[MOAB-dev] r2658 - MOAB/trunk
    kraftche at cae.wisc.edu
    Thu Feb 26 14:13:48 CST 2009
Author: kraftche
Date: 2009-02-26 14:13:48 -0600 (Thu, 26 Feb 2009)
New Revision: 2658
Modified:
   MOAB/trunk/AEntityFactory.cpp
   MOAB/trunk/HigherOrderFactory.cpp
   MOAB/trunk/MBCN.cpp
   MOAB/trunk/MBCN.hpp
   MOAB/trunk/MBCNArrays.hpp
   MOAB/trunk/MBSkinner.cpp
   MOAB/trunk/mbcn_test.cc
Log:
o Fix bug getting number of edges, edge indices, etc. for MBKNIFE.
o Add new form of MBCN::HasMidNodes that returns an integer with bits set
  for mid nodes at the corresponding dimension.
o Re-implement all forms of MBCN::HasMid*Nodes as table lookups.
o Rename MBCN::num_nodes_per_sub_element to MBCN::num_corners_per_sub_element
o Add new function: SubEntityNodeIndices.  Similar to SubEntityVertexIndices,
  but also returns any higher order nodes on the side.
o Add unit tests for SubEntityNodeIndices
Modified: MOAB/trunk/AEntityFactory.cpp
--- MOAB/trunk/AEntityFactory.cpp	2009-02-25 19:39:48 UTC (rev 2657)
+++ MOAB/trunk/AEntityFactory.cpp	2009-02-26 20:13:48 UTC (rev 2658)
@@ -806,7 +806,7 @@
     const MBCN::ConnMap &cmap =
       MBCN::mConnectivityMap[source_type][target_dimension-1];
-    int verts_per_sub = cmap.num_nodes_per_sub_element[j];
+    int verts_per_sub = cmap.num_corners_per_sub_element[j];
       // get the corner vertices
     for (int i = 0; i < verts_per_sub; i++)
@@ -992,24 +992,27 @@
     // shouldn't be here if source entity is not an element
   assert(conn_len > 1);
-    // create necessary entities
-  if (create_if_missing) {
-    rval = get_adjacency_ptr( conn[0], vtx_adj );
-    if (MB_SUCCESS != rval)
-      return rval;
-    assert(vtx_adj != NULL); // should contain at least source_entity
+    // create necessary entities. this only makes sense if there exists of a
+    // dimension greater than the target dimension.
+  if (create_if_missing && target_dimension < 3 && MBCN::Dimension(src_type) < 2) {
+    for (size_t i = 0; i < conn_len; ++i) {
+      rval = get_adjacency_ptr( conn[i], vtx_adj );
+      if (MB_SUCCESS != rval)
+        return rval;
+      assert(vtx_adj != NULL); // should contain at least source_entity
-    std::vector<MBEntityHandle> tmp2, tmp(*vtx_adj); // copy in case adjacency vector is changed
-    for (size_t j = 0; j < tmp.size(); ++j) {
-      if (MBCN::Dimension(TYPE_FROM_HANDLE(tmp[j])) <= (int)target_dimension)
-        continue;
-      if (TYPE_FROM_HANDLE(tmp[j]) == MBENTITYSET)
-        break;
+      std::vector<MBEntityHandle> tmp2, tmp(*vtx_adj); // copy in case adjacency vector is changed
+      for (size_t j = 0; j < tmp.size(); ++j) {
+        if (MBCN::Dimension(TYPE_FROM_HANDLE(tmp[j])) <= (int)target_dimension)
+          continue;
+        if (TYPE_FROM_HANDLE(tmp[j]) == MBENTITYSET)
+          break;
-      tmp2.clear();
-      rval = get_down_adjacency_elements( tmp[j], target_dimension, tmp2, true, option );
-        return rval;
+        tmp2.clear();
+        rval = get_down_adjacency_elements( tmp[j], target_dimension, tmp2, true, option );
+          return rval;
Modified: MOAB/trunk/HigherOrderFactory.cpp
--- MOAB/trunk/HigherOrderFactory.cpp	2009-02-25 19:39:48 UTC (rev 2657)
+++ MOAB/trunk/HigherOrderFactory.cpp	2009-02-26 20:13:48 UTC (rev 2658)
