[MOAB-dev] r2919 - in MOAB/trunk/tools/iMesh/python: . doc itaps perf test tools
jvporter at wisc.edu jvporter at wisc.edu
Fri May 29 18:31:47 CDT 2009
Author: jvporter
Date: 2009-05-29 18:31:46 -0500 (Fri, 29 May 2009)
New Revision: 2919
Modified:
   MOAB/trunk/tools/iMesh/python/common.h
   MOAB/trunk/tools/iMesh/python/doc/ibase.rst
   MOAB/trunk/tools/iMesh/python/doc/imesh.rst
   MOAB/trunk/tools/iMesh/python/errors.h
   MOAB/trunk/tools/iMesh/python/iBase.c
   MOAB/trunk/tools/iMesh/python/iMesh.c
   MOAB/trunk/tools/iMesh/python/iMesh_Python.h
   MOAB/trunk/tools/iMesh/python/iMesh_entSet.c
   MOAB/trunk/tools/iMesh/python/itaps/__init__.py
   MOAB/trunk/tools/iMesh/python/perf/perf.py
   MOAB/trunk/tools/iMesh/python/setup.py
   MOAB/trunk/tools/iMesh/python/test/adj.py
   MOAB/trunk/tools/iMesh/python/test/basic.py
   MOAB/trunk/tools/iMesh/python/test/entset.py
   MOAB/trunk/tools/iMesh/python/test/iter.py
   MOAB/trunk/tools/iMesh/python/test/tags.py
   MOAB/trunk/tools/iMesh/python/tools/volume.py
Log:
* Minor refactoring
* More consistent naming scheme for Python class names
* Friendlier adjacency lists (still need to update docs!)
Modified: MOAB/trunk/tools/iMesh/python/common.h
--- MOAB/trunk/tools/iMesh/python/common.h	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/common.h	2009-05-29 23:31:46 UTC (rev 2919)
@@ -36,10 +36,11 @@
   SIMPLE_TYPE(name ## _Object,name ## _Type,		\
 		     namestr,docstr)
-#define ADD_ENUM(type,name,value)                       \
+#define ADD_ENUM(typename,name,value)                   \
   do {                                                  \
     PyObject *o = Py_BuildValue("i",(value));           \
-    PyDict_SetItemString((type)->tp_dict,(name),o);     \
+    PyDict_SetItemString((&typename ## _Type)->         \
+                         tp_dict,(name),o);             \
     Py_DECREF(o);                                       \
   } while(0)
Modified: MOAB/trunk/tools/iMesh/python/doc/ibase.rst
--- MOAB/trunk/tools/iMesh/python/doc/ibase.rst	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/doc/ibase.rst	2009-05-29 23:31:46 UTC (rev 2919)
@@ -4,7 +4,7 @@
 .. module:: itaps.iBase
-.. class:: itaps.iBase.type
+.. class:: itaps.iBase.Type
    An enumeration of entity types corresponding to ``iBase_EntityType``.
@@ -29,7 +29,7 @@
       Allows the user to request information about all the types
-.. class:: itaps.iBase.adjCost
+.. class:: itaps.iBase.AdjCost
    An enumeration of entity types corresponding to ``iBase_AdjacencyCost``.
@@ -62,7 +62,7 @@
       Only some adjacency info, exhaustive
-.. class:: itaps.iBase.storageOrder
+.. class:: itaps.iBase.StorageOrder
    An enumeration of entity types corresponding to ``iBase_StorageOrder``.
@@ -76,7 +76,7 @@
-.. class:: itaps.iBase.creationStatus
+.. class:: itaps.iBase.CreationStatus
    An enumeration of entity types corresponding to ``iBase_CreationStatus``.
Modified: MOAB/trunk/tools/iMesh/python/doc/imesh.rst
--- MOAB/trunk/tools/iMesh/python/doc/imesh.rst	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/doc/imesh.rst	2009-05-29 23:31:46 UTC (rev 2919)
@@ -2,11 +2,11 @@
  iMesh Interface
-.. module:: itaps
+.. module:: itaps.iMesh
-.. class:: itaps.iMesh([options])
+.. class:: itaps.iMesh.Mesh([options])
-   Return a new ``iMesh`` object with any implementation-specific options
+   Return a new ``Mesh`` object with any implementation-specific options
    defined in ``options``.
    :param options: Implementation-specific options string
@@ -229,7 +229,7 @@
       :return: Array of tags associated with ``entities``
-.. class:: itaps.iMesh.topology
+.. class:: itaps.iMesh.Topology
    An enumeration of mesh element topologies corresponding to
    ``iMesh_EntityTopology``.
@@ -285,13 +285,13 @@
       Allows the user to request information about all the topology types
-.. class:: itaps.iMesh.iterator(set, type, topology[, size=1])
+.. class:: itaps.iMesh.Iterator(set, type, topology[, count=1])
    Return a new iterator on the entity set ``set`` to iterate over entities of
    the specified ``type`` and ``topology``. If ``size`` is greater than 1, each
    step of the iteration will return an array of ``size`` entities. All
    entities of a given type or topology are requested by specifying
-   ``iBase.type.all`` or  `iMesh.topology.all``, respectively.
+   ``iBase.Type.all`` or  ``iMesh.Topology.all``, respectively.
    :param set: Entity set to iterate over
    :param type: Type of entities being requested
@@ -303,7 +303,7 @@
       Resets the iterator to the beginning.
