[MOAB-dev] r2796 - MOAB/trunk/mhdf/src
kraftche at cae.wisc.edu
Thu Apr 2 15:42:35 CDT 2009
Author: kraftche
Date: 2009-04-02 15:42:34 -0500 (Thu, 02 Apr 2009)
New Revision: 2796
Removed:
MOAB/trunk/mhdf/src/file-desc.h
Log:
didn't mean to add this one
Deleted: MOAB/trunk/mhdf/src/file-desc.h
--- MOAB/trunk/mhdf/src/file-desc.h 2009-04-02 18:45:32 UTC (rev 2795)
+++ MOAB/trunk/mhdf/src/file-desc.h 2009-04-02 20:42:34 UTC (rev 2796)
@@ -1,479 +0,0 @@
-#include "mhdf.h"
-#include "util.h"
-#include "status.h"
-#include <assert.h>
-#include <stdlib.h>
-#include <string.h>
-static struct mhdf_FileDesc* alloc_file_desc( mhdf_Status* status );
-static void* realloc_data( struct mhdf_FileDesc** data, size_t append_bytes, mhdf_Status* status );
-static char buffer[512];
- struct mhdf_FileDesc* result;
- /* allocate a little short of a page */
- result = (struct mhdf_FileDesc*)mhdf_malloc(4000, status);
- if (mhdf_isError( status ))
- return 0;
- memset( result, 0, sizeof(struct mhdf_FileDesc) );
- result->total_size = 4000;
- offset = ((char*)result) + sizeof(struct mhdf_FileDesc);
- return result;
- void* result_ptr;
- struct mhdf_FileDesc* const input_ptr = *data;
- unsigned char* const mem_ptr = (unsigned char*)input_ptr;
- unsigned char* new_mem_ptr;
- size_t new_size;
- if (mem_ptr + total_size < input_ptr->offset + append_bytes) {
- if (append_bytes < inputptr->total_size)
- new_size = 2 * input_ptr->total_size;
- else
- new_size = input_ptr->total_size + append_bytes;
- *data = (struct mhdf_FileDesc*)mhdf_realloc( *data, new_size, status );
- return 0;
- if (*data != input_ptr)
- mhdf_fixFileDesc( *data, input_ptr );
- result_ptr = input_ptr->offset;
- input_ptr->offset += append_bytes;
- return result_ptr;
-#define FIX_OFFSET( TYPE, FIELD ) \
- copy_ptr->(FIELD) = (TYPE)( ((char*)(copy_ptr->(FIELD)) - (char*)orig_addr) + (char*)copy_ptr )
-void
-mhdf_fixFileDesc( struct FileDesc* copy_ptr, const struct FileDesc* orig_addr )
- int i;
- API_BEGIN;
- FIX_OFFSET( const struct mhdf_ElemDesc*, elems );
- FIX_OFFSET( const struct mhdf_TagDesc*, tags );
- for (i = 0; i < copy_ptr->num_elem_desc; ++i) {
- FIX_OFFSET( const char*, elems[i].handle );
- FIX_OFFSET( const char*, elems[i].type );
- FIX_OFFSET( const int*, elems[i].dense_tag_indices );
- for (i = 0; i < copy_ptr->num_tag_desc; ++i) {
- FIX_OFFSET( const char*, tags[i].name );
- FIX_OFFSET( void*, tags[i].default_value );
- FIX_OFFSET( void*, tags[i].global_value );
- FIX_OFFSET( const int*, tags[i].dense_elem_indices );
- API_END;
-static
-struct mhdf_FileDesc*
-get_elem_desc( mhdf_FileHandle file_handle,
- struct mhdf_FileDesc* result,
- const char* elem_handle,
- int index,
- mhdf_Status* status )
- hid_t id_pair[2];
- int poly;
- void* ptr;
- long junk;
- ptr = realloc_data( &result, strlen(elem_handle)+1, status );
- if (!ptr) return NULL;
- strcpy( ptr, elem_handle );
- result->elems[index]->handle = ptr;
- mhdf_getElemTypeName( file_handle, elem_handle,
- buffer, sizeof(buffer), status );
- if (mhdf_isError(status)) {
- free( result );
- return NULL;
- ptr = realloc_data( &result, strlen(buffer)+1, status );
- strcpy( ptr, buffer );
- result->elems[index]->type = ptr;
- poly = mhdf_isPolyElement( file_handle, elem_handle, status );
- free( result );
- return NULL;
- if (!poly) {
- id_pair[0] = mhdf_OpenConnectivity( file_handle,
- elem_handle,
- &result->elems[index].conn_len,
- &result->elems[index].count,
- &result->elems[index].start_id,
- status );
