, sharedhs_tag, pstatus_tag;
-  MBErrorCode result = get_shared_proc_tags(sharedp_tag, sharedps_tag,
-                                            sharedh_tag, sharedhs_tag, pstatus_tag);
-  RRA("Trouble getting shared proc tags in tag_shared_ents.");
   const MBEntityHandle *connect; int num_connect;
-  std::vector<int> sharing_procs, sharing_procs1, sharing_procs2;
-  std::vector<int>::iterator vii;
-  std::vector<unsigned char> pstatus_flags;
+  std::set<int> sharing_procs;
   std::vector<MBEntityHandle> dum_connect;
+  std::vector<int> sp_vec;
   for (int d = 3; d > 0; d--) {
     if (resolve_dim == d) continue;
@@ -3136,67 +3213,15 @@
                                         &dum_connect);
       RRA("Failed to get connectivity on non-vertex skin entities.");
-        // if any vertices not shared, this entity isn't
-      bool is_shared = true;
-      pstatus_flags.resize( num_connect );
-      result = mbImpl->tag_get_data(pstatus_tag, connect, num_connect,
-                                    &pstatus_flags[0]);
-      RRA("Couldn't get pstatus flag.");
-      for (int nc = 0; nc < num_connect; nc++) {
-        if (!(pstatus_flags[nc] & PSTATUS_SHARED)) {
-          is_shared = false;
-          break;
-      if (!is_shared) continue;
+      int op = (resolve_dim < shared_dim ? MBInterface::UNION : MBInterface::INTERSECT);
+      result = get_sharing_data(connect, num_connect, sharing_procs, op);
+      RRA("Failed to get sharing data in tag_shared_ents");
+      if (sharing_procs.empty()) continue;
-        sharing_procs2.clear();
-          // get sharing procs
-        sharing_procs2.resize(1);
-        result = mbImpl->tag_get_data(sharedp_tag, connect+nc, 1, &sharing_procs2[0]);
-        RRA("Couldn't get sharedp_tag on skin vertices in entity.");
-        if (sharing_procs2[0] == -1) {
-          sharing_procs2.resize(MAX_SHARING_PROCS);
-          result = mbImpl->tag_get_data(sharedps_tag, connect+nc, 1, &sharing_procs2[0]);
-          RRA("Couldn't get sharedps_tag on skin vertices in entity.");
-        assert(-1 != sharing_procs2[0]);
-          // remove any unnecessary entries
-        vii = std::find( sharing_procs2.begin(), sharing_procs2.end(), -1 );
-        sharing_procs2.erase( vii, sharing_procs2.end() );
-          // build range of sharing procs for this vertex
-          // intersect with range for this skin ent
-        if (0 == nc) {
-          sharing_procs.swap( sharing_procs2 );
-        else if (resolve_dim < shared_dim) {
-          sharing_procs1.clear();
-          set_union( sharing_procs.begin(), sharing_procs.end(),
-                     sharing_procs2.begin(), sharing_procs2.end(),
-                     std::back_inserter( sharing_procs1 ) );
-          sharing_procs.swap( sharing_procs1 );
-        else {
-          set_intersection( sharing_procs.begin(), sharing_procs.end(),
-      if (sharing_procs.empty() && resolve_dim < shared_dim) continue;
         // intersection is the owning proc(s) for this skin ent
-      if (sharing_procs.empty()) continue;
-      proc_nranges[sharing_procs].insert(*rit);
-        // reset sharing proc(s) tags
-      sharing_procs.clear();
+      sp_vec.clear();
+      std::copy(sharing_procs.begin(), sharing_procs.end(), std::back_inserter(sp_vec));
+      proc_nranges[sp_vec].insert(*rit);
@@ -3602,7 +3627,7 @@
     // number of incoming messages for ghosts is the number of procs we
     // communicate with; for iface, it's the number of those with lower rank
   int num_incoming = buffProcs.size();
-  std::vector<MPI_Status> status(buffProcs.size());
+  std::vector<MPI_Status> status(MAX_SHARING_PROCS);
   std::vector<std::vector<MBEntityHandle> > recd_ents(num_incoming);
   std::vector<std::vector<MBEntityHandle> > L1hloc(buffProcs.size()), L1hrem(buffProcs.size());
   std::vector<std::vector<int> > L1p(buffProcs.size());
@@ -3663,13 +3688,17 @@
       // handles for them from all expected procs; if not, need to clean
       // them up
     result = check_clean_iface(allsent);
-    RRA("Failed check.");
+    if (MB_SUCCESS != result) std::cout << "Failed check." << std::endl;
+      // now set the shared/interface tag on non-vertex entities on interface
+    result = tag_iface_entities();
+    RRA("Failed to tag iface entities.");
 #ifndef NDEBUG
     result = check_sent_ents(allsent);
-    RRA("Failed check on shared entities.");
