[MOAB-dev] r2795 - in MOAB/trunk/mhdf: . example include src
    kraftche at cae.wisc.edu
    Thu Apr  2 13:45:32 CDT 2009
Author: kraftche
Date: 2009-04-02 13:45:32 -0500 (Thu, 02 Apr 2009)
New Revision: 2795
Added:
   MOAB/trunk/mhdf/example/info.c
   MOAB/trunk/mhdf/src/file-desc.c
   MOAB/trunk/mhdf/src/file-desc.h
Modified:
   MOAB/trunk/mhdf/Makefile.am
   MOAB/trunk/mhdf/include/mhdf.h
   MOAB/trunk/mhdf/src/connectivity.c
   MOAB/trunk/mhdf/src/nodes.c
   MOAB/trunk/mhdf/src/sets.c
   MOAB/trunk/mhdf/src/util.c
   MOAB/trunk/mhdf/src/util.h
Log:
o Add new function: mhdf_getFileSummary
   - reads summary of file contents
   - returns summary in a single block of memory for easy copy/send/bcast, etc.
o Add new function: mhdf_fixFileDesc
   - fix copy of struct returned by mhdf_getFileSummary, updating
     internal pointers using offset from original struct start.
o Add new functions that open tables w/out reading attributes.
o Add utility (h5minfo) that calls mhdf_getFileSummary for a file
    and prints the results.
Modified: MOAB/trunk/mhdf/Makefile.am
--- MOAB/trunk/mhdf/Makefile.am	2009-04-01 20:44:55 UTC (rev 2794)
+++ MOAB/trunk/mhdf/Makefile.am	2009-04-02 18:45:32 UTC (rev 2795)
@@ -1,10 +1,12 @@
 noinst_LTLIBRARIES = libmhdf.la
 libmhdf_la_LIBADD = $(HDF5_LIBS)
+bin_PROGRAMS = h5minfo
 libmhdf_la_SOURCES = include/mhdf.h \
                      src/adjacency.c \
                      src/connectivity.c \
+                     src/file-desc.c \
                      src/file-handle.c \
                      src/file-handle.h \
                      src/file.c \
@@ -17,6 +19,10 @@
                      src/util.c \
                      src/util.h
+h5minfo_SOURCES = include/mhdf.h example/info.c
+h5minfo_LDADD = libmhdf.la
 DEFS = -I$(srcdir)/include
 EXTRA_DIST = doc/Doxyfile example/hexes_to_gmsh.c
Added: MOAB/trunk/mhdf/example/info.c
--- MOAB/trunk/mhdf/example/info.c	                        (rev 0)
+++ MOAB/trunk/mhdf/example/info.c	2009-04-02 18:45:32 UTC (rev 2795)
@@ -0,0 +1,245 @@
+#include "mhdf.h"
+#include <stdlib.h>
+#include <stdio.h>
+#include <string.h>
+#include <ctype.h>
+#include <H5Tpublic.h>
+static int print_file_summary( struct mhdf_FileDesc* data );
+int main( int argc, char* argv[] )
+  int result;
+  mhdf_FileHandle file;
+  mhdf_Status status;
+  unsigned long max_id;
+  struct mhdf_FileDesc* data;
+  if (argc != 2) {
+    fprintf( stderr,"Usage: %s <filename>\n", argv[0] );
+    return 1;
+  file = mhdf_openFile( argv[1], 0, &max_id, &status );
+  if (mhdf_isError( &status )) {
+    fprintf( stderr,"%s: %s\n", argv[1], mhdf_message( &status ) );
+    return 1;
+  data = mhdf_getFileSummary( file, H5T_NATIVE_ULONG, &status );
+    return 1;
+  mhdf_closeFile( file, &status );
+  printf( "%s:\n", argv[1] );
+  result = print_file_summary( data );
+  free( data );
+  return result;
+static void print_ent_desc( const char* name,
+                            const char* subname,
+                            struct mhdf_EntDesc* data,
+                            const char* vals_label,
+                            struct mhdf_FileDesc* all )
+  int i, len = 10;
+  if (vals_label && strlen(vals_label) > len)
+    len = strlen(vals_label);
+  if (subname)
+    printf( "    %s (%s):\n", name, subname );
+  else
+    printf( "    %s:\n", name );
+  if (vals_label)
+    printf( "      %-*s: %d\n", len, vals_label, data->vals_per_ent );
+  printf( "      %-*s: %ld [%ld - %ld]\n", len, "entities", data->count, data->start_id, data->start_id + data->count - 1 );
+  if (!data->num_dense_tags)
+    return;
+  printf( "      %-*s: \"%s\"", len, "dense tags", all->tags[data->dense_tag_indices[0]].name );
+  for (i = 1; i < data->num_dense_tags; ++i)
+    printf( ", \"%s\"", all->tags[data->dense_tag_indices[i]].name );
+  printf ("\n");
+static void print_elem_desc( struct mhdf_ElemDesc* data, struct mhdf_FileDesc* all )
+  print_ent_desc( data->handle, data->type, &data->desc, "nodes per element", all );
+static const char* tag_type_name( enum mhdf_TagDataType type )
+  static const char opaque[] = "opaque";
+  static const char integer[] = "integer";
+  static const char real[] = "real";
+  static const char bits[] = "bit field";
+  static const char boolean[] = "boolean";
+  static const char id[] = "entity id";
+  static const char unknown[] = "(UNKNOWN TYPE ID)";
