[MOAB-dev] Problems with MOAB not finding hdf5
    Tim Tautges
    tautges at mcs.anl.gov
    Thu Apr 16 15:32:36 CDT 2009
No, not important, though I should remember to put this info in the FAQ.
- tim
Jason Kraftcheck wrote:
> Tim Tautges wrote:
>> Jason, is there any way of checking for that library before checking for
>> hdf5?  Or, do we not want to do that because we might have a
>> locally-built hdf5 w/o szip?
> SZIP is not free, HDF5 libraries shipped by linux distributions are built
> w/out it, etc.  So I think it will be common enough that people won't have it.
> The way the configure script works now is to:
>   a) try linking with HDF5 library to verify that it is link-able
>   b) if that fails, try again with "-lszip"
> This will fairly robustly determine if the HDF5 library is usable.  The
> failure was in no way unique to MOAB.  If you download pre-compiled HDF5
> libraries and don't have libszip, then it will not be possible to link those
> HDF5 libraries into any application (they're broken.)
> If MOAB users frequently encounter this error, it might be helpful to print
> a more informative diagnostic.  I'm not familiar with any autoconf mechanism
> to test for required libraries if those libraries are not present on the
> system (i.e. any way other than how we do it know.)  I could spend some time
> trying to come up with a portable method of doing so if you think this is
> important.
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