-.. class:: itaps.iMesh.entitySet
+.. class:: itaps.iMesh.EntitySet
    .. attribute:: isList
@@ -342,7 +342,7 @@
       Get entities of a specific type and/or topology in this entity set. All
-      ``iBase.type.all`` or ``iMesh.topology.all``, respectively.
       :param entSet: Entity set being queried
@@ -480,12 +480,12 @@
       this entity set. If ``count`` is greater than 1, each step of the
       iteration returns an array of ``count`` entities. Equivalent to::
-        itaps.iMesh.iterator(self, type, topo, count)
+        itaps.iMesh.Iterator(self, type, topo, count)
       :param topo: Topology of entities being requested
       :param count: Number of entities to return on each step of iteration
-      :return: An ``itaps.iMesh.iterator`` instance
+      :return: An ``itaps.iMesh.Iterator`` instance
    .. method:: difference(entSet)
@@ -512,7 +512,7 @@
       :return: Resulting entity set
-.. class:: itaps.iMesh.tag
+.. class:: itaps.iMesh.Tag
    .. attribute:: name
@@ -541,7 +541,7 @@
       :param data: Data to set
       :param type: Character representing the tag's type (as above)
-   .. method:: getData(entities, [, type])
+   .. method:: getData(entities[, type])
       Get value(s) for the tag on an entity, entity set, or array of entities.
       If ``type`` is not specified, this function will retrieve the tag type
@@ -552,7 +552,7 @@
       :return: The retrieved data
-   .. method:: rmvTag(entities)
+   .. method:: remove(entities)
       Remove the tag value from an entity, entity set, or array of entities.
Modified: MOAB/trunk/tools/iMesh/python/errors.h
--- MOAB/trunk/tools/iMesh/python/errors.h	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/errors.h	2009-05-29 23:31:46 UTC (rev 2919)
@@ -7,3 +7,4 @@
 #define ERR_ARR_SIZE      "unexpected array size"
 #define ERR_ARR_DIMS      "1- or 2-dimensional array expected"
 #define ERR_TYPE_CODE     "invalid type code"
+#define ERR_ADJ_LIST      "unable to create adjacency list"
Modified: MOAB/trunk/tools/iMesh/python/iBase.c
--- MOAB/trunk/tools/iMesh/python/iBase.c	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/iBase.c	2009-05-29 23:31:46 UTC (rev 2919)
@@ -35,10 +35,10 @@
 static int NPY_IBASETAG;
-ENUM_TYPE(type,           "iBase.type",           "");
-ENUM_TYPE(adjCost,        "iBase.adjCost",        "");
-ENUM_TYPE(storageOrder,   "iBase.storageOrder",   "");
-ENUM_TYPE(creationStatus, "iBase.creationStatus", "");
+ENUM_TYPE(Type,           "iBase.Type",           "");
+ENUM_TYPE(AdjCost,        "iBase.AdjCost",        "");
+ENUM_TYPE(StorageOrder,   "iBase.StorageOrder",   "");
+ENUM_TYPE(CreationStatus, "iBase.CreationStatus", "");
 static PyMethodDef module_methods[] = {
     {0}
@@ -252,38 +252,38 @@
         PyModule_AddObject(m, "_C_API", api_obj);
     /***** initialize type enum *****/
-    REGISTER_SIMPLE(m,type);
+    REGISTER_SIMPLE(m,Type);
-    ADD_ENUM(&type_Type,"vertex", iBase_VERTEX);
-    ADD_ENUM(&type_Type,"edge",   iBase_EDGE);
-    ADD_ENUM(&type_Type,"face",   iBase_FACE);
-    ADD_ENUM(&type_Type,"region", iBase_REGION);
-    ADD_ENUM(&type_Type,"all",    iBase_ALL_TYPES);
+    ADD_ENUM(Type,"vertex", iBase_VERTEX);
+    ADD_ENUM(Type,"edge",   iBase_EDGE);
+    ADD_ENUM(Type,"face",   iBase_FACE);
+    ADD_ENUM(Type,"region", iBase_REGION);
+    ADD_ENUM(Type,"all",    iBase_ALL_TYPES);
     /***** initialize adjacency cost enum *****/
-    REGISTER_SIMPLE(m,adjCost);
+    REGISTER_SIMPLE(m,AdjCost);
-    ADD_ENUM(&adjCost_Type,"unavailable",     iBase_UNAVAILABLE);
-    ADD_ENUM(&adjCost_Type,"all_order_1",     iBase_ALL_ORDER_1);
-    ADD_ENUM(&adjCost_Type,"all_order_logn",  iBase_ALL_ORDER_LOGN);
-    ADD_ENUM(&adjCost_Type,"all_order_n",     iBase_ALL_ORDER_N);
-    ADD_ENUM(&adjCost_Type,"some_order_1",    iBase_SOME_ORDER_1);
-    ADD_ENUM(&adjCost_Type,"some_order_logn", iBase_SOME_ORDER_LOGN);
-    ADD_ENUM(&adjCost_Type,"some_order_n",    iBase_SOME_ORDER_N);
+    ADD_ENUM(AdjCost,"unavailable",     iBase_UNAVAILABLE);
+    ADD_ENUM(AdjCost,"all_order_1",     iBase_ALL_ORDER_1);
+    ADD_ENUM(AdjCost,"all_order_logn",  iBase_ALL_ORDER_LOGN);
+    ADD_ENUM(AdjCost,"all_order_n",     iBase_ALL_ORDER_N);
+    ADD_ENUM(AdjCost,"some_order_1",    iBase_SOME_ORDER_1);
