[MOAB-dev] r2889 - MOAB/trunk
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Sat May 16 15:09:02 CDT 2009
Author: kraftche
Date: 2009-05-16 15:09:01 -0500 (Sat, 16 May 2009)
New Revision: 2889
Modified:
   MOAB/trunk/MBBSPTree.cpp
   MOAB/trunk/MBBSPTree.hpp
   MOAB/trunk/bsp_tree_test.cpp
Log:
add neighbor query for BSP trees for which every leaf is a box
Modified: MOAB/trunk/MBBSPTree.cpp
--- MOAB/trunk/MBBSPTree.cpp	2009-05-16 20:08:25 UTC (rev 2888)
+++ MOAB/trunk/MBBSPTree.cpp	2009-05-16 20:09:01 UTC (rev 2889)
@@ -541,6 +541,62 @@
   return (MBBSPTreeBoxIter::SideBits)result;
+static inline void copy_coords( const double src[3], double dest[3] )
+  dest[0] = src[0];
+  dest[1] = src[1];
+  dest[2] = src[2];
+MBErrorCode MBBSPTreeBoxIter::face_corners( const SideBits face,
+                                            const double hex_corners[8][3],
+                                            double face_corners[4][3] )
+  switch (face) {
+    case MBBSPTreeBoxIter::B0154:
+      copy_coords( hex_corners[0], face_corners[0] );
+      copy_coords( hex_corners[1], face_corners[1] );
+      copy_coords( hex_corners[5], face_corners[2] );
+      copy_coords( hex_corners[4], face_corners[3] );
+      break;
+    case MBBSPTreeBoxIter::B1265:
+      copy_coords( hex_corners[1], face_corners[0] );
+      copy_coords( hex_corners[2], face_corners[1] );
+      copy_coords( hex_corners[6], face_corners[2] );
+      copy_coords( hex_corners[5], face_corners[3] );
+      break;
+    case MBBSPTreeBoxIter::B2376:
+      copy_coords( hex_corners[2], face_corners[0] );
+      copy_coords( hex_corners[3], face_corners[1] );
+      copy_coords( hex_corners[7], face_corners[2] );
+      copy_coords( hex_corners[6], face_corners[3] );
+      break;
+    case MBBSPTreeBoxIter::B3047:
+      copy_coords( hex_corners[3], face_corners[0] );
+      copy_coords( hex_corners[0], face_corners[1] );
+      copy_coords( hex_corners[4], face_corners[2] );
+      copy_coords( hex_corners[7], face_corners[3] );
+      break;
+    case MBBSPTreeBoxIter::B3210:
+      copy_coords( hex_corners[1], face_corners[2] );
+      copy_coords( hex_corners[0], face_corners[3] );
+      break;
+    case MBBSPTreeBoxIter::B4567:
+      copy_coords( hex_corners[4], face_corners[0] );
+      copy_coords( hex_corners[5], face_corners[1] );
+      break;
+    default:
+      return MB_FAILURE; // child is not a box
+  return MB_SUCCESS;
 /** \brief Clip an edge using a plane
  * Given an edge from keep_end_coords to cut_end_coords,
@@ -846,6 +902,113 @@
   return MB_SUCCESS;
+MBErrorCode MBBSPTreeBoxIter::get_neighbors(
+                      SideBits side,
+                      std::vector<MBBSPTreeBoxIter>& results,
+                      double epsilon ) const
+  MBEntityHandle handle;
+  MBBSPTree::Plane plane;
+  MBErrorCode rval;
+  int n;
+  Corners face;
+  rval = face_corners( side, leafCoords, face.coords );
+  if (MB_SUCCESS != rval)
+    return rval;
+    // Move up tree until we find the split that created the specified side.
+    // Push the sibling at that level onto the iterator stack as
+    // all neighbors will be rooted at that node.
