[MOAB-dev] r2918 - in MOAB/trunk/tools/iMesh/python: . doc perf test
    jvporter at wisc.edu
    Thu May 28 18:14:04 CDT 2009
Author: jvporter
Date: 2009-05-28 18:14:04 -0500 (Thu, 28 May 2009)
New Revision: 2918
Modified:
   MOAB/trunk/tools/iMesh/python/doc/ibase.rst
   MOAB/trunk/tools/iMesh/python/doc/imesh.rst
   MOAB/trunk/tools/iMesh/python/iBase.c
   MOAB/trunk/tools/iMesh/python/iMesh.c
   MOAB/trunk/tools/iMesh/python/iMesh_entSet.c
   MOAB/trunk/tools/iMesh/python/iMesh_iter.c
   MOAB/trunk/tools/iMesh/python/iMesh_tag.c
   MOAB/trunk/tools/iMesh/python/perf/perf.py
   MOAB/trunk/tools/iMesh/python/test/adj.py
   MOAB/trunk/tools/iMesh/python/test/basic.py
   MOAB/trunk/tools/iMesh/python/test/iter.py
   MOAB/trunk/tools/iMesh/python/test/tags.py
Log:
* Add iBase.creationStatus enum
* More API changes (tag and entity set interfaces)
* Updated tests
* Finished API reference
Modified: MOAB/trunk/tools/iMesh/python/doc/ibase.rst
--- MOAB/trunk/tools/iMesh/python/doc/ibase.rst	2009-05-28 20:45:59 UTC (rev 2917)
+++ MOAB/trunk/tools/iMesh/python/doc/ibase.rst	2009-05-28 23:14:04 UTC (rev 2918)
@@ -6,36 +6,92 @@
 .. class:: itaps.iBase.type
+   An enumeration of entity types corresponding to ``iBase_EntityType``.
    .. data:: vertex
+      A zero-dimensional entity
    .. data:: edge
+      A one-dimensional entity
    .. data:: face
+      A two-dimensional entity
    .. data:: region
+      A three-dimensional entity
    .. data:: all
+      Allows the user to request information about all the types
 .. class:: itaps.iBase.adjCost
+   An enumeration of entity types corresponding to ``iBase_AdjacencyCost``.
    .. data:: unavailable
+      Adjacency information not supported
    .. data:: all_order_1
+      No more than local mesh traversal required
    .. data:: all_order_logn
+      Global tree search
    .. data:: all_order_n
+      Global exhaustive search
    .. data:: some_order_1
+      Only some adjacency info, local
    .. data:: some_order_logn
+      Only some adjacency info, tree
    .. data:: some_order_n
+      Only some adjacency info, exhaustive
 .. class:: itaps.iBase.storageOrder
+   An enumeration of entity types corresponding to ``iBase_StorageOrder``.
    .. data:: interleaved
-   .. data:: blocked
\ No newline at end of file
+      Coordinates are interleaved, e.g. ``[ x0, y0, z0, x1, y1, z1, ... ]``.
+   .. data:: blocked
+      Coordinates are blocked, e.g. ``[ x0, x1, ..., y0, y1, ..., z0, z1,
+.. class:: itaps.iBase.creationStatus
+   An enumeration of entity types corresponding to ``iBase_CreationStatus``.
+   .. data:: new
+      New entity was created
+   .. data:: exists
+      Entity already exists
+   .. data:: duplicated
+      Duplicate entity created
+   .. data:: failed
+      Creation failed
Modified: MOAB/trunk/tools/iMesh/python/doc/imesh.rst
--- MOAB/trunk/tools/iMesh/python/doc/imesh.rst	2009-05-28 20:45:59 UTC (rev 2917)
+++ MOAB/trunk/tools/iMesh/python/doc/imesh.rst	2009-05-28 23:14:04 UTC (rev 2918)
@@ -4,8 +4,13 @@
 .. module:: itaps
-.. class:: itaps.iMesh
+.. class:: itaps.iMesh([options])
+   Return a new ``iMesh`` object with any implementation-specific options
+   defined in ``options``.
+   :param options: Implementation-specific options string
    .. attribute:: rootSet
       Get the handle of the root set for this instance. The entire mesh in this
@@ -57,18 +62,6 @@
                       which handles are invariant.
       :return: True iff entity handles have changed
-   .. method:: getEntities(entSet, type, topo)
-      Get entities of a specific type and/or topology in ``entSet``. All
-      entities of a given type or topology are requested by specifying
-      ``iBase.type.all`` or ``iMesh.topology.all``, respectively.
-      :param entSet: Entity set being queried
-      :param type: Type of entities being requested
-      :param topo: Topology of entities being requested
-      :return: Array of entity handles from ``entSet`` meeting the requirements
-               of ``type`` and ``topo``.
    .. method:: getVtxCoords(entities[, storageOrder])
       Get coordinates of specified vertices. If ``entitites`` is an array of
@@ -132,8 +125,6 @@
                entities. Otherwise, a tuple containing an array of offsets and
                an array of adjacent entities.
-   .. method:: getAdjEntIndices(entSet, typeRequestor, topoRequestor, typeRequested)
    .. method:: createEntSet(isList)
       Create an entity set, either ordered (``isList == True``) or unordered
@@ -198,15 +189,15 @@
       size is the number of values of type ``type`` that can be held. ``type``
       is one of the following:
-      | i | Integer       |
-      | d | Double        |
-      | E | Entity handle |
-      | b | Binary data   |
+      | ``i`` | Integer       |
+      | ``d`` | Double        |
+      | ``E`` | Entity handle |
+      | ``b`` | Binary data   |
       :param name: Tag name
       :param size: Size of tag in number of values
@@ -230,30 +221,6 @@
       :param name: The name of the tag to find
       :return: The tag with the specified name
-   .. method:: setData(entities, tag, data[, type])
-      Set value(s) for a tag on an entity, entity set, or array of entities.
-      If ``type`` is not specified, this function will retrieve the tag type
-      automatically.
-      :param entities: Entity, entity set, or array of entities on which tag is
-                       being set
-      :param tag: Tag being set
-      :param data: Data to set
-      :param type: Character representing the tag's type (as above)
-   .. method:: getData(entities, tag[, type])
-      Get value(s) for a tag on an entity, entity set, or array of entities.
-      automatically.
-                       being retrieved
-      :param tag: Tag being retrieved
-      :return: The retrieved data
    .. method:: getAllTags(entities)
       Get all the tags associated with a specified entity or entity set.
@@ -261,15 +228,7 @@
       :param entities: Entity or entity set being queried
       :return: Array of tags associated with ``entities``
-   .. method:: rmvTag(entities, tag)
-      Remove a tag value from an entity, entity set, or array of entities.
-      :param entities: Entity, entity set, or array of entities from which tag
-                       is being removed
-      :param tag: Tag to be removed
 .. class:: itaps.iMesh.topology
    An enumeration of mesh element topologies corresponding to
@@ -326,85 +285,276 @@
       Allows the user to request information about all the topology types
-.. class:: itaps.iMesh.iterator
+.. class:: itaps.iMesh.iterator(set, type, topology[, size=1])
+   Return a new iterator on the entity set ``set`` to iterate over entities of
+   the specified ``type`` and ``topology``. If ``size`` is greater than 1, each
+   step of the iteration will return an array of ``size`` entities. All
+   entities of a given type or topology are requested by specifying
+   ``iBase.type.all`` or  `iMesh.topology.all``, respectively.
+   :param set: Entity set to iterate over
+   :param type: Type of entities being requested
+   :param topo: Topology of entities being requested
+   :param count: Number of entities to return on each step of iteration
    .. method:: reset()
+      Resets the iterator to the beginning.
 .. class:: itaps.iMesh.entitySet
    .. attribute:: isList
-      Returns whether the entity set is ordered.
+      Return whether this entity set is ordered.
    .. method:: load(entSet, filename[, options])
-      Load a mesh from a file, adding it to the entity set.
