[MOAB-dev] r2103 - MOAB/trunk/parallel
kraftche at mcs.anl.gov
Mon Sep 29 15:21:46 CDT 2008
Author: kraftche
Date: 2008-09-29 15:21:45 -0500 (Mon, 29 Sep 2008)
New Revision: 2103
Modified:
MOAB/trunk/parallel/MBParallelComm.cpp
Log:
Some cleanups to MBParallelComm::tag_shared_ents:
o remove arbitrary limitation on element connectivity length
o remove use of MBRange to store processor ranks (and hack to
work around storing a zero rank). Work directly with sorted
std::vector<int> instead.
Both above changes result in cleaner, and probably faster, code.
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-09-29 19:24:13 UTC (rev 2102)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-09-29 20:21:45 UTC (rev 2103)
@@ -2712,10 +2712,9 @@
sharedh_tag, sharedhs_tag, pstatus_tag);
RRA("Trouble getting shared proc tags in tag_shared_ents.");
const MBEntityHandle *connect; int num_connect;
- std::vector<int> sharing_procs(MAX_SHARING_PROCS);
- int sharing_procs2[MAX_SHARING_PROCS];
- std::fill(sharing_procs.begin(), sharing_procs.end(), -1);
- std::vector<unsigned char> pstatus_flags(MB_MAX_SUB_ENTITIES);
+ std::vector<int> sharing_procs, sharing_procs1, sharing_procs2;
+ std::vector<int>::iterator vii;
+ std::vector<unsigned char> pstatus_flags;
for (int d = 3; d > 0; d--) {
if (resolve_dim == d) continue;
@@ -2725,11 +2724,10 @@
// get connectivity
result = mbImpl->get_connectivity(*rit, connect, num_connect);
RRA("Failed to get connectivity on non-vertex skin entities.");
- MBRange sp_range, vp_range;
// if any vertices not shared, this entity isn't
- assert(num_connect <= MB_MAX_SUB_ENTITIES);
bool is_shared = true;
+ pstatus_flags.resize( num_connect );
result = mbImpl->tag_get_data(pstatus_tag, connect, num_connect,
&pstatus_flags[0]);
RRA("Couldn't get pstatus flag.");
@@ -2741,54 +2739,56 @@
if (!is_shared) continue;
- bool and_zero = false;
for (int nc = 0; nc < num_connect; nc++) {
- // only have to initialize the 2nd one; if sharedps tag is used,
- // all get initialized
- sharing_procs2[1] = -1;
+ sharing_procs2.clear();
// get sharing procs
- result = mbImpl->tag_get_data(sharedp_tag, connect+nc, 1, sharing_procs2);
+ sharing_procs2.resize(1);
+ result = mbImpl->tag_get_data(sharedp_tag, connect+nc, 1, &sharing_procs2[0]);
RRA("Couldn't get sharedp_tag on skin vertices in entity.");
if (sharing_procs2[0] == -1) {
- result = mbImpl->tag_get_data(sharedps_tag, connect+nc, 1, sharing_procs2);
+ sharing_procs2.resize(MAX_SHARING_PROCS);
+ result = mbImpl->tag_get_data(sharedps_tag, connect+nc, 1, &sharing_procs2[0]);
RRA("Couldn't get sharedps_tag on skin vertices in entity.");
assert(-1 != sharing_procs2[0]);
+ // remove any unnecessary entries
+ vii = std::find( sharing_procs2.begin(), sharing_procs2.end(), -1 );
+ sharing_procs2.erase( vii, sharing_procs2.end() );
// build range of sharing procs for this vertex
- unsigned int p = 0; vp_range.clear();
- while (sharing_procs2[p] != -1 && p < MAX_SHARING_PROCS)
- vp_range.insert(sharing_procs2[p]), p++;
- assert(p < MAX_SHARING_PROCS);
// intersect with range for this skin ent
if (0 == nc) {
- sp_range = vp_range;
- if (sharing_procs2[0] == 0) and_zero = true;
+ sharing_procs.swap( sharing_procs2 );
- else if (resolve_dim < shared_dim)
- sp_range.merge(vp_range);
- else
- sp_range = sp_range.intersect(vp_range);
- // need to also save rank zero, since ranges don't handle that
- if (and_zero && sharing_procs2[0] != 0) and_zero = false;
+ else if (resolve_dim < shared_dim) {
+ sharing_procs1.clear();
+ set_union( sharing_procs.begin(), sharing_procs.end(),
+ sharing_procs2.begin(), sharing_procs2.end(),
+ std::back_inserter( sharing_procs1 ) );
+ sharing_procs.swap( sharing_procs1 );
+ else {
+ set_intersection( sharing_procs.begin(), sharing_procs.end(),
- if (sp_range.empty() && resolve_dim < shared_dim) continue;
+ if (sharing_procs.empty() && resolve_dim < shared_dim) continue;
// intersection is the owning proc(s) for this skin ent
- if (sp_range.empty() && !and_zero) continue;
+ if (sharing_procs.empty()) continue;
- MBRange::iterator rit2;
- // set tag for this ent
- int j = 0;
- if (and_zero) sharing_procs[j++] = 0;
- for (rit2 = sp_range.begin(); rit2 != sp_range.end();
- rit2++, j++) sharing_procs[j] = *rit2;
+ for (vii = sharing_procs.begin(); vii != sharing_procs.end(); ++vii)
+ assert( *vii < (int)procConfig.proc_size() );
+ // fill extra entries with -1
+ assert(sharing_procs.size() <= MAX_SHARING_PROCS);
+ sharing_procs.resize( MAX_SHARING_PROCS, -1 );
proc_nranges[sharing_procs].insert(*rit);
- if (2 > j) {
+ if (sharing_procs.size() < 2) {
result = mbImpl->tag_set_data(sharedp_tag, &(*rit), 1,
&sharing_procs[0]);
RRA("Failed to set sharedp_tag on non-vertex skin entity.");
@@ -2805,7 +2805,7 @@
// reset sharing proc(s) tags
+ sharing_procs.clear();
@@ -2813,8 +2813,8 @@
std::map<int, MBRange> proc_ranges;
for (std::map<std::vector<int>, MBRange>::iterator mit = proc_nranges.begin();
mit != proc_nranges.end(); mit++) {
- for (unsigned int i = 0; i < (*mit).first.size(); i++)
- proc_ranges[(*mit).first[i]].merge((*mit).second);
+ for (unsigned int i = 0; i < mit->first.size(); i++)
+ proc_ranges[mit->first[i]].merge(mit->second);
return MB_SUCCESS;