+  MBBSPTreeBoxIter iter( *this ); // temporary iterator (don't modifiy *this)
+  for (;;) {
+    handle = iter.handle();
+    rval = iter.up();
+    if (MB_SUCCESS != rval) // reached root - no neighbors on that side
+      return (rval == MB_ENTITY_NOT_FOUND) ? MB_SUCCESS : rval;
+    iter.childVect.clear();
+    rval = tool()->moab()->get_child_meshsets( iter.handle(), iter.childVect );
+    if (MB_SUCCESS!= rval)
+      return rval;
+    rval = tool()->get_split_plane( iter.handle(), plane );
+      return rval;
+    SideBits s = side_above_plane( iter.leafCoords, plane );
+    if (handle == iter.childVect[0] && s == side) {
+      rval = iter.down( plane, RIGHT );
+        return rval;
+      break;
+    else if (handle == iter.childVect[1] && opposite_face(s) == side) {
+      rval = iter.down( plane, LEFT );
+        return rval;
+      break;
+    // now move down tree, searching for adjacent boxes
+  std::vector<MBBSPTreeBoxIter> list;
+    // loop over all potential paths to neighbors (until list is empty)
+  for (;;) {
+      // follow a single path to a leaf, append any other potential
+      // paths to neighbors to 'list'
+    for (;;) {
+      rval = tool()->moab()->num_child_meshsets( iter.handle(), &n );
+        return rval;
+        // if leaf
+      if (!n) {
+        results.push_back( iter );
+        break;
+        return rval;
+      bool some_above = false, some_below = false;
+      for (int i = 0; i < 4; ++i) {
+        double signed_d = plane.signed_distance( face.coords[i] );
+        if (signed_d > -epsilon)
+          some_above = true;
+        if (signed_d < epsilon)
+          some_below = true;
+      if (some_above && some_below) {
+        list.push_back( iter );
+        list.back().down( plane, RIGHT );
+        iter.down( plane, LEFT );
+      else if (some_above) {
+        iter.down( plane, RIGHT );
+      else if (some_below) {
+      else {
+        // tolerance issue -- epsilon to small? 2D box?
+    if (list.empty())
+      break;
+    iter = list.back();
+    list.pop_back();
 MBErrorCode MBBSPTree::leaf_containing_point( MBEntityHandle tree_root,
                                               const double point[3],
                                               MBEntityHandle& leaf_out )
Modified: MOAB/trunk/MBBSPTree.hpp
--- MOAB/trunk/MBBSPTree.hpp	2009-05-16 20:08:25 UTC (rev 2888)
+++ MOAB/trunk/MBBSPTree.hpp	2009-05-16 20:09:01 UTC (rev 2889)
@@ -304,6 +304,10 @@
   static SideBits opposite_face( const SideBits& bits )
     { return (SideBits)((~bits) & 0xFF); }
+  static MBErrorCode face_corners( const SideBits face,
+                                   double face_corners_out[4][3] );
   //! Advance the iterator either left or right in the tree
   //! Note:  stepping past the end of the tree will invalidate
   //!        the iterator.  It will *not* work to subsequently
@@ -335,6 +339,22 @@
     //!        MB_SUCCESS otherwise.
   MBErrorCode sibling_side( SideBits& side_out ) const;
+    //! Get adjacent leaf nodes on indicated side
+    //!\param side   Face of box for which to retrieve neighbors
+    //!\param results List to which to append results.  This function does
+    //!             *not* clear existing values in list.
+    //!\param epsilon Tolerance on overlap.  A positive value E will
+    //!              result in nodes that are separated by as much as E
+    //!              to be considered touching.  A negative value -E will
+    //!              cause leaves that do not overlap by at least E to be
+    //!              considered non-overlapping.  Amongst other things,
+    //!              this value can be used to control whether or not
+    //!              leaves adjacent at only their edges or corners are
+    //!              returned.