+  switch (type) {
+    case mhdf_OPAQUE:    return opaque;
+    case mhdf_INTEGER:   return integer;
+    case mhdf_FLOAT:     return real;
+    case mhdf_BITFIELD:  return bits;
+    case mhdf_BOOLEAN:   return boolean;
+    case mhdf_ENTITY_ID: return id;
+    default:             return unknown;
+  return unknown;
+static const char* string_tag_value( const void* value,
+                                     enum mhdf_TagDataType type,
+                                     int size )
+  static char buffer[1024];
+  const char* data = value;
+  char* offset = buffer;
+  int print, i;
+  const int* intptr = value;
+  const double* dblptr = value;
+  const unsigned long* idptr = value;
+  if (size <= 0) {
+    *buffer = '\0';
+    return buffer;
+  switch (type) {
+    case mhdf_OPAQUE:
+      print = 1;
+      for (i = 0; i < size; ++i)
+        if (!isprint(data[i]))
+          print = 0;
+      if (print) {
+        offset[0] = '"';
+        memcpy( offset+1, data, size );
+        offset[size+1] = '"';
+        offset[size+2] = '\0';
+        offset += size+2;
+      else {
+        strcpy( offset, "0x" );
+        offset += 2;
+          offset += sprintf( offset, "%02x", (unsigned int)data[i] );
+      break;
+      if (size == 1) {
+        offset += sprintf( offset, "%d", intptr[0] );
+      else {
+        offset += sprintf( offset, "{%d", intptr[0] );
+        for (i = 1; i < size; ++i)
+          offset += sprintf( offset, ",%d", intptr[i] );
+        offset += sprintf( offset, "}" );
+      break;
+    case mhdf_FLOAT:
+      if (size == 1) {
+        offset += sprintf( offset, "%g", dblptr[0] );
+      else {
+        offset += sprintf( offset, "{%g", dblptr[0] );
+          offset += sprintf( offset, ",%g", dblptr[i] );
+      break;
+      if (size > 8)
+        offset += sprintf( offset, "(more than 8 bits)" );
+      else {
+        for (i = size - 1; i >= 0; --i)
+          *(offset++) = *data & (1<<i) ? '1' : '0';
+        *offset = '\0';
+      break;
+      if (size == 1) {
+        offset += sprintf( offset, "%s", data[0] ? "true" : "false" );
+      else {
+        offset += sprintf( offset, "{%s", data[0] ? "true" : "false" );
+          offset += sprintf( offset, ",%s", data[i] ? "true" : "false" );
+      break;
+      if (size == 1) {
+        offset += sprintf( offset, "%ld", idptr[0] );
+      else {
+        offset += sprintf( offset, "{%ld", idptr[0] );
+          offset += sprintf( offset, ",%ld", idptr[i] );
+      break;
+    default:
+      strcpy( buffer, "(unknown data type)" );
+      break;
+  return buffer;
+static void print_tag_desc( struct mhdf_TagDesc* data, struct mhdf_FileDesc* all )
+  int i, width = 8;
+  printf( "    \"%s\":\n", data->name );
+  printf( "      %-*s: %s\n", width, "type", tag_type_name( data->type ) );
+  if (data->size < 0)
+    printf( "      %-*s: (variable)\n", width, "size" );
+  else
+    printf( "      %-*s: %d (%d bytes)\n", width, "size", data->size, data->bytes );
+  printf( "      %-*s: %x\n", width, "flags", data->storage );
+  if (data->default_value)
+    printf( "      %-*s: %s\n", width, "default",
+      string_tag_value( data->default_value, data->type, data->default_value_size ) );
+  if (data->global_value)
+    printf( "      %-*s: %s\n", width, "mesh val",
+      string_tag_value( data->global_value, data->type, data->global_value_size ) );
+  if (data->have_sparse) {
+    printf( "      %-*s: (sparse)", width, "tables" );
+    for (i = 0; i < data->num_dense_indices; ++i)
+      printf( ", %s", all->elems[data->dense_elem_indices[i]].handle );
+  else if (data->num_dense_indices) {
+    printf( "      %-*s: %s", width, "tables", all->elems[data->dense_elem_indices[0]].handle );
+    for (i = 1; i < data->num_dense_indices; ++i)
+  else {
+    printf( "      %-*s: (none)", width, "tables" );
+  printf( "\n" );
+  int i;
+  printf( "  Entities:\n" );
+  print_ent_desc( "Nodes", NULL, &data->nodes, "dimension", data );
+  for (i = 0; i < data->num_elem_desc; ++i)
+    print_elem_desc( data->elems + i, data );
+  print_ent_desc( "Sets", NULL, &data->sets, NULL, data );
+  printf( "  Tags:\n" );
+  for (i = 0; i < data->num_tag_desc; ++i)
+    print_tag_desc( data->tags + i, data );
+  return 0;
Modified: MOAB/trunk/mhdf/include/mhdf.h
--- MOAB/trunk/mhdf/include/mhdf.h	2009-04-01 20:44:55 UTC (rev 2794)
