[MOAB-dev] r2972 - MOAB/branches/parallel_ghosting/parallel
    tautges at mcs.anl.gov
    Fri Jun 26 17:22:55 CDT 2009
Author: tautges
Date: 2009-06-26 17:22:55 -0500 (Fri, 26 Jun 2009)
New Revision: 2972
Modified:
   MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
   MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
   MOAB/branches/parallel_ghosting/parallel/ReadParallel.hpp
   MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp
   MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp
Log:
Fixing pcomm_unit for more arbitrary cases where you don't know
beforehand how many / which procs you're communicating with.
pcomm_unit: added a test_pack_shared_arbitrary test, to test parallel
  read of an arbitrary file (may be commented out eventually)
parallel_unit_tests: replaced ptest.cub with 64bricks_512hex.h5m
ReadParallel: made some functions public so that they can be called in
  tests
MBParallelComm:
- don't initialize size of buffers, leave them to be zero-sized
- move calls to get_buffers into get_interface_procs, controlled by a
  boolean flag to the function (normally false, so it isn't done)
- in serial version of exchange_ghost_cells, if buffer is empty, don't
  call unpack function; this happens sometimes when a proc receives
  entities owned by a third proc, and has to return handles to that
  proc; in this case, that third proc didn't send this proc any
  entities, even though it's in this proc's communicating procs list;
  parallel version doesn't see this 'cuz it never receives a message
  with entities from that third proc
- added function to set proc size in addition to proc rank
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp	2009-06-26 22:19:54 UTC (rev 2971)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.cpp	2009-06-26 22:22:55 UTC (rev 2972)
@@ -104,7 +104,7 @@
       unsigned int _old_size = buff_ptr - &buff_vec[0],            \
           _new_size = _old_size + (addl_space);    \
       if (_new_size > buff_vec.size()) {               \
-        buff_vec.resize(1.5*_new_size);             \
+        buff_vec.resize(1.5*_new_size);            \
         buff_ptr = &buff_vec[_new_size-(addl_space)];} }
@@ -330,11 +330,11 @@
   if (vit == buffProcs.end()) {
     ind = buffProcs.size();
     buffProcs.push_back((unsigned int)to_proc);
-    ownerSBuffs.push_back(std::vector<unsigned char>(INITIAL_BUFF_SIZE));
-    ghostRBuffs.push_back(std::vector<unsigned char>(INITIAL_BUFF_SIZE));
+    ownerSBuffs.push_back(std::vector<unsigned char>());
+    ghostRBuffs.push_back(std::vector<unsigned char>());
       // allocate these other buffs in case we're storing remote handles
-    ownerRBuffs.push_back(std::vector<unsigned char>(INITIAL_BUFF_SIZE));
-    ghostSBuffs.push_back(std::vector<unsigned char>(INITIAL_BUFF_SIZE));
+    ownerRBuffs.push_back(std::vector<unsigned char>());
+    ghostSBuffs.push_back(std::vector<unsigned char>());
     if (is_new) *is_new = true;
   else {
@@ -1427,7 +1427,8 @@
 MBErrorCode MBParallelComm::list_entities(const MBEntityHandle *ents, int num_ents)
   if (NULL == ents && 0 == num_ents) {
-    return list_entities(NULL, 0);
+    sharedEnts.print("Shared entities:\n");
+    return MB_SUCCESS;
   else if (NULL == ents || 0 == num_ents) {
@@ -2611,10 +2612,8 @@
     // establish comm procs and buffers for them
   std::set<unsigned int> procs;
-  result = get_interface_procs(procs);
+  result = get_interface_procs(procs, true);
   RRA("Trouble getting iface procs.");
-  for (std::set<unsigned int>::iterator sit = procs.begin(); sit != procs.end(); sit++)
-    get_buffers(*sit);
     // resolve shared entity remote handles; implemented in ghost cell exchange
     // code because it's so similar
@@ -2718,11 +2717,8 @@
     if (MB_SUCCESS != rval) return rval;
     psets.clear();
-    rval = pc[p]->get_interface_procs(psets);