+    ADD_ENUM(AdjCost,"some_order_logn", iBase_SOME_ORDER_LOGN);
+    ADD_ENUM(AdjCost,"some_order_n",    iBase_SOME_ORDER_N);
     /***** initialize storage order enum *****/
-    REGISTER_SIMPLE(m,storageOrder);
+    REGISTER_SIMPLE(m,StorageOrder);
-    ADD_ENUM(&storageOrder_Type,"blocked",    iBase_BLOCKED);
-    ADD_ENUM(&storageOrder_Type,"interleaved",iBase_INTERLEAVED);
+    ADD_ENUM(StorageOrder,"blocked",     iBase_BLOCKED);
+    ADD_ENUM(StorageOrder,"interleaved", iBase_INTERLEAVED);
     /***** initialize creation status enum *****/
-    REGISTER_SIMPLE(m,creationStatus);
+    REGISTER_SIMPLE(m,CreationStatus);
-    ADD_ENUM(&creationStatus_Type,"new",        iBase_NEW);
-    ADD_ENUM(&creationStatus_Type,"exists",     iBase_ALREADY_EXISTED);
-    ADD_ENUM(&creationStatus_Type,"duplicated", iBase_CREATED_DUPLICATE);
-    ADD_ENUM(&creationStatus_Type,"failed",     iBase_CREATION_FAILED);
+    ADD_ENUM(CreationStatus,"new",        iBase_NEW);
+    ADD_ENUM(CreationStatus,"exists",     iBase_ALREADY_EXISTED);
+    ADD_ENUM(CreationStatus,"duplicated", iBase_CREATED_DUPLICATE);
+    ADD_ENUM(CreationStatus,"failed",     iBase_CREATION_FAILED);
     /***** initialize iBaseEntity handle *****/
     iBaseEntity_Type.tp_repr = (reprfunc)iBaseEntObj_repr;
Modified: MOAB/trunk/tools/iMesh/python/iMesh.c
--- MOAB/trunk/tools/iMesh/python/iMesh.c	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/iMesh.c	2009-05-29 23:31:46 UTC (rev 2919)
@@ -2,7 +2,6 @@
 #include "iMesh_Python.h"
 #include "iBase_Python.h"
 int checkError(iMesh_Instance mesh,int err)
     if(err)
@@ -26,6 +25,45 @@
     return ret;
+/* TODO: these are never freed! */
+static PyObject *g_helper_module;
+static PyObject *g_adj_list;
+static PyObject *g_ind_adj_list;
+/* NOTE: steals references to adj and offsets */
+PyObject *
+AdjacencyList_New(PyObject *adj,PyObject *offsets)
+    PyObject *res;
+    if( (res = PyObject_CallFunction(g_adj_list,"OO",adj,offsets)) == NULL)
+        PyErr_SetString(PyExc_RuntimeError,ERR_ADJ_LIST);
+    Py_DECREF(adj);
+    Py_DECREF(offsets);
+    return res;
+PyObject *
+IndexedAdjacencyList_New(PyObject *ents, PyObject *adj,PyObject *indices,
+                         PyObject *offsets)
+    PyObject *res;
+    if( (res = PyObject_CallFunction(g_ind_adj_list,"OOOO",ents,adj,indices,
+                                     offsets)) == NULL)
+    Py_DECREF(ents);
+    Py_DECREF(adj);
+    Py_DECREF(indices);
+    return res;
 static int
 iMeshObj_init(iMeshObject *self,PyObject *args,PyObject *kwds)
@@ -370,10 +408,16 @@
         if(checkError(self->mesh,err))
             return NULL;
-        /* TODO: this is clunky */
+        npy_intp adj_dims[] = {adj_size};
+        npy_intp off_dims[] = {offsets_size};
+        return AdjacencyList_New(
+            PyArray_NewFromMalloc(1,adj_dims,NPY_IBASEENT,adj),
+            PyArray_NewFromMalloc(1,off_dims,NPY_INT,offsets) );
         PyObject *pair = PyTuple_New(2);
         npy_intp dims[1];
         dims[0] = adj_size;
         PyTuple_SET_ITEM(pair, 0,
             PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,adj));
@@ -435,10 +479,16 @@
             return NULL;
         npy_intp dims[1];
         dims[0] = adj_size;
@@ -954,7 +1004,7 @@
 static PyTypeObject iMeshType = {
     PyObject_HEAD_INIT(NULL)
     0,                            /* ob_size */
-    "itaps.iMesh",                /* tp_name */
+    "itaps.iMesh.Mesh",           /* tp_name */
     sizeof(iMeshObject),          /* tp_basicsize */
     0,                            /* tp_itemsize */
     (destructor)iMeshObj_dealloc, /* tp_dealloc */
@@ -1031,7 +1081,7 @@
 static PyArray_ArrFuncs iMeshTagArr_Funcs;
 int NPY_IMESHTAG;
-ENUM_TYPE(topology,"iMesh.topology","");
+ENUM_TYPE(Topology,"iMesh.Topology","");
 static void
@@ -1098,45 +1148,55 @@
     import_array();
     import_iBase();
+    /***** import helper module *****/
+    if( (g_helper_module = PyImport_ImportModule("itaps.helpers")) == NULL)
+        return;
+    if( (g_adj_list = PyObject_GetAttrString(g_helper_module,"AdjacencyList") )
+        == NULL)
+        return;
+    if( (g_ind_adj_list = PyObject_GetAttrString(g_helper_module,
+        "IndexedAdjacencyList")) == NULL)
+        return;
     iMeshType.tp_new = PyType_GenericNew;