+      Load a mesh from a file, adding it to this entity set.
       :param filename: File name from which the mesh is to be loaded
    .. method:: save(filename[, options])
-      Save the subset of the mesh contained in the entity set to a file.
+      Save the subset of the mesh contained in this entity set to a file.
       :param filename: File name to which the mesh is to be saved
    .. method:: getNumOfType(type)
-      Get the number of entities with the specified type in the entity set.
+      Get the number of entities with the specified type in this entity set.
       :param type: Type of entity requested
       :return: The number of entities in entity set of the requested type
    .. method:: getNumOfTopo(topo)
-      Get the number of entities with the specified topology in the entity set.
+      Get the number of entities with the specified topology in this entity set.
       :param type: Topology of entity requested
       :return: The number of entities in the entity set of the requested
                topology
+   .. method:: getEntities(type, topo)
+      Get entities of a specific type and/or topology in this entity set. All
+      ``iBase.type.all`` or ``iMesh.topology.all``, respectively.
+      :param entSet: Entity set being queried
+      :return: Array of entity handles from ``entSet`` meeting the requirements
+               of ``type`` and ``topo``.
+   .. method:: getAdjEntIndices(type, topo, adjType)
+      Given an entity set and optionally a type or topology, return a tuple
+      containing the following:
+      * The entities in the set of the specified ``type`` and/or ``topology``
+      * The entities adjacent to those entities with the specified type
+        ``adjType``, as a list of unique handles
+      * An index buffer containing, for each entity in the first list,
+        the indices of the entities adjacent to it
+      * An array of offsets into the index buffer for each entity in the first
+        list
+      That is, given an entity located in ``ret[0][i]``, the list of entities to
+      which it is adjacent is::
+        ret[1][  ret[2][ ret[3][i]:ret[3][i+1] ]  ]
+      :param adjType: Type of adjacent entities being requested
+      :return: 4-tuple containing the adjacency information
    .. method:: getNumEntSets(numHops)
+      Get the number of sets contained in this entity set. If this entity set is
+      not the root set, ``numHops`` indicates the maximum number of contained
+      sets from ``self`` to one of the contained sets, inclusive of ``self``.
+      :param numHops: Maximum number of contained sets from ``self`` to a
+                      contained set, including ``self``.
+      :return: Number of entity sets found
    .. method:: getEntSets(numHops)
+      Get the sets contained in this entity set. If this entity set is not the
+      root set, ``numHops`` indicates the maximum number of contained sets from
+      ``self`` to one of the contained sets, inclusive of ``self``.
+      :return: Array of entity sets found
    .. method:: add(entities)
+      Add an entity, entity set, or array of entities to this entity set.
+      :param entities: The entity, entity set, or array of entities to add
    .. method:: remove(entities)
+      Remove an entity, entity set, or array of entities from this entity set.
+      :param entities: The entity, entity set, or array of entities to remove
    .. method:: contains(entities)
+      Return whether an entity, entity set, or array of entities is contained
+      in this entity set.
+      :param entities: The entity, entity set, or array of entities to query
+      :return: If ``entities`` is an array of entities, an array of booleans
+               corresponding to each element of ``entities``. Otherwise, a
+               single boolean.
    .. method:: addChild(entSet)
+      Add ``entSet`` as a child to this entity set.
+      :param entSet: The entity set to add
    .. method:: removeChild(entSet)
+      Remove ``entSet`` as a child from this entity set.
+      :param entSet: The entity set to remove
    .. method:: isChild(entSet)
+      Return whether an entity set is a child of this entity set.
+      :param entSet: The entity set to query:
+      :return: True if ``entSet`` is a child of this entity set, false otherwise
    .. method:: getNumChildren(numHops)
+      Get the number of child sets linked from this entity set. If ``numHops``
+      is non-zero, this represents the maximum hops from this entity set to any
+      child in the count.
+      :param numHops: Maximum hops from this entity set to a child set,
+                      inclusive of the child set
+      :return: Number of children
    .. method:: getNumParents(numHops)
+      Get the number of parent sets linked from this entity set. If ``numHops``
+      parents in the count.
+      :param numHops: Maximum hops from this entity set to a parent set,
+                      inclusive of the parent set
+      :return: Number of parents
    .. method:: getChildren(numHops)
+      Get the child sets linked from this entity set. If ``numHops`` is
+      non-zero, this represents the maximum hops from this entity set to any
+      child in the result.
+      :return: Array of children
    .. method:: getParents(numHops)
+      Get the parents sets linked from this entity set. If ``numHops`` is
+      parent in the result.
+      :return: Array of parents
    .. method:: iterate(type, topo[, count=1])
+      Initialize an iterator over the specified entity type and topology for
+      this entity set. If ``count`` is greater than 1, each step of the
+      iteration returns an array of ``count`` entities. Equivalent to::
+        itaps.iMesh.iterator(self, type, topo, count)
+      :return: An ``itaps.iMesh.iterator`` instance
    .. method:: difference(entSet)
+      Subtract contents of an entity set from this set. Equivalent to
+      ``self - entSet``.
+      :param entSet: Entity set to subtract
+      :return: Resulting entity set
    .. method:: intersection(entSet)
+      Intersect contents of an entity set with this set. Equivalent to
+      ``self & entSet``.
+      :param entSet: Entity set to intersect
    .. method:: union(entSet)
+      Unite contents of an entity set with this set. Equivalent to
+      ``self | entSet``.
+      :param entSet: Entity set to unite
 .. class:: itaps.iMesh.tag
    .. attribute:: name
+      Get the name for this tag.
    .. attribute:: sizeValues
+      Get the size in number of values for this tag.
    .. attribute:: sizeBytes
-   .. attribute:: type
+      Get the size in bytes for this tag.
+   .. attribute:: type
+      Get the data type for this tag as a character code (see above).
+   .. method:: setData(entities, data[, type])
+      Set value(s) for the tag on an entity, entity set, or array of entities.
+      If ``type`` is not specified, this function will retrieve the tag type
+      automatically.
+      :param entities: Entity, entity set, or array of entities on which tag is
+                       being set
+      :param data: Data to set
+      :param type: Character representing the tag's type (as above)
+   .. method:: getData(entities, [, type])
+      Get value(s) for the tag on an entity, entity set, or array of entities.
+      automatically.
+                       being retrieved
+      :return: The retrieved data
+   .. method:: rmvTag(entities)
+      Remove the tag value from an entity, entity set, or array of entities.
