[MOAB-dev] r2831 - in MOAB/trunk: . parallel tools/dagmc	tools/iMesh tools/mbcoupler
    kraftche at cae.wisc.edu
    Thu Apr 16 17:07:22 CDT 2009
Author: kraftche
Date: 2009-04-16 17:07:21 -0500 (Thu, 16 Apr 2009)
New Revision: 2831
Added:
   MOAB/trunk/MBUnknownInterface.hpp
Removed:
Modified:
   MOAB/trunk/MBCN_protos.h
   MOAB/trunk/MBEntityType.h
   MOAB/trunk/MBInterface.hpp
   MOAB/trunk/Makefile.am
   MOAB/trunk/ReadWriteDefines.h
   MOAB/trunk/exodus_order.h
   MOAB/trunk/parallel/gs.h
   MOAB/trunk/patran_order.h
   MOAB/trunk/tools/dagmc/cubfile.h
   MOAB/trunk/tools/iMesh/iMesh.h
   MOAB/trunk/tools/mbcoupler/extrafindpt.h
   MOAB/trunk/tools/mbcoupler/poly.h
Log:
Apparently the GCC warning about C++-style comments in C code will
never be fixed, so remove a C++-style comments from C headers.
Modified: MOAB/trunk/MBCN_protos.h
--- MOAB/trunk/MBCN_protos.h	2009-04-16 18:14:34 UTC (rev 2830)
+++ MOAB/trunk/MBCN_protos.h	2009-04-16 22:07:21 UTC (rev 2831)
@@ -1,7 +1,7 @@
 #include "MBCN_FCDefs.h"
 #ifdef FC_FUNC_
-  //! get the basis of the numbering system
+  /* get the basis of the numbering system */
 #define MBCN_GetBasis FC_FUNC_(mbcn_getbasis, MBCN_GETBASIS)
 #define MBCN_SetBasis FC_FUNC_(mbcn_setbasis, MBCN_SETBASIS)
 #define MBCN_EntityTypeName FC_FUNC_(mbcn_entitytypename, MBCN_ENTITYTYPENAME)
Modified: MOAB/trunk/MBEntityType.h
--- MOAB/trunk/MBEntityType.h	2009-04-16 18:14:34 UTC (rev 2830)
+++ MOAB/trunk/MBEntityType.h	2009-04-16 22:07:21 UTC (rev 2831)
@@ -44,16 +44,16 @@
 #ifdef __cplusplus
-} // extern "C"
+} /* extern "C" */
-//! prefix increment operator for MBEntityType
+/** prefix increment operator for MBEntityType */
 inline MBEntityType & operator++(MBEntityType &type)
   return type = static_cast<MBEntityType>(type+1);
-//! postfix increment operator for MBEntityType
+/** postfix increment operator for MBEntityType */
 inline MBEntityType operator++(MBEntityType &type, int)
   MBEntityType oldval = type;
@@ -61,13 +61,13 @@
   return oldval;
 inline MBEntityType & operator--(MBEntityType &type)
   return type = static_cast<MBEntityType>(type-1);
 inline MBEntityType operator--(MBEntityType &type, int)
Modified: MOAB/trunk/MBInterface.hpp
--- MOAB/trunk/MBInterface.hpp	2009-04-16 18:14:34 UTC (rev 2830)
+++ MOAB/trunk/MBInterface.hpp	2009-04-16 22:07:21 UTC (rev 2831)
@@ -54,7 +54,7 @@
 #endif
-#include "MBUnknownInterface.h"
+#include "MBUnknownInterface.hpp"
 #define MB_INTERFACE_VERSION "2.0.0"
 static const MBuuid IDD_MBCore = MBuuid( 0x8956e0a, 0xc300, 0x4005,
                                          0xbd, 0xf6, 0xc3, 0x4e, 0xf7, 0x1f, 0x5a, 0x52 );
Deleted: MOAB/trunk/MBUnknownInterface.h
--- MOAB/trunk/MBUnknownInterface.h	2009-04-16 18:14:34 UTC (rev 2830)
+++ MOAB/trunk/MBUnknownInterface.h	2009-04-16 22:07:21 UTC (rev 2831)
@@ -1,101 +0,0 @@
-/*  Filename   :     MBUnkonwnInterface.h
- *  Creator    :     Clinton Stimpson
- *  Date       :     10 Jan 2002
- *  Owner      :     Clinton Stimpson
- *  Description:     Contains declarations for MBuuid which keeps
- *                   track of different interfaces.