+++ MOAB/trunk/mhdf/include/mhdf.h	2009-04-02 18:45:32 UTC (rev 2795)
@@ -209,6 +209,76 @@
                       hid_t options,
                       mhdf_Status* status );
+/** Data common to sets, nodes, and each element type */
+struct mhdf_EntDesc {
+  long start_id;           /**< First file ID for table of data */
+  long count;              /**< Number of entities in table */
+  int vals_per_ent;        /**< Connectivity length for elems, dimension for verts, unused for sets */
+  int* dense_tag_indices;  /**< Indices into mhdf_FileDesc::tags for each tag for which dense data is present for these entities */
+  int num_dense_tags;      /**< Length of dense_tag_indices */
+/** Struct describing a tag */
+struct mhdf_TagDesc {
+  const char* name;           /**< Tag name */
+  enum mhdf_TagDataType type; /**< Data type */
+  int size;                   /**< Tag size (num of data type) */
+  int bytes;                  /**< Tag size (number of bytes) */
+  int storage;                /**< MOAB tag type (dense or sparse) */
+  int have_sparse;            /**< Have sparse id/data pairs in file */
+  void* default_value;        /**< Default value, NULL if none. */
+  int default_value_size;
+  void* global_value;         /**< Global value, NULL if none. */
+  int global_value_size;
+  int* dense_elem_indices;    /**< Array of indices indicating element types for which dense
+                                   data is stored.  -2 for sets, -1 for nodes. */
+  int num_dense_indices;
+struct mhdf_ElemDesc {
+  const char* handle;       /**< String table identifier */
+  const char* type;         /**< String type designator */
+  struct mhdf_EntDesc desc;
+struct mhdf_FileDesc {
+  struct mhdf_EntDesc nodes;
+  struct mhdf_EntDesc sets;
+  struct mhdf_ElemDesc* elems; /**< Array of element table descriptions */
+  int num_elem_desc;
+  struct mhdf_TagDesc* tags;   /**< Array of tag descriptions */
+  int num_tag_desc;
+  size_t total_size;           /**< Size of memory block containing all struct data */
+  unsigned char* offset;       /**< Unused, may be used by application */
+/** \brief Get summary of data tables contained within file.
+ * Returned struct, including all pointed-to data, is allocated in a
+ * single contiguous block of memory with a size equal to 'total_size'.
+ * Caller is responsible for freeing the returned struct FileDesc pointer
+ * (and *only* that pointer, not pointers nexted within the struct!).
+ * Caller may copy (e.g. MPI_BCast) entire struct as one contiguous block,
+ * assuming all nested pointers in the copy are updated to the correct
+ * relative offset from the beginning of the struct.
+struct mhdf_FileDesc*
+mhdf_getFileSummary( mhdf_FileHandle file_handle,
+                     hid_t file_id_type,
+                     mhdf_Status* status );
+/**\brief Fix nested pointers for copied/moved FileDesc struct
+ * This is a utility method to facility copying/moving/communicating
+ * struct FileDesc instances.  The structure and all data it references
+ * are allocated in a single contiguous block of memory of size
+ * FileDesc::total_size.  As such, the struct can be copied with a single
+ * memcpy, packed into a single network packet, communicated with a single
+ * MPI call, etc.  However, the pointers contained within the struct will
+ * not be valid in the copied instance (they will still point into the
+ * original instance.)  Given a pointer to the copied struct and the address
+ * of the original struct, this function will updated all contained pointers.
+void
+mhdf_fixFileDesc( struct mhdf_FileDesc* copy_ptr, const struct mhdf_FileDesc* orig_addr );
 /** \brief Given an element type Id, get the name.
  * Fails if buffer is not of sufficient size.
  * \param file_handle The file.
@@ -326,6 +396,9 @@
                      long* first_node_id_out,
+hid_t
+mhdf_openNodeCoordsSimple( mhdf_FileHandle file_handle, mhdf_Status* status );
 /** \brief Write node coordinate data
  * Write interleaved coordinate data for a block of nodes
@@ -595,6 +668,12 @@
                        long* first_elem_id_out,
+hid_t
+mhdf_openConnectivitySimple( mhdf_FileHandle file_handle,
+                             const char* elem_handle,
 /** \brief Write element coordinate data
  * Write interleaved fixed-connectivity element data for a block of elements.
