[MOAB-dev] r2917 - in MOAB/trunk/tools/iMesh/python: . doc perf test tools
jvporter at wisc.edu
Thu May 28 15:45:59 CDT 2009
Author: jvporter
Date: 2009-05-28 15:45:59 -0500 (Thu, 28 May 2009)
New Revision: 2917
Modified:
MOAB/trunk/tools/iMesh/python/doc/imesh.rst
MOAB/trunk/tools/iMesh/python/iMesh.c
MOAB/trunk/tools/iMesh/python/iMesh_entSet.c
MOAB/trunk/tools/iMesh/python/perf/perf.py
MOAB/trunk/tools/iMesh/python/test/adj.py
MOAB/trunk/tools/iMesh/python/test/basic.py
MOAB/trunk/tools/iMesh/python/tools/volume.py
Log:
* Add more documentation
* Change API slightly to be more consistent
Modified: MOAB/trunk/tools/iMesh/python/doc/imesh.rst
--- MOAB/trunk/tools/iMesh/python/doc/imesh.rst 2009-05-27 23:28:23 UTC (rev 2916)
+++ MOAB/trunk/tools/iMesh/python/doc/imesh.rst 2009-05-28 20:45:59 UTC (rev 2917)
@@ -29,40 +29,22 @@
the relative cost of retrieving adjacencies between entities of dimension
i to entities of dimension j.
- .. method:: load(entSet, filename[, options])
+ .. method:: load(filename[, options])
- Load a mesh from a file.
+ Load a mesh from a file. Equivalent to ``rootSet.load(filename,
+ options)``.
- :param entSet: Set to which loaded mesh will be added, root set if not
- desired
:param filename: File name from which the mesh is to be loaded
:param options: Implementation-specific options string
- .. method:: save(entSet, filename[, options])
+ .. method:: save(filename[, options])
- Save the mesh to a file.
+ Save the mesh to a file. Equivalent to ``rootSet.load(filename,
+ options)``.
- :param entSet: Save a mesh to a file. If entity set is specified, save
- only the mesh contained in that set.
:param filename: File name to which the mesh is to be saved
- .. method:: getNumOfType(entSet, type)
- Get the number of entities with the specified type in ``entSet``.
- :param entSet: Entity set being queried
- :param type: Type of entity requested
- :return: The number of entities in ``entSet`` of the requested type
- .. method:: getNumOfTopo(entSet, topo)
- Get the number of entities with the specified topology in ``entSet``.
- :param type: Topology of entity requested
- :return: The number of entities in ``entSet`` of the requested topology
.. method:: areEHValid(doReset)
Return whether entity handles have changed since last reset or since
@@ -122,7 +104,7 @@
If ``entities`` is an array of entities, returns a tuple type, with the
first element being an array of offsets into the second element such that
- ``ret[1][ ret[0][i]:ret[0][i+1] ]`` is a list of entities adjacent to
+ ``ret[0][ ret[1][i]:ret[1][i+1] ]`` is a list of entities adjacent to
``entities[i]``.
:param entities: Entity or array of entities being queried
@@ -140,7 +122,7 @@
``entities[i]``.
@@ -154,33 +136,140 @@
.. method:: createEntSet(isList)
+ Create an entity set, either ordered (``isList == True``) or unordered
+ (``isList == False``). Unordered entity sets can contain a given entity
+ or set only once.
+ :param isList: True if the list should be ordered, false otherwise
+ :return: The newly-created entity set
.. method:: destroyEntSet(entSet)
+ Destroy an entity set.
+ :param entSet: Entity set to be destroyed
.. method:: setVtxCoords(entities, coords[, storageOrder])
+ Set the coordinates for the specified vertex or array of vertices. If
+ ``entities`` is an array of vertices, ``storageOrder`` must be specified;
+ otherwise it is ignored.
+ :param entities: Vertex handle or array of vertex handles being set
+ :param coords: New coordinates to assign to vertices
+ :param storageOrder: Storage order of coordinates to be assigned
.. method:: createVtx(coords[, storageOrder])
+ Create a vertex or array of vertices with the specified coordinates. If
+ creating multiple vertices, ``storageOrder`` must be specified; otherwise
+ it is ignored.