     if(PyType_Ready(&iMeshType) < 0)
         return;
     Py_INCREF(&iMeshType);
-    PyModule_AddObject(m,"iMesh",(PyObject *)&iMeshType);
+    PyModule_AddObject(m,"Mesh",(PyObject *)&iMeshType);
     /***** initialize topology enum *****/
-    REGISTER_SIMPLE_SUB(iMeshType,topology);
+    REGISTER_SIMPLE(m,Topology);
-    ADD_ENUM(&topology_Type,"point",         iMesh_POINT);
-    ADD_ENUM(&topology_Type,"line_segment",  iMesh_LINE_SEGMENT);
-    ADD_ENUM(&topology_Type,"polygon",       iMesh_POLYGON);
-    ADD_ENUM(&topology_Type,"triangle",      iMesh_TRIANGLE);
-    ADD_ENUM(&topology_Type,"quadrilateral", iMesh_QUADRILATERAL);
-    ADD_ENUM(&topology_Type,"polyhedron",    iMesh_POLYHEDRON);
-    ADD_ENUM(&topology_Type,"tetrahedron",   iMesh_TETRAHEDRON);
-    ADD_ENUM(&topology_Type,"hexahedron",    iMesh_HEXAHEDRON);
-    ADD_ENUM(&topology_Type,"prism",         iMesh_PRISM);
-    ADD_ENUM(&topology_Type,"pyramid",       iMesh_PYRAMID);
-    ADD_ENUM(&topology_Type,"septahedron",   iMesh_SEPTAHEDRON);
-    ADD_ENUM(&topology_Type,"all",           iMesh_ALL_TOPOLOGIES);
+    ADD_ENUM(Topology,"point",         iMesh_POINT);
+    ADD_ENUM(Topology,"line_segment",  iMesh_LINE_SEGMENT);
+    ADD_ENUM(Topology,"polygon",       iMesh_POLYGON);
+    ADD_ENUM(Topology,"triangle",      iMesh_TRIANGLE);
+    ADD_ENUM(Topology,"quadrilateral", iMesh_QUADRILATERAL);
+    ADD_ENUM(Topology,"polyhedron",    iMesh_POLYHEDRON);
+    ADD_ENUM(Topology,"tetrahedron",   iMesh_TETRAHEDRON);
+    ADD_ENUM(Topology,"hexahedron",    iMesh_HEXAHEDRON);
+    ADD_ENUM(Topology,"prism",         iMesh_PRISM);
+    ADD_ENUM(Topology,"pyramid",       iMesh_PYRAMID);
+    ADD_ENUM(Topology,"septahedron",   iMesh_SEPTAHEDRON);
+    ADD_ENUM(Topology,"all",           iMesh_ALL_TOPOLOGIES);
+    /***** initialize iterator type *****/
     iMeshIter_Type.tp_new = PyType_GenericNew;
     if(PyType_Ready(&iMeshIter_Type) < 0)
         return;
-    PyDict_SetItemString(iMeshType.tp_dict,"iterator",
-                         (PyObject *)&iMeshIter_Type);
+    PyModule_AddObject(m,"Iterator",(PyObject *)&iMeshIter_Type);
+    /***** initialize entity set type *****/
     iMeshEntitySet_Type.tp_base = &iBaseEntitySet_Type;
     if(PyType_Ready(&iMeshEntitySet_Type) < 0)
         return;
-    PyDict_SetItemString(iMeshType.tp_dict,"entitySet",
-                         (PyObject *)&iMeshEntitySet_Type);
+    PyModule_AddObject(m,"EntitySet",(PyObject *)&iMeshEntitySet_Type);
+    /***** initialize tag type *****/
     iMeshTag_Type.tp_base = &iBaseTag_Type;
     if(PyType_Ready(&iMeshTag_Type) < 0)
         return;
-    PyDict_SetItemString(iMeshType.tp_dict,"tag",
-                         (PyObject *)&iMeshTag_Type);
+    PyModule_AddObject(m,"Tag",(PyObject *)&iMeshTag_Type);
     /***** initialize iMeshEntitySet array *****/
Modified: MOAB/trunk/tools/iMesh/python/iMesh_Python.h
--- MOAB/trunk/tools/iMesh/python/iMesh_Python.h	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/iMesh_Python.h	2009-05-29 23:31:46 UTC (rev 2919)
@@ -40,6 +40,12 @@
 enum iBase_TagValueType char_to_type(char c);
 char type_to_char(enum iBase_TagValueType t);
+PyObject *
+AdjacencyList_New(PyObject *adj,PyObject *offsets);
+PyObject *
+                         PyObject *offsets);
 typedef struct
     PyObject_HEAD
Modified: MOAB/trunk/tools/iMesh/python/iMesh_entSet.c
--- MOAB/trunk/tools/iMesh/python/iMesh_entSet.c	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/iMesh_entSet.c	2009-05-29 23:31:46 UTC (rev 2919)
@@ -118,27 +118,16 @@
     if(checkError(self->mesh->mesh,err))
         return NULL;
-    PyObject *tup = PyTuple_New(4);
-    npy_intp dims[1];
+    npy_intp ent_dims[] = {ent_size};
+    npy_intp ind_dims[] = {ind_size};
+    npy_intp off_dims[] = {off_size};
-    dims[0] = ent_size;
-    PyTuple_SET_ITEM(tup, 0,
-        PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,entities));
-    dims[0] = adj_size;
-    PyTuple_SET_ITEM(tup, 1,
-        PyArray_NewFromMalloc(1,dims,NPY_IBASEENT,adj_ents));
-    dims[0] = ind_size;
-    PyTuple_SET_ITEM(tup, 2,
-        PyArray_NewFromMalloc(1,dims,NPY_INT,indices));
-    dims[0] = off_size;
-    PyTuple_SET_ITEM(tup, 3,
-        PyArray_NewFromMalloc(1,dims,NPY_INT,offsets));
