[MOAB-dev] MOAB build issue
    Jason Kraftcheck
    kraftche at cae.wisc.edu
    Thu Feb 26 10:53:49 CST 2009
Paul Wilson wrote:
> Hi,
> I am having a problem building a clean install of MOAB (as I try to help
> a student resolve their problem).
> When I check out a clean set of files from the repo and try to build in
> a separate directory, it is unable to find iMesh_protos.h.  It seems
> that this file is created by the make process in the current build
> location, but when it tries to build mbperf (and perhaps other tools?)
> it doesn't look in the current build location, only in the original
> source location.  This causes the build to fail.
Okay.  Thanks for the info.  I'll fix this today.
- jason
