[MOAB-dev] r2836 - in MOAB/trunk: . tools/mbcoupler
kraftche at cae.wisc.edu kraftche at cae.wisc.edu
Fri Apr 17 14:44:03 CDT 2009
Author: kraftche
Date: 2009-04-17 14:44:02 -0500 (Fri, 17 Apr 2009)
New Revision: 2836
Added:
   MOAB/trunk/MBElemUtil.cpp
   MOAB/trunk/MBElemUtil.hpp
Removed:
   MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp
   MOAB/trunk/tools/mbcoupler/MBElemUtil.hpp
Modified:
   MOAB/trunk/MBGeomUtil.hpp
   MOAB/trunk/Makefile.am
   MOAB/trunk/tools/mbcoupler/Makefile.am
Log:
move MBElemUtil back into MOAB proper
Copied: MOAB/trunk/MBElemUtil.cpp (from rev 2835, MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp)
--- MOAB/trunk/MBElemUtil.cpp	                        (rev 0)
+++ MOAB/trunk/MBElemUtil.cpp	2009-04-17 19:44:02 UTC (rev 2836)
@@ -0,0 +1,297 @@
+#include <iostream>
+#include <limits>
+#include <assert.h>
+#include "MBElemUtil.hpp"
+#include "MBMatrix3.hpp"
+#include "types.h"
+namespace MBElemUtil {
+/**\brief Class representing a 3-D mapping function (e.g. shape function for volume element) */
+class VolMap {
+  public:
+      /**\brief Return $\vec \xi$ corresponding to logical center of element */
+    virtual MBCartVect center_xi() const = 0;
+      /**\brief Evaluate mapping function (calculate $\vec x = F($\vec \xi)$ )*/
+    virtual MBCartVect evaluate( const MBCartVect& xi ) const = 0;
+      /**\brief Evaluate Jacobian of mapping function */
+    virtual MBMatrix3 jacobian( const MBCartVect& xi ) const = 0;
+      /**\brief Evaluate inverse of mapping function (calculate $\vec \xi = F^-1($\vec x)$ )*/
+    bool solve_inverse( const MBCartVect& x, MBCartVect& xi, double tol ) const ;
+bool VolMap::solve_inverse( const MBCartVect& x, MBCartVect& xi, double tol ) const
+  const double error_tol_sqr = tol*tol;
+  double det;
+  xi = center_xi();
+  MBCartVect delta = evaluate(xi) - x;
+  MBMatrix3 J;
+  while (delta % delta > error_tol_sqr) {
+    J = jacobian(xi);
+    det = J.determinant();
+    if (det < std::numeric_limits<double>::epsilon())
+      return false;
+    xi -= J.inverse(1.0/det) * delta;
+    delta = evaluate( xi ) - x;
+  return true;
+/**\brief Shape function for trilinear hexahedron */
+class LinearHexMap : public VolMap {
+  public:
+    LinearHexMap( const MBCartVect* corner_coords ) : corners(corner_coords) {}
+    virtual MBCartVect center_xi() const;
+    virtual MBCartVect evaluate( const MBCartVect& xi ) const;
+    virtual MBMatrix3 jacobian( const MBCartVect& xi ) const;
+  private:
+    const MBCartVect* corners;
+    static const double corner_xi[8][3];
+const double LinearHexMap::corner_xi[8][3] = { { -1, -1, -1 },
+                                               {  1, -1, -1 },
+                                               {  1,  1, -1 },
+                                               { -1,  1, -1 },
+                                               { -1, -1,  1 },
+                                               {  1, -1,  1 },
+                                               {  1,  1,  1 },
+                                               { -1,  1,  1 } };
+MBCartVect LinearHexMap::center_xi() const
+  { return MBCartVect(0.0); }
+MBCartVect LinearHexMap::evaluate( const MBCartVect& xi ) const
+  MBCartVect x(0.0);
+  for (unsigned i = 0; i < 8; ++i) {
+    const double N_i = (1 + xi[0]*corner_xi[i][0])
+                     * (1 + xi[1]*corner_xi[i][1])
+                     * (1 + xi[2]*corner_xi[i][2]);
+    x += N_i * corners[i];
+  x *= 0.125;
+  return x;
+MBMatrix3 LinearHexMap::jacobian( const MBCartVect& xi ) const
+  MBMatrix3 J(0.0);
+    const double   xi_p = 1 + xi[0]*corner_xi[i][0];
+    const double  eta_p = 1 + xi[1]*corner_xi[i][1];