+      :param entities: Entity, entity set, or array of entities from which tag
+                       is being removed
Modified: MOAB/trunk/tools/iMesh/python/iBase.c
--- MOAB/trunk/tools/iMesh/python/iBase.c	2009-05-28 20:45:59 UTC (rev 2917)
+++ MOAB/trunk/tools/iMesh/python/iBase.c	2009-05-28 23:14:04 UTC (rev 2918)
@@ -35,9 +35,10 @@
 static int NPY_IBASETAG;
-ENUM_TYPE(type,         "iBase.type",         "");
-ENUM_TYPE(adjCost,      "iBase.adjCost",      "");
-ENUM_TYPE(storageOrder, "iBase.storageOrder", "");
+ENUM_TYPE(type,           "iBase.type",           "");
+ENUM_TYPE(adjCost,        "iBase.adjCost",        "");
+ENUM_TYPE(storageOrder,   "iBase.storageOrder",   "");
+ENUM_TYPE(creationStatus, "iBase.creationStatus", "");
 static PyMethodDef module_methods[] = {
     {0}
@@ -85,6 +86,9 @@
 static PyObject *
 iBaseEntObj_richcompare(iBaseEntity_Object *lhs,iBaseEntity_Object *rhs,int op)
+    if(!iBaseEntity_Check(lhs) || !iBaseEntity_Check(rhs))
+        return Py_NotImplemented;
     switch(op)
     case Py_EQ:
@@ -150,6 +154,9 @@
 iBaseEntSetObj_richcompare(iBaseEntitySet_Object *lhs,
                            iBaseEntitySet_Object *rhs,int op)
+    if(!iBaseEntitySet_Check(lhs) || !iBaseEntitySet_Check(rhs))
     switch(op)
     case Py_EQ:
@@ -270,6 +277,14 @@
     ADD_ENUM(&storageOrder_Type,"blocked",    iBase_BLOCKED);
     ADD_ENUM(&storageOrder_Type,"interleaved",iBase_INTERLEAVED);
+    /***** initialize creation status enum *****/
+    REGISTER_SIMPLE(m,creationStatus);
+    ADD_ENUM(&creationStatus_Type,"new",        iBase_NEW);
+    ADD_ENUM(&creationStatus_Type,"exists",     iBase_ALREADY_EXISTED);
+    ADD_ENUM(&creationStatus_Type,"duplicated", iBase_CREATED_DUPLICATE);
+    ADD_ENUM(&creationStatus_Type,"failed",     iBase_CREATION_FAILED);
     /***** initialize iBaseEntity handle *****/
     iBaseEntity_Type.tp_repr = (reprfunc)iBaseEntObj_repr;
     iBaseEntity_Type.tp_richcompare = (richcmpfunc)iBaseEntObj_richcompare;
Modified: MOAB/trunk/tools/iMesh/python/iMesh.c
--- MOAB/trunk/tools/iMesh/python/iMesh.c	2009-05-28 20:45:59 UTC (rev 2917)
+++ MOAB/trunk/tools/iMesh/python/iMesh.c	2009-05-28 23:14:04 UTC (rev 2918)
@@ -188,27 +188,6 @@
 static PyObject *
-iMeshObj_getEntities(iMeshObject *self,PyObject *args)
-    iBaseEntitySet_Object *set;
-    enum iBase_EntityType type;
-    enum iMesh_EntityTopology topo;
-    iBase_EntityHandle *entities=0;
-    int alloc=0,size,err;
-    if(!PyArg_ParseTuple(args,"O!ii",&iBaseEntitySet_Type,&set,&type,&topo))
-        return NULL;
-    iMesh_getEntities(self->mesh,set->handle,type,topo,&entities,&alloc,&size,
-                      &err);
-    if(checkError(self->mesh,err))
-        return NULL;
-    npy_intp dims[] = {size};
-    return PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,entities);
-static PyObject *
 iMeshObj_getVtxCoords(iMeshObject *self,PyObject *args)
     PyObject *obj;
@@ -492,59 +471,6 @@
 static PyObject *
-iMeshObj_getAdjEntIndices(iMeshObject *self,PyObject *args)
-    int type_requestor,topo_requestor,type_requested;
-    int err;
-    if(!PyArg_ParseTuple(args,"O!iii",&iBaseEntitySet_Type,&set,
-                         &type_requestor,&topo_requestor,&type_requested))
-        return NULL;
-    int ent_alloc=0,ent_size;
-    iBase_EntityHandle *adj_ents=0;
-    int adj_alloc=0,adj_size;
-    int *indices=0;
-    int ind_alloc=0,ind_size;
-    int *offsets=0;
-    int off_alloc=0,off_size;
-    iMesh_getAdjEntIndices(self->mesh,set->handle,type_requestor,
-                           topo_requestor,type_requested,
-                           &entities,&ent_alloc,&ent_size,
-                           &adj_ents,&adj_alloc,&adj_size,
-                           &indices, &ind_alloc,&ind_size,
-                           &offsets, &off_alloc,&off_size,
-                           &err);
-        return NULL;
-    /* TODO: this is clunky */
-    PyObject *tup = PyTuple_New(4);
-    npy_intp dims[1];
-    dims[0] = ent_size;
-    PyTuple_SET_ITEM(tup, 0,
-        PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,entities));
-    dims[0] = adj_size;
-    PyTuple_SET_ITEM(tup, 1,
-        PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,adj_ents));
-    dims[0] = ind_size;
-    PyTuple_SET_ITEM(tup, 2,
-        PyArray_NewFromMalloc(1,dims,NPY_INT,indices));
-    dims[0] = off_size;
-    PyTuple_SET_ITEM(tup, 3,
-        PyArray_NewFromMalloc(1,dims,NPY_INT,offsets));
-    return tup;
-static PyObject *
 iMeshObj_createEntSet(iMeshObject *self,PyObject *args)
     int isList,err;
@@ -907,380 +833,6 @@
 static PyObject *
-iMeshObj_setData(iMeshObject *self,PyObject *args)
-    PyObject *obj;
-    iBaseTag_Object *tag;
-    PyObject *data_obj;
-    char typechar=0;
-    int type;
-    int err;
-    if(!PyArg_ParseTuple(args,"OO!O|c",&obj,&iBaseTag_Type,&tag,&data_obj,
-                         &typechar))
-        return NULL;
-    if(typechar == 0)
-        /* infer the type of the data */
-        iMesh_getTagType(self->mesh,tag->handle,&type,&err);
-            return NULL;
-    else
-        type = char_to_type(typechar);
-        if(type == -1)
-            PyErr_SetString(PyExc_ValueError,ERR_TYPE_CODE);
-            return NULL;
-    PyObject *ents = PyArray_TryFromObject(obj,NPY_IBASEENT,1,1);
-    if(ents)
-        int ent_size;
-        iBase_EntityHandle *entities;
-        int data_size;
-        PyObject *data_arr=0;
-        ent_size = PyArray_SIZE(ents);
-        entities = PyArray_DATA(ents);
-        if(type == iBase_INTEGER)
-            data_arr = PyArray_FROMANY(data_obj,NPY_INT,1,1,NPY_C_CONTIGUOUS);
-            if(data_arr == NULL)
-                return NULL;
-            data_size = PyArray_SIZE(data_arr);
-            int *data = PyArray_DATA(data_arr);
-            iMesh_setIntArrData(self->mesh,entities,ent_size,tag->handle,data,
-                                data_size,&err);
-        else if(type == iBase_DOUBLE)
-            data_arr = PyArray_FROMANY(data_obj,NPY_DOUBLE,1,1,
-                                       NPY_C_CONTIGUOUS);
-                return NULL;
-            double *data = PyArray_DATA(data_arr);
-            iMesh_setDblArrData(self->mesh,entities,ent_size,tag->handle,data,
-                                data_size,&err);
-        else if(type == iBase_ENTITY_HANDLE)
-            data_arr = PyArray_FROMANY(data_obj,NPY_IBASEENT,1,1,
-                return NULL;
-            iBase_EntityHandle *data = PyArray_DATA(data_arr);
-            iMesh_setEHArrData(self->mesh,entities,ent_size,tag->handle,data,
-                               data_size,&err);
-        else /* iBase_BYTES */
-            data_arr = PyArray_FROMANY(data_obj,NPY_BYTE,1,1,NPY_C_CONTIGUOUS);
-                return NULL;
-            char *data = PyArray_DATA(data_arr);
-            iMesh_setArrData(self->mesh,entities,ent_size,tag->handle,data,
-                             data_size,&err);
-        Py_DECREF(ents);
-        Py_XDECREF(data_arr);
-    else if(iBaseEntitySet_Check(obj))
-        iBase_EntitySetHandle set = iBaseEntitySet_GetHandle(obj);
-            PyObject *o = PyNumber_Int(data_obj);
-            if(o == NULL)
-                return NULL;
-            iMesh_setEntSetIntData(self->mesh,set,tag->handle,PyInt_AsLong(o),