-    return tup;
+    return IndexedAdjacencyList_New(
+        PyArray_NewFromMalloc(1,ent_dims,NPY_IBASEENT,entities),
+        PyArray_NewFromMalloc(1,adj_dims,NPY_IBASEENT,adj_ents),
+        PyArray_NewFromMalloc(1,ind_dims,NPY_INT,indices),
 static PyObject *
Modified: MOAB/trunk/tools/iMesh/python/itaps/__init__.py
--- MOAB/trunk/tools/iMesh/python/itaps/__init__.py	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/itaps/__init__.py	2009-05-29 23:31:46 UTC (rev 2919)
@@ -1,2 +1 @@
-import iBase
-from iMesh import *
+__all__ = ['iBase', 'iMesh', 'helpers']
Modified: MOAB/trunk/tools/iMesh/python/perf/perf.py
--- MOAB/trunk/tools/iMesh/python/perf/perf.py	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/perf/perf.py	2009-05-29 23:31:46 UTC (rev 2919)
@@ -63,50 +63,49 @@
     ##### 1 #####
     timer.reset()
     for x in range(count):
-        m = iMesh()
+        m = iMesh.Mesh()
         m.load(file)
         m = None
     py_stats[file].append( timer.delta()/count )
     list_stats[file].append(0)
     ##### Intermission #####
-    mesh = iMesh()
+    mesh = iMesh.Mesh()
     root = mesh.rootSet
     mesh.load(file)
     ##### 2 #####
     timer.reset()
-        root.getAdjEntIndices(iBase.type.all, iMesh.topology.all,
-                              iBase.type.all)
+        root.getAdjEntIndices(iBase.Type.all, iMesh.Topology.all,
+                              iBase.Type.all)
-    arr = root.getAdjEntIndices(iBase.type.all, iMesh.topology.all,
-                                iBase.type.all)
-    list = map(lambda x: x.tolist(), arr)
+    arr = root.getEntities(iBase.Type.all, iMesh.Topology.all)
+    list = arr.tolist()
     ##### 3 #####
     timer.reset()
-        mesh.getEntAdj(arr[0], iBase.type.all)
+        mesh.getEntAdj(arr, iBase.Type.all)
     timer.reset()
-        mesh.getEntAdj(list[0], iBase.type.all)
+        mesh.getEntAdj(list, iBase.Type.all)
     list_stats[file].append( timer.delta()/count )
     ##### 4 #####
     timer.reset()
-        mesh.getEnt2ndAdj(arr[0], iBase.type.edge, iBase.type.vertex)
+        mesh.getEnt2ndAdj(arr, iBase.Type.edge, iBase.Type.vertex)
     timer.reset()
-        mesh.getEnt2ndAdj(list[0], iBase.type.edge, iBase.type.vertex)
+        mesh.getEnt2ndAdj(list, iBase.Type.edge, iBase.Type.vertex)
     mesh = None
Modified: MOAB/trunk/tools/iMesh/python/setup.py
--- MOAB/trunk/tools/iMesh/python/setup.py	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/setup.py	2009-05-29 23:31:46 UTC (rev 2919)
@@ -21,5 +21,6 @@
       author = 'Jim Porter',
       author_email = 'jvporter at wisc.edu',
       packages = ['itaps'],
-      ext_modules = [iBase, iMesh]
+      ext_modules = [iBase, iMesh],
+      py_modules = ['itaps.helpers']
Modified: MOAB/trunk/tools/iMesh/python/test/adj.py
--- MOAB/trunk/tools/iMesh/python/test/adj.py	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/test/adj.py	2009-05-29 23:31:46 UTC (rev 2919)
@@ -1,14 +1,14 @@
 from itaps import *
 import unittest
-topo = iMesh.topology # shorthand
+topo = iMesh.Topology # shorthand
 class TestAdj(unittest.TestCase):
     def setUp(self):
-        self.mesh = iMesh()
+        self.mesh = iMesh.Mesh()
         self.verts = [[0,0,0], [0,0,1], [0,1,0], [0,1,1]]
         self.ents = self.mesh.createVtx(self.verts,
-                                        iBase.storageOrder.interleaved)
+                                        iBase.StorageOrder.interleaved)
         self.lines = [
             self.mesh.createEnt(topo.line_segment, self.ents[0:2] )[0],
@@ -23,76 +23,69 @@
         self.root  = None
         self.lines = None
-    @staticmethod
-    def jaggify(arr,offsets):
-        prev = offsets[0]
-        jag = []
-        for i in offsets[1:]:
-            jag.append(arr[prev:i].tolist())
-            prev = i
-        return jag
     def testSquare(self):
         quad = self.mesh.createEnt(topo.quadrilateral, self.lines)[0]
         root = self.mesh.rootSet
-        self.assertEqual(root.getNumOfType(iBase.type.vertex),  4)
-        self.assertEqual(root.getNumOfType(iBase.type.edge),    4)
-        self.assertEqual(root.getNumOfType(iBase.type.face),    1)
+        self.assertEqual(root.getNumOfType(iBase.Type.vertex),  4)
+        self.assertEqual(root.getNumOfType(iBase.Type.edge),    4)