+    const double zeta_p = 1 + xi[2]*corner_xi[i][2];
+    const double dNi_dxi   = corner_xi[i][0] * eta_p * zeta_p;
+    const double dNi_deta  = corner_xi[i][1] *  xi_p * zeta_p;
+    const double dNi_dzeta = corner_xi[i][2] *  xi_p *  eta_p;
+    J(0,0) += dNi_dxi   * corners[i][0];
+    J(1,0) += dNi_dxi   * corners[i][1];
+    J(2,0) += dNi_dxi   * corners[i][2];
+    J(0,1) += dNi_deta  * corners[i][0];
+    J(1,1) += dNi_deta  * corners[i][1];
+    J(2,1) += dNi_deta  * corners[i][2];
+    J(0,2) += dNi_dzeta * corners[i][0];
+    J(1,2) += dNi_dzeta * corners[i][1];
+    J(2,2) += dNi_dzeta * corners[i][2];
+  return J *= 0.125;
+bool nat_coords_trilinear_hex( const MBCartVect* corner_coords,
+                               const MBCartVect& x,
+                               MBCartVect& xi,
+                               double tol )
+  return LinearHexMap( corner_coords ).solve_inverse( x, xi, tol );
+// nat_coords_trilinear_hex2
+//  Duplicate functionality of nat_coords_trilinear_hex using hex_findpt
+void nat_coords_trilinear_hex2(const MBCartVect hex[8],
+                               const MBCartVect& xyz,
+                               MBCartVect &ncoords,
+                               double etol)
+  const int ndim = 3;
+  const int nverts = 8;
+  const int vertMap[nverts] = {0,1,3,2, 4,5,7,6}; //Map from nat to lex ordering
+  const int n = 2; //linear
+  real coords[ndim*nverts]; //buffer
+  real *xm[ndim];
+  for(int i=0; i<ndim; i++)
+    xm[i] = coords + i*nverts;
+  //stuff hex into coords
+  for(int i=0; i<nverts; i++){
+    real vcoord[ndim];
+    hex[i].get(vcoord);
+    for(int d=0; d<ndim; d++)
+      coords[d*nverts + vertMap[i]] = vcoord[d];
+  double dist = 0.0;
+  MBElemUtil::hex_findpt(xm, n, xyz, ncoords, dist);
+  if (3*EPS < dist) {
+      // outside element, set extremal values to something outside range
+    for (int j = 0; j < 3; j++) {
+      if (ncoords[j] < (-1.0-etol) || ncoords[j] > (1.0+etol))
+        ncoords[j] *= 10;
+bool point_in_trilinear_hex(const MBCartVect *hex,
+                            double etol)
+  MBCartVect xi;
+  return nat_coords_trilinear_hex( hex, xyz, xi, etol )
+      && fabs(xi[0])-1 < etol
+      && fabs(xi[1])-1 < etol
+      && fabs(xi[2])-1 < etol;
+                            const MBCartVect& box_min,
+                            const MBCartVect& box_max,
+                            double etol)
+    // all values scaled by 2 (eliminates 3 flops)
+  const MBCartVect mid = box_max + box_min;
+  const MBCartVect dim = box_max - box_min;
+  const MBCartVect pt = 2*xyz - mid;
+  return fabs(pt[0]) - dim[0] < etol &&
+         fabs(pt[1]) - dim[1] < etol &&
+         fabs(pt[2]) - dim[2] < etol &&
+         point_in_trilinear_hex( hex, xyz, etol );
+// Wrapper to James Lottes' findpt routines
+// hex_findpt
+// Find the parametric coordinates of an xyz point inside
+// a 3d hex spectral element with n nodes per dimension
+// xm: coordinates fields, value of x,y,z for each of then n*n*n gauss-lobatto nodes. Nodes are in lexicographical order (x is fastest-changing)
+// n: number of nodes per dimension -- n=2 for a linear element
+// xyz: input, point to find
+// rst: output: parametric coords of xyz inside the element. If xyz is outside the element, rst will be the coords of the closest point
+// dist: output: distance between xyz and the point with parametric coords rst
+extern "C"{
+#include "types.h"
+#include "poly.h"
+#include "tensor.h"
+#include "findpt.h"
+#include "extrafindpt.h"
+#include "errmem.h"
+void hex_findpt(real *xm[3],
+                int n,
+                MBCartVect xyz,
+                MBCartVect &rst,
+                double &dist)