- *                   Also contains the declaration for the base class
- *                   MBUknownInterface from which all interfaces are
- *                   derived from
-#ifndef MBUNKNOWNINTERFACE_HPP
-#define MBUNKNOWNINTERFACE_HPP
-#include <memory.h>
-typedef unsigned char   MBuchar;
-typedef unsigned short  MBushort;
-typedef unsigned        MBuint;
-//!  struct that handles universally unique id's for the Mesh Database
-// note: this MBuuid is compliant with the windows GUID.
-// It is possible to do a memcpy() to copy the data from a MBuuid to a GUID
-// if we want to support dll registration
-struct MBuuid
-   //! default constructor that initializes to zero
-   MBuuid()
-      memset( this, 0, sizeof(MBuuid) );
-   //! constructor that takes initialization arguments
-   MBuuid( MBuint l, MBushort w1, MBushort w2,
-         MBuchar b1, MBuchar b2, MBuchar b3,
-         MBuchar b4, MBuchar b5, MBuchar b6,
-         MBuchar b7, MBuchar b8 )
-      data1 = l;
-      data2 = w1;
-      data3 = w2;
-      data4[0] = b1;
-      data4[1] = b2;
-      data4[2] = b3;
-      data4[3] = b4;
-      data4[4] = b5;
-      data4[5] = b6;
-      data4[6] = b7;
-      data4[7] = b8;
-   //! copy constructor
-   MBuuid( const MBuuid& mdbuuid )
-      memcpy( this, &mdbuuid, sizeof(MBuuid));
-   //! sets this uuid equal to another one
-   MBuuid &operator=(const MBuuid& orig)
-      memcpy( this, &orig, sizeof(MBuuid));
-      return *this;
-   //! returns whether two uuid's are equal
-   bool operator==(const MBuuid& orig) const
-      return !memcmp(this, &orig, sizeof(MBuuid));
-   //! returns whether two uuid's are not equal
-   bool operator!=(const MBuuid& orig) const
-      return!(*this == orig);
-   //! uuid data storage
-   MBuint   data1;
-   MBushort data2;
-   MBushort data3;
-   MBuchar  data4[8];
-//! MBuuid for an unknown interface
-//! this can be used to either return a default interface
-//! or a NULL interface
-static const MBuuid IDD_MBUnknown = MBuuid( 0xf4f6605e, 0x2a7e, 0x4760,
-   0xbb, 0x06, 0xb9, 0xed, 0x27, 0xe9, 0x4a, 0xec );
-//! base class for all interface classes
-class MBUnknownInterface
-public:
-   virtual int QueryInterface
-      ( const MBuuid&, MBUnknownInterface** ) = 0;
-   virtual ~MBUnknownInterface() {};
-#endif  // MBUNKNOWNINTERFACE_HPP
Copied: MOAB/trunk/MBUnknownInterface.hpp (from rev 2826, MOAB/trunk/MBUnknownInterface.h)
--- MOAB/trunk/MBUnknownInterface.hpp	                        (rev 0)
+++ MOAB/trunk/MBUnknownInterface.hpp	2009-04-16 22:07:21 UTC (rev 2831)
@@ -0,0 +1,101 @@
+/*  Filename   :     MBUnkonwnInterface.h
+ *  Creator    :     Clinton Stimpson
+ *  Date       :     10 Jan 2002
+ *  Owner      :     Clinton Stimpson
+ *  Description:     Contains declarations for MBuuid which keeps
+ *                   track of different interfaces.
+ *                   Also contains the declaration for the base class
+ *                   MBUknownInterface from which all interfaces are
+ *                   derived from
+#ifndef MBUNKNOWNINTERFACE_HPP
+#define MBUNKNOWNINTERFACE_HPP
+#include <memory.h>
+typedef unsigned char   MBuchar;
+typedef unsigned short  MBushort;
+typedef unsigned        MBuint;
+//!  struct that handles universally unique id's for the Mesh Database
+// note: this MBuuid is compliant with the windows GUID.
