[MOAB-dev] r3057 - in MOAB/trunk: . m4
kraftche at cae.wisc.edu
Thu Jul 23 15:27:56 CDT 2009
Author: kraftche
Date: 2009-07-23 15:27:56 -0500 (Thu, 23 Jul 2009)
New Revision: 3057
Modified:
MOAB/trunk/configure.ac
MOAB/trunk/m4/netcdf.m4
Log:
Partial support for hdf5-based netcdf4 library: will configure correctly as long as MOAB's HDF5 support is enabled
Modified: MOAB/trunk/configure.ac
--- MOAB/trunk/configure.ac 2009-07-23 20:13:21 UTC (rev 3056)
+++ MOAB/trunk/configure.ac 2009-07-23 20:27:56 UTC (rev 3057)
@@ -356,13 +356,14 @@
# NetCDF OPTIONS
+old_LDFLAGS="$LDFLAGS"
+LDFLAGS="$LDFLAGS $HDF5_LDFLAGS"
SNL_CHECK_NETCDF
+LDFLAGS="$old_LDFLAGS"
if test "xno" = "x$HAVE_NETCDF"; then
AC_MSG_WARN([Support for ExodusII file format disabled])
- NETCDF_LIBS=
else
DEFINES="$DEFINES -DNETCDF_FILE"
- NETCDF_LIBS="-lnetcdf_c++ -lnetcdf"
fi
AM_CONDITIONAL(NETCDF_FILE, [test "xno" != "x$HAVE_NETCDF"])
AM_CPPFLAGS="$NETCDF_CPPFLAGS $AM_CPPFLAGS"
Modified: MOAB/trunk/m4/netcdf.m4
--- MOAB/trunk/m4/netcdf.m4 2009-07-23 20:13:21 UTC (rev 3056)
+++ MOAB/trunk/m4/netcdf.m4 2009-07-23 20:27:56 UTC (rev 3057)
@@ -1,7 +1,10 @@
# Check for NetCDF library ((C++)
# Sets HAVE_NETCDF to 'yes' or 'no'
-# If HAVE_NETCDF == yes, then exports NETCDF_CPPFLAGS and NETCDF_LDFLAGS
+# If HAVE_NETCDF == yes, then exports:
+# NETCDF_CPPFLAGS
+# NETCDF_LDFLAGS
+# NETCDF_LIBS
AC_DEFUN([SNL_CHECK_NETCDF],[
@@ -82,14 +85,20 @@
LIBS="$LIBS -lnetcdf_c++ -lnetcdf"
AC_TRY_LINK(
[#include <netcdf.hh>], [NcFile ncf("foo",NcFile::ReadOnly);],
- [AC_MSG_RESULT([yes])],
- [AC_MSG_RESULT([no]);
- AC_MSG_WARN([NetCDF C++ API not found])
- HAVE_NETCDF=no] )
+ [AC_MSG_RESULT([yes]); NETCDF_LIBS="-lnetcdf_c++ -lnetcdf"],
+ [AC_MSG_RESULT([no]);
+ AC_MSG_CHECKING([for netcdf_c++ library requiring HDF5-high-level])
+ LIBS="$LIBS -lhdf5_hl -lhdf5"
+ AC_TRY_LINK(
+ [#include <netcdf.hh>], [NcFile ncf("foo",NcFile::ReadOnly);],
+ [AC_MSG_RESULT([yes]); NETCDF_LIBS="-lnetcdf_c++ -lnetcdf -lhdf5_hl ${HDF5_LIBS}"],
+ [AC_MSG_RESULT([no]); HAVE_NETCDF=no] )
LIBS="$old_LIBS"
AC_LANG_RESTORE
CPPFLAGS="$old_CPPFLAGS"
if test "x$HAVE_NETCDF" = "xno"; then
if test "x$NETCDF_ARG" != "x"; then
AC_MSG_ERROR("NetCDF not found or not working")
