[MOAB-dev] r2974 - in MOAB/trunk/tools/iMesh/python: . doc
jvporter at wisc.edu
Tue Jun 30 18:11:39 CDT 2009
Author: jvporter
Date: 2009-06-30 18:11:38 -0500 (Tue, 30 Jun 2009)
New Revision: 2974
Added:
MOAB/trunk/tools/iMesh/python/numpy_extensions.h
MOAB/trunk/tools/iMesh/python/numpy_extensions.inl
Modified:
MOAB/trunk/tools/iMesh/python/doc/imesh.rst
MOAB/trunk/tools/iMesh/python/iMesh.c
MOAB/trunk/tools/iMesh/python/iMesh_Python.h
MOAB/trunk/tools/iMesh/python/iMesh_entSet.inl
MOAB/trunk/tools/iMesh/python/iMesh_iter.inl
MOAB/trunk/tools/iMesh/python/iMesh_tag.inl
MOAB/trunk/tools/iMesh/python/setup.py
Log:
Add automatic forwarding for Mesh.rootSet
Modified: MOAB/trunk/tools/iMesh/python/doc/imesh.rst
--- MOAB/trunk/tools/iMesh/python/doc/imesh.rst 2009-06-26 22:39:15 UTC (rev 2973)
+++ MOAB/trunk/tools/iMesh/python/doc/imesh.rst 2009-06-30 23:11:38 UTC (rev 2974)
@@ -39,22 +39,6 @@
the relative cost of retrieving adjacencies between entities of dimension
i to entities of dimension j.
- .. method:: load(filename[, options])
- Load a mesh from a file. Equivalent to ``rootSet.load(filename,
- options)``.
- :param filename: File name from which the mesh is to be loaded
- :param options: Implementation-specific options string
- .. method:: save(filename[, options])
- Save the mesh to a file. Equivalent to ``rootSet.load(filename,
- options)``.
- :param filename: File name to which the mesh is to be saved
.. method:: areEHValid(doReset)
Return whether entity handles have changed since last reset or since
@@ -227,7 +211,18 @@
:param entities: Entity or entity set being queried
:return: Array of :class:`Tag`\ s associated with ``entities``
+Forwards
+In addition to the methods listed above, :class:`Mesh` automatically forwards
+method calls to the root :class:`EntitySet`. Thus, ::
+ mesh.getEntities(iBase.type.all, iMesh.topology.all)
+is equivalent to::
+ mesh.rootSet.getEntities(iBase.type.all, iMesh.topology.all)
EntitySet
@@ -576,4 +571,4 @@
.. data:: all
- Allows the user to request information about all the topology types
\ No newline at end of file
+ Allows the user to request information about all the topology types
Modified: MOAB/trunk/tools/iMesh/python/iMesh.c
--- MOAB/trunk/tools/iMesh/python/iMesh.c 2009-06-26 22:39:15 UTC (rev 2973)
+++ MOAB/trunk/tools/iMesh/python/iMesh.c 2009-06-30 23:11:38 UTC (rev 2974)
@@ -2,7 +2,13 @@
#include "iMesh_Python.h"
#include "iBase_Python.h"
-int checkError(iMesh_Instance mesh,int err)
+/* TODO: these are never freed! */
+static PyObject *g_helper_module;
+static PyObject *g_adj_list;
+static PyObject *g_ind_adj_list;
+static int
+checkError(iMesh_Instance mesh,int err)
if(err)
@@ -16,22 +22,8 @@
return 0;
-PyObject *
-PyArray_TryFromObject(PyObject *obj,int typenum,int min_depth,int max_depth)
- PyObject *ret = PyArray_FromAny(obj,PyArray_DescrFromType(typenum),
- min_depth,max_depth,NPY_C_CONTIGUOUS,NULL);
- PyErr_Clear();
- return ret;
-/* TODO: these are never freed! */
-static PyObject *g_helper_module;
-static PyObject *g_adj_list;