+  MBErrorCode get_neighbors( SideBits side,
+                             double epsilon = 0.0 ) const;
 #endif
Modified: MOAB/trunk/bsp_tree_test.cpp
--- MOAB/trunk/bsp_tree_test.cpp	2009-05-16 20:08:25 UTC (rev 2888)
+++ MOAB/trunk/bsp_tree_test.cpp	2009-05-16 20:09:01 UTC (rev 2889)
@@ -1,6 +1,7 @@
 #include "MBCore.hpp"
 #include "TestUtil.hpp"
 #include "MBBSPTree.hpp"
+#include <algorithm>
 void test_set_plane();
 void test_iterator();
@@ -10,6 +11,7 @@
 void test_leaf_containing_point_bounded_tree();
 void test_leaf_containing_point_unbounded_tree();
 void test_merge_leaf();
+void test_box_iter_neighbors();
 int main()
@@ -23,6 +25,7 @@
   failures += RUN_TEST( test_leaf_containing_point_bounded_tree );
   failures += RUN_TEST( test_leaf_containing_point_unbounded_tree );
   failures += RUN_TEST( test_merge_leaf );
+  failures += RUN_TEST( test_box_iter_neighbors );
   return failures;
@@ -1113,3 +1116,347 @@
   CHECK_EQUAL( MB_ENTITY_NOT_FOUND, rval );
+static std::vector<int>
+neighbors( const MBBSPTreeBoxIter& iter,
+           const MBEntityHandle leaves[8],
+           MBBSPTreeBoxIter::SideBits side,
+           double epsilon )
+  MBErrorCode rval = iter.get_neighbors( side, list, epsilon );
+  CHECK_ERR(rval);
+  std::vector<int> results;
+  for (size_t i = 0; i < list.size(); ++i)
+    results.push_back( std::find( leaves, leaves+8, list[i].handle() ) - leaves );
+  std::sort( results.begin(), results.end() );
+  return results;
+  MBCore moab;
+  MBBSPTree tool( &moab );
+  MBErrorCode rval;
+  MBEntityHandle root;
+  MBBSPTreeBoxIter iter;
+  MBBSPTree::Plane p;
+/*  Build Tree */
+  const double corners[8][3] = { { 0, 0, 0 },
+                                 { 8, 0, 0 },
+                                 { 8, 2, 0 },
+                                 { 0, 2, 0 },
+                                 { 0, 0, 1 },
+                                 { 8, 0, 1 },
+                                 { 8, 2, 1 },
+                                 { 0, 2, 1 } };
+  rval = tool.create_tree( corners, root );
+  CHECK_ERR(rval);
+  rval = tool.get_tree_iterator( root, iter );
+  CHECK_ERR(rval);
+  MBEntityHandle leaves[8];
+     |                   0*                   |
+  p = MBBSPTree::Plane( 1, 0, 0, -4 );
+  rval = tool.split_leaf( iter, p );
+  CHECK_ERR(rval);
+     |         0*        |         1          |
+  p = MBBSPTree::Plane( -1, 0, 0, 2 );
+  CHECK_ERR(rval);
+     |    1    |    0*   |         2          |
+  p = MBBSPTree::Plane( 0, 1, 0, -1 );
+  CHECK_ERR(rval);
+     |         |    1    |                    |
+     |    2    +---------+         3          |
+     |         |    0*   |                    |
+  leaves[0] = iter.handle();
+  rval = iter.step(); CHECK_ERR(rval);
+  leaves[1] = iter.handle();
+     |         |    1    |                    |
+     |    2*   +---------+         3          |
+     |         |    0    |                    |
+  p = MBBSPTree::Plane( 0, -1, 0, 1 );
+  CHECK_ERR(rval);
+     |    2*   |    1    |                    |
+     +---------+---------+         4          |
+     |    3    |    0    |                    |
+  leaves[2] = iter.handle();
+  leaves[3] = iter.handle();
+     |    2    |    1    |                    |
+     +---------+---------+         4*         |
+     |    3    |    0    |                    |
+  CHECK_ERR(rval);
+     |    2    |    1    |         5          |
+     |    3    |    0    |         4*         |
+  p = MBBSPTree::Plane( 1, 0, 0, -6 );
+  CHECK_ERR(rval);
+     |    2    |    1    |          6         |
+     |    3    |    0    |    4*    |    5    |
+  leaves[4] = iter.handle();
+  leaves[5] = iter.handle();
+     |    2    |    1    |          6*        |
+     |    3    |    0    |     4    |    5    |
+  p = MBBSPTree::Plane( -1, 0, 0, 6 );
+  CHECK_ERR(rval);
+     |    2    |    1    |     7    |    6    |
+     |    3    |    0    |     4    |    5    |
+  leaves[6] = iter.handle();
+  leaves[7] = iter.handle();
+    /* check all neighbors of each leaf */
+  CHECK_ERR(rval);
+  // NOTE:  Several values in the expected result list are
+  //        commented out in the tests below.  When the tolerance
+  //        is greater than zero, the search algorithm may or may
+  //        not return leaves that are not face-adjacent (e.g. adjacent
+  //        only along edges or at corners.)  The determining factor
+  //        for whether or not such a neighbor is returned is which
+  //        sub-tree from the split that defined the source leaf side
+  //        the neighbor is on.  The algorithm will not search the subtree
+  //        of the split that created the side and that contains the
+  //        source leaf.