- if (id_pair[0] < 0) {
- free( result );
- return NULL;
- mhdf_closeData( file_handle, id_pair[0], status );
- else {
- result->elems[index].conn_len = -1;
- mhdf_openPolyConnectivity( file_handle,
- elem_handle,
- &junk,
- id_pair[2],
- status );
- free( result );
- return NULL;
- mhdf_closeData( file_handle, id_pair[1], status );
- result->elems[index].dense_tag_indices = NULL;
- result->elems[index].num_dense_indices = 0;
- return result;
-static
-unsigned get_file_id_size( hid_t file_id_type, mhdf_Status* status )
- if (H5Tget_class( file_id_type ) != H5T_INTEGER) {
- mhdf_setFail( status, "Invalid handle or type class for file ID type." );
- return 0;
- return H5Tget_size( file_id_type );
-static
-get_tag_desc( mhdf_FileHandle file_handle,
- const char* name,
- int index,
- hid_t type,
- void* ptr;
- int have_default, have_global, have_sparse;
- int valsize;
- ptr = realloc_data( &result, strlen(name)+1, status );
- if (NULL == ptr) return NULL;
- strcpy( ptr, name );
- result->tags[index]->name = ptr;
- mhdf_getTagInfo( file_handle,
- name,
- &result->tags[index].type,
- &result->tags[index].size,
- &result->tags[index].storage,
- &have_default,
- &have_global,
- &result->tags[index].have_sparse,
- status );
- free( result );
- return NULL;
- /* For variable lengt tags, have_default and have_global will
- contain the size of the respective values. For fixed-length
- tags, they are either zero or one. Simplify later code by
- making them contain the size for both cases. */
- valsize = tags[index].size;
- if (result->tags[index].size >= 0) {
- if (have_default)
- have_default = valsize;
- if (have_global)
- have_global = valsize;
- result->tags[index].default_value = NULL;
- result->tags[index].default_value_size = have_default;
- result->tags[index].global_value = NULL;
- result->tags[index].global_value_size = have_global;
- switch (result->tags[index].type) {
- case mhdf_OPAQUE:
- type = 0;
- break;
- case mhdf_BOOLEAN:
- type = H5T_UNSIGNED_CHAR;
- break;
- case mhdf_INTEGER:
- type = H5T_INTEGER;
- have_default *= sizeof(int);
- have_global *= sizeof(int);
- valsize *= sizeof(int);
- break;
- case mhdf_FLOAT:
- type = H5T_DOUBLE;
- have_default *= sizeof(double);
- have_global *= sizeof(double);
- valsize *= sizeof(double);
- break;
- case mhdf_BITFIELD:
- have_default = (have_default+7)/8;
- have_global = (have_global+7)/8;
- valsize = (valsize+7)/8;
- if (size <= 8)
- hdf_type = H5Tcopy( H5T_NATIVE_B8 );
- else if (size <= 16)
- hdf_type = H5Tcopy( H5T_NATIVE_B16 );
- else if (size <= 32)
- hdf_type = H5Tcopy( H5T_NATIVE_B32 );
- else if (size <= 64)
- hdf_type = H5Tcopy( H5T_NATIVE_B64 );
- else
- free( result );
- mhdf_setFail( status, "Cannot create a bit tag larger than 64-bits. %d bits requested.\n", (int)size);
- return NULL;
- break;
- case mhdf_ENTITY_ID:
- if (0 == type)
- type = H5T_NATIVE_ULONG;
- size = get_file_id_size( type, status );
- if (!size) {
- free( result );
- return NULL;
- have_default *= size;
- have_global *= size;
- valsize *= size;
- break;
- default:
- mhdf_setFail( status, "Unknown mhdf_TagDataType value (%d) for tag (\"%s\")",
- (int)result->tags[index].type, name );
- free( result );
- return NULL;
- result->tags[index].bytes = valsize;
- if (have_default || have_global) {
- if (have_default) {
- ptr = realloc_data( &result, have_default, status );
- if (NULL == ptr) {
- if (result->tags[index].type == mhdf_BITFIELD)
- H5Tclose( type );
- return NULL;