-                                   &err);
-            Py_DECREF(o);
-            PyObject *o = PyNumber_Float(data_obj);
-            if(o == NULL)
-                return NULL;
-            iMesh_setEntSetDblData(self->mesh,set,tag->handle,
-                                   PyFloat_AsDouble(o),&err);
-            Py_DECREF(o);
-            if(!iBaseEntity_Check(data_obj))
-                return NULL;
-            iMesh_setEntSetEHData(self->mesh,set,tag->handle,
-                                  iBaseEntity_GetHandle(data_obj),&err);
-            PyObject *data_arr = PyArray_FROMANY(data_obj,NPY_BYTE,1,1,
-                return NULL;
-            int data_size = PyArray_SIZE(data_arr);
-            iMesh_setEntSetData(self->mesh,set,tag->handle,data,data_size,
-                                &err);
-            Py_DECREF(data_arr);
-    else if(iBaseEntity_Check(obj))
-        iBase_EntityHandle entity = iBaseEntity_GetHandle(obj);
-            if(o == NULL)
-                return NULL;
-            iMesh_setIntData(self->mesh,entity,tag->handle,PyInt_AsLong(o),
-                             &err);
-            Py_DECREF(o);
-            if(o == NULL)
-                return NULL;
-            iMesh_setDblData(self->mesh,entity,tag->handle,
-            Py_DECREF(o);
-                return NULL;
-            iMesh_setEHData(self->mesh,entity,tag->handle,
-                return NULL;
-            iMesh_setData(self->mesh,entity,tag->handle,data,data_size,&err);
-    else
-        PyErr_SetString(PyExc_ValueError,ERR_ANY_ENT);
-        return NULL;
-        return NULL;
-    Py_RETURN_NONE;
-static PyObject *
-iMeshObj_getData(iMeshObject *self,PyObject *args)
-    PyObject *obj;
-    char typechar=0;
-    int type;
-    int err;
-    if(!PyArg_ParseTuple(args,"OO!|c",&obj,&iBaseTag_Type,&tag,&typechar))
-        return NULL;
-    if(typechar == 0)
-            return NULL;
-    else
-        if(type == -1)
-            PyErr_SetString(PyExc_ValueError,"invalid type code");
-            return NULL;
-    if(ents)
-        int ent_size = PyArray_SIZE(ents);
-        iBase_EntityHandle *entities = PyArray_DATA(ents);
-        PyObject *ret = 0;
-            int *data=0;
-            int alloc=0,size;
-            iMesh_getIntArrData(self->mesh,entities,ent_size,tag->handle,&data,
-                                &alloc,&size,&err);
-            if(!checkError(self->mesh,err))
-                ret = PyArray_NewFromMalloc(1,dims,NPY_INT,data);
-            double *data=0;
-            int alloc=0,size;
-            iMesh_getDblArrData(self->mesh,entities,ent_size,tag->handle,&data,
-                ret = PyArray_NewFromMalloc(1,dims,NPY_DOUBLE,data);
-            iBase_EntityHandle *data=0;
-            int alloc=0,size;
-            iMesh_getEHArrData(self->mesh,entities,ent_size,tag->handle,&data,
-                ret = PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,data);
-            char *data=0;
-            int alloc=0,size;
-            iMesh_getArrData(self->mesh,entities,ent_size,tag->handle,&data,
-                ret = PyArray_NewFromMalloc(1,dims,NPY_BYTE,data);
-        Py_DECREF(ents);
-        return ret;
-            int data;
-            iMesh_getEntSetIntData(self->mesh,set,tag->handle,&data,&err);
-                return NULL;
-            return Py_BuildValue("i",data);
-            double data;
-            iMesh_getEntSetDblData(self->mesh,set,tag->handle,&data,&err);
-                return NULL;
-            return Py_BuildValue("d",data);
-            iBaseEntity_Object *data = iBaseEntity_New();
-            iMesh_getEntSetEHData(self->mesh,set,tag->handle,&data->handle,
-                                  &err);
-                Py_DECREF(data);
-                return NULL;
-            return (PyObject*)data;
-            char *data=0;
-            int alloc=0,size;
-            iMesh_getEntSetData(self->mesh,set,tag->handle,&data,&alloc,&size,
-                                &err);
-                return NULL;
-            return PyArray_NewFromMalloc(1,dims,NPY_BYTE,data);
-            int data;
-            iMesh_getIntData(self->mesh,entity,tag->handle,&data,&err);
-                return NULL;
-            double data;
-            iMesh_getDblData(self->mesh,entity,tag->handle,&data,&err);
-                return NULL;
-            iMesh_getEHData(self->mesh,entity,tag->handle,&data->handle,&err);
-                Py_DECREF(data);
-                return NULL;
-            char *data=0;
-            int alloc=0,size;
-            iMesh_getData(self->mesh,entity,tag->handle,&data,&alloc,&size,
-                          &err);
-                return NULL;
-    else
-        return NULL;
-static PyObject *
 iMeshObj_getAllTags(iMeshObject *self,PyObject *args)
     PyObject *ents;
@@ -1318,46 +870,7 @@
                                      (PyObject*)self);
-static PyObject *
-iMeshObj_rmvTag(iMeshObject *self,PyObject *args)
-    PyObject *obj;
-    int err;
-    if(!PyArg_ParseTuple(args,"OO!",&obj,&iBaseTag_Type,&tag))
-        return NULL;
-    if(ents)
-        iMesh_rmvArrTag(self->mesh,entities,ent_size,tag->handle,&err);
-        Py_DECREF(ents);
-        iMesh_rmvEntSetTag(self->mesh,set,tag->handle,&err);
-        iMesh_rmvTag(self->mesh,entity,tag->handle,&err);
-    else
-        return NULL;
-        return NULL;
-    Py_RETURN_NONE;
 static PyMethodDef iMesh_methods[] = {
     { "load", (PyCFunction)iMeshObj_load, METH_VARARGS,
       "Load a mesh from a file"
@@ -1369,9 +882,6 @@
       "Return whether entity handles have changed since last reset or since "
       "instance construction"
-    { "getEntities", (PyCFunction)iMeshObj_getEntities, METH_VARARGS,
-      "Get entities of specific type and/or topology in set or instance"
     { "getVtxCoords", (PyCFunction)iMeshObj_getVtxCoords, METH_VARARGS,
       "Get coordinates of specified vertex(ices)"
@@ -1387,9 +897,6 @@
     { "getEnt2ndAdj", (PyCFunction)iMeshObj_getEnt2ndAdj, METH_VARARGS,
       "Get \"2nd order\" adjacencies to entity(ies)"
-    { "getAdjEntIndices", (PyCFunction)iMeshObj_getAdjEntIndices, METH_VARARGS,
-      "Get indexed representation of mesh or subset of mesh"
     { "createEntSet", (PyCFunction)iMeshObj_createEntSet, METH_VARARGS,
       "Create an entity set"
@@ -1420,19 +927,10 @@
     { "getTagHandle", (PyCFunction)iMeshObj_getTagHandle, METH_VARARGS,
       "Get the handle of an existing tag with the specified name"
-    { "setData", (PyCFunction)iMeshObj_setData, METH_VARARGS,
-      "Set tag values on an entity (or array/set of entities)"
-    { "getData", (PyCFunction)iMeshObj_getData, METH_VARARGS,
-      "Get tag values on an entity (or array/set of entities)"
     { "getAllTags", (PyCFunction)iMeshObj_getAllTags, METH_VARARGS,
       "Get all the tags associated with a specified entity handle (or "
       "array/set of entities)"
-    { "rmvTag", (PyCFunction)iMeshObj_rmvTag, METH_VARARGS,
-      "Remove a tag value from an entity (or array/set of entities)"
   {0}
Modified: MOAB/trunk/tools/iMesh/python/iMesh_entSet.c
--- MOAB/trunk/tools/iMesh/python/iMesh_entSet.c	2009-05-28 20:45:59 UTC (rev 2917)
+++ MOAB/trunk/tools/iMesh/python/iMesh_entSet.c	2009-05-28 23:14:04 UTC (rev 2918)
@@ -48,7 +48,7 @@
         return NULL;
