[MOAB-dev] getNumEntSets not working to spec,	at least as I	read it
    Mark Miller
    miller86 at llnl.gov
    Thu May 14 12:05:15 CDT 2009
Ah, ok, well that explains it. Thanks.
> > Mark Miller wrote:
> >> Hi Jason,
> >> when I call getNumEntSets with 'num_hops' set to say '1' and then call
> >> it again with num_hops set to say '2', then I'd expect the result from
> >> the second call to be at least as large as from the first call. Right?
> >> In other words, the way I read the spec. is that it returns the number
> >> of entity sets contained IN the specified set that are up to an
> >> including num_hops 'sets away' from the contained set. I am not seeing
> >> this with current version of MOAB. Haven't tested other impls.
> > Forwarding this to MOAB-dev.
>   void iMesh_getNumEntSets(iMesh_Instance instance,
>                      /*in*/ const iBase_EntitySetHandle entity_set_handle,
>                      /*in*/ const int num_hops,
>                             int *num_sets, int *err)
>     if (num_hops > 1) {
>       iMesh_processError(iBase_NOT_SUPPORTED,
>         "iMesh_getNumEntSets: not currently implemented for num_hops > 1.");
>       *num_sets = 0;
>       RETURN(iBase_NOT_SUPPORTED);
Mark C. Miller, Lawrence Livermore National Laboratory
email: mailto:miller86 at llnl.gov
(M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
(Th/F)  (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