- result->tags[index].default_value = ptr;
- if (have_global) {
- ptr = realloc_data( &result, have_global, status );
- H5Tclose( type );
- return NULL;
- result->tags[index].global_value = ptr;
- mhdf_getTagValues( file_handle,
- name,
- type,
- result->tags[index].default_value,
- result->tags[index].global_value,
- status );
- H5Tclose( type );
- free( result );
- return NULL;
- return result;
-mhdf_getFileSummary( mhdf_FileHandle file_handle,
- hid_t file_id_type,
- hid_t table_id;
- int i, j, k, size;
- void* ptr;
- char **elem_handles = 0, **tag_names = 0;
- unsigned char* array;
- API_BEGIN;
- mhdf_setOkay( status );
- result = alloc_file_desc( status );
- if (NULL == result) return NULL;
- /* get node info */
- table_id = mhdf_openNodeCoords( file_handle,
- &result->node_count,
- &result->node_dim,
- &result->node_start_id,
- status );
- if (table_id < 0) {
- free( result );
- return NULL;
- mhdf_closeData( file_handle, table_id, status );
- /* get set info */
- table_id = mhdf_openSetMeta( file_handle,
- &result->set_count,
- &status );
- free( result );
- return NULL;
- /* get element list */
- elem_handles = mhdf_getElemHandles( file_handle,
- &result->num_elem_desc,
- status );
- if (elem_handles == NULL) {
- free( result );
- return NULL;
- /* allocate array of element descriptors */
- size = result->num_elem_desc * sizeof(struct mhdf_ElemDesc);
- ptr = realloc_data( &result, size, status );
- free( elem_handles );
- return NULL;
- memset( ptr, 0, size );
- result->elems = ptr;
- /* Initialize each element descriptor */
- for (i = 0; i < result->num_elem_desc; ++i) {
- result = get_elem_desc( file_handle, result, elem_handles[i], i, status );
- if (NULL == result) {
- return NULL;
- /* get tag list */
- tag_names = mhdf_getTagNames( file_handle, &result->num_tag_desc, status );
- if (tag_names == NULL) {
- free( result );
- return NULL;
- /* allocate array of tag descriptors */
- size = result->num_tag_desc * sizeof(struct mhdf_TagDesc);
- free( tag_names );
- return NULL;
- result->tags = ptr;
- /* Initialize each tag descriptor */
- for (i = 0; i < result->num_tag_desc; ++i) {
- result = get_tag_desc( file_handle, result, tag_names[i], i, file_id_type, status );
- return NULL;
- /* Determine which dense tags are present */
- size = result->num_elem_desc * result->num_tag_desc;
- array = mhdf_malloc( size, status );
- if (NULL == array) {
- free( result );
- return NULL;
- memset( array, 0, size );
- for (j = 0; j < result->num_tag_desc; ++j)
- if (mhdf_haveDenseTag( file_hanlde, tag_names[j], elem_handles[i], status ))
- array[i*result->num_tag_desc+j] = 1;
- /* Populate dense tag lists for element types */
- size = 0;
- size += array[i*result->num_tag_desc+j];
- if (!size)
- continue;
- ptr = realloc_data( &result, size*sizeof(int), status );
- free( array );
- return NULL;
- result->elems[i].num_dense_indices = size;
- result->elems[i].dense_tag_indices = ptr;
- k = 0;
- if (array[i*result->num_tag_desc+j])
- result->elems[i].dense_tag_indices[k++] = j;
- assert( k == size );
- /* Populate dense tag lists for each tag */
- for (j = 0; j < result->num_tag_desc; ++j) {
- size = 0;
- if (!size)
- continue;
- free( array );
- return NULL;
- result->tags[i].num_dense_indices = size;
- result->tags[i].dense_elem_indices = ptr;
- k = 0;
- result->tags[i].dense_elem_indices[k++] = i;
- /* Compact memory and return */
- free( array );
- result->total_size = offset - (unsigned char*)result;
- API_END;
- return result;