@@ -343,7 +343,7 @@
       tmp_face_conn[0] = element[entity_faces.conn[i][0]];
       tmp_face_conn[1] = element[entity_faces.conn[i][1]];
       tmp_face_conn[2] = element[entity_faces.conn[i][2]];
-      if(entity_faces.num_nodes_per_sub_element[i] == 4)
+      if(entity_faces.num_corners_per_sub_element[i] == 4)
         tmp_face_conn[3] = element[entity_faces.conn[i][3]];
       else
         tmp_face_conn[3] = 0;
@@ -359,7 +359,7 @@
         EntitySequence* tmp_sequence = NULL;
         double sum_coords[3] = {0,0,0};
-        int max_nodes = entity_faces.num_nodes_per_sub_element[i];
+        int max_nodes = entity_faces.num_corners_per_sub_element[i];
         for(int k=0; k<max_nodes; k++)
           seq_manager->find(tmp_face_conn[k], tmp_sequence);
Modified: MOAB/trunk/MBCN.cpp
--- MOAB/trunk/MBCN.cpp	2009-02-25 19:39:48 UTC (rev 2657)
+++ MOAB/trunk/MBCN.cpp	2009-02-26 20:13:48 UTC (rev 2658)
@@ -65,6 +65,50 @@
   return MBMAXTYPE;
+void MBCN::SubEntityNodeIndices( const MBEntityType this_topo,
+                                 const int num_nodes,
+                                 const int sub_dimension,
+                                 const int sub_index,
+                                 MBEntityType& subentity_topo,
+                                 int& num_sub_entity_nodes,
+                                 int sub_entity_conn[] )
+    // If asked for a node, the special case...
+  if (sub_dimension == 0) {
+    assert( sub_index < num_nodes );
+    subentity_topo = MBVERTEX;
+    num_sub_entity_nodes = 1;
+    sub_entity_conn[0] = sub_index;
+    return;
+  const int ho_bits = HasMidNodes( this_topo, num_nodes );
+  subentity_topo = SubEntityType(this_topo, sub_dimension, sub_index);
+  num_sub_entity_nodes = VerticesPerEntity(subentity_topo);
+  const short* corners = mConnectivityMap[this_topo][sub_dimension-1].conn[sub_index];
+  std::copy( corners, corners+num_sub_entity_nodes, sub_entity_conn );
+  int sub_sub_corners[MB_MAX_SUB_ENTITY_VERTICES];
+  int side, sense, offset;
+  for (int dim = 1; dim <= sub_dimension; ++dim) {
+    if (!(ho_bits & (1<<dim)))
+      continue;
+    const short num_mid = NumSubEntities( subentity_topo, dim );
+    for (int i = 0; i < num_mid; ++i) {
+      const MBEntityType sub_sub_topo = SubEntityType( subentity_topo, dim, i );
+      const int sub_sub_num_vert = VerticesPerEntity( sub_sub_topo );
+      SubEntityVertexIndices( subentity_topo, dim, i, sub_sub_corners );
+      for (int j = 0; j < sub_sub_num_vert; ++j)
+        sub_sub_corners[j] = corners[sub_sub_corners[j]];
+      SideNumber( this_topo, sub_sub_corners, sub_sub_num_vert, dim, side, sense, offset );
+      sub_entity_conn[num_sub_entity_nodes++] = HONodeIndex( this_topo, num_nodes, dim, side );
 //! return the vertices of the specified sub entity
 //! \param parent_conn Connectivity of parent entity
 //! \param parent_type Entity type of parent entity
@@ -108,7 +152,7 @@
          ((source_dim > 0 &&
            *it1 < mConnectivityMap[this_type][source_dim-1].num_sub_elements) ||
           (source_dim == 0 &&
-           *it1 < mConnectivityMap[this_type][Dimension(this_type)-1].num_nodes_per_sub_element[0])) &&
+           *it1 < mConnectivityMap[this_type][Dimension(this_type)-1].num_corners_per_sub_element[0])) &&