+        self.assertEqual(root.getNumOfType(iBase.Type.face),    1)
         self.assertEqual(root.getNumOfTopo(topo.point),         4)
         self.assertEqual(root.getNumOfTopo(topo.line_segment),  4)
         self.assertEqual(root.getNumOfTopo(topo.quadrilateral), 1)
         self.mesh.deleteEnt(quad)
-        self.assertEqual(root.getNumOfType(iBase.type.face),    0)
+        self.assertEqual(root.getNumOfType(iBase.Type.face),    0)
         self.assertEqual(root.getNumOfTopo(topo.quadrilateral), 0)
         self.mesh.deleteEnt(self.lines)
-        self.assertEqual(root.getNumOfType(iBase.type.edge),    0)
+        self.assertEqual(root.getNumOfType(iBase.Type.edge),    0)
         self.assertEqual(root.getNumOfTopo(topo.line_segment),  0)
         self.mesh.deleteEnt(self.ents)
-        self.assertEqual(root.getNumOfType(iBase.type.vertex),  0)
+        self.assertEqual(root.getNumOfType(iBase.Type.vertex),  0)
         self.assertEqual(root.getNumOfTopo(topo.point),         0)
     def testAdj(self):
-        adj = self.mesh.getEntAdj(self.ents[1], iBase.type.all)
+        adj = self.mesh.getEntAdj(self.ents[1], iBase.Type.all)
         self.assertEqual(adj.tolist(), self.lines[0:2])
-        adj = self.mesh.getEntAdj(self.ents, iBase.type.all)
-        self.assertEqual(TestAdj.jaggify(adj[0],adj[1]),
-                         [ self.lines[::3],
-                           self.lines[0:2],
-                           self.lines[1:3],
-                           self.lines[2:4] ])
+        adj = self.mesh.getEntAdj(self.ents, iBase.Type.all)
+        self.assertEqual(adj[0].tolist(), self.lines[::3])
+        self.assertEqual(adj[1].tolist(), self.lines[0:2])
+        self.assertEqual(adj[2].tolist(), self.lines[1:3])
+        self.assertEqual(adj[3].tolist(), self.lines[2:4])
     def test2ndAdj(self):
-        adj = self.mesh.getEnt2ndAdj(self.ents[1], iBase.type.edge,
-                                     iBase.type.vertex)
+        adj = self.mesh.getEnt2ndAdj(self.ents[1], iBase.Type.edge,
+                                     iBase.Type.vertex)
         self.assertEqual(adj.tolist(), self.ents[0:3:2].tolist())
-        adj = self.mesh.getEnt2ndAdj(self.ents, iBase.type.edge,
-                         [ self.ents[1::2].tolist(),
-                           self.ents[0::2].tolist(),
-                           self.ents[1::2].tolist(),
-                           self.ents[0::2].tolist() ])
+        adj = self.mesh.getEnt2ndAdj(self.ents, iBase.Type.edge,
+        self.assertEqual(adj[0].tolist(), self.ents[1::2].tolist())
+        self.assertEqual(adj[1].tolist(), self.ents[0::2].tolist())
+        self.assertEqual(adj[2].tolist(), self.ents[1::2].tolist())
+        self.assertEqual(adj[3].tolist(), self.ents[0::2].tolist())
     def testAdjIndices(self):
         set = self.mesh.createEntSet(True)
         set.add(self.ents)
-        adj = set.getAdjEntIndices(iBase.type.all, topo.all,
-                                   iBase.type.all)
+        adj = set.getAdjEntIndices(iBase.Type.all, topo.all,
+                                   iBase.Type.all)
-        self.assertEqual(adj[0].tolist(), self.ents.tolist())
-        self.assertEqual(adj[1].tolist(), self.lines)
-        self.assertEqual(TestAdj.jaggify(adj[2],adj[3]),
-                         [ [0,3], [0,1], [1,2], [2,3] ])
+        self.assertEqual(adj.entities.tolist(), self.ents.tolist())
+        self.assertEqual(adj.adj.tolist(), self.lines)
+        self.assert_( (adj.index(0) == [0,3]).all() )
+        self.assert_( (adj.index(1) == [0,1]).all() )
+        self.assert_( (adj.index(2) == [1,2]).all() )
+        self.assert_( (adj.index(3) == [2,3]).all() )
 suite = unittest.TestLoader().loadTestsFromTestCase(TestAdj)
 unittest.TextTestRunner(verbosity=2).run(suite)
Modified: MOAB/trunk/tools/iMesh/python/test/basic.py
--- MOAB/trunk/tools/iMesh/python/test/basic.py	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/test/basic.py	2009-05-29 23:31:46 UTC (rev 2919)
@@ -4,7 +4,7 @@
 class TestBasic(unittest.TestCase):
     def testMinimal(self):
-        mesh = iMesh("hello there")
+        mesh = iMesh.Mesh("hello there")
         mesh.geometricDimension = 2
         self.assertEqual(mesh.geometricDimension, 2)