+  //compute stuff that only depends on the order -- could be cached
+  real *z[3];
+  lagrange_data ld[3];
+  opt_data_3 data;
+  //triplicates
+  for(int d=0; d<3; d++){
+    z[d] = tmalloc(real, n);
+    lobatto_nodes(z[d], n);
+    lagrange_setup(&ld[d], z[d], n);
+  opt_alloc_3(&data, ld);
+  //find nearest point
+  real x_star[3];
+  xyz.get(x_star);
+  real r[3] = {0, 0, 0 }; // initial guess for parametric coords
+  unsigned c = opt_no_constraints_3;
+  dist = opt_findpt_3(&data, (const real **)xm, x_star, r, &c);
+  //c tells us if we landed inside the element or exactly on a face, edge, or node
+  //copy parametric coords back
+  rst = r;
+  //Clean-up (move to destructor if we decide to cache)
+  opt_free_3(&data);
+  for(int d=0; d<3; ++d)
+    lagrange_free(&ld[d]);
+    free(z[d]);
+// hex_eval
+// Evaluate a field in a 3d hex spectral element with n nodes per dimension, at some given parametric coordinates
+// field: field values for each of then n*n*n gauss-lobatto nodes. Nodes are in lexicographical order (x is fastest-changing)
+// rst: input: parametric coords of the point where we want to evaluate the field
+// value: output: value of field at rst
+void hex_eval(real *field,
+	      int n,
+	      MBCartVect rstCartVec,
+	      double &value)
+  int d;
+  real rst[3];
+  rstCartVec.get(rst);
+  //can cache stuff below
+  real *z[3];
+  for(d=0;d<3;++d){
+  //cut and paste -- see findpt.c
+  const unsigned
+    nf = n*n,
+    ne = n,
+    nw = 2*n*n + 3*n;
+  real *od_work = tmalloc(real, 6*nf + 9*ne + nw);
+  //piece that we shouldn't want to cache
+  for(d=0; d<3; d++){
+    lagrange_0(&ld[d], rst[d]);
+  value = tensor_i3(ld[0].J,ld[0].n,
+		    ld[1].J,ld[1].n,
+		    ld[2].J,ld[2].n,
+		    field,
+		    od_work);
+  //all this could be cached
+    free(z[d]);
+  free(od_work);
+} // namespace MBElemUtil
Property changes on: MOAB/trunk/MBElemUtil.cpp
___________________________________________________________________
Copied: MOAB/trunk/MBElemUtil.hpp (from rev 2835, MOAB/trunk/tools/mbcoupler/MBElemUtil.hpp)
--- MOAB/trunk/MBElemUtil.hpp	                        (rev 0)
+++ MOAB/trunk/MBElemUtil.hpp	2009-04-17 19:44:02 UTC (rev 2836)
@@ -0,0 +1,38 @@
+#include "MBCore.hpp"
+#include "MBCartVect.hpp"
+  bool nat_coords_trilinear_hex(const MBCartVect* hex_corners,
+                                MBCartVect& xi,
+                                double tol);
+  bool point_in_trilinear_hex(const MBCartVect *hex_corners,
+                              double etol);
+                              double etol);
+    //wrapper to hex_findpt
+  void nat_coords_trilinear_hex2(const MBCartVect* hex_corners,
+                                 MBCartVect& xi,
+                                 double til);
+  void hex_findpt(double *xm[3],
+                  int n,
+                  MBCartVect xyz,
+                  MBCartVect& rst,
+                  double& dist);
+  void hex_eval(double *field,
+		int n,
+		MBCartVect rst,
+		double &value);
Property changes on: MOAB/trunk/MBElemUtil.hpp
Modified: MOAB/trunk/MBGeomUtil.hpp
--- MOAB/trunk/MBGeomUtil.hpp	2009-04-17 16:49:56 UTC (rev 2835)
+++ MOAB/trunk/MBGeomUtil.hpp	2009-04-17 19:44:02 UTC (rev 2836)
@@ -254,30 +254,6 @@
                       const MBCartVect& box_center,
                       const MBCartVect& box_dims);
-// point_in_trilinear_hex
-// Tests if a point in xyz space is within a hex element defined with
-// its eight vertex points forming a trilinear basis function.  Computes
-// the natural coordinates with respect to the hex of the xyz point
-// and checks if each are between +/-1.  If anyone is outside the range
-// the function returns false, otherwise it returns true.