          *it1 >= 0);
@@ -122,7 +166,7 @@
       // less than source_dim, which should give the connectivity of that sub element
     const ConnMap &cm = mConnectivityMap[this_type][source_dim-1];
     std::copy(cm.conn[source_indices[0]],
-              cm.conn[source_indices[0]]+cm.num_nodes_per_sub_element[source_indices[0]],
+              cm.conn[source_indices[0]]+cm.num_corners_per_sub_element[source_indices[0]],
               std::back_inserter(index_list));
     return 0;
Modified: MOAB/trunk/MBCN.hpp
--- MOAB/trunk/MBCN.hpp	2009-02-25 19:39:48 UTC (rev 2657)
+++ MOAB/trunk/MBCN.hpp	2009-02-26 20:13:48 UTC (rev 2658)
@@ -38,6 +38,7 @@
 #include <vector>
 #include <algorithm>
+#include <assert.h>
 #include "MBEntityType.h"
@@ -67,6 +68,11 @@
 public:
+  enum { MAX_NODES_PER_ELEMENT = 27 };
+  enum { MID_EDGE_BIT   = 1<<1,
+         MID_FACE_BIT   = 1<<2,
+         MID_REGION_BIT = 1<<3 };
     //! enum used to specify operation type
   enum {INTERSECT = 0, UNION};
@@ -82,7 +88,7 @@
     short int num_sub_elements;
       // Number of nodes in each sub-element of this dimension
-    short int num_nodes_per_sub_element[MB_MAX_SUB_ENTITIES];
+    short int num_corners_per_sub_element[MB_MAX_SUB_ENTITIES];
       // Type of each sub-element
     MBEntityType target_type[MB_MAX_SUB_ENTITIES];
@@ -93,7 +99,7 @@
     // mConnectivityMap[i=entity type][j=0,1,2]:
     //  num_sub_elements = # bounding edges(j=0) or faces(j=1) for entity type i, or self (j=2)
-    //  num_nodes_per_sub_element[k] (k=0..num_sub_elements-1) = number of nodes in sub-facet k
+    //  num_corners_per_sub_element[k] (k=0..num_sub_elements-1) = number of nodes in sub-facet k
     //    (can vary over sub-facets, e.g. faces bounding a pyramid) or self (j=2)
     //  target_type[k] = entity type of sub-facet k (e.g. MBTRI or MBQUAD bounding a pyramid) or self (j=2)
     //  conn[k][l] (l=0..MBCN::VerticesPerEntity[target_type[k]]) = vertex connectivity of sub-facet k,
@@ -117,6 +123,9 @@
     // efficient sorting)
     // (not documented with Doxygen)
   static const UpConnMap mUpConnMap[MBMAXTYPE][4][4];
+    // Mid-node bits indexed by number of nodes in element
+  static const unsigned char midNodesPerType[MBMAXTYPE][MAX_NODES_PER_ELEMENT+1];
     //! Permutation and reverse permutation vectors
   static short int permuteVec[MBMAXTYPE][3][MB_MAX_SUB_ENTITIES+1];
@@ -166,6 +175,22 @@
                                      int sub_entity_conn[]);
+  //! return the node indices of the specified sub-entity.
+  //! \param this_topo            The topology of the queried element type
+  //! \param num_nodes            The number of nodes in the queried element type.
+  //! \param sub_dimension        Dimension of sub-entity
+  //! \param sub_index            Index of sub-entity
+  //! \param sub_entity_topo      (Output) Topology of requested sub-entity.
+  //! \param num_sub_entity_nodes (Output) Number of nodes in the requested sub-entity.
+  //! \param sub_entity_conn      (Output) Connectivity of sub-entity
+  static void SubEntityNodeIndices(const MBEntityType this_topo,
+                                   MBEntityType& sub_entity_topo,
+                                   int sub_entity_conn[]);
@@ -370,11 +395,16 @@
   //! are present.