+    rval = pc[p]->get_interface_procs(psets, true);
-    for (std::set<unsigned int>::iterator sit = psets.begin(); sit != psets.end(); sit++)
-      pc[p]->get_buffers(*sit);
   return MB_SUCCESS;
@@ -3167,7 +3163,8 @@
   //! get processors with which this processor communicates; sets are sorted by processor
-MBErrorCode MBParallelComm::get_interface_procs(std::set<unsigned int> &procs_set)
+MBErrorCode MBParallelComm::get_interface_procs(std::set<unsigned int> &procs_set,
+                                                bool get_buffs)
     // make sure the sharing procs vector is empty
   procs_set.clear();
@@ -3200,6 +3197,11 @@
+  if (get_buffs) {
+    for (std::set<unsigned int>::iterator sit = procs_set.begin(); sit != procs_set.end(); sit++)
+      get_buffers(*sit);
   return MB_SUCCESS;
@@ -3739,6 +3741,12 @@
     for (ind = 0; ind < pc->buffProcs.size(); ind++) {
         // incoming ghost entities; unpack; returns entities received
         // both from sending proc and from owning proc (which may be different)
+        // buffer could be empty, which means there isn't any message to
+        // unpack (due to this comm proc getting added as a result of indirect
+        // communication); just skip this unpack
+      if (pc->ownerSBuffs[ind].empty()) continue;
       unsigned int to_p = pc->buffProcs[ind];
       unsigned char *buff_ptr = &pc->ownerSBuffs[ind][0];
       result = pcs[to_p]->unpack_entities(buff_ptr,
Modified: MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp
--- MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp	2009-06-26 22:19:54 UTC (rev 2971)
+++ MOAB/branches/parallel_ghosting/parallel/MBParallelComm.hpp	2009-06-26 22:22:55 UTC (rev 2972)
@@ -326,7 +326,8 @@
                                  const char *tag_name = NULL);
     //! get processors with which this processor shares an interface
-  MBErrorCode get_interface_procs(std::set<unsigned int> &iface_procs);
+  MBErrorCode get_interface_procs(std::set<unsigned int> &iface_procs,
+                                  const bool get_buffs = false);
   MBErrorCode get_comm_procs(std::set<unsigned int> &procs);
@@ -495,6 +496,9 @@
     //! set rank for this pcomm; USED FOR TESTING ONLY!
   void set_rank(unsigned int r);
+    //! set rank for this pcomm; USED FOR TESTING ONLY!
+  void set_size(unsigned int r);
     //! get (and possibly allocate) buffers for messages to/from to_proc; returns
     //! index of to_proc in buffProcs vector; if is_new is non-NULL, sets to
     //! whether new buffer was allocated
@@ -1033,6 +1037,11 @@
   if (procConfig.proc_size() < r) procConfig.proc_size(r+1);
+inline void MBParallelComm::set_size(unsigned int s)
+  procConfig.proc_size(s);
 inline MBErrorCode MBParallelComm::get_sharing_data(MBEntityHandle entity,
                                                     int *ps,
                                                     MBEntityHandle *hs,
Modified: MOAB/branches/parallel_ghosting/parallel/ReadParallel.hpp
--- MOAB/branches/parallel_ghosting/parallel/ReadParallel.hpp	2009-06-26 22:19:54 UTC (rev 2971)
+++ MOAB/branches/parallel_ghosting/parallel/ReadParallel.hpp	2009-06-26 22:22:55 UTC (rev 2972)
@@ -31,21 +31,6 @@
                         const int* material_set_list,
                         const int num_material_sets );
-    //! Constructor
-  ReadParallel(MBInterface* impl = NULL, MBParallelComm *pc = NULL);
-   //! Destructor
-  virtual ~ReadParallel() {}
-  static const char *parallelOptsNames[];
-  enum ParallelOpts {POPT_NONE=0, POPT_BCAST, POPT_BCAST_DELETE,
-                     POPT_READ_DELETE, POPT_READ_PARALLEL,
-                     POPT_FORMAT, POPT_DEFAULT};
-protected:
-private:
   MBErrorCode load_file(const char **file_names,
                         const int num_files,
