[MOAB-dev] MOAB build issue
    Paul Wilson
    wilsonp at engr.wisc.edu
    Thu Feb 26 10:43:49 CST 2009
I am having a problem building a clean install of MOAB (as I try to help
a student resolve their problem).
When I check out a clean set of files from the repo and try to build in
a separate directory, it is unable to find iMesh_protos.h.  It seems
that this file is created by the make process in the current build
location, but when it tries to build mbperf (and perhaps other tools?)
it doesn't look in the current build location, only in the original
source location.  This causes the build to fail.
Paul
Paul P H Wilson                  UW-Madison Engineering Physics
Associate Professor               419 Engineering Research Bldg
wilsonp at engr.wisc.edu                       1500 Engineering Dr
608/263-0807 fax:608/263-4499                 Madison, WI 53706
http://www.cae.wisc.edu/~wilsonp    http://www.engr.wisc.edu/ep
                       My calendar
http://www.google.com/calendar/embed?src=paul@nagus-wilson.net
          Contributing to the joy and improvement
                  of all those around me
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
URL: <http://lists.mcs.anl.gov/pipermail/moab-dev/attachments/20090226/b32b3381/attachment.bin>