@@ -1202,6 +1281,9 @@
                   long* first_set_id_out,
+hid_t
+mhdf_openSetMetaSimple( mhdf_FileHandle file_handle, mhdf_Status* status );
 /** \brief Read list of sets and meta-information about sets.
  * Read set descriptions.  See \ref mhdf_createSetMeta or \ref mhdf_set
Modified: MOAB/trunk/mhdf/src/connectivity.c
--- MOAB/trunk/mhdf/src/connectivity.c	2009-04-01 20:44:55 UTC (rev 2794)
+++ MOAB/trunk/mhdf/src/connectivity.c	2009-04-02 18:45:32 UTC (rev 2795)
@@ -130,6 +130,34 @@
   return table_id;
+hid_t
+  FileHandle* file_ptr;
+  hid_t elem_id, table_id;
+  API_BEGIN;
+  file_ptr = (FileHandle*)(file_handle);
+  if (!mhdf_check_valid_file( file_ptr, status ))
+    return -1;
+  elem_id = mhdf_elem_group_from_handle( file_ptr, elem_handle, status );
+  if (elem_id < 0) return -1;
+  table_id = mhdf_open_table_simple( elem_id, CONNECTIVITY_NAME, status );
+  H5Gclose( elem_id );
+  if (table_id < 0)
+    return -1;
+  file_ptr->open_handle_count++;
+  mhdf_setOkay( status );
+  API_END_H(1);
+  return table_id;
 void
 mhdf_writeConnectivity( hid_t table_id,
                         long offset,
Added: MOAB/trunk/mhdf/src/file-desc.c
--- MOAB/trunk/mhdf/src/file-desc.c	                        (rev 0)
+++ MOAB/trunk/mhdf/src/file-desc.c	2009-04-02 18:45:32 UTC (rev 2795)
@@ -0,0 +1,518 @@
+#include "mhdf.h"
+#include "util.h"
+#include "status.h"
+#include <assert.h>
+static struct mhdf_FileDesc* alloc_file_desc( mhdf_Status* status );
+static void* realloc_data( struct mhdf_FileDesc** data, size_t append_bytes, mhdf_Status* status );
+static char buffer[512];
+  struct mhdf_FileDesc* result;
+  /* allocate a little short of a page */
+  result = (struct mhdf_FileDesc*)mhdf_malloc(4000, status);
+  if (mhdf_isError( status ))
+    return 0;
+  memset( result, 0, sizeof(struct mhdf_FileDesc) );
+  result->total_size = 4000;
+  result->offset = ((char*)result) + sizeof(struct mhdf_FileDesc);
+  return result;
+  void* result_ptr;
+  struct mhdf_FileDesc* const input_ptr = *data;
+  unsigned char* const mem_ptr = (unsigned char*)input_ptr;
+  size_t new_size;
+  if (mem_ptr + input_ptr->total_size < input_ptr->offset + append_bytes) {
+    if (append_bytes < input_ptr->total_size)
+      new_size = 2 * input_ptr->total_size;
+    else
+      new_size = input_ptr->total_size + append_bytes;
+    *data = (struct mhdf_FileDesc*)mhdf_realloc( *data, new_size, status );
+      return 0;
+    if (*data != input_ptr)
+      mhdf_fixFileDesc( *data, input_ptr );
+  result_ptr = input_ptr->offset;
+  input_ptr->offset += append_bytes;
+  return result_ptr;
+#define FIX_OFFSET( TYPE, FIELD ) \
+  copy_ptr->FIELD = (TYPE)( ((char*)(copy_ptr->FIELD) - (char*)orig_addr) + (char*)copy_ptr )
+void
+  int i;
+  API_BEGIN;
+  FIX_OFFSET( int*, nodes.dense_tag_indices );
+  FIX_OFFSET( int*, sets.dense_tag_indices );
+  FIX_OFFSET( struct mhdf_ElemDesc*, elems );
+  FIX_OFFSET( struct mhdf_TagDesc*, tags );
+  for (i = 0; i < copy_ptr->num_elem_desc; ++i) {
+    FIX_OFFSET( const char*, elems[i].handle );
+    FIX_OFFSET( const char*, elems[i].type );
+    FIX_OFFSET(        int*, elems[i].desc.dense_tag_indices );
+  for (i = 0; i < copy_ptr->num_tag_desc; ++i) {
+    FIX_OFFSET( const char*, tags[i].name );
+    FIX_OFFSET(       void*, tags[i].default_value );
+    FIX_OFFSET(       void*, tags[i].global_value );
+    FIX_OFFSET(        int*, tags[i].dense_elem_indices );
+  API_END;
+static
+get_elem_desc( mhdf_FileHandle file_handle,
+               struct mhdf_FileDesc* result,
+               int index,
+  hid_t id_pair[2];
+  int poly;
+  void* ptr;
+  long junk;
+  ptr = realloc_data( &result, strlen(elem_handle)+1, status );
+  if (!ptr) return NULL;
+  strcpy( ptr, elem_handle );
+  result->elems[index].handle = ptr;
+  mhdf_getElemTypeName( file_handle, elem_handle,
+                        buffer, sizeof(buffer), status );
+  if (mhdf_isError(status)) {
+    free( result );
+    return NULL;
+  ptr = realloc_data( &result, strlen(buffer)+1, status );
+  strcpy( ptr, buffer );
+  result->elems[index].type = ptr;
+  poly = mhdf_isPolyElement( file_handle, elem_handle, status );
+    free( result );
+    return NULL;
+  if (!poly) {
+    id_pair[0] = mhdf_openConnectivity( file_handle,
+                                      elem_handle,