     result = check_all_shared_handles();
-    RRA("Failed check on all shared handles.");
 #endif
 #ifdef DEBUG_MPE
@@ -5449,23 +5478,36 @@
   MBErrorCode result;
   MBRange bad_ents;
-  for (MBRange::const_iterator rit = sharedEnts.begin(); rit != sharedEnts.end(); rit++) {
+  std::vector<std::string> errors;
+  std::string dum_err;
+  MBRange::const_iterator rit;
+  for (rit = sharedEnts.begin(); rit != sharedEnts.end(); rit++) {
       // get sharing procs for this ent
     result = get_sharing_data(*rit, tmp_procs, tmp_hs, pstat, num_ps);
-    if (MB_SUCCESS != result || num_ps < (int)vset.size()) {
+    if (MB_SUCCESS != result) {
       bad_ents.insert(*rit);
+      errors.push_back(std::string("Failure getting sharing data."));
       continue;
+    bool bad = false;
       // entity must be shared
-    if (!(pstat & PSTATUS_SHARED) ||
+    if (!(pstat & PSTATUS_SHARED))
+      errors.push_back(std::string("Entity should be shared but isn't.")), bad = true;
       // if entity is not owned this must not be first proc
-        (pstat & PSTATUS_NOT_OWNED && tmp_procs[0] == (int)procConfig.proc_rank()) ||
+    if (pstat & PSTATUS_NOT_OWNED && tmp_procs[0] == (int)procConfig.proc_rank())
+      errors.push_back(std::string("Entity not owned but is first proc.")), bad = true;
       // if entity is owned and multishared, this must be first proc
-        (!(pstat & PSTATUS_NOT_OWNED) && pstat & PSTATUS_MULTISHARED &&
-         (tmp_procs[0] != (int)procConfig.proc_rank() || tmp_hs[0] != *rit))) {
-      bad_ents.insert(*rit);
+    if (!(pstat & PSTATUS_NOT_OWNED) && pstat & PSTATUS_MULTISHARED &&
+        (tmp_procs[0] != (int)procConfig.proc_rank() || tmp_hs[0] != *rit))
+      errors.push_back(std::string("Entity owned and multishared but not first proc or not first handle.")), bad = true;
+    if (bad) {
+      bad_ents.insert(*rit);
       continue;
@@ -5477,7 +5519,11 @@
       // get vertices for this ent and intersection of sharing procs
     result = mbImpl->get_connectivity(*rit, connect, num_connect, false, &dum_connect);
-    if (MB_SUCCESS != result) {bad_ents.insert(*rit); continue;}
+      errors.push_back(std::string("Couldn't get connectivity."));
+      continue;
     for (int i = 0; i < num_connect; i++) {
       result = get_sharing_data(connect[i], tmp_procs, NULL, pstat, num_ps);
@@ -5495,11 +5541,19 @@
     tmp_set.clear();
     std::set_intersection(tmp_procs, tmp_procs+num_ps,
                           vset.begin(), vset.end(), std::inserter(tmp_set, tmp_set.end()));
-    if (orig_ps != (int)tmp_set.size()) bad_ents.insert(*rit);
+    if (orig_ps != (int)tmp_set.size()) {
+      errors.push_back(std::string("Vertex proc set not same size as entity proc set."));
   if (!bad_ents.empty()) {
-    list_entities(bad_ents);
+    std::cout << "Found bad entities in check_local_shared:" << std::endl;
+    std::vector<std::string>::iterator vit;
+    for (rit = bad_ents.begin(), vit = errors.begin(); rit != bad_ents.end(); rit++, vit++) {
+      list_entities(&(*rit), 1);
+      std::cout << "Reason: " << *vit << std::endl;
     return MB_FAILURE;
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp	2009-07-23 18:04:18 UTC (rev 3055)
+++ MOAB/trunk/parallel/MBParallelComm.hpp	2009-07-23 20:13:21 UTC (rev 3056)
@@ -324,18 +324,45 @@
      * \param hs Pointer to shared proc handle data
      * \param pstat Reference to pstatus data returned from this function
-  MBErrorCode get_sharing_data(MBEntityHandle entity,
+  MBErrorCode get_sharing_data(const MBEntityHandle entity,
                                int *ps,
                                MBEntityHandle *hs,
                                unsigned int &num_ps);
+    /** \brief Get the shared processors/handles for an entity
+     * Same as other version but with int num_ps
+     * \param entity Entity being queried
+     * \param ps Pointer to sharing proc data
+     * \param hs Pointer to shared proc handle data
+     * \param pstat Reference to pstatus data returned from this function
                                int *ps,
                                MBEntityHandle *hs,
                                int &num_ps);
+    /** \brief Get the intersection or union of all sharing processors
+     * Get the intersection or union of all sharing processors.  Processor set
+     * is cleared as part of this function.