   //! \param this_type Type of entity for which sub-entity connectivity is being queried
   //! \param num_verts Number of nodes defining entity
-  //! \param mid_nodes If <em>mid_nodes[i], i=1..2</em> is true, indicates that mid-edge
+  //! \param mid_nodes If <em>mid_nodes[i], i=1..2</em> is non-zero, indicates that mid-edge
   //!    (i=1), mid-face (i=2), and/or mid-region (i=3) nodes are likely
   static void HasMidNodes(const MBEntityType this_type,
                           const int num_verts,
                           int mid_nodes[4]);
+  //! Same as above, except returns a single integer withthe bits, from
+  //! least significant to most significant set to one if the cooresponding
+  //! mid nodes on sub entities of the least dimension (0) to the highest
+  //! dimension (3) are present in the elment type.
+  static int HasMidNodes( const MBEntityType this_type, const int num_verts );
   //! given data about an element and a vertex in that element, return the dimension
   //! and index of the sub-entity that the vertex resolves.  If it does not resolve a
@@ -418,7 +448,7 @@
 inline short int MBCN::VerticesPerEntity(const MBEntityType t)
-  return (MBVERTEX == t ? 1 : mConnectivityMap[t][mConnectivityMap[t][0].topo_dimension-1].num_nodes_per_sub_element[0]);
+  return (MBVERTEX == t ? 1 : mConnectivityMap[t][mConnectivityMap[t][0].topo_dimension-1].num_corners_per_sub_element[0]);
 inline short int MBCN::NumSubEntities(const MBEntityType t, const int d)
@@ -454,75 +484,39 @@
 inline bool MBCN::HasMidEdgeNodes(const MBEntityType this_type,
                                      const int num_nodes)
-    // poly elements never have mid nodes as far as canonical ordering is concerned
-  if (MBPOLYGON == this_type || MBPOLYHEDRON == this_type) return false;
-  if (num_nodes == (VerticesPerEntity(this_type) + NumSubEntities(this_type, 1)) ||
-      num_nodes == (VerticesPerEntity(this_type) + NumSubEntities(this_type, 1) +
-                    NumSubEntities(this_type, 2)) ||
-                    NumSubEntities(this_type, 2) + 1) ||
-      num_nodes == (VerticesPerEntity(this_type) + NumSubEntities(this_type, 1) + 1) )
-    return true;
-  else
-    return false;
+  const int bits = HasMidNodes( this_type, num_nodes );
+  return static_cast<bool>( (bits & (1<<1)) >> 1 );
 inline bool MBCN::HasMidFaceNodes(const MBEntityType this_type,
-    // edges cannot have mid-face nodes
-  if (Dimension(this_type) < 2) return false;
-  if (num_nodes == (VerticesPerEntity(this_type) + NumSubEntities(this_type, 2)) ||
-      num_nodes == (VerticesPerEntity(this_type) + NumSubEntities(this_type, 2) + 1) )
-    return true;
-  else
-    return false;
+  return static_cast<bool>( (bits & (1<<2)) >> 2 );
 inline bool MBCN::HasMidRegionNodes(const MBEntityType this_type,
-  if (Dimension(this_type) != 3 || MBPOLYHEDRON == this_type) return false;
+  return static_cast<bool>( (bits & (1<<3)) >> 3 );
-  if (num_nodes == (VerticesPerEntity(this_type) + 1) ||
-      num_nodes == (VerticesPerEntity(this_type) + NumSubEntities(this_type, 1) + 1) ||
-    return true;
-  else
-    return false;
+inline int MBCN::HasMidNodes( const MBEntityType this_type, const int num_nodes )