+ :param coords: Coordinates of new vertices to create
.. method:: createEnt(topo, entities)
+ Create a new entity with the specified lower-order topology.
+ :param topo: Topology of the entity to be created
+ :param entities: Array of lower order entity handles used to construct
+ new entity
+ :return: Tuple containing the created entity and its creation status
.. method:: createEntArr(topo, entitites)
+ Create an array of new entities with the specified lower-oder topology.
+ :param topo: Topology of the entities to be created
+ new entities
+ :return: Tuple containing the created entities and their creation statuses
.. method:: deleteEnt(entities)
+ Delete the specified entity or array of entities.
+ :param entities: An entity or array of entities to delete
.. method:: createTag(name, size, type)
+ Create a tag with specified ``name``, ``size``, and ``type``. The tag
+ size is the number of values of type ``type`` that can be held. ``type``
+ is one of the following:
+ | i | Integer |
+ | d | Double |
+ | E | Entity handle |
+ | b | Binary data |
+ :param name: Tag name
+ :param size: Size of tag in number of values
+ :param type: Character representing the tag's type
+ :return: The created tag
.. method:: destroyTag(tag, forced)
+ Destroy a tag. If ``forced`` is true and entities still have values set
+ for this tag, the tag is deleted anyway and those values disappear.
+ Otherwise the tag is not deleted if entities still have values set for it.
+ :param tag: Tag to delete
+ :param forced: True if the tag should be deleted even if there are values
+ set for it
.. method:: getTagHandle(name)
+ Get the handle of an existing tag with the specified ``name``.
+ :param name: The name of the tag to find
+ :return: The tag with the specified name
.. method:: setData(entities, tag, data[, type])
+ Set value(s) for a tag on an entity, entity set, or array of entities.
+ If ``type`` is not specified, this function will retrieve the tag type
+ automatically.
+ :param entities: Entity, entity set, or array of entities on which tag is
+ being set
+ :param tag: Tag being set
+ :param data: Data to set
+ :param type: Character representing the tag's type (as above)
.. method:: getData(entities, tag[, type])
+ Get value(s) for a tag on an entity, entity set, or array of entities.
+ automatically.
+ being retrieved
+ :param tag: Tag being retrieved
+ :return: The retrieved data
.. method:: getAllTags(entities)
+ Get all the tags associated with a specified entity or entity set.
+ :param entities: Entity or entity set being queried
+ :return: Array of tags associated with ``entities``
.. method:: rmvTag(entities, tag)
+ Remove a tag value from an entity, entity set, or array of entities.
+ :param entities: Entity, entity set, or array of entities from which tag
+ is being removed
+ :param tag: Tag to be removed
.. class:: itaps.iMesh.topology
An enumeration of mesh element topologies corresponding to
@@ -246,6 +335,37 @@
.. attribute:: isList
+ Returns whether the entity set is ordered.
+ .. method:: load(entSet, filename[, options])
+ Load a mesh from a file, adding it to the entity set.
+ :param filename: File name from which the mesh is to be loaded
+ :param options: Implementation-specific options string
+ Save the subset of the mesh contained in the entity set to a file.
+ :param filename: File name to which the mesh is to be saved
+ .. method:: getNumOfType(type)
+ Get the number of entities with the specified type in the entity set.
+ :param type: Type of entity requested
+ :return: The number of entities in entity set of the requested type
+ .. method:: getNumOfTopo(topo)
+ Get the number of entities with the specified topology in the entity set.
