[MOAB-dev] r2916 - MOAB/trunk/tools/iMesh/python/doc
jvporter at wisc.edu jvporter at wisc.edu
Wed May 27 18:28:23 CDT 2009
Author: jvporter
Date: 2009-05-27 18:28:23 -0500 (Wed, 27 May 2009)
New Revision: 2916
Modified:
   MOAB/trunk/tools/iMesh/python/doc/imesh.rst
Log:
Partway through documenting the Python iMesh interface methods
Modified: MOAB/trunk/tools/iMesh/python/doc/imesh.rst
--- MOAB/trunk/tools/iMesh/python/doc/imesh.rst	2009-05-27 21:47:11 UTC (rev 2915)
+++ MOAB/trunk/tools/iMesh/python/doc/imesh.rst	2009-05-27 23:28:23 UTC (rev 2916)
@@ -8,38 +8,148 @@
    .. attribute:: rootSet
+      Get the handle of the root set for this instance. The entire mesh in this
+      instance can be accessed from this set.
    .. attribute:: geometricDimension
+      Get/set the geometric dimension of mesh represented in this instance.
+      When setting the dimension, an application should not expect this
+      function to succeed unless the mesh database is empty (no vertices
+      created, no files read, etc.)
    .. attribute:: dfltStorage
+      Get the default storage order used by this implementation.
    .. attribute:: adjTable
-   .. method:: load(set, filename[, options])
+      Get the adjacency table for this implementation.  This table is a 4x4
+      array, with indices 0-based, where A(i,j) (i=row, j=column) represents
+      the relative cost of retrieving adjacencies between entities of dimension
+      i to entities of dimension j.
-      Load a mesh
+   .. method:: load(entSet, filename[, options])
-   .. method:: save(set, filename[, options])
+      Load a mesh from a file.
-      Save the mesh
+      :param entSet: Set to which loaded mesh will be added, root set if not
+                      desired
+      :param filename: File name from which the mesh is to be loaded
+      :param options: Implementation-specific options string
-   .. method:: getNumOfType(type)
+   .. method:: save(entSet, filename[, options])
-   .. method:: getNumOfTopo(topo)
+      Save the mesh to a file.
+      :param entSet: Save a mesh to a file. If entity set is specified, save
+                     only the mesh contained in that set.
+      :param filename: File name to which the mesh is to be saved
+   .. method:: getNumOfType(entSet, type)
+      Get the number of entities with the specified type in ``entSet``.
+      :param entSet: Entity set being queried
+      :param type: Type of entity requested
+      :return: The number of entities in ``entSet`` of the requested type
+   .. method:: getNumOfTopo(entSet, topo)
+      Get the number of entities with the specified topology in ``entSet``.
+      :param type: Topology of entity requested
+      :return: The number of entities in ``entSet`` of the requested topology
    .. method:: areEHValid(doReset)
-   .. method:: getEntities(set, type, topo)
+      Return whether entity handles have changed since last reset or since
+      instance construction. If true, it is not guaranteed that a handle from
+      before the last call to this function represents the same entity as the
+      same handle value does now. If ``doReset`` is true, resets the starting
+      point for this function.
+      :param doReset: If true, perform a reset on the starting point after
+                      which handles are invariant.
+      :return: True iff entity handles have changed
+   .. method:: getEntities(entSet, type, topo)
+      Get entities of a specific type and/or topology in ``entSet``. All
+      entities of a given type or topology are requested by specifying
+      ``iBase.type.all`` or ``iMesh.topology.all``, respectively.
+      :param type: Type of entities being requested
+      :param topo: Topology of entities being requested
+      :return: Array of entity handles from ``entSet`` meeting the requirements
+               of ``type`` and ``topo``.
    .. method:: getVtxCoords(entities[, storageOrder])
+      Get coordinates of specified vertices. If ``entitites`` is an array of
+      entity handles, ``storageOrder`` is required. Otherwise, it is unused.
+      :param entities: Entity or array of entities being queried
+      :param storageOrder: Storage order of vertices to be returned
+      :return: Array of vertices in the specified storage order. One-dimensional
+               array if ``entities`` is a single element, two-dimesional
+               otherwise
    .. method:: getEntType(entities)
+      Get the entity type for the specified entities.
+      :return: If ``entities`` is a single element, the type of the entity.
+               Otherwise, an array of the entity types.
    .. method:: getEntTopo(entities)
+      Get the entity topology for the specified entities.
+      :return: If ``entities`` is a single element, the topology of the entity.
+               Otherwise, an array of the entity topologies.
    .. method:: getEntAdj(entities, typeReq)
+      Get entities of the specified type adjacent to elements of ``entities``.
+      If ``entities`` is a single entity handle, returns an array of adjacent
+      entities.
+      If ``entities`` is an array of entities, returns a tuple type, with the
+      first element being an array of offsets into the second element such that
+      ``ret[1][ ret[0][i]:ret[0][i+1] ]`` is a list of entities adjacent to
+      ``entities[i]``.
+      :param typeReq: Type of adjacent entities being requested
+      :return: If ``entities`` is a single element, an array of adjacent
+               entities. Otherwise, a tuple containing an array of offsets and
+               an array of adjacent entities.
    .. method:: getEnt2ndAdj(entities, bridgeType, typeReq)
+      Get "2nd order" adjacencies to an array of entities, that is, from each
+      entity, through other entities of a specified "bridge" dimension, to
+      other entities of another specified "to" dimension. If ``entities`` is a
+      single entity handle, returns an array of adjacent entities.
+      ``entities[i]``.
+      :param brideType: Type of bridge entity for 2nd order adjacencies
    .. method:: getAdjEntIndices(entSet, typeRequestor, topoRequestor, typeRequested)
    .. method:: createEntSet(isList)
