[MOAB-dev] r2789 - MOAB/trunk/tools/dagmc
    kraftche at cae.wisc.edu
    Tue Mar 31 15:39:13 CDT 2009
Author: kraftche
Date: 2009-03-31 15:39:12 -0500 (Tue, 31 Mar 2009)
New Revision: 2789
Added:
   MOAB/trunk/tools/dagmc/Makefile.am
Log:
try to recover svn history
Copied: MOAB/trunk/tools/dagmc/Makefile.am (from rev 2785, MOAB/trunk/tools/dagmc/Makefile.am)
--- MOAB/trunk/tools/dagmc/Makefile.am	                        (rev 0)
+++ MOAB/trunk/tools/dagmc/Makefile.am	2009-03-31 20:39:12 UTC (rev 2789)
@@ -0,0 +1,50 @@
+AUTOMAKE_OPTIONS = foreign
+ at CGM_CONFIG_OPTIONS@
+DEFS = $(DEFINES)
+INCLUDES += -I$(top_srcdir) -I$(top_builddir)
+lib_LTLIBRARIES = libdagmc.la
+libdagmc_la_SOURCES = DagMC.cpp
+libdagmc_la_includedir = $(includedir)
+libdagmc_la_include_HEADERS = cgm2moab.hpp cubfile.h DagMC.hpp
+if HAVE_CGM
+INCLUDES += $(CGM_INCLUDES)
+CPPFLAGS += $(CGM_CPPFLAGS) -DCGM $(MOAB_CGM_DEFINES)
+CXXFLAGS += $(CGM_CXXFLAGS)
+libdagmc_la_SOURCES += cgm2moab.cc
+noinst_PROGRAMS = cub2h5m
+bin_PROGRAMS = cgm2moab
+cgm2moab_SOURCES = main.cc cubfile.c
+cgm2moab_LDFLAGS = $(CGM_LTFLAGS)
+cgm2moab_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LIBS_LINK)
+cgm2moab_DEPENDENCIES = libdagmc.la $(top_builddir)/libMOAB.la
+dist_man1_MANS = cgm2moab.man
+endif
+# Automake doesn't seem to have a directory defined for
+# platform-dependent data (or include) files. So put
+# in $(libdir).  Define a $(cfgdir) to get around automake's
+# check that only libraries are going in $(libdir)
+cfgdir = $(libdir)
+cfg_DATA = dagmc.make
+TESTS = test_geom
+check_PROGRAMS = $(TESTS) pt_vol_test ray_fire_test
+test_geom_SOURCES = test_geom.cc
+cub2h5m_SOURCES = cub2h5m.cc
+test_geom_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LTFLAGS)  $(CGM_LIBS_LINK)
+cub2h5m_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LTFLAGS) $(CGM_LIBS_LINK)
+pt_vol_test_SOURCES = pt_vol_test.cc
+pt_vol_test_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LTFLAGS)  $(CGM_LIBS_LINK)
+ray_fire_test_SOURCES = ray_fire_test.cc
+ray_fire_test_LDADD = libdagmc.la $(top_builddir)/libMOAB.la $(CGM_LTFLAGS)  $(CGM_LIBS_LINK)
Property changes on: MOAB/trunk/tools/dagmc/Makefile.am
___________________________________________________________________
   + Author Date Id Revision
   + native