+                                      &result->elems[index].desc.vals_per_ent,
+                                      &result->elems[index].desc.count,
+                                      &result->elems[index].desc.start_id,
+                                      status );
+    if (id_pair[0] < 0) {
+      free( result );
+      return NULL;
+    mhdf_closeData( file_handle, id_pair[0], status );
+  else {
+    result->elems[index].desc.vals_per_ent = -1;
+    mhdf_openPolyConnectivity( file_handle,
+                               elem_handle,
+                               &junk,
+                               id_pair,
+                               status );
+      free( result );
+      return NULL;
+    mhdf_closeData( file_handle, id_pair[1], status );
+  result->elems[index].desc.dense_tag_indices = NULL;
+  result->elems[index].desc.num_dense_tags = 0;
+  return result;
+static
+unsigned get_file_id_size( hid_t file_id_type, mhdf_Status* status )
+  if (H5Tget_class( file_id_type ) != H5T_INTEGER) {
+    mhdf_setFail( status, "Invalid handle or type class for file ID type." );
+    return 0;
+  return H5Tget_size( file_id_type );
+static
+get_tag_desc( mhdf_FileHandle file_handle,
+              const char* name,
+              int index,
+              hid_t type,
+  void* ptr;
+  int have_default, have_global;
+  int valsize, size;
+  ptr = realloc_data( &result, strlen(name)+1, status );
+  if (NULL == ptr) return NULL;
+  strcpy( ptr, name );
+  result->tags[index].name = ptr;
+  mhdf_getTagInfo( file_handle,
+                   name,
+                   &result->tags[index].type,
+                   &result->tags[index].size,
+                   &result->tags[index].storage,
+                   &have_default,
+                   &have_global,
+                   &result->tags[index].have_sparse,
+                   status );
+    free( result );
+    return NULL;
+  /* For variable lengt tags, have_default and have_global will
+     contain the size of the respective values.  For fixed-length
+     tags, they are either zero or one.  Simplify later code by
+     making them contain the size for both cases. */
+  valsize = result->tags[index].size;
+  if (result->tags[index].size >= 0) {
+    if (have_default)
+      have_default = valsize;
+    if (have_global)
+      have_global = valsize;
+  result->tags[index].default_value = NULL;
+  result->tags[index].default_value_size = have_default;
+  result->tags[index].global_value  = NULL;
+  result->tags[index].global_value_size = have_global;
+  switch (result->tags[index].type) {
+    case mhdf_OPAQUE:
+      type = 0;
+      break;
+      type = H5T_NATIVE_UCHAR;
+      break;
+      type = H5T_INTEGER;
+      have_default *= sizeof(int);
+      have_global *= sizeof(int);
+      valsize *= sizeof(int);
+      break;
+    case mhdf_FLOAT:
+      type = H5T_NATIVE_DOUBLE;
+      have_default *= sizeof(double);
+      have_global *= sizeof(double);
+      valsize *= sizeof(double);
+      break;
+      have_default = (have_default+7)/8;
+      have_global = (have_global+7)/8;
+      valsize = (valsize+7)/8;
+      switch (valsize) {
+      case 1:
+        type = H5Tcopy( H5T_NATIVE_B8 );
+        break;
+      case 2:
+        type = H5Tcopy( H5T_NATIVE_B16 );
+        break;
+      case 3:
+        ++valsize;
+      case 4:
+        type = H5Tcopy( H5T_NATIVE_B32 );
+        break;
+      case 5:
+        ++valsize;
+      case 6:
+        ++valsize;
+      case 7:
+        ++valsize;
+      case 8:
+        type = H5Tcopy( H5T_NATIVE_B64 );
+        break;
+      default:
+        free( result );
+        mhdf_setFail( status, "Cannot create a bit tag larger than 64-bits.  %d bits requested.\n", (int)valsize);
+        return NULL;
+      break;
+      if (0 == type)
+        type = H5T_NATIVE_ULONG;
+      size = get_file_id_size( type, status );
+      if (!size) {
+        free( result );
+        return NULL;
+      have_default *= size;
+      have_global *= size;
+      valsize *= size;
+      break;
+    default:
+      mhdf_setFail( status, "Unknown mhdf_TagDataType value (%d) for tag (\"%s\")",
+                    (int)result->tags[index].type, name );
+      free( result );
+      return NULL;
+  result->tags[index].bytes = valsize;
+  if (have_default || have_global) {
+    if (have_default) {
