[MOAB-dev] r2105 - MOAB/trunk/tools/mbzoltan
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Mon Sep 29 15:57:48 CDT 2008
Author: kraftche
Date: 2008-09-29 15:57:42 -0500 (Mon, 29 Sep 2008)
New Revision: 2105
Modified:
   MOAB/trunk/tools/mbzoltan/MBZoltan.cpp
   MOAB/trunk/tools/mbzoltan/MBZoltan.hpp
Log:
Patch from Jed Brown fixing MBZoltan, which I broke with recent
changes to the handling of MPI rank and size data in MOAB.
Modified: MOAB/trunk/tools/mbzoltan/MBZoltan.cpp
--- MOAB/trunk/tools/mbzoltan/MBZoltan.cpp	2008-09-29 20:54:32 UTC (rev 2104)
+++ MOAB/trunk/tools/mbzoltan/MBZoltan.cpp	2008-09-29 20:57:42 UTC (rev 2105)
@@ -61,7 +61,7 @@
       !strcmp(zmethod, "PHG") && !strcmp(zmethod, "PARMETIS") &&
       !strcmp(zmethod, "OCTPART"))
-    std::cout << "ERROR node " << mbImpl->proc_rank() << ": Method must be "
+    std::cout << "ERROR node " << mbpc->proc_config().proc_rank() << ": Method must be "
               << "RCB, RIB, HSFC, Hypergraph (PHG), PARMETIS, or OCTPART"
               << std::endl;
     return MB_FAILURE;
@@ -76,7 +76,7 @@
   MBErrorCode result;
-  if (mbImpl->proc_rank() == 0) {
+  if (mbpc->proc_config().proc_rank() == 0) {
     result = assemble_graph(3, pts, ids, adjs, length, elems); RR;
@@ -166,8 +166,8 @@
   mbFinalizePoints((int)ids.size(), numExport, exportLocalIds,
                    exportProcs, &assignment);
-    MBErrorCode result = write_partition(mbImpl->proc_size(), elems, assignment,
+    MBErrorCode result = write_partition(mbpc->proc_config().proc_size(), elems, assignment,
                                          write_as_sets, write_as_tags);
     if (MB_SUCCESS != result) return result;
@@ -202,7 +202,7 @@
                                      const int part_dim)
     // should only be called in serial
-  if (mbImpl->proc_size() != 1) {
+  if (mbpc->proc_config().proc_size() != 1) {
     std::cout << "MBZoltan::partition_mesh must be called in serial."
               << std::endl;
     return MB_FAILURE;
@@ -213,7 +213,7 @@
       strcmp(zmethod, "PHG") && strcmp(zmethod, "PARMETIS") &&
               << std::endl;
     return MB_FAILURE;
@@ -334,8 +334,7 @@
   if (MB_SUCCESS != result || elems.empty()) return result;
     // assign global ids
-  MBParallelComm mbpc(mbImpl);
-  result = mbpc.assign_global_ids(0, dimension); RR;
+  result = mbpc->assign_global_ids(0, dimension); RR;
     // now assemble the graph, calling MeshTopoUtil to get bridge adjacencies through d-1 dimensional
     // neighbors
@@ -477,7 +476,7 @@
 void MBZoltan::SetRCB_Parameters()
-  if (mbImpl->proc_rank() == 0) std::cout << "\nRecursive Coordinate Bisection" << std::endl;
+  if (mbpc->proc_config().proc_rank() == 0) std::cout << "\nRecursive Coordinate Bisection" << std::endl;
   // General parameters:
   myZZ->Set_Param("DEBUG_LEVEL", "0");     // no debug messages
@@ -492,7 +491,7 @@
 void MBZoltan::SetRIB_Parameters()
-  if (mbImpl->proc_rank() == 0) std::cout << "\nRecursive Inertial Bisection" << std::endl;
+  if (mbpc->proc_config().proc_rank() == 0) std::cout << "\nRecursive Inertial Bisection" << std::endl;
@@ -506,7 +505,7 @@
 void MBZoltan::SetHSFC_Parameters()
-  if (mbImpl->proc_rank() == 0) std::cout << "\nHilbert Space Filling Curve" << std::endl;
+  if (mbpc->proc_config().proc_rank() == 0) std::cout << "\nHilbert Space Filling Curve" << std::endl;
@@ -519,7 +518,7 @@
 void MBZoltan::SetHypergraph_Parameters(const char *phg_method)
-  if (mbImpl->proc_rank() == 0) std::cout << "\nHypergraph (or PHG): " << std::endl;
+  if (mbpc->proc_config().proc_rank() == 0) std::cout << "\nHypergraph (or PHG): " << std::endl;
@@ -531,7 +530,7 @@