+    // check neighbors of leaf 0
+  std::vector<int> expected;
+  CHECK_EQUAL( leaves[0], iter.handle() );
+  expected.clear();
+  CHECK_EQUAL( expected, neighbors( iter, leaves, MBBSPTreeBoxIter::B0154, 1e-6 ) );
+  CHECK_EQUAL( expected, neighbors( iter, leaves, MBBSPTreeBoxIter::B3210, 1e-6 ) );
+  CHECK_EQUAL( expected, neighbors( iter, leaves, MBBSPTreeBoxIter::B4567, 1e-6 ) );
+  expected.push_back( 3 );
+  CHECK_EQUAL( expected, neighbors( iter, leaves, MBBSPTreeBoxIter::B3047, -1e-6 ) );
+  expected.insert( expected.begin(), 2 );
+  CHECK_EQUAL( expected, neighbors( iter, leaves, MBBSPTreeBoxIter::B3047,  1e-6 ) );
+  expected.clear(); expected.push_back( 1 );
+  CHECK_EQUAL( expected, neighbors( iter, leaves, MBBSPTreeBoxIter::B2376, -1e-6 ) );
+  // See NOTE //  expected.push_back( 2 ); expected.push_back( 7 );
+  CHECK_EQUAL( expected, neighbors( iter, leaves, MBBSPTreeBoxIter::B2376,  1e-6 ) );
+  expected.clear(); expected.push_back( 4 );
+  CHECK_EQUAL( expected, neighbors( iter, leaves, MBBSPTreeBoxIter::B1265, -1e-6 ) );
+  expected.push_back( 7 );
+  CHECK_EQUAL( expected, neighbors( iter, leaves, MBBSPTreeBoxIter::B1265,  1e-6 ) );
+    // check neighbors of leaf 1
+  CHECK_ERR( iter.step() );
+  CHECK_EQUAL( leaves[1], iter.handle() );
+  expected.clear();
+  expected.push_back( 2 );
+  expected.clear(); expected.push_back( 0 );
+  CHECK_EQUAL( expected, neighbors( iter, leaves, MBBSPTreeBoxIter::B0154, -1e-6 ) );
+  // See NOTE //  expected.push_back( 3 ); expected.push_back( 4 );
+  expected.clear(); expected.push_back( 7 );
+  expected.insert( expected.begin(), 4 );
+     |    2    |    1    |     7    |    6    |
+     |    3    |    0    |     4    |    5    |
+    // check neighbors of leaf 2
+  CHECK_EQUAL( leaves[2], iter.handle() );
+  expected.clear();
+  // See NOTE // expected.insert( expected.begin(), 0 );
+  expected.insert( expected.begin(), 0 );
+    // check neighbors of leaf 3
+  CHECK_EQUAL( leaves[3], iter.handle() );
+  expected.clear();
+  // See NOTE // expected.insert( expected.begin(), 1 );
+  expected.push_back( 1 );
+     |    2    |    1    |     7    |    6    |
+     |    3    |    0    |     4    |    5    |
+    // check neighbors of leaf 4
+  CHECK_EQUAL( leaves[4], iter.handle() );
+  expected.clear();
+  expected.push_back( 0 );
+  expected.insert( expected.begin(), 6 );
+  expected.clear(); expected.push_back( 5 );
+  // See NOTE // expected.push_back( 6 );
+    // check neighbors of leaf 5
+  CHECK_EQUAL( leaves[5], iter.handle() );
+  expected.clear();
+  expected.push_back( 4 );
+  // See NOTE // expected.push_back( 7 );
+  expected.clear(); expected.push_back( 6 );
+     |    2    |    1    |     7    |    6    |
+     |    3    |    0    |     4    |    5    |
+    // check neighbors of leaf 6
+  CHECK_EQUAL( leaves[6], iter.handle() );
+  expected.clear();
+  // See NOTE // expected.insert( expected.begin(), 4 );
+    // check neighbors of leaf 7
+  CHECK_EQUAL( leaves[7], iter.handle() );
+  expected.clear();
+  expected.push_back( 5 );
+  // See NOTE // expected.insert( expected.begin(), 5 );