+      ptr = realloc_data( &result, have_default, status );
+      if (NULL == ptr) {
+        if (result->tags[index].type == mhdf_BITFIELD)
+          H5Tclose( type );
+        return NULL;
+      result->tags[index].default_value = ptr;
+    if (have_global) {
+      ptr = realloc_data( &result, have_global, status );
+          H5Tclose( type );
+        return NULL;
+      result->tags[index].global_value = ptr;
+    mhdf_getTagValues( file_handle,
+                       name,
+                       type,
+                       result->tags[index].default_value,
+                       result->tags[index].global_value,
+                       status );
+      H5Tclose( type );
+      free( result );
+      return NULL;
+  return result;
+  hid_t table_id;
+  int i, j, k, size, *indices;
+  void* ptr;
+  char **elem_handles = 0, **tag_names = 0;
+  unsigned char *array, *matrix;
+  API_BEGIN;
+  result = alloc_file_desc( status );
+  if (NULL == result) return NULL;
+    /* get node info */
+  table_id = mhdf_openNodeCoords( file_handle,
+                                  &result->nodes.count,
+                                  &result->nodes.vals_per_ent,
+                                  &result->nodes.start_id,
+                                  status );
+  if (table_id < 0) {
+    free( result );
+    return NULL;
+  mhdf_closeData( file_handle, table_id, status );
+    /* get set info */
+  result->sets.vals_per_ent = -1;
+  table_id = mhdf_openSetMeta( file_handle,
+                               &result->sets.count,
+                               &result->sets.start_id,
+                               status );
+    free( result );
+    return NULL;
+    /* get element list */
+  elem_handles = mhdf_getElemHandles( file_handle,
+                                      &result->num_elem_desc,
+                                      status );
+  if (elem_handles == NULL) {
+    free( result );
+    return NULL;
+    /* allocate array of element descriptors */
+  size = result->num_elem_desc * sizeof(struct mhdf_ElemDesc);
+  ptr = realloc_data( &result, size, status );
+    free( elem_handles );
+    return NULL;
+  memset( ptr, 0, size );
+  result->elems = ptr;
+    /* Initialize each element descriptor */
+  for (i = 0; i < result->num_elem_desc; ++i) {
+    result = get_elem_desc( file_handle, result, elem_handles[i], i, status );
+    if (NULL == result) {
+      return NULL;
+    /* get tag list */
+  tag_names = mhdf_getTagNames( file_handle, &result->num_tag_desc, status );
+  if (tag_names == NULL) {
+    free( result );
+    return NULL;
+    /* allocate array of tag descriptors */
+  size = result->num_tag_desc * sizeof(struct mhdf_TagDesc);
+    free( tag_names );
+    return NULL;
+  result->tags = ptr;
+    /* Initialize each tag descriptor */
+  for (i = 0; i < result->num_tag_desc; ++i) {
+    result = get_tag_desc( file_handle, result, tag_names[i], i, file_id_type, status );
+      return NULL;
+    /* Determine which dense tags are present */
+  size = (2 + result->num_elem_desc) * result->num_tag_desc;
+  array = mhdf_malloc( size, status );
+  if (NULL == array) {
+    free( result );
+    return NULL;
+  memset( array, 0, size );
+  matrix = array + (2 * result->num_tag_desc);
+  for (j = 0; j < result->num_tag_desc; ++j) {
+    if (mhdf_haveDenseTag( file_handle, tag_names[j], mhdf_node_type_handle(), status ))
+      matrix[-1*result->num_tag_desc+j] = 1;
+    if (mhdf_haveDenseTag( file_handle, tag_names[j], mhdf_set_type_handle(), status ))
+      matrix[-2*result->num_tag_desc+j] = 1;
+      if (mhdf_haveDenseTag( file_handle, tag_names[j], elem_handles[i], status ))
+        matrix[i*result->num_tag_desc+j] = 1;
+    /* Populate dense tag lists for element types */
+  for (i = -2; i < result->num_elem_desc; ++i) {
+    size = 0;
+      size += matrix[i*result->num_tag_desc+j];
+    if (!size) {
+      indices = NULL;
+    else {
+      indices = realloc_data( &result, size*sizeof(int), status );
+      if (NULL == indices) {
+        free( array );
+        return NULL;
+      k = 0;
+        if (matrix[i*result->num_tag_desc+j])
+          indices[k++] = j;
+      assert( k == size );
+    if (i == -2) {
+      result->sets.dense_tag_indices = indices;
+      result->sets.num_dense_tags = size;
+    else if (i == -1) {
+      result->nodes.dense_tag_indices = indices;