     iMesh_getNumOfType(self->mesh->mesh,self->set.handle,type,&num,&err);
+    if(checkError(self->mesh->mesh,err))
         return NULL;
     return Py_BuildValue("i",num);
@@ -63,13 +63,85 @@
         return NULL;
     iMesh_getNumOfTopo(self->mesh->mesh,self->set.handle,topo,&num,&err);
         return NULL;
 static PyObject *
+iMeshEntSetObj_getEntities(iMeshEntitySet_Object *self,PyObject *args)
+    enum iBase_EntityType type;
+    enum iMesh_EntityTopology topo;
+    iBase_EntityHandle *entities=0;
+    int alloc=0,size,err;
+    if(!PyArg_ParseTuple(args,"ii",&type,&topo))
+        return NULL;
+    iMesh_getEntities(self->mesh->mesh,self->set.handle,type,topo,&entities,
+                      &alloc,&size,&err);
+        return NULL;
+    npy_intp dims[] = {size};
+    return PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,entities);
+static PyObject *
+iMeshEntSetObj_getAdjEntIndices(iMeshEntitySet_Object *self,PyObject *args)
+    int type_requestor,topo_requestor,type_requested;
+    int err;
+    if(!PyArg_ParseTuple(args,"iii",&type_requestor,&topo_requestor,
+                         &type_requested))
+        return NULL;
+    int ent_alloc=0,ent_size;
+    iBase_EntityHandle *adj_ents=0;
+    int adj_alloc=0,adj_size;
+    int *indices=0;
+    int ind_alloc=0,ind_size;
+    int *offsets=0;
+    int off_alloc=0,off_size;
+    iMesh_getAdjEntIndices(self->mesh->mesh,self->set.handle,type_requestor,
+                           topo_requestor,type_requested,
+                           &entities,&ent_alloc,&ent_size,
+                           &adj_ents,&adj_alloc,&adj_size,
+                           &indices, &ind_alloc,&ind_size,
+                           &offsets, &off_alloc,&off_size,
+                           &err);
+        return NULL;
+    /* TODO: this is clunky */
+    PyObject *tup = PyTuple_New(4);
+    npy_intp dims[1];
+    dims[0] = ent_size;
+    PyTuple_SET_ITEM(tup, 0,
+        PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,entities));
+    dims[0] = adj_size;
+    PyTuple_SET_ITEM(tup, 1,
+        PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,adj_ents));
+    dims[0] = ind_size;
+    PyTuple_SET_ITEM(tup, 2,
+        PyArray_NewFromMalloc(1,dims,NPY_INT,indices));
+    dims[0] = off_size;
+    PyTuple_SET_ITEM(tup, 3,
+        PyArray_NewFromMalloc(1,dims,NPY_INT,offsets));
+    return tup;
+static PyObject *
 iMeshEntSetObj_isList(iMeshEntitySet_Object *self,void *closure)
     int is_list,err;
@@ -378,7 +450,7 @@
     if(!PyArg_UnpackTuple(args,"iterate",2,3,&type,&topo,&count))
         return NULL;
-    tuple = PyTuple_Pack(size+2,self->mesh,self,type,topo,count);
+    tuple = PyTuple_Pack(size+1,self,type,topo,count);
     ret = PyObject_CallObject((PyObject*)&iMeshIter_Type,tuple);
     Py_DECREF(tuple);
@@ -486,32 +558,39 @@
 static PyMethodDef iMeshEntSetObj_methods[] = {
     { "load", (PyCFunction)iMeshEntSetObj_load, METH_VARARGS,
-      "Load a mesh from a file"
+      "Load a mesh from a file into this set"
     { "save", (PyCFunction)iMeshEntSetObj_save, METH_VARARGS,
-      "Save the mesh to a file"
+      "Save this set of the mesh to a file"
     { "getNumOfType", (PyCFunction)iMeshEntSetObj_getNumOfType, METH_VARARGS,
-      "Get the number of entities with the specified type in the set"
+      "Get the number of entities with the specified type in this set"
     { "getNumOfTopo", (PyCFunction)iMeshEntSetObj_getNumOfTopo, METH_VARARGS,
       "Get the number of entities with the specified topology in the set"
+    { "getEntities", (PyCFunction)iMeshEntSetObj_getEntities, METH_VARARGS,
+      "Get entities of specific type and/or topology in this set"
+    { "getAdjEntIndices", (PyCFunction)iMeshEntSetObj_getAdjEntIndices,
+      METH_VARARGS,
+      "Get indexed representation of this set"
     { "getNumEntSets", (PyCFunction)iMeshEntSetObj_getNumEntSets, METH_VARARGS,
-      "Get the number of entity sets contained in the set"
+      "Get the number of entity sets contained in this set"
     { "getEntSets", (PyCFunction)iMeshEntSetObj_getEntSets, METH_VARARGS,
-      "Get the entity sets contained in the set"
+      "Get the entity sets contained in this set"
     { "add", (PyCFunction)iMeshEntSetObj_add, METH_VARARGS,
-      "Add an entity (or array of entities or entity set) to the set"
+      "Add an entity (or array of entities or entity set) to this set"
     { "remove", (PyCFunction)iMeshEntSetObj_remove, METH_VARARGS,
-      "Remove an entity (or array of entities or entity set) from the set"
+      "Remove an entity (or array of entities or entity set) from this set"
     { "contains", (PyCFunction)iMeshEntSetObj_contains, METH_VARARGS,
       "Return whether an entity (or array of entities or entity set) are "
-      "contained in the set"
+      "contained in this set"
     { "addChild", (PyCFunction)iMeshEntSetObj_addChild, METH_VARARGS,
       "Add parent/child links between two sets"
Modified: MOAB/trunk/tools/iMesh/python/iMesh_iter.c
--- MOAB/trunk/tools/iMesh/python/iMesh_iter.c	2009-05-28 20:45:59 UTC (rev 2917)
+++ MOAB/trunk/tools/iMesh/python/iMesh_iter.c	2009-05-28 23:14:04 UTC (rev 2918)
@@ -7,26 +7,26 @@
 static int
 iMeshIterObj_init(iMeshIter_Object *self,PyObject *args,PyObject *kwds)
-    static char *kwlist[] = {"mesh","entity_set","type","topology",
-                             "array_size",0};
-    iMeshObject *mesh;
+    static char *kwlist[] = {"set","type","topology","size",0};
+    iMeshEntitySet_Object *set;
     int type,topo,array_size=1,err;
-    if( !PyArg_ParseTupleAndKeywords(args,kwds,"OOii|i",kwlist,&mesh,&set,
-                                     &type,&topo,&array_size) )
+    if( !PyArg_ParseTupleAndKeywords(args,kwds,"O!ii|i",kwlist,
+                                     &iMeshEntitySet_Type,&set,&type,&topo,
+                                     &array_size) )
         return -1;
-    self->mesh = mesh->mesh;
+    self->mesh = set->mesh->mesh;
     if(array_size == 1)
         self->is_arr = 0;
-        iMesh_initEntIter(self->mesh,set->handle,type,topo,&self->iter,&err);
+        iMesh_initEntIter(self->mesh,set->set.handle,type,topo,&self->iter,
+                          &err);
     else
         self->is_arr = 1;
-        iMesh_initEntArrIter(self->mesh,set->handle,type,topo,array_size,
+        iMesh_initEntArrIter(self->mesh,set->set.handle,type,topo,array_size,
                              &self->arr_iter,&err);
Modified: MOAB/trunk/tools/iMesh/python/iMesh_tag.c
--- MOAB/trunk/tools/iMesh/python/iMesh_tag.c	2009-05-28 20:45:59 UTC (rev 2917)
+++ MOAB/trunk/tools/iMesh/python/iMesh_tag.c	2009-05-28 23:14:04 UTC (rev 2918)
@@ -3,6 +3,7 @@
 #include "iMesh_Python.h"
 #include "iBase_Python.h"
+#include "errors.h"
 static char typechars[] = {'i','d','E','b'};
@@ -70,8 +71,433 @@
     return Py_BuildValue("c",type_to_char(type));
+static PyObject *
+iMeshTagObj_setData(iMeshTag_Object *self,PyObject *args)
+    PyObject *obj;
+    PyObject *data_obj;
+    char typechar=0;
+    int type;
+    int err;
+    if(!PyArg_ParseTuple(args,"OO|c",&obj,&data_obj,&typechar))
+        return NULL;
+    if(typechar == 0)
+        /* infer the type of the data */
+        iMesh_getTagType(self->mesh->mesh,self->tag.handle,&type,&err);