+  assert( (unsigned)num_nodes <= (unsigned)MAX_NODES_PER_ELEMENT );
+  return midNodesPerType[this_type][num_nodes];
 inline void MBCN::HasMidNodes(const MBEntityType this_type, const int num_nodes,
                               int mid_nodes[4])
-  if (num_nodes <= VerticesPerEntity(this_type) ||
-      MBPOLYGON == this_type || MBPOLYHEDRON == this_type) {
-    mid_nodes[0] = 0;
-    mid_nodes[1] = 0;
-    mid_nodes[2] = 0;
-    mid_nodes[3] = 0;
-    return;
   mid_nodes[0] = 0;
-  mid_nodes[1] = HasMidEdgeNodes(this_type, num_nodes);
-  mid_nodes[2] = HasMidFaceNodes(this_type, num_nodes);
-  mid_nodes[3] = HasMidRegionNodes(this_type, num_nodes);
+  mid_nodes[1] = bits & MID_EDGE_BIT;
+  mid_nodes[2] = bits & MID_FACE_BIT;
+  mid_nodes[3] = bits & MID_REGION_BIT;
 //! Set permutation or reverse permutation vector
Modified: MOAB/trunk/MBCNArrays.hpp
--- MOAB/trunk/MBCNArrays.hpp	2009-02-25 19:39:48 UTC (rev 2657)
+++ MOAB/trunk/MBCNArrays.hpp	2009-02-26 20:13:48 UTC (rev 2658)
@@ -18,8 +18,9 @@
 const MBCN::ConnMap MBCN::mConnectivityMap[MBMAXTYPE][3] =
     // vertex-edge
-  {{ 0, 0 , {0}, {MBMAXTYPE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE,
-                  MBMAXTYPE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE}, {{0}} },
+  {{ 0, 0 , {0},
+    {MBMAXTYPE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE,
+     MBMAXTYPE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE}, {{0}} },
      // vertex-face
@@ -103,9 +104,9 @@
      {{0,1,2,3,4,5}} }},
     // knife-edge
-  {{ 3, 8, {2,2,2,2,2,2,2,2}, {MBEDGE,MBEDGE,MBEDGE,MBEDGE,MBEDGE,MBEDGE,
-                                MBEDGE,MBEDGE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE, MBMAXTYPE},
-     { {0,1},{1,2},{2,3},{3,0},{0,4},{1,5},{2,6},{3,5} } },
+  {{ 3, 10, {2,2,2,2,2,2,2,2,2,2}, {MBEDGE,MBEDGE,MBEDGE,MBEDGE,MBEDGE,MBEDGE,
+                                    MBEDGE,MBEDGE,MBEDGE,MBEDGE, MBMAXTYPE, MBMAXTYPE},
+     { {0,1},{1,2},{2,3},{3,0},{0,4},{1,5},{2,6},{3,5},{4,5},{5,6} } },
      // knife-face
    { 3, 5, {4,4,4,4,4}, {MBQUAD,MBQUAD,MBQUAD,MBQUAD,MBQUAD, MBMAXTYPE,
@@ -687,4 +688,34 @@
     {{{0}, {{0}} }, {{0}, {{0}} }, {{0}, {{0}} }} // source dim 3
   } // end type MBENTITYSET
+const unsigned char E = MBCN::MID_EDGE_BIT;
+const unsigned char F = MBCN::MID_FACE_BIT;
+const unsigned char R = MBCN::MID_REGION_BIT;
+const unsigned char MBCN::midNodesPerType[MBMAXTYPE][MAX_NODES_PER_ELEMENT+1] = {
+// vertex
+  { 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
+// edge
+  { 0, 0, 0, E, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
+// tri
+  { 0, 0, 0, 0, F, 0, E, E|F, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
+// quad
+  { 0, 0, 0, 0, 0, F, 0, 0, E, E|F, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
+// polygon
+// tet 1, 2, 3, 4, 5, 6, 7, 8, 9,  10, 11, 12,13, 14,  15
+  { 0, 0, 0, 0, 0, R, 0, 0, F, F|R, E, E|R, 0, 0, E|F, E|F|R, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0 },
+// pyramid   3, 4, 5, 6, 7, 8, 9,10, 11, 12,13, 14, 15,16,17, 18,  19
+  { 0, 0, 0, 0, 0, 0, R, 0, 0, 0, F, F|R, 0, E, E|R, 0, 0, 0, E|F, E|F|R, 0, 0, 0, 0, 0, 0, 0, 0 },