-static PyObject *g_ind_adj_list;
/* NOTE: steals references to adj and offsets */
-PyObject *
+static PyObject *
AdjacencyList_New(PyObject *adj,PyObject *offsets)
PyObject *res;
@@ -46,7 +38,7 @@
/* NOTE: steals references to ents, adj, indices, and offsets */
-PyObject *
+static PyObject *
IndexedAdjacencyList_New(PyObject *ents, PyObject *adj,PyObject *indices,
PyObject *offsets)
@@ -64,7 +56,7 @@
return res;
-iMeshEntitySet_Object *
+static iMeshEntitySet_Object *
iMeshEntitySet_New(iMesh_Object *mesh)
iMeshEntitySet_Object *o = iMeshEntitySet_NewRaw();
@@ -73,7 +65,7 @@
return o;
-iMeshTag_Object *
+static iMeshTag_Object *
iMeshTag_New(iMesh_Object *mesh)
iMeshTag_Object *o = iMeshTag_NewRaw();
@@ -110,50 +102,6 @@
static PyObject *
-iMeshObj_load(iMesh_Object *self,PyObject *args)
- const char *name = 0;
- const char *options = "";
- iBase_EntitySetHandle root;
- int err;
- if(!PyArg_ParseTuple(args,"s|s",&name,&options))
- return NULL;
- iMesh_getRootSet(self->mesh,&root,&err);
- if(checkError(self->mesh,err))
- return NULL;
- iMesh_load(self->mesh,root,name,options,&err,strlen(name),strlen(options));
- return NULL;
- Py_RETURN_NONE;
-static PyObject *
-iMeshObj_save(iMesh_Object *self,PyObject *args)
- int err;
- return NULL;
- return NULL;
- iMesh_save(self->mesh,root,name,options,&err,strlen(name),strlen(options));
- return NULL;
- Py_RETURN_NONE;
-static PyObject *
iMeshObj_getRootSet(iMesh_Object *self,void *closure)
iMeshEntitySet_Object *rootset = iMeshEntitySet_New(self);
@@ -931,12 +879,6 @@
static PyMethodDef iMesh_methods[] = {
- { "load", (PyCFunction)iMeshObj_load, METH_VARARGS,
- "Load a mesh from a file"
- { "save", (PyCFunction)iMeshObj_save, METH_VARARGS,
- "Save the mesh to a file"
{ "areEHValid", (PyCFunction)iMeshObj_areEHValid, METH_VARARGS,
"Return whether entity handles have changed since last reset or since "
"instance construction"
@@ -1010,6 +952,25 @@
{0}
+static PyObject * iMeshObj_getAttr(PyObject *self,PyObject *attr_name)
+ PyObject *ret;
+ ret = PyObject_GenericGetAttr(self,attr_name);
+ if(ret)
+ return ret;
+ else
+ PyErr_Clear();
+ PyObject *root = iMeshObj_getRootSet((iMesh_Object*)self,0);
+ if(!root)
+ return NULL;
+ ret = PyObject_GetAttr(root,attr_name);
+ Py_DECREF(root);
+ return ret;
static PyTypeObject iMesh_Type = {
PyObject_HEAD_INIT(NULL)
0, /* ob_size */
@@ -1028,7 +989,7 @@
0, /* tp_hash */
0, /* tp_call */
0, /* tp_str */
- 0, /* tp_getattro */
+ iMeshObj_getAttr, /* tp_getattro */
0, /* tp_setattro */
0, /* tp_as_buffer */
Py_TPFLAGS_DEFAULT |
@@ -1091,57 +1052,6 @@
ENUM_TYPE(iMeshTopology,"iMesh.Topology","");
-static void
-ArrDeallocObj_dealloc(ArrDealloc_Object *self)
- free(self->memory);
- Py_XDECREF(self->base);
- self->ob_type->tp_free((PyObject *)self);
-static PyTypeObject ArrDealloc_Type = {
- PyObject_HEAD_INIT(NULL)
- 0, /* ob_size */
- "arrdealloc", /* tp_name */
- sizeof(ArrDealloc_Object), /* tp_basicsize */
- 0, /* tp_itemsize */
- (destructor)ArrDeallocObj_dealloc, /* tp_dealloc */