+            return NULL;
+    else
+        type = char_to_type(typechar);
+        if(type == -1)
+            PyErr_SetString(PyExc_ValueError,ERR_TYPE_CODE);
+            return NULL;
+    PyObject *ents = PyArray_TryFromObject(obj,NPY_IBASEENT,1,1);
+    if(ents)
+        int ent_size;
+        iBase_EntityHandle *entities;
+        int data_size;
+        PyObject *data_arr=0;
+        ent_size = PyArray_SIZE(ents);
+        entities = PyArray_DATA(ents);
+        if(type == iBase_INTEGER)
+            data_arr = PyArray_FROMANY(data_obj,NPY_INT,1,1,NPY_C_CONTIGUOUS);
+            if(data_arr == NULL)
+                return NULL;
+            data_size = PyArray_SIZE(data_arr);
+            int *data = PyArray_DATA(data_arr);
+            iMesh_setIntArrData(self->mesh->mesh,entities,ent_size,
+                                self->tag.handle,data,data_size,&err);
+        else if(type == iBase_DOUBLE)
+            data_arr = PyArray_FROMANY(data_obj,NPY_DOUBLE,1,1,
+                                       NPY_C_CONTIGUOUS);
+                return NULL;
+            double *data = PyArray_DATA(data_arr);
+            iMesh_setDblArrData(self->mesh->mesh,entities,ent_size,
+        else if(type == iBase_ENTITY_HANDLE)
+            data_arr = PyArray_FROMANY(data_obj,NPY_IBASEENT,1,1,
+                return NULL;
+            iBase_EntityHandle *data = PyArray_DATA(data_arr);
+            iMesh_setEHArrData(self->mesh->mesh,entities,ent_size,
+        else /* iBase_BYTES */
+            data_arr = PyArray_FROMANY(data_obj,NPY_BYTE,1,1,NPY_C_CONTIGUOUS);
+                return NULL;
+            char *data = PyArray_DATA(data_arr);
+            iMesh_setArrData(self->mesh->mesh,entities,ent_size,
+        Py_DECREF(ents);
+        Py_XDECREF(data_arr);
+    else if(iBaseEntitySet_Check(obj))
+        iBase_EntitySetHandle set = iBaseEntitySet_GetHandle(obj);
+            PyObject *o = PyNumber_Int(data_obj);
+            if(o == NULL)
+                return NULL;
+            iMesh_setEntSetIntData(self->mesh->mesh,set,self->tag.handle,
+                                   PyInt_AsLong(o),&err);
+            Py_DECREF(o);
+            PyObject *o = PyNumber_Float(data_obj);
+            if(o == NULL)
+                return NULL;
+            iMesh_setEntSetDblData(self->mesh->mesh,set,self->tag.handle,
+                                   PyFloat_AsDouble(o),&err);
+            Py_DECREF(o);
+            if(!iBaseEntity_Check(data_obj))
+                return NULL;
+            iMesh_setEntSetEHData(self->mesh->mesh,set,self->tag.handle,
+                                  iBaseEntity_GetHandle(data_obj),&err);
+            PyObject *data_arr = PyArray_FROMANY(data_obj,NPY_BYTE,1,1,
+                return NULL;
+            int data_size = PyArray_SIZE(data_arr);
+            iMesh_setEntSetData(self->mesh->mesh,set,self->tag.handle,data,
+                                data_size,&err);
+            Py_DECREF(data_arr);
+    else if(iBaseEntity_Check(obj))
+        iBase_EntityHandle entity = iBaseEntity_GetHandle(obj);
+            if(o == NULL)
+                return NULL;
+            iMesh_setIntData(self->mesh->mesh,entity,self->tag.handle,
+            Py_DECREF(o);
+            if(o == NULL)
+                return NULL;
+            iMesh_setDblData(self->mesh->mesh,entity,self->tag.handle,
+            Py_DECREF(o);
+                return NULL;
+            iMesh_setEHData(self->mesh->mesh,entity,self->tag.handle,
+                return NULL;
+            iMesh_setData(self->mesh->mesh,entity,self->tag.handle,data,
+                          data_size,&err);
+    else
+        PyErr_SetString(PyExc_ValueError,ERR_ANY_ENT);
+        return NULL;
+        return NULL;
+    Py_RETURN_NONE;
+static PyObject *
+iMeshTagObj_getData(iMeshTag_Object *self,PyObject *args)
+    PyObject *obj;
+    char typechar=0;
+    int type;
+    int err;
+    if(!PyArg_ParseTuple(args,"O|c",&obj,&typechar))
+        return NULL;
+    if(typechar == 0)
+            return NULL;
+    else
+        if(type == -1)
+            PyErr_SetString(PyExc_ValueError,"invalid type code");
+            return NULL;
+    if(ents)
+        int ent_size = PyArray_SIZE(ents);
+        iBase_EntityHandle *entities = PyArray_DATA(ents);
+        PyObject *ret = 0;
+            int *data=0;
+            int alloc=0,size;
+            iMesh_getIntArrData(self->mesh->mesh,entities,ent_size,
+                                self->tag.handle,&data,&alloc,&size,&err);
+            if(!checkError(self->mesh->mesh,err))
+                ret = PyArray_NewFromMalloc(1,dims,NPY_INT,data);
+            double *data=0;
+            int alloc=0,size;
+            iMesh_getDblArrData(self->mesh->mesh,entities,ent_size,
+                ret = PyArray_NewFromMalloc(1,dims,NPY_DOUBLE,data);
+            iBase_EntityHandle *data=0;
+            int alloc=0,size;
+            iMesh_getEHArrData(self->mesh->mesh,entities,ent_size,
+                ret = PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,data);
+            char *data=0;
+            int alloc=0,size;
+            iMesh_getArrData(self->mesh->mesh,entities,ent_size,
+                ret = PyArray_NewFromMalloc(1,dims,NPY_BYTE,data);
+        Py_DECREF(ents);
+        return ret;
+            int data;
+            iMesh_getEntSetIntData(self->mesh->mesh,set,self->tag.handle,&data,
+                                   &err);
+                return NULL;
+            return Py_BuildValue("i",data);
+            double data;
+            iMesh_getEntSetDblData(self->mesh->mesh,set,self->tag.handle,&data,
+                                   &err);
+                return NULL;
+            return Py_BuildValue("d",data);
+            iBaseEntity_Object *data = iBaseEntity_New();
+            iMesh_getEntSetEHData(self->mesh->mesh,set,self->tag.handle,
+                                  &data->handle,&err);
+                Py_DECREF(data);
+                return NULL;
+            return (PyObject*)data;
+            char *data=0;
+            int alloc=0,size;
+            iMesh_getEntSetData(self->mesh->mesh,set,self->tag.handle,&data,
+                return NULL;
+            return PyArray_NewFromMalloc(1,dims,NPY_BYTE,data);
+            int data;
+            iMesh_getIntData(self->mesh->mesh,entity,self->tag.handle,&data,
+                             &err);
+                return NULL;
+            double data;
+            iMesh_getDblData(self->mesh->mesh,entity,self->tag.handle,&data,
+                             &err);
+                return NULL;
+            iMesh_getEHData(self->mesh->mesh,entity,self->tag.handle,
+                Py_DECREF(data);
+                return NULL;
+            char *data=0;
+            int alloc=0,size;
+            iMesh_getData(self->mesh->mesh,entity,self->tag.handle,&data,
+                return NULL;
+    else
+        return NULL;
+static PyObject *
+iMeshTagObj_remove(iMeshTag_Object *self,PyObject *args)
+    PyObject *obj;
+    int err;
+    if(!PyArg_ParseTuple(args,"O",&obj))
+        return NULL;
+    if(ents)
+        iMesh_rmvArrTag(self->mesh->mesh,entities,ent_size,self->tag.handle,
+                        &err);
+        Py_DECREF(ents);
+        iMesh_rmvEntSetTag(self->mesh->mesh,set,self->tag.handle,&err);