-bool point_in_trilinear_hex(MBCartVect *hex,
-                            MBCartVect xyz,
-                            double etol);
-// its eight vertex points forming a trilinear basis function.  Like the
-// test above except that it gets a bounding box as arguments to filter
-// the test for acceleration.
-                            MBCartVect xyz,
-                            MBCartVect box_min, MBCartVect box_max,
-                            double etol);
 } // namespace MBGeoemtry
 #endif
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2009-04-17 16:49:56 UTC (rev 2835)
+++ MOAB/trunk/Makefile.am	2009-04-17 19:44:02 UTC (rev 2836)
@@ -139,6 +139,7 @@
   MBCN.cpp \
   MBCNArrays.hpp \
   MBCartVect.cpp \
+  MBElemUtil.cpp \
   MBMatrix3.cpp \
   MBMatrix3.hpp \
   MBCore.cpp \
@@ -245,6 +246,7 @@
   MBCN_protos.h \
   MBCartVect.hpp \
   MBCore.hpp \
+  MBElemUtil.hpp \
   MBEntityType.h \
   MBEntityHandle.h \
   MBError.hpp \
Deleted: MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp
--- MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp	2009-04-17 16:49:56 UTC (rev 2835)
+++ MOAB/trunk/tools/mbcoupler/MBElemUtil.cpp	2009-04-17 19:44:02 UTC (rev 2836)
@@ -1,297 +0,0 @@
-#include <iostream>
-#include <limits>
-#include <assert.h>
-#include "MBElemUtil.hpp"
-#include "MBMatrix3.hpp"
-#include "types.h"
-namespace MBElemUtil {
-/**\brief Class representing a 3-D mapping function (e.g. shape function for volume element) */
-class VolMap {
-  public:
-      /**\brief Return $\vec \xi$ corresponding to logical center of element */
-    virtual MBCartVect center_xi() const = 0;
-      /**\brief Evaluate mapping function (calculate $\vec x = F($\vec \xi)$ )*/
-    virtual MBCartVect evaluate( const MBCartVect& xi ) const = 0;
-      /**\brief Evaluate Jacobian of mapping function */
-    virtual MBMatrix3 jacobian( const MBCartVect& xi ) const = 0;
-      /**\brief Evaluate inverse of mapping function (calculate $\vec \xi = F^-1($\vec x)$ )*/
-    bool solve_inverse( const MBCartVect& x, MBCartVect& xi, double tol ) const ;
-bool VolMap::solve_inverse( const MBCartVect& x, MBCartVect& xi, double tol ) const
-  const double error_tol_sqr = tol*tol;
-  double det;
-  xi = center_xi();
-  MBCartVect delta = evaluate(xi) - x;
-  MBMatrix3 J;
-  while (delta % delta > error_tol_sqr) {
-    J = jacobian(xi);
-    det = J.determinant();
-    if (det < std::numeric_limits<double>::epsilon())
-      return false;
-    xi -= J.inverse(1.0/det) * delta;
-    delta = evaluate( xi ) - x;
-  return true;
-/**\brief Shape function for trilinear hexahedron */
-class LinearHexMap : public VolMap {
-  public:
-    LinearHexMap( const MBCartVect* corner_coords ) : corners(corner_coords) {}
-    virtual MBCartVect center_xi() const;
-    virtual MBCartVect evaluate( const MBCartVect& xi ) const;
-    virtual MBMatrix3 jacobian( const MBCartVect& xi ) const;
-  private:
-    const MBCartVect* corners;
-    static const double corner_xi[8][3];
-const double LinearHexMap::corner_xi[8][3] = { { -1, -1, -1 },
-                                               {  1, -1, -1 },
-                                               {  1,  1, -1 },
-                                               { -1,  1, -1 },
-                                               { -1, -1,  1 },
-                                               {  1, -1,  1 },
-                                               {  1,  1,  1 },
-                                               { -1,  1,  1 } };
-MBCartVect LinearHexMap::center_xi() const
-  { return MBCartVect(0.0); }
-MBCartVect LinearHexMap::evaluate( const MBCartVect& xi ) const
-  MBCartVect x(0.0);
-  for (unsigned i = 0; i < 8; ++i) {