- 0, /* tp_print */
- 0, /* tp_getattr */
- 0, /* tp_setattr */
- 0, /* tp_compare */
- 0, /* tp_repr */
- 0, /* tp_as_number */
- 0, /* tp_as_sequence */
- 0, /* tp_as_mapping */
- 0, /* tp_hash */
- 0, /* tp_call */
- 0, /* tp_str */
- 0, /* tp_setattro */
- 0, /* tp_as_buffer */
- Py_TPFLAGS_DEFAULT, /* tp_flags */
- "Internal deallocator object", /* tp_doc */
-PyObject *
-PyArray_NewFromMallocBaseStrided(int nd,npy_intp *dims,npy_intp *strides,
- int typenum,void *data,PyObject *base)
- ArrDealloc_Object *newobj;
- PyObject *arr = PyArray_New(&PyArray_Type,nd,dims,typenum,strides,data,0,
- NPY_CARRAY,NULL);
- newobj = PyObject_New(ArrDealloc_Object,&ArrDealloc_Type);
- newobj->memory = data;
- Py_XINCREF(base);
- newobj->base = base;
- PyArray_BASE(arr) = (PyObject*)newobj;
- return arr;
PyMODINIT_FUNC initiMesh(void)
PyObject *m;
@@ -1229,3 +1139,4 @@
#include "iMesh_entSet.inl"
#include "iMesh_iter.inl"
#include "iMesh_tag.inl"
+#include "numpy_extensions.inl"
Modified: MOAB/trunk/tools/iMesh/python/iMesh_Python.h
--- MOAB/trunk/tools/iMesh/python/iMesh_Python.h 2009-06-26 22:39:15 UTC (rev 2973)
+++ MOAB/trunk/tools/iMesh/python/iMesh_Python.h 2009-06-30 23:11:38 UTC (rev 2974)
@@ -10,33 +10,8 @@
#define PY_ARRAY_UNIQUE_SYMBOL itaps_ARRAY_API
-#include <numpy/arrayobject.h>
+#include "numpy_extensions.h"
-typedef struct
- PyObject_HEAD
- PyObject *base;
- void *memory;
-} ArrDealloc_Object;
-#define PyArray_NewFromMalloc(nd,dims,typenum,data) \
- PyArray_NewFromMallocBaseStrided(nd,dims,NULL,typenum,data,0)
-#define PyArray_NewFromMallocBase(nd,dims,typenum,data,base) \
- PyArray_NewFromMallocBaseStrided(nd,dims,NULL,typenum,data,base)
-#define PyArray_NewFromMallocStrided(nd,dims,strides,typenum,data) \
- PyArray_NewFromMallocBaseStrided(nd,dims,strides,typenum,data,0)
-static PyObject *
- int typenum,void *data,PyObject *base);
-static PyObject *
-PyArray_TryFromObject(PyObject *obj,int typenum,int min_depth,int max_depth);
static int checkError(iMesh_Instance mesh,int err);
static enum iBase_TagValueType char_to_type(char c);
static char type_to_char(enum iBase_TagValueType t);
Modified: MOAB/trunk/tools/iMesh/python/iMesh_entSet.inl
--- MOAB/trunk/tools/iMesh/python/iMesh_entSet.inl 2009-06-26 22:39:15 UTC (rev 2973)
+++ MOAB/trunk/tools/iMesh/python/iMesh_entSet.inl 2009-06-30 23:11:38 UTC (rev 2974)
@@ -1,6 +1,3 @@
-#define NO_IMPORT_ARRAY
-#define NO_IMPORT_IBASE
#include "errors.h"
Modified: MOAB/trunk/tools/iMesh/python/iMesh_iter.inl
--- MOAB/trunk/tools/iMesh/python/iMesh_iter.inl 2009-06-26 22:39:15 UTC (rev 2973)
+++ MOAB/trunk/tools/iMesh/python/iMesh_iter.inl 2009-06-30 23:11:38 UTC (rev 2974)
@@ -1,6 +1,3 @@
-#define NO_IMPORT_ITER
#include "structmember.h"
Modified: MOAB/trunk/tools/iMesh/python/iMesh_tag.inl
--- MOAB/trunk/tools/iMesh/python/iMesh_tag.inl 2009-06-26 22:39:15 UTC (rev 2973)
+++ MOAB/trunk/tools/iMesh/python/iMesh_tag.inl 2009-06-30 23:11:38 UTC (rev 2974)
@@ -1,6 +1,3 @@
#include "errors.h"
Added: MOAB/trunk/tools/iMesh/python/numpy_extensions.h