@@ -12,63 +12,63 @@
         mesh.dfltStorage
         self.assert_(mesh.areEHValid(True))
-        self.assertEqual(root.getNumOfType(iBase.type.all),     0)
-        self.assertEqual(root.getNumOfTopo(iMesh.topology.all), 0)
+        self.assertEqual(root.getNumOfType(iBase.Type.all),     0)
+        self.assertEqual(root.getNumOfTopo(iMesh.Topology.all), 0)
         self.assertEqual(mesh.adjTable.shape, (4,4))
     def testVertex(self):
-        mesh = iMesh()
         ent = mesh.createVtx([1,2,3])
         root = mesh.rootSet
-        self.assertEqual(root.getNumOfType(iBase.type.vertex),    1)
-        self.assertEqual(root.getNumOfTopo(iMesh.topology.point), 1)
+        self.assertEqual(root.getNumOfType(iBase.Type.vertex),    1)
+        self.assertEqual(root.getNumOfTopo(iMesh.Topology.point), 1)
         self.assert_( (mesh.getVtxCoords(ent) == [1,2,3]).all() )
-        self.assert_( (mesh.getVtxCoords([ent], iBase.storageOrder.interleaved)
+        self.assert_( (mesh.getVtxCoords([ent], iBase.StorageOrder.interleaved)
                        == [[1,2,3]]).all() )
-        self.assertEqual(mesh.getEntType(ent), iBase.type.vertex)
-        self.assertEqual(mesh.getEntTopo(ent), iMesh.topology.point)
+        self.assertEqual(mesh.getEntType(ent), iBase.Type.vertex)
+        self.assertEqual(mesh.getEntTopo(ent), iMesh.Topology.point)
         mesh.setVtxCoords(ent,[4,5,6])
         self.assert_( (mesh.getVtxCoords(ent) == [4,5,6]).all() )
     def testVertices(self):
-        mesh = iMesh()
         verts = [[1,2,3], [4,5,6], [7,8,9], [10,11,12]]
-        ents = mesh.createVtx(verts, iBase.storageOrder.interleaved)
+        ents = mesh.createVtx(verts, iBase.StorageOrder.interleaved)
         root = mesh.rootSet
-        self.assertEqual(root.getNumOfTopo(iMesh.topology.point), 4)
+        self.assertEqual(root.getNumOfTopo(iMesh.Topology.point), 4)
-        coords = mesh.getVtxCoords(ents, iBase.storageOrder.interleaved)
+        coords = mesh.getVtxCoords(ents, iBase.StorageOrder.interleaved)
         self.assert_( (coords == verts).all())
-        self.assertEqual(mesh.getEntType(ents[0]), iBase.type.vertex)
-        self.assert_( (mesh.getEntType(ents) == 4*[iBase.type.vertex]).all() )
+        self.assertEqual(mesh.getEntType(ents[0]), iBase.Type.vertex)
+        self.assert_( (mesh.getEntType(ents) == 4*[iBase.Type.vertex]).all() )
-        self.assertEqual(mesh.getEntTopo(ents[0]), iMesh.topology.point)
+        self.assertEqual(mesh.getEntTopo(ents[0]), iMesh.Topology.point)
         self.assert_( (mesh.getEntTopo(ents) ==
-                       4*[iMesh.topology.point]).all() )
+                       4*[iMesh.Topology.point]).all() )
         verts = [[12,11,10], [9,8,7], [6,5,4], [3,2,1]]
-        mesh.setVtxCoords(ents, verts, iBase.storageOrder.interleaved)
+        mesh.setVtxCoords(ents, verts, iBase.StorageOrder.interleaved)
     def testCreateEntArr(self):
-        mesh = iMesh()
         root = mesh.rootSet
-        topo = iMesh.topology
+        topo = iMesh.Topology
         lines = mesh.createEntArr(topo.line_segment,ents)[0]
-        self.assertEqual(root.getNumOfType(iBase.type.edge),    2)
+        self.assertEqual(root.getNumOfType(iBase.Type.edge),    2)
         self.assertEqual(root.getNumOfTopo(topo.line_segment),  2)
@@ -76,41 +76,41 @@
     def testSave(self):
         file = tempfile.NamedTemporaryFile()
-        mesh = iMesh()
         verts = [1,2,3]
         mesh.createVtx(verts)
         mesh.save(file.name)
-        mesh = iMesh()
         root = mesh.rootSet
         mesh.load(file.name)
-        ents = root.getEntities(iBase.type.all, iMesh.topology.all)
+        ents = root.getEntities(iBase.Type.all, iMesh.Topology.all)
         self.assert_( (coords == [1,2,3]).all() )
     def testAltSave(self):
-        mesh = iMesh()
         verts = [1,2,3]
         mesh.rootSet.save(file.name)
-        mesh = iMesh()
         root = mesh.rootSet
         root.load(file.name)
Modified: MOAB/trunk/tools/iMesh/python/test/entset.py
--- MOAB/trunk/tools/iMesh/python/test/entset.py	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/test/entset.py	2009-05-29 23:31:46 UTC (rev 2919)
@@ -3,7 +3,7 @@
 class TestEntSet(unittest.TestCase):