+ :param type: Topology of entity requested
+ :return: The number of entities in the entity set of the requested
+ topology
.. method:: getNumEntSets(numHops)
.. method:: getEntSets(numHops)
Modified: MOAB/trunk/tools/iMesh/python/iMesh.c
--- MOAB/trunk/tools/iMesh/python/iMesh.c 2009-05-27 23:28:23 UTC (rev 2916)
+++ MOAB/trunk/tools/iMesh/python/iMesh.c 2009-05-28 20:45:59 UTC (rev 2917)
@@ -58,36 +58,44 @@
static PyObject *
iMeshObj_load(iMeshObject *self,PyObject *args)
- iBaseEntitySet_Object *set;
const char *name = 0;
const char *options = "";
- if(!PyArg_ParseTuple(args,"O!s|s",&iBaseEntitySet_Type,&set,&name,&options))
+ iBase_EntitySetHandle root;
+ int err;
+ if(!PyArg_ParseTuple(args,"s|s",&name,&options))
return NULL;
- int err;
- iMesh_load(self->mesh,set->handle,name,options,&err,strlen(name),
- strlen(options));
+ iMesh_getRootSet(self->mesh,&root,&err);
if(checkError(self->mesh,err))
return NULL;
+ iMesh_load(self->mesh,root,name,options,&err,strlen(name),strlen(options));
+ if(checkError(self->mesh,err))
+ return NULL;
Py_RETURN_NONE;
static PyObject *
iMeshObj_save(iMeshObject *self,PyObject *args)
+ int err;
return NULL;
- int err;
- iMesh_save(self->mesh,set->handle,name,options,&err,strlen(name),
- strlen(options));
return NULL;
+ iMesh_save(self->mesh,root,name,options,&err,strlen(name),strlen(options));
+ return NULL;
Py_RETURN_NONE;
@@ -166,38 +174,6 @@
static PyObject *
-iMeshObj_getNumOfType(iMeshObject *self,PyObject *args)
- enum iBase_EntityType type;
- int num,err;
- if(!PyArg_ParseTuple(args,"O!i",&iBaseEntitySet_Type,&set,&type))
- return NULL;
- iMesh_getNumOfType(self->mesh,set->handle,type,&num,&err);
- if(checkError(self->mesh,err))
- return NULL;
- return Py_BuildValue("i",num);
-static PyObject *
-iMeshObj_getNumOfTopo(iMeshObject *self,PyObject *args)
- enum iMesh_EntityTopology topo;
- int num,err;
- if(!PyArg_ParseTuple(args,"O!i",&iBaseEntitySet_Type,&set,&topo))
- return NULL;
- iMesh_getNumOfTopo(self->mesh,set->handle,topo,&num,&err);
- return NULL;
-static PyObject *
iMeshObj_areEHValid(iMeshObject *self,PyObject *args)
int doReset,areInv,err;
@@ -761,7 +737,6 @@
int lower_size = PyArray_SIZE(ents);
iBase_EntityHandle *lower = PyArray_DATA(ents);
- PyObject *pair = PyTuple_New(2);
iBaseEntity_Object *entity = iBaseEntity_New();
iMesh_createEnt(self->mesh,topo,lower,lower_size,&entity->handle,&status,
@@ -769,11 +744,11 @@
Py_DECREF(ents);
- Py_DECREF(pair);
Py_DECREF((PyObject*)entity);
return NULL;
+ PyObject *pair = PyTuple_New(2);
PyTuple_SET_ITEM(pair,0,(PyObject*)entity);
PyTuple_SET_ITEM(pair,1,Py_BuildValue("i",status));
return pair;
@@ -1007,7 +982,7 @@
iBase_EntityHandle *data = PyArray_DATA(data_arr);
iMesh_setEHArrData(self->mesh,entities,ent_size,tag->handle,data,
data_size,&err);
else /* iBase_BYTES */
data_arr = PyArray_FROMANY(data_obj,NPY_BYTE,1,1,NPY_C_CONTIGUOUS);
@@ -1385,19 +1360,11 @@
static PyMethodDef iMesh_methods[] = {
{ "load", (PyCFunction)iMeshObj_load, METH_VARARGS,