--- MOAB/trunk/tools/iMesh/python/numpy_extensions.h (rev 0)
+++ MOAB/trunk/tools/iMesh/python/numpy_extensions.h 2009-06-30 23:11:38 UTC (rev 2974)
@@ -0,0 +1,31 @@
+#ifndef PYTAPS_NUMPY_EXTENSIONS_H
+#define PYTAPS_NUMPY_EXTENSIONS_H
+#include <numpy/arrayobject.h>
+typedef struct
+ PyObject_HEAD
+ PyObject *base;
+ void *memory;
+} ArrDealloc_Object;
+static PyTypeObject ArrDealloc_Type;
+#define PyArray_NewFromMalloc(nd,dims,typenum,data) \
+ PyArray_NewFromMallocBaseStrided(nd,dims,NULL,typenum,data,0)
+#define PyArray_NewFromMallocBase(nd,dims,typenum,data,base) \
+ PyArray_NewFromMallocBaseStrided(nd,dims,NULL,typenum,data,base)
+#define PyArray_NewFromMallocStrided(nd,dims,strides,typenum,data) \
+ PyArray_NewFromMallocBaseStrided(nd,dims,strides,typenum,data,0)
+static PyObject *
+PyArray_NewFromMallocBaseStrided(int nd,npy_intp *dims,npy_intp *strides,
+ int typenum,void *data,PyObject *base);
+static PyObject *
+PyArray_TryFromObject(PyObject *obj,int typenum,int min_depth,int max_depth);
+#endif
Added: MOAB/trunk/tools/iMesh/python/numpy_extensions.inl
--- MOAB/trunk/tools/iMesh/python/numpy_extensions.inl (rev 0)
+++ MOAB/trunk/tools/iMesh/python/numpy_extensions.inl 2009-06-30 23:11:38 UTC (rev 2974)
@@ -0,0 +1,59 @@
+static PyObject *
+ PyObject *ret = PyArray_FromAny(obj,PyArray_DescrFromType(typenum),
+ min_depth,max_depth,NPY_C_CONTIGUOUS,NULL);
+ PyErr_Clear();
+ return ret;
+static void
+ArrDeallocObj_dealloc(ArrDealloc_Object *self)
+ free(self->memory);
+ Py_XDECREF(self->base);
+ self->ob_type->tp_free((PyObject *)self);
+static PyTypeObject ArrDealloc_Type = {
+ PyObject_HEAD_INIT(NULL)
+ 0, /* ob_size */
+ "arrdealloc", /* tp_name */
+ sizeof(ArrDealloc_Object), /* tp_basicsize */
+ 0, /* tp_itemsize */
+ (destructor)ArrDeallocObj_dealloc, /* tp_dealloc */
+ 0, /* tp_print */
+ 0, /* tp_getattr */
+ 0, /* tp_setattr */
+ 0, /* tp_compare */
+ 0, /* tp_repr */
+ 0, /* tp_as_number */
+ 0, /* tp_as_sequence */
+ 0, /* tp_as_mapping */
+ 0, /* tp_hash */
+ 0, /* tp_call */
+ 0, /* tp_str */
+ 0, /* tp_getattro */
+ 0, /* tp_setattro */
+ 0, /* tp_as_buffer */
+ Py_TPFLAGS_DEFAULT, /* tp_flags */
+ "Internal deallocator object", /* tp_doc */
+static PyObject *
+ ArrDealloc_Object *newobj;
+ PyObject *arr = PyArray_New(&PyArray_Type,nd,dims,typenum,strides,data,0,
+ NPY_CARRAY,NULL);
+ newobj = PyObject_New(ArrDealloc_Object,&ArrDealloc_Type);
+ newobj->memory = data;
+ Py_XINCREF(base);
+ newobj->base = base;
+ PyArray_BASE(arr) = (PyObject*)newobj;
+ return arr;
Modified: MOAB/trunk/tools/iMesh/python/setup.py
--- MOAB/trunk/tools/iMesh/python/setup.py 2009-06-26 22:39:15 UTC (rev 2973)
+++ MOAB/trunk/tools/iMesh/python/setup.py 2009-06-30 23:11:38 UTC (rev 2974)
@@ -48,7 +48,8 @@
iMesh = Extension('itaps.iMesh',
depends = ['common.h', 'errors.h', 'iMesh_Python.h',
'iBase_Python.h', 'iMesh_entSet.inl',
- 'iMesh_iter.inl', 'iMesh_tag.inl'],
+ 'iMesh_iter.inl', 'iMesh_tag.inl',
+ 'numpy_extensions.h', 'numpy_extensions.inl'],
sources = ['iMesh.c']