+// It is possible to do a memcpy() to copy the data from a MBuuid to a GUID
+// if we want to support dll registration
+struct MBuuid
+   //! default constructor that initializes to zero
+   MBuuid()
+      memset( this, 0, sizeof(MBuuid) );
+   //! constructor that takes initialization arguments
+   MBuuid( MBuint l, MBushort w1, MBushort w2,
+         MBuchar b1, MBuchar b2, MBuchar b3,
+         MBuchar b4, MBuchar b5, MBuchar b6,
+         MBuchar b7, MBuchar b8 )
+      data1 = l;
+      data2 = w1;
+      data3 = w2;
+      data4[0] = b1;
+      data4[1] = b2;
+      data4[2] = b3;
+      data4[3] = b4;
+      data4[4] = b5;
+      data4[5] = b6;
+      data4[6] = b7;
+      data4[7] = b8;
+   //! copy constructor
+   MBuuid( const MBuuid& mdbuuid )
+      memcpy( this, &mdbuuid, sizeof(MBuuid));
+   //! sets this uuid equal to another one
+   MBuuid &operator=(const MBuuid& orig)
+      memcpy( this, &orig, sizeof(MBuuid));
+      return *this;
+   //! returns whether two uuid's are equal
+   bool operator==(const MBuuid& orig) const
+      return !memcmp(this, &orig, sizeof(MBuuid));
+   //! returns whether two uuid's are not equal
+   bool operator!=(const MBuuid& orig) const
+      return!(*this == orig);
+   //! uuid data storage
+   MBuint   data1;
+   MBushort data2;
+   MBushort data3;
+   MBuchar  data4[8];
+//! MBuuid for an unknown interface
+//! this can be used to either return a default interface
+//! or a NULL interface
+static const MBuuid IDD_MBUnknown = MBuuid( 0xf4f6605e, 0x2a7e, 0x4760,
+   0xbb, 0x06, 0xb9, 0xed, 0x27, 0xe9, 0x4a, 0xec );
+//! base class for all interface classes
+class MBUnknownInterface
+public:
+   virtual int QueryInterface
+      ( const MBuuid&, MBUnknownInterface** ) = 0;
+   virtual ~MBUnknownInterface() {};
+#endif  // MBUNKNOWNINTERFACE_HPP
Property changes on: MOAB/trunk/MBUnknownInterface.hpp
___________________________________________________________________
   + Author Date Id Revision
   + native
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2009-04-16 18:14:34 UTC (rev 2830)
+++ MOAB/trunk/Makefile.am	2009-04-16 22:07:21 UTC (rev 2831)
@@ -261,7 +261,7 @@
   MBSkinner.hpp \
   MBTagConventions.hpp \
   MBTypes.h \
-  MBUnknownInterface.h \
+  MBUnknownInterface.hpp \
   MBUtil.hpp \
   MBWriteUtilIface.hpp \
   MBWriterIface.hpp \
Modified: MOAB/trunk/ReadWriteDefines.h
--- MOAB/trunk/ReadWriteDefines.h	2009-04-16 18:14:34 UTC (rev 2830)
+++ MOAB/trunk/ReadWriteDefines.h	2009-04-16 22:07:21 UTC (rev 2831)
@@ -6,7 +6,7 @@
 #pragma warning(disable : 4786)
 #endif
-// CJS  -- we need to figure out how this fits in the component framework
+/* CJS  -- we need to figure out how this fits in the component framework */
 #error "don't include this file"
Modified: MOAB/trunk/exodus_order.h
--- MOAB/trunk/exodus_order.h	2009-04-16 18:14:34 UTC (rev 2830)
+++ MOAB/trunk/exodus_order.h	2009-04-16 22:07:21 UTC (rev 2831)
@@ -25,22 +25,22 @@
 static const int* const* exodus_hex_order = patran_hex_order;
 static const int *const *const exodus_elem_order_map[] = {
-  patran_null_order, // MBVERTEX
-  patran_null_order, // MBEDGE
-  patran_null_order, // MBTRI
-  patran_null_order, // MBQUAD
-  patran_null_order, // MBPOLYGON
-  exodus_tet_order,  // MBTET
-  patran_null_order, // MBPYRAMID
-  patran_pri_order,  // MBPRISM
-  patran_null_order, // MBKNIFE
-  exodus_hex_order,  // MBHEX
-  patran_null_order, // MBPOLYHEDRON
+  patran_null_order, /*  MBVERTEX */
+  patran_null_order, /*  MBEDGE */
+  patran_null_order, /*  MBTRI */
+  patran_null_order, /*  MBQUAD */
+  patran_null_order, /*  MBPOLYGON */
+  exodus_tet_order,  /*  MBTET */