+      result->nodes.num_dense_tags = size;
+    else {
+      result->elems[i].desc.dense_tag_indices = indices;
+      result->elems[i].desc.num_dense_tags = size;
+    /* Populate dense tag lists for each tag */
+    size = 0;
+    if (!size) {
+      indices = 0;
+    else {
+        free( array );
+        return NULL;
+      k = 0;
+          indices[k++] = i;
+    result->tags[i].num_dense_indices = size;
+    result->tags[i].dense_elem_indices = indices;
+    /* Compact memory and return */
+  free( array );
+  result->total_size = result->offset - (unsigned char*)result;
+  API_END;
+  return result;
Added: MOAB/trunk/mhdf/src/file-desc.h
--- MOAB/trunk/mhdf/src/file-desc.h	                        (rev 0)
+++ MOAB/trunk/mhdf/src/file-desc.h	2009-04-02 18:45:32 UTC (rev 2795)
@@ -0,0 +1,479 @@
+#include "mhdf.h"
+#include "util.h"
+    return 0;
+  offset = ((char*)result) + sizeof(struct mhdf_FileDesc);
+  return result;
+  void* result_ptr;
+  unsigned char* new_mem_ptr;
+  size_t new_size;
+  if (mem_ptr + total_size < input_ptr->offset + append_bytes) {
+    if (append_bytes < inputptr->total_size)
+    else
+      return 0;
+  copy_ptr->(FIELD) = (TYPE)( ((char*)(copy_ptr->(FIELD)) - (char*)orig_addr) + (char*)copy_ptr )
+void
+mhdf_fixFileDesc( struct FileDesc* copy_ptr, const struct FileDesc* orig_addr )
+  int i;
+  API_BEGIN;
+  FIX_OFFSET( const struct mhdf_ElemDesc*, elems );
+  FIX_OFFSET( const struct mhdf_TagDesc*, tags );
+    FIX_OFFSET( const  int*, elems[i].dense_tag_indices );
+    FIX_OFFSET( const  int*, tags[i].dense_elem_indices );
+  API_END;
+static
+               int index,
+  hid_t id_pair[2];
+  int poly;
+  void* ptr;
+  long junk;
+  result->elems[index]->handle = ptr;
+    free( result );
+    return NULL;
+  result->elems[index]->type = ptr;
+    free( result );
+    return NULL;
+  if (!poly) {
+    id_pair[0] = mhdf_OpenConnectivity( file_handle,
+                                      elem_handle,
+                                      &result->elems[index].conn_len,
+                                      &result->elems[index].count,
+                                      &result->elems[index].start_id,
+                                      status );
+      free( result );
+      return NULL;
+  else {
+    result->elems[index].conn_len = -1;
+                               elem_handle,
+                               &junk,
+                               id_pair[2],
+                               status );
+      free( result );
+      return NULL;
+  result->elems[index].dense_tag_indices = NULL;
+  result->elems[index].num_dense_indices = 0;
+  return result;
+static
+    return 0;
+static
+              const char* name,
+              int index,
+              hid_t type,
+  void* ptr;
+  int have_default, have_global, have_sparse;
+  int valsize;
+  result->tags[index]->name = ptr;
+                   name,
+                   &have_default,
+                   &have_global,
+                   status );
+    free( result );
+    return NULL;
+  valsize = tags[index].size;
+    if (have_default)
+    if (have_global)
+    case mhdf_OPAQUE:
+      type = 0;
+      break;
+      type = H5T_UNSIGNED_CHAR;
+      break;
+      break;
+    case mhdf_FLOAT:
+      type = H5T_DOUBLE;
+      break;
+      if (size <= 8)
+        hdf_type = H5Tcopy( H5T_NATIVE_B8 );
+      else if (size <= 16)
+        hdf_type = H5Tcopy( H5T_NATIVE_B16 );
+      else if (size <= 32)
+        hdf_type = H5Tcopy( H5T_NATIVE_B32 );
+      else if (size <= 64)
+        hdf_type = H5Tcopy( H5T_NATIVE_B64 );
+      else
+        free( result );
+        mhdf_setFail( status, "Cannot create a bit tag larger than 64-bits.  %d bits requested.\n", (int)size);
+        return NULL;
+      break;
+      if (0 == type)
+      if (!size) {
+        free( result );
+        return NULL;
+      valsize *= size;
+      break;
+    default:
+      free( result );
+      return NULL;
+          H5Tclose( type );
+        return NULL;
+          H5Tclose( type );
+        return NULL;
+                       name,
+                       type,
+                       status );
+      H5Tclose( type );
+      free( result );
+      return NULL;
+  return result;
+  hid_t table_id;
+  int i, j, k, size;
+  void* ptr;
+  unsigned char* array;