                         MBEntityHandle& file_set,
@@ -64,7 +49,19 @@
                         const int ghost_dim,
                         const int bridge_dim,
                         const int num_layers);
+    //! Constructor
+  ReadParallel(MBInterface* impl = NULL, MBParallelComm *pc = NULL);
+   //! Destructor
+  virtual ~ReadParallel() {}
+  static const char *parallelOptsNames[];
+  enum ParallelOpts {POPT_NONE=0, POPT_BCAST, POPT_BCAST_DELETE,
+                     POPT_READ_DELETE, POPT_READ_PARALLEL,
+                     POPT_FORMAT, POPT_DEFAULT};
+    //! PUBLIC TO ALLOW TESTING
   MBErrorCode delete_nonlocal_entities(std::string &ptag_name,
                                        std::vector<int> &ptag_vals,
                                        bool distribute,
@@ -72,6 +69,10 @@
   MBErrorCode delete_nonlocal_entities(MBEntityHandle file_set);
+protected:
+private:
   MBInterface *mbImpl;
     // each reader can keep track of its own pcomm
Modified: MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp
--- MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp	2009-06-26 22:19:54 UTC (rev 2971)
+++ MOAB/branches/parallel_ghosting/parallel/parallel_unit_tests.cpp	2009-06-26 22:22:55 UTC (rev 2972)
@@ -187,9 +187,9 @@
   if (!filename) {
 #ifdef SRCDIR
-    filename = STRINGIFY(SRCDIR) "/ptest.cub";
+    filename = STRINGIFY(SRCDIR) "/../test/64bricks_512hex.h5m";
 #else
-    filename = "ptest.cub";
+    filename = "../test/64bricks_512hex.h5m";
 #endif
Modified: MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp
--- MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp	2009-06-26 22:19:54 UTC (rev 2971)
+++ MOAB/branches/parallel_ghosting/parallel/pcomm_unit.cpp	2009-06-26 22:22:55 UTC (rev 2972)
@@ -3,6 +3,8 @@
 #include "MBTagConventions.hpp"
 #include "MBCore.hpp"
 #include "MeshTopoUtil.hpp"
+#include "ReadParallel.hpp"
+#include "FileOptions.hpp"
 #include "TestUtil.hpp"
 #include <algorithm>
 #include <vector>
@@ -43,6 +45,8 @@
 void test_pack_shared_entities_2d();
 /** Test pack/unpack of shared entities in 3d*/
 void test_pack_shared_entities_3d();
+/** Test pack/unpack of arbitrary mesh file */
+void test_pack_shared_arbitrary();
 /** Test filter_pstatus function*/
 void test_filter_pstatus();
@@ -69,6 +73,7 @@
   num_err += RUN_TEST( test_pack_tag_handle_data );
   num_err += RUN_TEST( test_pack_shared_entities_2d );
   num_err += RUN_TEST( test_pack_shared_entities_3d );
+  num_err += RUN_TEST( test_pack_shared_arbitrary );
   num_err += RUN_TEST( test_filter_pstatus );
 #ifdef USE_MPI
@@ -1851,6 +1856,52 @@
   CHECK_ERR(rval);
+#define NP 4
+  MBCore moab[NP];
+  MBParallelComm *pc[NP];
+  for (unsigned int i = 0; i < NP; i++) {
+    pc[i] = new MBParallelComm(&moab[i]);
+    pc[i]->set_rank(i);
+    pc[i]->set_size(NP);
+  std::string ptag_name("MATERIAL_SET");
+  std::vector<int> pa_vec;
+  pa_vec.push_back(0);
+  pa_vec.push_back(4);
+  pa_vec.push_back(2);
+  MBErrorCode rval;
+  const char *fnames[] = {"/home/tautges/MOABpar2/test/64bricks_512hex.h5m"};
+  std::string partition_name("MATERIAL_SET");
+  FileOptions fopts(NULL);
+    ReadParallel rp(moab+i, pc[i]);
+    MBEntityHandle tmp_set = 0;
+    std::vector<int> partition_tag_vals;
+    rval = rp.load_file(fnames, 1, tmp_set, ReadParallel::POPT_READ_DELETE,
+                        partition_name,
+                        partition_tag_vals, true, pa_vec, NULL, 0,
+                        fopts, i, false, -1, -1, -1, -1, 0);
+    CHECK_ERR(rval);
+  rval = MBParallelComm::resolve_shared_ents(pc, NP, 3);
+  CHECK_ERR(rval);
+    // exchange interface cells
+  rval = MBParallelComm::exchange_ghost_cells(pc, NP, -1, -1, 0, true);
+  CHECK_ERR(rval);
+    // now 1 layer of hex ghosts
+  rval = MBParallelComm::exchange_ghost_cells(pc, NP, 3, 0, 1, true);
+  CHECK_ERR(rval);
   MBRange::iterator i;