-    const double N_i = (1 + xi[0]*corner_xi[i][0])
-                     * (1 + xi[1]*corner_xi[i][1])
-                     * (1 + xi[2]*corner_xi[i][2]);
-    x += N_i * corners[i];
-  x *= 0.125;
-  return x;
-MBMatrix3 LinearHexMap::jacobian( const MBCartVect& xi ) const
-  MBMatrix3 J(0.0);
-    const double   xi_p = 1 + xi[0]*corner_xi[i][0];
-    const double  eta_p = 1 + xi[1]*corner_xi[i][1];
-    const double zeta_p = 1 + xi[2]*corner_xi[i][2];
-    const double dNi_dxi   = corner_xi[i][0] * eta_p * zeta_p;
-    const double dNi_deta  = corner_xi[i][1] *  xi_p * zeta_p;
-    const double dNi_dzeta = corner_xi[i][2] *  xi_p *  eta_p;
-    J(0,0) += dNi_dxi   * corners[i][0];
-    J(1,0) += dNi_dxi   * corners[i][1];
-    J(2,0) += dNi_dxi   * corners[i][2];
-    J(0,1) += dNi_deta  * corners[i][0];
-    J(1,1) += dNi_deta  * corners[i][1];
-    J(2,1) += dNi_deta  * corners[i][2];
-    J(0,2) += dNi_dzeta * corners[i][0];
-    J(1,2) += dNi_dzeta * corners[i][1];
-    J(2,2) += dNi_dzeta * corners[i][2];
-  return J *= 0.125;
-bool nat_coords_trilinear_hex( const MBCartVect* corner_coords,
-                               const MBCartVect& x,
-                               MBCartVect& xi,
-                               double tol )
-  return LinearHexMap( corner_coords ).solve_inverse( x, xi, tol );
-// nat_coords_trilinear_hex2
-//  Duplicate functionality of nat_coords_trilinear_hex using hex_findpt
-void nat_coords_trilinear_hex2(const MBCartVect hex[8],
-                               const MBCartVect& xyz,
-                               MBCartVect &ncoords,
-                               double etol)
-  const int ndim = 3;
-  const int nverts = 8;
-  const int vertMap[nverts] = {0,1,3,2, 4,5,7,6}; //Map from nat to lex ordering
-  const int n = 2; //linear
-  real coords[ndim*nverts]; //buffer
-  real *xm[ndim];
-  for(int i=0; i<ndim; i++)
-    xm[i] = coords + i*nverts;
-  //stuff hex into coords
-  for(int i=0; i<nverts; i++){
-    real vcoord[ndim];
-    hex[i].get(vcoord);
-    for(int d=0; d<ndim; d++)
-      coords[d*nverts + vertMap[i]] = vcoord[d];
-  double dist = 0.0;
-  MBElemUtil::hex_findpt(xm, n, xyz, ncoords, dist);
-  if (3*EPS < dist) {
-      // outside element, set extremal values to something outside range
-    for (int j = 0; j < 3; j++) {
-      if (ncoords[j] < (-1.0-etol) || ncoords[j] > (1.0+etol))
-        ncoords[j] *= 10;
-bool point_in_trilinear_hex(const MBCartVect *hex,
-                            double etol)
-  MBCartVect xi;
-  return nat_coords_trilinear_hex( hex, xyz, xi, etol )
-      && fabs(xi[0])-1 < etol
-      && fabs(xi[1])-1 < etol
-      && fabs(xi[2])-1 < etol;
-                            const MBCartVect& box_min,
-                            const MBCartVect& box_max,
-                            double etol)
-    // all values scaled by 2 (eliminates 3 flops)
-  const MBCartVect mid = box_max + box_min;
-  const MBCartVect dim = box_max - box_min;
-  const MBCartVect pt = 2*xyz - mid;
-  return fabs(pt[0]) - dim[0] < etol &&
-         fabs(pt[1]) - dim[1] < etol &&
-         fabs(pt[2]) - dim[2] < etol &&
-         point_in_trilinear_hex( hex, xyz, etol );
-// Wrapper to James Lottes' findpt routines
-// hex_findpt
-// Find the parametric coordinates of an xyz point inside
-// a 3d hex spectral element with n nodes per dimension
-// xm: coordinates fields, value of x,y,z for each of then n*n*n gauss-lobatto nodes. Nodes are in lexicographical order (x is fastest-changing)
-// n: number of nodes per dimension -- n=2 for a linear element
-// xyz: input, point to find
-// rst: output: parametric coords of xyz inside the element. If xyz is outside the element, rst will be the coords of the closest point