+  API_BEGIN;
+                                  &result->node_count,
+                                  &result->node_dim,
+                                  &result->node_start_id,
+                                  status );
+    free( result );
+    return NULL;
+                               &result->set_count,
+                               &status );
+    free( result );
+    return NULL;
+                                      status );
+    free( result );
+    return NULL;
+    return NULL;
+      return NULL;
+    free( result );
+    return NULL;
+    return NULL;
+      return NULL;
+  size = result->num_elem_desc * result->num_tag_desc;
+    free( result );
+    return NULL;
+      if (mhdf_haveDenseTag( file_hanlde, tag_names[j], elem_handles[i], status ))
+        array[i*result->num_tag_desc+j] = 1;
+    size = 0;
+      size += array[i*result->num_tag_desc+j];
+    if (!size)
+      continue;
+    ptr = realloc_data( &result, size*sizeof(int), status );
+      free( array );
+      return NULL;
+    result->elems[i].num_dense_indices = size;
+    result->elems[i].dense_tag_indices = ptr;
+    k = 0;
+      if (array[i*result->num_tag_desc+j])
+        result->elems[i].dense_tag_indices[k++] = j;
+    size = 0;
+    if (!size)
+      continue;
+      free( array );
+      return NULL;
+    result->tags[i].dense_elem_indices = ptr;
+    k = 0;
+        result->tags[i].dense_elem_indices[k++] = i;
+  free( array );
+  result->total_size = offset - (unsigned char*)result;
+  API_END;
+  return result;
Modified: MOAB/trunk/mhdf/src/nodes.c
--- MOAB/trunk/mhdf/src/nodes.c	2009-04-01 20:44:55 UTC (rev 2794)
+++ MOAB/trunk/mhdf/src/nodes.c	2009-04-02 18:45:32 UTC (rev 2795)
@@ -109,6 +109,26 @@
   return table_id;
+hid_t
+  FileHandle* file_ptr = (FileHandle*)file_handle;
+  hid_t table_id;
+  API_BEGIN;
+    return -1;
+  table_id = mhdf_open_table_simple( file_ptr->hdf_handle,
+                                     NODE_COORD_PATH, status );
+  if (table_id < 0)
+    return -1;
+  API_END_H(1);
+  return table_id;
 void
 mhdf_writeNodeCoords( hid_t table_id,
Modified: MOAB/trunk/mhdf/src/sets.c
--- MOAB/trunk/mhdf/src/sets.c	2009-04-01 20:44:55 UTC (rev 2794)
+++ MOAB/trunk/mhdf/src/sets.c	2009-04-02 18:45:32 UTC (rev 2795)
@@ -202,6 +202,26 @@
   return table_id;
+hid_t
+mhdf_openSetMetaSimple( mhdf_FileHandle file, mhdf_Status* status )
+  FileHandle* file_ptr = (FileHandle*)file;
+  hid_t table_id;
+  API_BEGIN;
+    return -1;
+                                     SET_META_PATH, status );
+  if (table_id < 0)
+    return -1;
+  API_END_H(1);
+  return table_id;
 static int
 mhdf_readwriteSetMeta( hid_t table_id, int read,
Modified: MOAB/trunk/mhdf/src/util.c
--- MOAB/trunk/mhdf/src/util.c	2009-04-01 20:44:55 UTC (rev 2794)
+++ MOAB/trunk/mhdf/src/util.c	2009-04-02 18:45:32 UTC (rev 2795)
@@ -38,6 +38,15 @@
   return result;
+void* mhdf_realloc( void* ptr, size_t size, mhdf_Status* status )
+  void* result;
+  result = realloc(ptr, size);
+  if (!result)
+    mhdf_setFail( status, "Allocation of %d bytes failed.\n", (int)size );
+  return result;
 size_t mhdf_name_to_path( const char* name, char* path, size_t path_len )
   size_t length = 1;
@@ -681,6 +690,28 @@
   return table_id;
+hid_t
+mhdf_open_table_simple( hid_t group_id, const char* path, mhdf_Status* status )
+  hid_t table_id;
+#if defined(H5Dopen_vers) && H5Dopen_vers > 1
+  table_id = H5Dopen2( group_id, path, H5P_DEFAULT );
+#else
+  table_id = H5Dopen( group_id, path );
+#endif
+  if (table_id < 0)
+    mhdf_setFail( status, "HDF5 DataSet creation failed.");
+  else
+  return table_id;
 static int qs_comp_int ( const void* ptr1, const void* ptr2 )
   const int* left = (const int*)ptr1;
Modified: MOAB/trunk/mhdf/src/util.h
--- MOAB/trunk/mhdf/src/util.h	2009-04-01 20:44:55 UTC (rev 2794)
+++ MOAB/trunk/mhdf/src/util.h	2009-04-02 18:45:32 UTC (rev 2795)
@@ -27,6 +27,7 @@
 void* mhdf_malloc( size_t size, mhdf_Status* status );
+void* mhdf_realloc( void* ptr, size_t size, mhdf_Status* status );
 size_t mhdf_name_to_path( const char* name, char* path, size_t path_len );
@@ -130,6 +131,9 @@
                   long* start_id_out,
+hid_t
+mhdf_open_table_simple( hid_t group, const char* path, mhdf_Status* status );
 int
 mhdf_compact_to_ranges( int* length_in_out, int* ids_in, int ordered );