- "Load a mesh"
+ "Load a mesh from a file"
{ "save", (PyCFunction)iMeshObj_save, METH_VARARGS,
- "Save the mesh"
+ "Save the mesh to a file"
- { "getNumOfType", (PyCFunction)iMeshObj_getNumOfType, METH_VARARGS,
- "Get the number of entities with the specified type in the instance or "
- "set"
- { "getNumOfTopo", (PyCFunction)iMeshObj_getNumOfTopo, METH_VARARGS,
- "Get the number of entities with the specified topology in the instance "
- "or set"
{ "areEHValid", (PyCFunction)iMeshObj_areEHValid, METH_VARARGS,
"Return whether entity handles have changed since last reset or since "
"instance construction"
Modified: MOAB/trunk/tools/iMesh/python/iMesh_entSet.c
--- MOAB/trunk/tools/iMesh/python/iMesh_entSet.c 2009-05-27 23:28:23 UTC (rev 2916)
+++ MOAB/trunk/tools/iMesh/python/iMesh_entSet.c 2009-05-28 20:45:59 UTC (rev 2917)
@@ -6,6 +6,70 @@
#include "iBase_Python.h"
static PyObject *
+iMeshEntSetObj_load(iMeshEntitySet_Object *self,PyObject *args)
+ const char *name = 0;
+ const char *options = "";
+ return NULL;
+ int err;
+ iMesh_load(self->mesh->mesh,self->set.handle,name,options,&err,strlen(name),
+ strlen(options));
+ if(checkError(self->mesh->mesh,err))
+ return NULL;
+ Py_RETURN_NONE;
+static PyObject *
+iMeshEntSetObj_save(iMeshEntitySet_Object *self,PyObject *args)
+ return NULL;
+ int err;
+ iMesh_save(self->mesh->mesh,self->set.handle,name,options,&err,strlen(name),
+ strlen(options));
+ return NULL;
+ Py_RETURN_NONE;
+static PyObject *
+iMeshEntSetObj_getNumOfType(iMeshEntitySet_Object *self,PyObject *args)
+ enum iBase_EntityType type;
+ int num,err;
+ if(!PyArg_ParseTuple(args,"i",&type))
+ return NULL;
+ iMesh_getNumOfType(self->mesh->mesh,self->set.handle,type,&num,&err);
+ return NULL;
+ return Py_BuildValue("i",num);
+static PyObject *
+iMeshEntSetObj_getNumOfTopo(iMeshEntitySet_Object *self,PyObject *args)
+ enum iMesh_EntityTopology topo;
+ int num,err;
+ if(!PyArg_ParseTuple(args,"i",&topo))
+ return NULL;
+ iMesh_getNumOfTopo(self->mesh->mesh,self->set.handle,topo,&num,&err);
+ return NULL;
+static PyObject *
iMeshEntSetObj_isList(iMeshEntitySet_Object *self,void *closure)
int is_list,err;
@@ -421,11 +485,23 @@
static PyMethodDef iMeshEntSetObj_methods[] = {
+ { "load", (PyCFunction)iMeshEntSetObj_load, METH_VARARGS,
+ { "save", (PyCFunction)iMeshEntSetObj_save, METH_VARARGS,
+ { "getNumOfType", (PyCFunction)iMeshEntSetObj_getNumOfType, METH_VARARGS,
+ "Get the number of entities with the specified type in the set"
+ { "getNumOfTopo", (PyCFunction)iMeshEntSetObj_getNumOfTopo, METH_VARARGS,
+ "Get the number of entities with the specified topology in the set"
{ "getNumEntSets", (PyCFunction)iMeshEntSetObj_getNumEntSets, METH_VARARGS,
- "Get the number of entity sets contained in the set or interface"
+ "Get the number of entity sets contained in the set"
{ "getEntSets", (PyCFunction)iMeshEntSetObj_getEntSets, METH_VARARGS,
- "Get the entity sets contained in the set or interface"