+        iMesh_rmvTag(self->mesh->mesh,entity,self->tag.handle,&err);
+    else
+        return NULL;
+        return NULL;
+    Py_RETURN_NONE;
 static PyMethodDef iMeshTagObj_methods[] = {
+    { "setData", (PyCFunction)iMeshTagObj_setData, METH_VARARGS,
+      "Set tag values on an entity (or array/set of entities)"
+    { "getData", (PyCFunction)iMeshTagObj_getData, METH_VARARGS,
+      "Get tag values on an entity (or array/set of entities)"
+    { "remove", (PyCFunction)iMeshTagObj_remove, METH_VARARGS,
+      "Remove a tag value from an entity (or array/set of entities)"
     {0}
Modified: MOAB/trunk/tools/iMesh/python/perf/perf.py
--- MOAB/trunk/tools/iMesh/python/perf/perf.py	2009-05-28 20:45:59 UTC (rev 2917)
+++ MOAB/trunk/tools/iMesh/python/perf/perf.py	2009-05-28 23:14:04 UTC (rev 2918)
@@ -77,14 +77,14 @@
     ##### 2 #####
     timer.reset()
     for x in range(count):
-        mesh.getAdjEntIndices(root, iBase.type.all,
-                              iMesh.topology.all, iBase.type.all)
+        root.getAdjEntIndices(iBase.type.all, iMesh.topology.all,
+                              iBase.type.all)
     py_stats[file].append( timer.delta()/count )
     list_stats[file].append(0)
     ##### Intermission #####
-    arr = mesh.getAdjEntIndices(root, iBase.type.all,
+    arr = root.getAdjEntIndices(iBase.type.all, iMesh.topology.all,
+                                iBase.type.all)
     list = map(lambda x: x.tolist(), arr)
     ##### 3 #####
Modified: MOAB/trunk/tools/iMesh/python/test/adj.py
--- MOAB/trunk/tools/iMesh/python/test/adj.py	2009-05-28 20:45:59 UTC (rev 2917)
+++ MOAB/trunk/tools/iMesh/python/test/adj.py	2009-05-28 23:14:04 UTC (rev 2918)
@@ -85,8 +85,8 @@
     def testAdjIndices(self):
         set = self.mesh.createEntSet(True)
         set.add(self.ents)
-        adj = self.mesh.getAdjEntIndices(set, iBase.type.all, topo.all,
-                                         iBase.type.all)
+        adj = set.getAdjEntIndices(iBase.type.all, topo.all,
+                                   iBase.type.all)
         self.assertEqual(adj[0].tolist(), self.ents.tolist())
         self.assertEqual(adj[1].tolist(), self.lines)
Modified: MOAB/trunk/tools/iMesh/python/test/basic.py
--- MOAB/trunk/tools/iMesh/python/test/basic.py	2009-05-28 20:45:59 UTC (rev 2917)
+++ MOAB/trunk/tools/iMesh/python/test/basic.py	2009-05-28 23:14:04 UTC (rev 2918)
@@ -85,7 +85,7 @@
         mesh = iMesh()
         root = mesh.rootSet
         mesh.load(file.name)
-        ents = mesh.getEntities(root, iBase.type.all, iMesh.topology.all)
+        ents = root.getEntities(iBase.type.all, iMesh.topology.all)
         self.assertEqual(root.getNumOfType(iBase.type.vertex),    1)
         self.assertEqual(root.getNumOfTopo(iMesh.topology.point), 1)
@@ -93,6 +93,26 @@
         coords = mesh.getVtxCoords(ents, iBase.storageOrder.interleaved)
         self.assert_( (coords == [1,2,3]).all() )
+    def testAltSave(self):
+        file = tempfile.NamedTemporaryFile()
+        mesh = iMesh()
+        verts = [1,2,3]
+        mesh.createVtx(verts)
+        mesh.rootSet.save(file.name)
+        mesh = iMesh()
+        root = mesh.rootSet
+        root.load(file.name)
+        self.assertEqual(root.getNumOfType(iBase.type.vertex),    1)
+        self.assertEqual(root.getNumOfTopo(iMesh.topology.point), 1)
+        coords = mesh.getVtxCoords(ents, iBase.storageOrder.interleaved)
+        self.assert_( (coords == [1,2,3]).all() )
 suite = unittest.TestLoader().loadTestsFromTestCase(TestBasic)
 unittest.TextTestRunner(verbosity=2).run(suite)
Modified: MOAB/trunk/tools/iMesh/python/test/iter.py
--- MOAB/trunk/tools/iMesh/python/test/iter.py	2009-05-28 20:45:59 UTC (rev 2917)
+++ MOAB/trunk/tools/iMesh/python/test/iter.py	2009-05-28 23:14:04 UTC (rev 2918)
@@ -34,8 +34,7 @@
     def testAlternate(self):
         count = 0
-        iter = iMesh.iterator(self.mesh, self.set, iBase.type.all,
-                              iMesh.topology.all)
+        iter = iMesh.iterator(self.set, iBase.type.all, iMesh.topology.all)
         for i in iter:
             count += 1
             self.assertEqual(i, self.ent)
Modified: MOAB/trunk/tools/iMesh/python/test/tags.py
--- MOAB/trunk/tools/iMesh/python/test/tags.py	2009-05-28 20:45:59 UTC (rev 2917)
+++ MOAB/trunk/tools/iMesh/python/test/tags.py	2009-05-28 23:14:04 UTC (rev 2918)
@@ -29,46 +29,41 @@
         self.assertRaises(RuntimeError, self.mesh.getTagHandle, 'potato')
     def testIntData(self):
-        self.mesh.setData(self.ent, self.itag, 42)
-        self.assertEqual(self.mesh.getData(self.ent, self.itag), 42)
-        self.assertEqual(self.mesh.getData(self.ent, self.itag, 'i'), 42)
+        self.itag.setData(self.ent, 42)
+        self.assertEqual(self.itag.getData(self.ent),      42)
+        self.assertEqual(self.itag.getData(self.ent, 'i'), 42)
-        self.mesh.rmvTag(self.ent, self.itag)
-        self.assertRaises(RuntimeError, self.mesh.getData,
-                          self.ent,self.itag)
+        self.itag.remove(self.ent)
+        self.assertRaises(RuntimeError, self.itag.getData, self.ent)
     def testDblData(self):
-        self.mesh.setData(self.ent, self.dtag, 42.0)
-        self.assertEqual(self.mesh.getData(self.ent, self.dtag), 42.0)
-        self.assertEqual(self.mesh.getData(self.ent, self.dtag, 'd'), 42.0)
+        self.dtag.setData(self.ent, 42.0)
+        self.assertEqual(self.dtag.getData(self.ent),      42)
+        self.assertEqual(self.dtag.getData(self.ent, 'd'), 42)
-        self.mesh.rmvTag(self.ent, self.dtag)
-                          self.ent,self.dtag)
+        self.dtag.remove(self.ent)
+        self.assertRaises(RuntimeError, self.dtag.getData, self.ent)
     def testEHData(self):
-        self.mesh.setData(self.ent, self.etag, self.ent)
-        self.assertEqual(self.mesh.getData(self.ent, self.etag), self.ent)
-        self.assertEqual(self.mesh.getData(self.ent, self.etag, 'E'), self.ent)
+        self.etag.setData(self.ent, self.ent)
+        self.assertEqual(self.etag.getData(self.ent),      self.ent)
+        self.assertEqual(self.etag.getData(self.ent, 'E'), self.ent)
-        self.mesh.rmvTag(self.ent, self.etag)
-                          self.ent,self.etag)
+        self.etag.remove(self.ent)
+        self.assertRaises(RuntimeError, self.etag.getData, self.ent)
     def testRawData(self):
         data = array([1,2,3], int8)
-        self.mesh.setData(self.ent, self.btag, data)
-        self.assert_( (self.mesh.getData(self.ent, self.btag) == data).all() )
-        self.assert_( (self.mesh.getData(self.ent, self.btag, 'b') == data)
-                      .all() )
+        self.btag.setData(self.ent, data)
+        self.assert_( (self.btag.getData(self.ent)      == data).all() )
+        self.assert_( (self.btag.getData(self.ent, 'b') == data).all() )
-        self.mesh.rmvTag(self.ent, self.btag)
-                          self.ent,self.btag)
+        self.btag.remove(self.ent)
+        self.assertRaises(RuntimeError, self.btag.getData, self.ent)
     def testGetAll(self):
-        self.mesh.setData(self.ent, self.dtag, 42)
+        self.dtag.setData(self.ent, 42)
         tags = self.mesh.getAllTags(self.ent)
         self.assertEqual(tags[0].name, self.itag.name) # TODO: ignore order?