+// prism  2, 3, 4, 5, 6, 7, 8, 9,10,11, 12, 13,14,15, 16, 17,18,19, 20,  21
+  { 0, 0, 0, 0, 0, 0, 0, R, 0, 0, 0, F, F|R, 0, 0, E, E|R, 0, 0, 0, E|F, E|F|R, 0, 0, 0, 0, 0, 0 },
+// knife  2, 3, 4, 5, 6, 7, 8, 9,10,11, 12,13, 14,15,16,17, 18, 19,20,21, 22,  23
+  { 0, 0, 0, 0, 0, 0, 0, 0, R, 0, 0, 0, F, F|R, 0, 0, 0, E, E|R, 0, 0, 0, E|F, E|F|R, 0, 0, 0, 0 },
+// hex 1, 2, 3, 4, 5, 6, 7, 8, 9, 10,11,12,13,14,15, 16,17,18,19,20, 21, 22,23,24,25, 26,  27
+  { 0, 0, 0, 0, 0, 0, 0, 0, 0, R, 0, 0, 0, 0, F, F|R, 0, 0, 0, 0, E, E|R, 0, 0, 0, 0, E|F, E|F|R },
+// polyhedron
+// set
 #endif
Modified: MOAB/trunk/MBSkinner.cpp
--- MOAB/trunk/MBSkinner.cpp	2009-02-25 19:39:48 UTC (rev 2657)
+++ MOAB/trunk/MBSkinner.cpp	2009-02-26 20:13:48 UTC (rev 2658)
@@ -302,7 +302,7 @@
     const struct MBCN::ConnMap* conn_map = &(MBCN::mConnectivityMap[type][mTargetDim-1]);
     for(int i=0; i<conn_map->num_sub_elements; i++)
-      int num_sub_nodes = conn_map->num_nodes_per_sub_element[i];
+      int num_sub_nodes = conn_map->num_corners_per_sub_element[i];
       assert(num_sub_nodes <= 32);
       for(int j=0; j<num_sub_nodes; j++)
         sub_conn[j] = conn[conn_map->conn[i][j]];
@@ -652,7 +652,7 @@
     const struct MBCN::ConnMap* conn_map = &(MBCN::mConnectivityMap[type][0]);
Modified: MOAB/trunk/mbcn_test.cc
--- MOAB/trunk/mbcn_test.cc	2009-02-25 19:39:48 UTC (rev 2657)
+++ MOAB/trunk/mbcn_test.cc	2009-02-26 20:13:48 UTC (rev 2658)
@@ -38,10 +38,34 @@
 void test_opposite_side_tet();
 void test_opposite_side_hex();
-void test_has_mid_nodes();
+void test_has_mid_nodes( MBEntityType type );
+void test_has_mid_nodes_edge() { test_has_mid_nodes(MBEDGE); }
+void test_has_mid_nodes_tri()  { test_has_mid_nodes(MBTRI); }
+void test_has_mid_nodes_quad() { test_has_mid_nodes(MBQUAD); }
+void test_has_mid_nodes_tet()  { test_has_mid_nodes(MBTET); }
+void test_has_mid_nodes_pyr()  { test_has_mid_nodes(MBPYRAMID); }
+void test_has_mid_nodes_pri()  { test_has_mid_nodes(MBPRISM); }
+void test_has_mid_nodes_knife(){ test_has_mid_nodes(MBKNIFE); }
+void test_has_mid_nodes_hex()  { test_has_mid_nodes(MBHEX); }
 void test_ho_node_parent();
 void test_ho_node_index();
+void test_sub_entity_nodes( MBEntityType parent, int sub_dimension );
+void test_sub_entity_nodes( MBEntityType parent, int num_nodes, int sub_dimension );
+void test_sub_entity_nodes_tri_edges()  { test_sub_entity_nodes(MBTRI,     1 ); }
+void test_sub_entity_nodes_quad_edges() { test_sub_entity_nodes(MBQUAD,    1 ); }
+void test_sub_entity_nodes_tet_edges()  { test_sub_entity_nodes(MBTET,     1 ); }
+void test_sub_entity_nodes_tet_faces()  { test_sub_entity_nodes(MBTET,     2 ); }
+void test_sub_entity_nodes_pyr_edges()  { test_sub_entity_nodes(MBPYRAMID, 1 ); }
+void test_sub_entity_nodes_pyr_faces()  { test_sub_entity_nodes(MBPYRAMID, 2 ); }
+void test_sub_entity_nodes_pri_edges()  { test_sub_entity_nodes(MBPRISM,   1 ); }
+void test_sub_entity_nodes_pri_faces()  { test_sub_entity_nodes(MBPRISM,   2 ); }
+void test_sub_entity_nodes_kni_edges()  { test_sub_entity_nodes(MBKNIFE,   1 ); }
+void test_sub_entity_nodes_kni_faces()  { test_sub_entity_nodes(MBKNIFE,   2 ); }