+ "Get the entity sets contained in the set"
{ "add", (PyCFunction)iMeshEntSetObj_add, METH_VARARGS,
"Add an entity (or array of entities or entity set) to the set"
Modified: MOAB/trunk/tools/iMesh/python/perf/perf.py
--- MOAB/trunk/tools/iMesh/python/perf/perf.py 2009-05-27 23:28:23 UTC (rev 2916)
+++ MOAB/trunk/tools/iMesh/python/perf/perf.py 2009-05-28 20:45:59 UTC (rev 2917)
@@ -64,11 +64,7 @@
timer.reset()
for x in range(count):
m = iMesh()
- try:
- m.load(m.rootSet, file)
- except:
- print file
- exit(0)
+ m.load(file)
m = None
py_stats[file].append( timer.delta()/count )
list_stats[file].append(0)
@@ -76,7 +72,7 @@
##### Intermission #####
mesh = iMesh()
root = mesh.rootSet
- mesh.load(root, file)
+ mesh.load(file)
##### 2 #####
timer.reset()
@@ -114,7 +110,8 @@
list_stats[file].append( timer.delta()/count )
mesh = None
- arr = None
+ root = None
+ arr = None
list = None
Modified: MOAB/trunk/tools/iMesh/python/test/adj.py
--- MOAB/trunk/tools/iMesh/python/test/adj.py 2009-05-27 23:28:23 UTC (rev 2916)
+++ MOAB/trunk/tools/iMesh/python/test/adj.py 2009-05-28 20:45:59 UTC (rev 2917)
@@ -36,25 +36,25 @@
quad = self.mesh.createEnt(topo.quadrilateral, self.lines)[0]
root = self.mesh.rootSet
- self.assertEqual(self.mesh.getNumOfType(root, iBase.type.vertex), 4)
- self.assertEqual(self.mesh.getNumOfType(root, iBase.type.edge), 4)
- self.assertEqual(self.mesh.getNumOfType(root, iBase.type.face), 1)
+ self.assertEqual(root.getNumOfType(iBase.type.vertex), 4)
+ self.assertEqual(root.getNumOfType(iBase.type.edge), 4)
+ self.assertEqual(root.getNumOfType(iBase.type.face), 1)
- self.assertEqual(self.mesh.getNumOfTopo(root, topo.point), 4)
- self.assertEqual(self.mesh.getNumOfTopo(root, topo.line_segment), 4)
- self.assertEqual(self.mesh.getNumOfTopo(root, topo.quadrilateral), 1)
+ self.assertEqual(root.getNumOfTopo(topo.point), 4)
+ self.assertEqual(root.getNumOfTopo(topo.line_segment), 4)
+ self.assertEqual(root.getNumOfTopo(topo.quadrilateral), 1)
self.mesh.deleteEnt(quad)
- self.assertEqual(self.mesh.getNumOfType(root, iBase.type.face), 0)
- self.assertEqual(self.mesh.getNumOfTopo(root, topo.quadrilateral), 0)
+ self.assertEqual(root.getNumOfType(iBase.type.face), 0)
+ self.assertEqual(root.getNumOfTopo(topo.quadrilateral), 0)
self.mesh.deleteEnt(self.lines)
- self.assertEqual(self.mesh.getNumOfType(root, iBase.type.edge), 0)
- self.assertEqual(self.mesh.getNumOfTopo(root, topo.line_segment), 0)
+ self.assertEqual(root.getNumOfType(iBase.type.edge), 0)
+ self.assertEqual(root.getNumOfTopo(topo.line_segment), 0)
self.mesh.deleteEnt(self.ents)
- self.assertEqual(self.mesh.getNumOfType(root, iBase.type.vertex), 0)
- self.assertEqual(self.mesh.getNumOfTopo(root, topo.point), 0)
+ self.assertEqual(root.getNumOfType(iBase.type.vertex), 0)
+ self.assertEqual(root.getNumOfTopo(topo.point), 0)
def testAdj(self):
adj = self.mesh.getEntAdj(self.ents[1], iBase.type.all)
Modified: MOAB/trunk/tools/iMesh/python/test/basic.py