     def setUp(self):
         self.set = self.mesh.createEntSet(True)
     def tearDown(self):
@@ -33,7 +33,7 @@
     def testEntArr(self):
         ents = self.mesh.createVtx([[1,2,3], [4,5,6], [7,8,9]],
         self.assertFalse(self.set.contains(ents).any())
@@ -74,7 +74,7 @@
     def testSubtract(self):
         set2 = self.mesh.createEntSet(True)
         ents = self.mesh.createVtx([[1,2,3], [4,5,6]],
         self.set.add(ents)
         set2.add(ents[0])
@@ -89,7 +89,7 @@
     def testIntersect(self):
         self.set.add(ents[0:2])
         set2.add(ents[1:3])
@@ -106,7 +106,7 @@
     def testUnite(self):
         self.set.add(ents[0])
         set2.add(ents[1])
Modified: MOAB/trunk/tools/iMesh/python/test/iter.py
--- MOAB/trunk/tools/iMesh/python/test/iter.py	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/test/iter.py	2009-05-29 23:31:46 UTC (rev 2919)
@@ -3,7 +3,7 @@
 class TestIter(unittest.TestCase):
     def setUp(self):
         self.empty = self.mesh.createEntSet(True)
         self.ent = self.mesh.createVtx([1,2,3])
@@ -11,30 +11,30 @@
         self.set.add(self.ent)
     def testEmpty(self):
-        for i in self.empty.iterate(iBase.type.all, iMesh.topology.all):
+        for i in self.empty.iterate(iBase.Type.all, iMesh.Topology.all):
             self.fail('empty iterator has >0 elements')
     def testArrEmpty(self):
-        for i in self.empty.iterate(iBase.type.all, iMesh.topology.all, 16):
+        for i in self.empty.iterate(iBase.Type.all, iMesh.Topology.all, 16):
     def testSingle(self):
         count = 0
-        for i in self.set.iterate(iBase.type.all, iMesh.topology.all):
+        for i in self.set.iterate(iBase.Type.all, iMesh.Topology.all):
             count += 1
             self.assertEqual(i, self.ent)
         self.assertEqual(count, 1)
     def testArr(self):
         count = 0
-        for i in self.set.iterate(iBase.type.all, iMesh.topology.all, 16):
+        for i in self.set.iterate(iBase.Type.all, iMesh.Topology.all, 16):
             count += 1
             self.assertEqual(i[0], self.ent)
         self.assertEqual(count,1)
     def testAlternate(self):
         count = 0
-        iter = iMesh.iterator(self.set, iBase.type.all, iMesh.topology.all)
+        iter = iMesh.Iterator(self.set, iBase.Type.all, iMesh.Topology.all)
         for i in iter:
             count += 1
Modified: MOAB/trunk/tools/iMesh/python/test/tags.py
--- MOAB/trunk/tools/iMesh/python/test/tags.py	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/test/tags.py	2009-05-29 23:31:46 UTC (rev 2919)
@@ -4,7 +4,7 @@
 class TestTags(unittest.TestCase):
     def setUp(self):
         self.itag = self.mesh.createTag('int',    1, 'i')
         self.dtag = self.mesh.createTag('double', 1, 'd')
@@ -12,7 +12,7 @@
         self.btag = self.mesh.createTag('bytes',  3, 'b')
         self.ents = self.mesh.createVtx([[1,2,3], [4,5,6], [7,8,9]],
         self.ent = self.ents[0]
Modified: MOAB/trunk/tools/iMesh/python/tools/volume.py
--- MOAB/trunk/tools/iMesh/python/tools/volume.py	2009-05-28 23:14:04 UTC (rev 2918)
+++ MOAB/trunk/tools/iMesh/python/tools/volume.py	2009-05-29 23:31:46 UTC (rev 2919)
@@ -27,19 +27,19 @@
            subvolume(coords[1], coords[2], coords[5], coords[6], coords[7])
 def calc_volume(filename):
-    mesh = iMesh()
     mesh.load(filename)
-    volume = ndarray(mesh.rootSet.getNumOfType(iBase.type.region), float_)
+    volume = ndarray(mesh.rootSet.getNumOfType(iBase.Type.region), float_)
     x=0
-    for i in mesh.rootSet.iterate(iBase.type.region, iMesh.topology.all):
+    for i in mesh.rootSet.iterate(iBase.Type.region, iMesh.Topology.all):
         topo = mesh.getEntTopo(i)
-        curr = mesh.getVtxCoords( mesh.getEntAdj(i, iBase.type.vertex),
-                                  iBase.storageOrder.interleaved )
+        curr = mesh.getVtxCoords( mesh.getEntAdj(i, iBase.Type.vertex),
+                                  iBase.StorageOrder.interleaved )
-        if topo == iMesh.topology.tetrahedron:
+        if topo == iMesh.Topology.tetrahedron:
             volume[x] = tet_volume(curr)
-        elif topo == iMesh.topology.hexahedron:
+        elif topo == iMesh.Topology.hexahedron:
             volume[x] = hex_volume(curr)
         else:
             assert(False)