+     * \param entities Entity list ptr
+     * \param num_entities Number of entities
+     * \param procs Processors returned
+     * \param op Either MBInterface::UNION or MBInterface::INTERSECT
+  MBErrorCode get_sharing_data(const MBEntityHandle *entities,
+                               int num_entities,
+                               int op = MBInterface::INTERSECT);
+     * Same as previous variant but with range as input
+  MBErrorCode get_sharing_data(const MBRange &entities,
     /** \brief Get entities on an inter-processor interface and of specified dimension
      * If other_proc is -1, any interface entities are returned.  If dim is -1,
      * entities of all dimensions on interface are returned.
@@ -587,6 +614,9 @@
 private:
+    // common initialization code, called from various constructors
+  void initialize();
   MBErrorCode set_sharing_data(MBEntityHandle ent, unsigned char pstatus,
                                int old_nump, int new_nump,
                                int *ps, MBEntityHandle *hs);
@@ -992,9 +1022,6 @@
     //! Sequence manager, to get more efficient access to entities
   SequenceManager *sequenceManager;
-    //! data buffer used to communicate
-  std::vector<unsigned char> myBuffer;
     //! more data buffers, proc-specific
   std::vector<std::vector<unsigned char> > ownerSBuffs, ghostRBuffs;
@@ -1104,16 +1131,29 @@
   procConfig.proc_size(s);
-inline MBErrorCode MBParallelComm::get_sharing_data(MBEntityHandle entity,
+inline MBErrorCode MBParallelComm::get_sharing_data(const MBEntityHandle *entities,
+                                                    int num_entities,
+                                                    int op)
+  MBRange dum_range;
+    // cast away constness 'cuz the range is passed as const
+  MBEntityHandle *ents_cast = const_cast<MBEntityHandle*>(entities);
+  std::copy(ents_cast, ents_cast+num_entities, mb_range_inserter(dum_range));
+  return get_sharing_data(dum_range, procs, op);
+inline MBErrorCode MBParallelComm::get_sharing_data(const MBEntityHandle entity,
                                                     int *ps,
                                                     MBEntityHandle *hs,
                                                     int &num_ps)
-  unsigned int dum_int;
-  MBErrorCode result = get_sharing_data(entity, ps, hs, pstat, dum_int);
-  num_ps = dum_int;
+  unsigned int dum_ps;
+  MBErrorCode result = get_sharing_data(entity, ps, hs, pstat, dum_ps);
+  if (MB_SUCCESS == result)
+    num_ps = dum_ps;
   return result;
 #endif
Modified: MOAB/trunk/parallel/pcomm_unit.cpp
--- MOAB/trunk/parallel/pcomm_unit.cpp	2009-07-23 18:04:18 UTC (rev 3055)
+++ MOAB/trunk/parallel/pcomm_unit.cpp	2009-07-23 20:13:21 UTC (rev 3056)
@@ -15,6 +15,9 @@
 #  include <mpi.h>
 #endif
+#define STRINGIFY_(X) #X
+#define STRINGIFY(X) STRINGIFY_(X)
 /** Test pack/unpack of vertices */
 void test_pack_vertices();
 /** Test pack/unpack of elements */
@@ -1858,7 +1861,7 @@
 void test_pack_shared_arbitrary()
-#define NP 4
+#define NP 3
   MBCore moab[NP];
   MBParallelComm *pc[NP];
   for (unsigned int i = 0; i < NP; i++) {
@@ -1867,25 +1870,35 @@
     pc[i]->set_size(NP);
-  std::string ptag_name("MATERIAL_SET");
   std::vector<int> pa_vec;
   pa_vec.push_back(0);
   pa_vec.push_back(4);
   pa_vec.push_back(2);
   MBErrorCode rval;
+  std::vector<int> partition_tag_vals;
+  bool partition_distrib = false;
-  const char *fnames[] = {"/home/tautges/MOABpar2/test/64bricks_512hex.h5m"};
+#ifdef SRCDIR
+  const char *fnames[] = {STRINGIFY(SRCDIR) "/ptest.cub"};
+#else
+  const char *fnames[] = {"./ptest.cub"};
+#endif
-  std::string partition_name("MATERIAL_SET");
+  std::string ptag_name("GEOM_DIMENSION");
+  partition_tag_vals.push_back(3);
+  partition_distrib = true;
+    //std::string ptag_name("MATERIAL_SET");
+    //partition_distrib = true;
   FileOptions fopts(NULL);
     ReadParallel rp(moab+i, pc[i]);
     MBEntityHandle tmp_set = 0;
-    std::vector<int> partition_tag_vals;
     rval = rp.load_file(fnames, 1, tmp_set, ReadParallel::POPT_READ_DELETE,
-                        partition_name,
-                        partition_tag_vals, true, pa_vec,
+                        ptag_name,
+                        partition_tag_vals, partition_distrib, pa_vec,
                         fopts, NULL, NULL, 0, i, false, -1, -1, -1, -1, 0);
     CHECK_ERR(rval);
Modified: MOAB/trunk/test/64bricks_512hex.h5m
(Binary files differ)