--- MOAB/trunk/tools/iMesh/python/test/basic.py 2009-05-27 23:28:23 UTC (rev 2916)
+++ MOAB/trunk/tools/iMesh/python/test/basic.py 2009-05-28 20:45:59 UTC (rev 2917)
@@ -12,8 +12,8 @@
mesh.dfltStorage
self.assert_(mesh.areEHValid(True))
- self.assertEqual(mesh.getNumOfType(root, iBase.type.all), 0)
- self.assertEqual(mesh.getNumOfTopo(root, iMesh.topology.all), 0)
+ self.assertEqual(root.getNumOfType(iBase.type.all), 0)
+ self.assertEqual(root.getNumOfTopo(iMesh.topology.all), 0)
self.assertEqual(mesh.adjTable.shape, (4,4))
def testVertex(self):
@@ -21,8 +21,8 @@
ent = mesh.createVtx([1,2,3])
root = mesh.rootSet
- self.assertEqual(mesh.getNumOfType(root, iBase.type.vertex), 1)
- self.assertEqual(mesh.getNumOfTopo(root, iMesh.topology.point), 1)
+ self.assertEqual(root.getNumOfType(iBase.type.vertex), 1)
+ self.assertEqual(root.getNumOfTopo(iMesh.topology.point), 1)
self.assert_( (mesh.getVtxCoords(ent) == [1,2,3]).all() )
self.assert_( (mesh.getVtxCoords([ent], iBase.storageOrder.interleaved)
@@ -40,8 +40,8 @@
ents = mesh.createVtx(verts, iBase.storageOrder.interleaved)
root = mesh.rootSet
- self.assertEqual(mesh.getNumOfType(root, iBase.type.vertex), 4)
- self.assertEqual(mesh.getNumOfTopo(root, iMesh.topology.point), 4)
+ self.assertEqual(root.getNumOfTopo(iMesh.topology.point), 4)
coords = mesh.getVtxCoords(ents, iBase.storageOrder.interleaved)
self.assert_( (coords == verts).all())
@@ -67,11 +67,11 @@
topo = iMesh.topology
lines = mesh.createEntArr(topo.line_segment,ents)[0]
- self.assertEqual(mesh.getNumOfType(root, iBase.type.edge), 2)
+ self.assertEqual(root.getNumOfType(iBase.type.edge), 2)
- self.assertEqual(mesh.getNumOfTopo(root, topo.point), 4)
- self.assertEqual(mesh.getNumOfTopo(root, topo.line_segment), 2)
+ self.assertEqual(root.getNumOfTopo(topo.line_segment), 2)
def testSave(self):
file = tempfile.NamedTemporaryFile()
@@ -80,17 +80,17 @@
verts = [1,2,3]
mesh.createVtx(verts)
- mesh.save(mesh.rootSet,file.name)
+ mesh.save(file.name)
mesh = iMesh()
root = mesh.rootSet
- mesh.load(root,file.name)
- ents = mesh.getEntities(root,iBase.type.all,iMesh.topology.all)
+ mesh.load(file.name)
+ ents = mesh.getEntities(root, iBase.type.all, iMesh.topology.all)
- coords = mesh.getVtxCoords(ents,iBase.storageOrder.interleaved)
+ coords = mesh.getVtxCoords(ents, iBase.storageOrder.interleaved)
self.assert_( (coords == [1,2,3]).all() )
Modified: MOAB/trunk/tools/iMesh/python/tools/volume.py
--- MOAB/trunk/tools/iMesh/python/tools/volume.py 2009-05-27 23:28:23 UTC (rev 2916)
+++ MOAB/trunk/tools/iMesh/python/tools/volume.py 2009-05-28 20:45:59 UTC (rev 2917)
@@ -28,9 +28,9 @@
def calc_volume(filename):
mesh = iMesh()
- mesh.load(mesh.rootSet, filename)
+ mesh.load(filename)
- volume = ndarray(mesh.getNumOfType(mesh.rootSet, iBase.type.region), float_)
+ volume = ndarray(mesh.rootSet.getNumOfType(iBase.type.region), float_)
x=0
for i in mesh.rootSet.iterate(iBase.type.region, iMesh.topology.all):
topo = mesh.getEntTopo(i)