+void test_sub_entity_nodes_hex_edges()  { test_sub_entity_nodes(MBHEX,     1 ); }
+void test_sub_entity_nodes_hex_faces()  { test_sub_entity_nodes(MBHEX,     2 ); }
 int main()
   int result = 0;
@@ -82,7 +106,28 @@
   result += RUN_TEST(test_opposite_side_tet);
   result += RUN_TEST(test_opposite_side_hex);
-  result += RUN_TEST(test_has_mid_nodes);
+  result += RUN_TEST(test_has_mid_nodes_edge);
+  result += RUN_TEST(test_has_mid_nodes_tri);
+  result += RUN_TEST(test_has_mid_nodes_quad);
+  result += RUN_TEST(test_has_mid_nodes_tet);
+  result += RUN_TEST(test_has_mid_nodes_pyr);
+  result += RUN_TEST(test_has_mid_nodes_pri);
+  result += RUN_TEST(test_has_mid_nodes_knife);
+  result += RUN_TEST(test_has_mid_nodes_hex);
+  result += RUN_TEST(test_sub_entity_nodes_tri_edges);
+  result += RUN_TEST(test_sub_entity_nodes_quad_edges);
+  result += RUN_TEST(test_sub_entity_nodes_tet_edges);
+  result += RUN_TEST(test_sub_entity_nodes_tet_faces);
+  result += RUN_TEST(test_sub_entity_nodes_pyr_edges);
+  result += RUN_TEST(test_sub_entity_nodes_pyr_faces);
+  result += RUN_TEST(test_sub_entity_nodes_pri_edges);
+  result += RUN_TEST(test_sub_entity_nodes_pri_faces);
+  result += RUN_TEST(test_sub_entity_nodes_kni_edges);
+  result += RUN_TEST(test_sub_entity_nodes_kni_faces);
+  result += RUN_TEST(test_sub_entity_nodes_hex_edges);
+  result += RUN_TEST(test_sub_entity_nodes_hex_faces);
   result += RUN_TEST(test_ho_node_parent);
   result += RUN_TEST(test_ho_node_index);
   return result;
@@ -182,7 +227,7 @@
   CHECK_EQUAL( 5, MBCN::NumSubEntities(MBPRISM, 2));
   CHECK_EQUAL( 7, MBCN::NumSubEntities(MBKNIFE, 0));
-  CHECK_EQUAL( 8, MBCN::NumSubEntities(MBKNIFE, 1));
+  CHECK_EQUAL(10, MBCN::NumSubEntities(MBKNIFE, 1));
   CHECK_EQUAL( 5, MBCN::NumSubEntities(MBKNIFE, 2));
   CHECK_EQUAL( 8, MBCN::NumSubEntities(MBHEX, 0));
@@ -822,7 +867,7 @@
   CHECK_EQUAL( 4, idx );
+void test_has_mid_nodes(MBEntityType type)
   const int combinations[][4] = { { 0, 0, 0, 0 },
                                   { 0, 1, 0, 0 },
@@ -833,8 +878,6 @@
                                   { 0, 0, 1, 1 },
                                   { 0, 1, 1, 1 } };
-  for (const MBEntityType* t = elem_types; *t != MBMAXTYPE; ++t) {
-    const MBEntityType type = *t;
     const int dim = MBCN::Dimension(type);
       // calculate number of valid combinations of ho node flags
     int num_comb = 1;
@@ -857,12 +900,11 @@
       int results[4] = { 0, -1, -1, -1 };
       MBCN::HasMidNodes( type, num_vtx, results );
-      CHECK_EQUAL(           0, results[0] );
-      CHECK_EQUAL( ho_nodes[1], results[1] );
-      CHECK_EQUAL( ho_nodes[2], results[2] );
-      CHECK_EQUAL( ho_nodes[3], results[3] );
+      CHECK_EQUAL(           0, !!results[0] );
+      CHECK_EQUAL( ho_nodes[1], !!results[1] );
+      CHECK_EQUAL( ho_nodes[2], !!results[2] );
+      CHECK_EQUAL( ho_nodes[3], !!results[3] );
@@ -985,3 +1027,100 @@
   } // for each type
+  const int num_corner = MBCN::VerticesPerEntity( parent );
+  const int num_edge   = MBCN::NumSubEntities( parent, 1 );
+  const int num_face   = MBCN::NumSubEntities( parent, 2 );
+  switch (MBCN::Dimension(parent)) {
