[MOAB-dev] r2890 - MOAB/trunk
    kraftche at cae.wisc.edu
    Sat May 16 15:10:02 CDT 2009
Author: kraftche
Date: 2009-05-16 15:10:02 -0500 (Sat, 16 May 2009)
New Revision: 2890
Modified:
   MOAB/trunk/bsp_tree_test.cpp
Log:
typo in comment
Modified: MOAB/trunk/bsp_tree_test.cpp
--- MOAB/trunk/bsp_tree_test.cpp	2009-05-16 20:09:01 UTC (rev 2889)
+++ MOAB/trunk/bsp_tree_test.cpp	2009-05-16 20:10:02 UTC (rev 2890)
@@ -1285,7 +1285,7 @@
   //        not return leaves that are not face-adjacent (e.g. adjacent
   //        only along edges or at corners.)  The determining factor
   //        for whether or not such a neighbor is returned is which
-  //        sub-tree from the split that defined the source leaf side
+  //        sub-tree of the split that defined the source leaf side
   //        the neighbor is on.  The algorithm will not search the subtree
   //        of the split that created the side and that contains the
   //        source leaf.
