[MOAB-dev] r2973 - MOAB/branches/parallel_ghosting/parallel
tautges at mcs.anl.gov
Fri Jun 26 17:39:15 CDT 2009
Author: tautges
Date: 2009-06-26 17:39:15 -0500 (Fri, 26 Jun 2009)
New Revision: 2973
Modified:
MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
Log:
Need to initialize receive buffers to non-zero size.
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp 2009-06-26 22:22:55 UTC (rev 2972)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp 2009-06-26 22:39:15 UTC (rev 2973)
@@ -331,9 +331,9 @@
ind = buffProcs.size();
buffProcs.push_back((unsigned int)to_proc);
ownerSBuffs.push_back(std::vector<unsigned char>());
- ghostRBuffs.push_back(std::vector<unsigned char>());
+ ghostRBuffs.push_back(std::vector<unsigned char>(INITIAL_BUFF_SIZE));
// allocate these other buffs in case we're storing remote handles
- ownerRBuffs.push_back(std::vector<unsigned char>());
+ ownerRBuffs.push_back(std::vector<unsigned char>(INITIAL_BUFF_SIZE));
ghostSBuffs.push_back(std::vector<unsigned char>());
if (is_new) *is_new = true;
