[MOAB-dev] r2104 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Mon Sep 29 15:54:33 CDT 2008
Author: kraftche
Date: 2008-09-29 15:54:32 -0500 (Mon, 29 Sep 2008)
New Revision: 2104
Modified:
MOAB/trunk/parallel/MBParallelComm.cpp
Log:
In the "std::map<std::vector<int>, MBRange> proc_nranges" used by
MBParallelComm::resolve_shared_ents and subroutines, store only the
valid processor IDs in the key field (don't pad the std::vector
with -1's out to MAX_SHARING_PROCS anymore.) This:
a) is more efficient because we're not allocating all that memory
for -1's.
b) results in an easier to use data structure because the
size() method can be used directly. It is no longer necessary
to search for -1 to determine the real size.
c) results in cleaner code because the MAX_SHARING_PROCS constant
is isolated to those pieces of code for which it is truely
relevant (the fixed size of the tag used to store multiple
processor IDs on an entity.)
Fix possible bug in MBParallelComm::tag_shared_verts: processor IDs
are sorted, but the corresponding handle list is left in the original
order.
TIM: Is this right? It seems unlikely that this code would have worked
before with this bug? Is the sorting of processor IDs perhaps a no-op
(they're already sorted)?
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-09-29 20:21:45 UTC (rev 2103)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-09-29 20:54:32 UTC (rev 2104)
@@ -2488,8 +2488,8 @@
for (std::map<std::vector<int>, MBRange>::const_iterator mit = proc_nranges.begin();
mit != proc_nranges.end(); mit++) {
std::cout << "Iface: ";
- for (std::vector<int>::const_iterator vit = ((*mit).first).begin();
- vit != ((*mit).first).end(); vit++) std::cout << " " << *vit;
+ for (std::vector<int>::const_iterator vit = (mit->first).begin();
+ vit != (mit->first).end(); vit++) std::cout << " " << *vit;
std::cout << std::endl;
@@ -2580,6 +2580,7 @@
if (proc_nranges.empty()) return MB_SUCCESS;
+ int proc_ids[MAX_SHARING_PROCS];
MBTag sharedp_tag, sharedps_tag, sharedh_tag, sharedhs_tag, pstatus_tag;
MBErrorCode result = get_shared_proc_tags(sharedp_tag, sharedps_tag,
@@ -2598,32 +2599,33 @@
RRA("Failed to create interface set.");
interfaceSets.insert(new_set);
- int nump = 0;
- while (((*mit).first)[nump] != -1 && nump < MAX_SHARING_PROCS) nump++;
// add entities
- result = mbImpl->add_entities(new_set, (*mit).second);
+ result = mbImpl->add_entities(new_set, mit->second);
RRA("Failed to add entities to interface set.");
// tag set with the proc rank(s)
- if (nump == 1)
+ if (mit->first.size() == 1)
result = mbImpl->tag_set_data(sharedp_tag, &new_set, 1,
- &((*mit).first)[0]);
- else
- result = mbImpl->tag_set_data(sharedps_tag, &new_set, 1,
+ &(mit->first)[0]);
+ else {
+ // pad tag data out to MAX_SHARING_PROCS with -1
+ assert( mit->first.size() <= MAX_SHARING_PROCS );
+ std::copy( mit->first.begin(), mit->first.end(), proc_ids );
+ std::fill( proc_ids + mit->first.size(), proc_ids + MAX_SHARING_PROCS, -1 );
+ result = mbImpl->tag_set_data(sharedps_tag, &new_set, 1, proc_ids );
RRA("Failed to tag interface set with procs.");
// get the owning proc, then set the pstatus tag on iface set
- int min_proc = ((*mit).first)[0];
+ int min_proc = (mit->first)[0];
unsigned char pval = (PSTATUS_SHARED | PSTATUS_INTERFACE);
if (min_proc < (int) procConfig.proc_rank()) pval |= PSTATUS_NOT_OWNED;
result = mbImpl->tag_set_data(pstatus_tag, &new_set, 1, &pval);
RRA("Failed to tag interface set with pstatus.");
// tag the entities with the same thing
- pstatus.resize((*mit).second.size());
- std::fill(pstatus.begin(), pstatus.end(), pval);