+  patran_null_order, /*  MBPYRAMID */
+  patran_pri_order,  /*  MBPRISM */
+  patran_null_order, /*  MBKNIFE */
+  exodus_hex_order,  /*  MBHEX */
+  patran_null_order, /*  MBPOLYHEDRON */
   patran_null_order
 #ifdef __cplusplus
-} // extern "C"
+} /*  extern "C" */
 #endif
 #endif
Modified: MOAB/trunk/parallel/gs.h
--- MOAB/trunk/parallel/gs.h	2009-04-16 18:14:34 UTC (rev 2830)
+++ MOAB/trunk/parallel/gs.h	2009-04-16 22:07:21 UTC (rev 2831)
@@ -6,7 +6,7 @@
 #warning "gs.h" requires "types.h" and "crystal.h"
 #endif
-// typedef struct gs_data_ gs_data;
+/*  typedef struct gs_data_ gs_data; */
 #ifndef MPI
 #  define crystal_data void
Modified: MOAB/trunk/patran_order.h
--- MOAB/trunk/patran_order.h	2009-04-16 18:14:34 UTC (rev 2830)
+++ MOAB/trunk/patran_order.h	2009-04-16 22:07:21 UTC (rev 2831)
@@ -90,22 +90,22 @@
    is the same as PATRAN (or the number of nodes is invalid.) */
 static const int *const *const patran_elem_order_map[] = {
-  patran_tet_order,  // MBTET
-  patran_hex_order,  // MBHEX
+  patran_tet_order,  /*  MBTET */
+  patran_hex_order,  /*  MBHEX */
   patran_null_order
 #ifdef __cplusplus
-} // extern "C"
+} /*  extern "C" */
 #endif
 #endif
Modified: MOAB/trunk/tools/dagmc/cubfile.h
--- MOAB/trunk/tools/dagmc/cubfile.h	2009-04-16 18:14:34 UTC (rev 2830)
+++ MOAB/trunk/tools/dagmc/cubfile.h	2009-04-16 22:07:21 UTC (rev 2831)
@@ -75,7 +75,7 @@
 int cub_file_type( FILE* cubfile, FILE* output_file, enum CubFileType type );
 #ifdef __cplusplus
-} // extern "C"
+} /* extern "C" */
 #endif
 #endif
Modified: MOAB/trunk/tools/iMesh/iMesh.h
--- MOAB/trunk/tools/iMesh/iMesh.h	2009-04-16 18:14:34 UTC (rev 2830)
+++ MOAB/trunk/tools/iMesh/iMesh.h	2009-04-16 22:07:21 UTC (rev 2831)
@@ -1976,7 +1976,7 @@
                    /*out*/ int *err);
 #ifdef __cplusplus
-} // extern "C"
+} /*  extern "C" */
 #endif
 #endif /* ifndef IMESH_CBIND_H__ */
Modified: MOAB/trunk/tools/mbcoupler/extrafindpt.h
--- MOAB/trunk/tools/mbcoupler/extrafindpt.h	2009-04-16 18:14:34 UTC (rev 2830)
+++ MOAB/trunk/tools/mbcoupler/extrafindpt.h	2009-04-16 22:07:21 UTC (rev 2831)
@@ -1,5 +1,5 @@
-//extra stuff that james didn't expose
+/* extra stuff that james didn't expose */
 typedef struct {
   unsigned constraints;
Modified: MOAB/trunk/tools/mbcoupler/poly.h
--- MOAB/trunk/tools/mbcoupler/poly.h	2009-04-16 18:14:34 UTC (rev 2830)
+++ MOAB/trunk/tools/mbcoupler/poly.h	2009-04-16 22:07:21 UTC (rev 2831)
@@ -115,23 +115,23 @@
    Usage:
      lagrange_data p;
-     lagrange_setup(&p,z,n);    // setup for nodes z[0 ... n-1]
+     lagrange_setup(&p,z,n);    /*  setup for nodes z[0 ... n-1] */
      the weights
        p->J [0 ... n-1]     interpolation weights
        p->D [0 ... n-1]     1st derivative weights
        p->D2[0 ... n-1]     2nd derivative weights
      are computed for a given x with:
-       lagrange_0(p,x);  // compute p->J
-       lagrange_1(p,x);  // compute p->J, p->D
-       lagrange_2(p,x);  // compute p->J, p->D, p->D2
-       lagrange_2u(p);   // compute p->D2 after call of lagrange_1(p,x);
+       lagrange_0(p,x);  /*  compute p->J */
+       lagrange_1(p,x);  /*  compute p->J, p->D */
+       lagrange_2(p,x);  /*  compute p->J, p->D, p->D2 */
+       lagrange_2u(p);   /*  compute p->D2 after call of lagrange_1(p,x); */
      These functions use the z array supplied to setup
        (that pointer should not be freed between calls)
      Weights for x=z[0] and x=z[n-1] are computed during setup; access as:
        p->J_z0, etc. and p->J_zn, etc.
-     lagrange_free(&p);  // deallocate memory allocated by setup
+     lagrange_free(&p);  /*  deallocate memory allocated by setup */
 typedef struct {