-// dist: output: distance between xyz and the point with parametric coords rst
-extern "C"{
-#include "types.h"
-#include "poly.h"
-#include "tensor.h"
-#include "findpt.h"
-#include "extrafindpt.h"
-#include "errmem.h"
-void hex_findpt(real *xm[3],
-                int n,
-                MBCartVect xyz,
-                MBCartVect &rst,
-                double &dist)
-  //compute stuff that only depends on the order -- could be cached
-  real *z[3];
-  lagrange_data ld[3];
-  opt_data_3 data;
-  //triplicates
-  for(int d=0; d<3; d++){
-    z[d] = tmalloc(real, n);
-    lobatto_nodes(z[d], n);
-    lagrange_setup(&ld[d], z[d], n);
-  opt_alloc_3(&data, ld);
-  //find nearest point
-  real x_star[3];
-  xyz.get(x_star);
-  real r[3] = {0, 0, 0 }; // initial guess for parametric coords
-  unsigned c = opt_no_constraints_3;
-  dist = opt_findpt_3(&data, (const real **)xm, x_star, r, &c);
-  //c tells us if we landed inside the element or exactly on a face, edge, or node
-  //copy parametric coords back
-  rst = r;
-  //Clean-up (move to destructor if we decide to cache)
-  opt_free_3(&data);
-  for(int d=0; d<3; ++d)
-    lagrange_free(&ld[d]);
-    free(z[d]);
-// hex_eval
-// Evaluate a field in a 3d hex spectral element with n nodes per dimension, at some given parametric coordinates
-// field: field values for each of then n*n*n gauss-lobatto nodes. Nodes are in lexicographical order (x is fastest-changing)
-// rst: input: parametric coords of the point where we want to evaluate the field
-// value: output: value of field at rst
-void hex_eval(real *field,
-	      int n,
-	      MBCartVect rstCartVec,
-	      double &value)
-  int d;
-  real rst[3];
-  rstCartVec.get(rst);
-  //can cache stuff below
-  real *z[3];
-  for(d=0;d<3;++d){
-  //cut and paste -- see findpt.c
-  const unsigned
-    nf = n*n,
-    ne = n,
-    nw = 2*n*n + 3*n;
-  real *od_work = tmalloc(real, 6*nf + 9*ne + nw);
-  //piece that we shouldn't want to cache
-  for(d=0; d<3; d++){
-    lagrange_0(&ld[d], rst[d]);
-  value = tensor_i3(ld[0].J,ld[0].n,
-		    ld[1].J,ld[1].n,
-		    ld[2].J,ld[2].n,
-		    field,
-		    od_work);
-  //all this could be cached
-    free(z[d]);
-  free(od_work);
-} // namespace MBElemUtil
Deleted: MOAB/trunk/tools/mbcoupler/MBElemUtil.hpp
--- MOAB/trunk/tools/mbcoupler/MBElemUtil.hpp	2009-04-17 16:49:56 UTC (rev 2835)
+++ MOAB/trunk/tools/mbcoupler/MBElemUtil.hpp	2009-04-17 19:44:02 UTC (rev 2836)
@@ -1,38 +0,0 @@
-#include "MBCore.hpp"
-#include "MBCartVect.hpp"
-  bool nat_coords_trilinear_hex(const MBCartVect* hex_corners,
-                                MBCartVect& xi,
-                                double tol);
-  bool point_in_trilinear_hex(const MBCartVect *hex_corners,
-                              double etol);
-                              double etol);
-    //wrapper to hex_findpt
-  void nat_coords_trilinear_hex2(const MBCartVect* hex_corners,
-                                 MBCartVect& xi,
-                                 double til);
-  void hex_findpt(double *xm[3],
-                  int n,
-                  MBCartVect xyz,
-                  MBCartVect& rst,
-                  double& dist);
-  void hex_eval(double *field,
-		int n,
-		MBCartVect rst,
-		double &value);
Modified: MOAB/trunk/tools/mbcoupler/Makefile.am
--- MOAB/trunk/tools/mbcoupler/Makefile.am	2009-04-17 16:49:56 UTC (rev 2835)
+++ MOAB/trunk/tools/mbcoupler/Makefile.am	2009-04-17 19:44:02 UTC (rev 2836)
@@ -14,7 +14,6 @@
 endif
 libmbcoupler_la_SOURCES = \
-   MBElemUtil.cpp \
    poly.c   \
    poly.h   \
    tensor.c \
@@ -29,7 +28,6 @@
    MBCoupler.cpp
 libmbcoupler_la_include_HEADERS = \
-   MBElemUtil.hpp \
    MBCoupler.hpp
 libmbcoupler_la_includedir = $(includedir)