- result = mbImpl->tag_set_data(pstatus_tag, (*mit).second, &pstatus[0]);
+ pstatus.clear();
+ pstatus.resize(mit->second.size(), pval);
+ result = mbImpl->tag_set_data(pstatus_tag, mit->second, &pstatus[0]);
RRA("Failed to tag interface set entities with pstatus.");
@@ -2782,11 +2784,6 @@
// intersection is the owning proc(s) for this skin ent
if (sharing_procs.empty()) continue;
- for (vii = sharing_procs.begin(); vii != sharing_procs.end(); ++vii)
- assert( *vii < (int)procConfig.proc_size() );
- // fill extra entries with -1
- assert(sharing_procs.size() <= MAX_SHARING_PROCS);
- sharing_procs.resize( MAX_SHARING_PROCS, -1 );
proc_nranges[sharing_procs].insert(*rit);
if (sharing_procs.size() < 2) {
result = mbImpl->tag_set_data(sharedp_tag, &(*rit), 1,
@@ -2794,6 +2791,9 @@
RRA("Failed to set sharedp_tag on non-vertex skin entity.");
else {
+ // fill extra entries with -1
+ assert(sharing_procs.size() <= MAX_SHARING_PROCS);
+ sharing_procs.resize( MAX_SHARING_PROCS, -1 );
result = mbImpl->tag_set_data(sharedps_tag, &(*rit), 1,
&sharing_procs[0]);
RRA("Failed to set sharedps_tag on non-vertex skin entity.");
@@ -2831,36 +2831,52 @@
RRA("Trouble getting shared proc tags in tag_shared_verts.");
unsigned int j = 0, i = 0;
- std::vector<int> sharing_procs(MAX_SHARING_PROCS);
- MBEntityHandle sharing_handles[MAX_SHARING_PROCS];
- std::fill(sharing_procs.begin(), sharing_procs.end(), -1);
- std::fill(sharing_handles, sharing_handles+MAX_SHARING_PROCS, 0);
+ std::vector<int> sharing_procs, sharing_procs2;
+ std::vector<MBEntityHandle> sharing_handles, sharing_handles2;
while (j < 2*shared_ents.n) {
// count & accumulate sharing procs
- unsigned int nump = 0;
int this_idx = shared_ents.vi[j];
MBEntityHandle this_ent = skin_ents[0][this_idx];
while (j < 2*shared_ents.n && shared_ents.vi[j] == this_idx) {
j++;
- sharing_procs[nump] = shared_ents.vi[j++];
- sharing_handles[nump++] = shared_ents.vul[i++];
+ sharing_procs.push_back( shared_ents.vi[j++] );
+ sharing_handles.push_back( shared_ents.vul[i++] );
- std::sort(&sharing_procs[0], &sharing_procs[nump]);
+ // sort sharing_procs and sharing_handles such that
+ // sharing_procs is in ascending order. Use temporary
+ // lists and binary search to re-order sharing_handles.
+ sharing_procs2 = sharing_procs;
+ std::sort( sharing_procs2.begin(), sharing_procs2.end() );
+ sharing_handles2.resize( sharing_handles.size() );
+ for (size_t k = 0; k < sharing_handles.size(); ++k) {
+ size_t idx = std::lower_bound( sharing_procs2.begin(),
+ sharing_procs2.end(),
+ sharing_procs[k] ) - sharing_procs2.begin();
+ sharing_handles2[idx] = sharing_handles[k];
+ sharing_procs.swap( sharing_procs2 );
+ sharing_handles.swap( sharing_handles2 );
proc_nranges[sharing_procs].insert(this_ent);
- if (1 == nump) {
+ if (sharing_procs.size() == 1) {
result = mbImpl->tag_set_data(sharedp_tag, &this_ent, 1,
&sharing_procs[0]);
result = mbImpl->tag_set_data(sharedh_tag, &this_ent, 1,
- sharing_handles);
+ &sharing_handles[0]);
else {
+ // pad lists
+ assert( sharing_procs.size() <= MAX_SHARING_PROCS );
+ sharing_handles.resize( MAX_SHARING_PROCS, 0 );
result = mbImpl->tag_set_data(sharedps_tag, &this_ent, 1,
&sharing_procs[0]);
result = mbImpl->tag_set_data(sharedhs_tag, &this_ent, 1,
- sharing_handles);
RRA("Failed setting shared_procs tag on skin vertices.");
@@ -2871,8 +2887,8 @@
RRA("Couldn't set shared tag on shared vertex.");
// reset sharing proc(s) tags
- std::fill(sharing_handles, sharing_handles+nump, 0);
+ sharing_procs.clear();
+ sharing_handles.clear();
return MB_SUCCESS;