@@ -76,96 +71,94 @@
     def testIntArrData(self):
-        self.mesh.setData(self.ents, self.itag, 3*[42])
+        self.itag.setData(self.ents, 3*[42])
-        self.assert_((self.mesh.getData(self.ents, self.itag, 'i') ==
-                      3*[42]).all())
-        self.assertEqual(self.mesh.getData(self.ents[0], self.itag, 'i'), 42)
+        self.assert_((self.itag.getData(self.ents)      == 3*[42]).all())
+        self.assert_((self.itag.getData(self.ents, 'i') == 3*[42]).all())
-        self.mesh.rmvTag(self.ents, self.itag)
-                          self.ents,self.itag)
+        self.assertEqual(self.itag.getData(self.ents[0]),      42)
+        self.assertEqual(self.itag.getData(self.ents[0], 'i'), 42)
+        self.itag.remove(self.ents)
+        self.assertRaises(RuntimeError, self.itag.getData, self.ents)
     def testDblArrData(self):
-        self.mesh.setData(self.ents, self.dtag, 3*[42.0])
+        self.dtag.setData(self.ents, 3*[42])
-        self.assert_((self.mesh.getData(self.ents, self.dtag, 'd') ==
-                      3*[42.0]).all())
-        self.assertEqual(self.mesh.getData(self.ents[0], self.dtag, 'd'), 42.0)
+        self.assert_((self.dtag.getData(self.ents)      == 3*[42]).all())
+        self.assert_((self.dtag.getData(self.ents, 'd') == 3*[42]).all())
-        self.mesh.rmvTag(self.ents, self.dtag)
-                          self.ents,self.dtag)
+        self.assertEqual(self.dtag.getData(self.ents[0]),      42)
+        self.assertEqual(self.dtag.getData(self.ents[0], 'd'), 42)
+        self.dtag.remove(self.ents)
+        self.assertRaises(RuntimeError, self.dtag.getData, self.ents)
     def testEHArrData(self):
-        self.mesh.setData(self.ents, self.etag, self.ents)
+        self.etag.setData(self.ents, self.ents)
-        self.assertEqual(str(self.mesh.getData(self.ents, self.etag, 'E')),
-                         str(self.ents))
-        self.assertEqual(self.mesh.getData(self.ents[0], self.etag, 'E'),
-                         self.ents[0])
+        self.assertEqual(self.etag.getData(self.ents).tolist(),
+                         self.ents.tolist())
+        self.assertEqual(self.etag.getData(self.ents, 'E').tolist(),
-        self.mesh.rmvTag(self.ents, self.etag)
-                          self.ents,self.etag)
+        self.assertEqual(self.etag.getData(self.ents[0]),      self.ents[0])
+        self.assertEqual(self.etag.getData(self.ents[0], 'E'), self.ents[0])
+        self.etag.remove(self.ents)
+        self.assertRaises(RuntimeError, self.etag.getData, self.ents)
     def testRawArrData(self):
         data = array(3*[1,2,3], int8)
-        self.mesh.setData(self.ents, self.btag, data)
+        self.btag.setData(self.ents, data)
-        self.assert_((self.mesh.getData(self.ents, self.btag, 'b') ==
-                      data).all())
-        self.assert_((self.mesh.getData(self.ents[0], self.btag, 'b') ==
-                      data[0:3]).all())
+        self.assert_((self.btag.getData(self.ents)      == data).all())
+        self.assert_((self.btag.getData(self.ents, 'b') == data).all())
-        self.mesh.rmvTag(self.ents, self.btag)
-                          self.ents,self.btag)
+        self.assert_((self.btag.getData(self.ents[0])      == data[0:3]).all())
+        self.assert_((self.btag.getData(self.ents[0], 'b') == data[0:3]).all())
+        self.btag.remove(self.ents)
+        self.assertRaises(RuntimeError, self.btag.getData, self.ents)
     def testIntSetData(self):
-        self.mesh.setData(self.set, self.itag, 42)
-        self.assertEqual(self.mesh.getData(self.set, self.itag), 42)
-        self.assertEqual(self.mesh.getData(self.set, self.itag, 'i'), 42)
+        self.itag.setData(self.set, 42)
+        self.assertEqual(self.itag.getData(self.set),      42)
+        self.assertEqual(self.itag.getData(self.set, 'i'), 42)
-        self.mesh.rmvTag(self.set, self.itag)
-                          self.set,self.itag)
+        self.itag.remove(self.set)
+        self.assertRaises(RuntimeError, self.itag.getData, self.set)
     def testDblSetData(self):
-        self.mesh.setData(self.set, self.dtag, 42)
-        self.assertEqual(self.mesh.getData(self.set, self.dtag), 42)
-        self.assertEqual(self.mesh.getData(self.set, self.dtag, 'd'), 42)
+        self.dtag.setData(self.set, 42)
+        self.assertEqual(self.dtag.getData(self.set),      42)
+        self.assertEqual(self.dtag.getData(self.set, 'd'), 42)
-        self.mesh.rmvTag(self.set, self.dtag)
-                          self.set,self.dtag)
+        self.dtag.remove(self.set)
+        self.assertRaises(RuntimeError, self.dtag.getData, self.set)
     def testEHSetData(self):
-        self.mesh.setData(self.set, self.etag, self.ent)
-        self.assertEqual(self.mesh.getData(self.set, self.etag), self.ent)
-        self.assertEqual(self.mesh.getData(self.set, self.etag, 'd'), self.ent)
+        self.etag.setData(self.set, self.ent)
+        self.assertEqual(self.etag.getData(self.set),      self.ent)
+        self.assertEqual(self.etag.getData(self.set, 'E'), self.ent)
-        self.mesh.rmvTag(self.set, self.etag)
-                          self.set,self.etag)
+        self.etag.remove(self.set)
+        self.assertRaises(RuntimeError, self.etag.getData, self.set)
     def testRawSetData(self):
-        self.mesh.setData(self.set, self.btag, data)
+        self.btag.setData(self.set, data)
-        self.assert_((self.mesh.getData(self.set, self.btag) == data).all())
-        self.assert_((self.mesh.getData(self.set, self.btag, 'b') == data)
-                     .all())
+        self.assert_((self.btag.getData(self.set)      == data).all())
+        self.assert_((self.btag.getData(self.set, 'b') == data).all())
-        self.mesh.rmvTag(self.set, self.btag)
-                          self.set,self.btag)
+        self.btag.remove(self.set)
+        self.assertRaises(RuntimeError, self.btag.getData, self.set)
     def testGetAllSet(self):
         tags = self.mesh.getAllTags(self.set)