+    case 3:
+      test_sub_entity_nodes( parent, num_corner+num_face, sub_dimension );
+      test_sub_entity_nodes( parent, num_corner+num_edge+num_face, sub_dimension );
+      test_sub_entity_nodes( parent, num_corner+num_face+1, sub_dimension );
+      test_sub_entity_nodes( parent, num_corner+num_edge+num_face+1, sub_dimension );
+    case 2:
+      test_sub_entity_nodes( parent, num_corner+num_edge, sub_dimension );
+      test_sub_entity_nodes( parent, num_corner+num_edge+1, sub_dimension );
+    case 1:
+      test_sub_entity_nodes( parent, num_corner, sub_dimension );
+      test_sub_entity_nodes( parent, num_corner+1, sub_dimension );
+      break;
+    default:
+      CHECK(false);
+  const int num_sub = MBCN::NumSubEntities( parent, sub_dimension );
+  const int parent_ho = MBCN::HasMidNodes( parent, num_nodes );
+  int child_ho = 0;
+  for (int d = 1; d <= sub_dimension; ++d)
+    child_ho |= (parent_ho & (1<<d));
+    // first test the types
+  for (int i = 0; i < num_sub; ++i) {
+    int num, conn[MB_MAX_SUB_ENTITY_VERTICES];
+    MBEntityType type;
+    MBCN::SubEntityNodeIndices( parent, num_nodes, sub_dimension, i, type, num, conn );
+    CHECK_EQUAL( MBCN::SubEntityType(parent, sub_dimension, i), type );
+    // now test that they have the correct number of higher-order node
+    const int ho = MBCN::HasMidNodes( type, num );
+    CHECK_EQUAL( child_ho, ho );
+    // now test the actual indices
+    int num, conn[MB_MAX_SUB_ENTITY_VERTICES], corners[MB_MAX_SUB_ENTITY_VERTICES];
+      // check corner indices against SubEntityVertexIndices
+    const int num_corner = MBCN::VerticesPerEntity(type);
+    CHECK( num >= num_corner );
+    MBCN::SubEntityVertexIndices( parent, sub_dimension, i, corners );
+    for (int j = 0; j < num_corner; ++j)
+      CHECK_EQUAL( corners[j], conn[j] );
+      // check mid-edge indices, if present
+    int idx = num_corner;
+    if (child_ho & MBCN::MID_EDGE_BIT) {
+        // for each edge in the sub-entity type
+      const int num_edge = MBCN::NumSubEntities( type, 1 );
+      for (int j = 0; j < num_edge; ++j) {
+          // get edge indices for sub-entity connectivity
+        int edge_ends[2];
+        MBCN::SubEntityVertexIndices( type, 1, j, edge_ends );
+          // convert to indices into parent type's connectivity
+        CHECK( edge_ends[0] < num_corner );
+        edge_ends[0] = corners[edge_ends[0]];
+        CHECK( edge_ends[1] < num_corner );
+        edge_ends[1] = corners[edge_ends[1]];
+          // find edge index in parent element
+        int side, sense, off;
+        int result = MBCN::SideNumber( parent, edge_ends, 2, 1, side, sense, off );
+        CHECK_EQUAL( 0, result );
+          // get location in parent entity connectivity for mid-edge node
+        int loc = MBCN::HONodeIndex( parent, num_nodes, 1, side );
+        CHECK_EQUAL( loc, conn[idx++] );
+      // check mid-face indices, if present
+    if (child_ho & MBCN::MID_FACE_BIT) {
+      CHECK_EQUAL( 2, MBCN::Dimension(type) );
+      int loc = MBCN::HONodeIndex( parent, num_nodes, 2, i );
+      // make sure there were no extra node indices returned
+    CHECK_EQUAL( idx, num );