 void MBZoltan::SetPARMETIS_Parameters(const char *parmetis_method)
-  if (mbImpl->proc_rank() == 0) std::cout << "\nPARMETIS: " << parmetis_method << std::endl;
+  if (mbpc->proc_config().proc_rank() == 0) std::cout << "\nPARMETIS: " << parmetis_method << std::endl;
@@ -544,7 +543,7 @@
 void MBZoltan::SetOCTPART_Parameters(const char *oct_method)
-  if (mbImpl->proc_rank() == 0) std::cout << "\nOctree Partitioning: " << oct_method
+  if (mbpc->proc_config().proc_rank() == 0) std::cout << "\nOctree Partitioning: " << oct_method
 			   << std::endl;
@@ -571,23 +570,23 @@
   int *sendNborId;
   int *sendProcs;
       /* divide pts to start */
-    numPts = (int *)malloc(sizeof(int) * mbImpl->proc_size());
-    ptsPerProc = npts / mbImpl->proc_size();
+    numPts = (int *)malloc(sizeof(int) * mbpc->proc_config().proc_size());
+    ptsPerProc = npts / mbpc->proc_config().proc_size();
     ptsAssigned = 0;
-    for (i=0; (int) i < mbImpl->proc_size()-1; i++)
+    for (i=0; (int) i < mbpc->proc_config().proc_size()-1; i++)
       numPts[i] = ptsPerProc;
       ptsAssigned += ptsPerProc;
-    numPts[mbImpl->proc_size()-1] = npts - ptsAssigned;
+    numPts[mbpc->proc_config().proc_size()-1] = npts - ptsAssigned;
-    mySize = numPts[mbImpl->proc_rank()];
+    mySize = numPts[mbpc->proc_config().proc_rank()];
     sendPts = pts + (3 * numPts[0]);
     sendIds = ids + numPts[0];
     sendEdges = length + numPts[0];
@@ -604,14 +603,14 @@
     nborProcs = (int *)malloc(sizeof(int) * sum);
     for (j=0; j<sum; j++)
-      if ((i = adjs[j]/ptsPerProc) < mbImpl->proc_size())
+      if ((i = adjs[j]/ptsPerProc) < mbpc->proc_config().proc_size())
         nborProcs[j] = i;
       else
-        nborProcs[j] = mbImpl->proc_size() - 1;
+        nborProcs[j] = mbpc->proc_config().proc_size() - 1;
     sendProcs = nborProcs + (sendNborId - adjs);
-    for (i=1; (int)i<mbImpl->proc_size(); i++)
+    for (i=1; (int)i<mbpc->proc_config().proc_size(); i++)
       MPI_Send(&numPts[i], 1, MPI_INT, i, 0x00,MPI_COMM_WORLD);
       MPI_Send(sendPts, 3 * numPts[i], MPI_DOUBLE, i, 0x01,MPI_COMM_WORLD);
@@ -675,24 +674,24 @@
   /* assign pts to start */
     MyAssignment = (int *)malloc(sizeof(int) * npts);
   else
     MyAssignment = (int *)malloc(sizeof(int) * NumPoints);
   for (i=0; i<NumPoints; i++)
-    MyAssignment[i] = mbImpl->proc_rank();
+    MyAssignment[i] = mbpc->proc_config().proc_rank();
   for (i=0; i<numExport; i++)
     MyAssignment[exportLocalIDs[i]] = exportProcs[i];
       /* collect pts */
       recvA = MyAssignment + NumPoints;
-      for (i=1; i< (int) mbImpl->proc_size(); i++)
+      for (i=1; i< (int) mbpc->proc_config().proc_size(); i++)
 	  MPI_Recv(&numPts, 1, MPI_INT, i, 0x04, MPI_COMM_WORLD, &stat);
 	  MPI_Recv(recvA, numPts, MPI_INT, i, 0x05, MPI_COMM_WORLD, &stat);
@@ -713,13 +712,13 @@
   int fail = 0;
   int i;
-  int *vals = (int *)malloc(mbImpl->proc_size() * sizeof(int));
+  int *vals = (int *)malloc(mbpc->proc_config().proc_size() * sizeof(int));
   MPI_Allgather(&rc, 1, MPI_INT, vals, 1, MPI_INT, MPI_COMM_WORLD);
-  for (i=0; i<mbImpl->proc_size(); i++){
+  for (i=0; i<mbpc->proc_config().proc_size(); i++){
     if (vals[i] != ZOLTAN_OK){
-      if (0 == mbImpl->proc_rank()){
+      if (0 == mbpc->proc_config().proc_rank()){
         mbShowError(vals[i], "Result on process ");
       fail = 1;
@@ -743,15 +742,15 @@
   v1[2] = exp;
   v1[3] = change;
-  if (mbImpl->proc_rank() == 0){
-    v2 = (int *)malloc(4 * mbImpl->proc_size() * sizeof(int));
+  if (mbpc->proc_config().proc_rank() == 0){
+    v2 = (int *)malloc(4 * mbpc->proc_config().proc_size() * sizeof(int));
   MPI_Gather(v1, 4, MPI_INT, v2, 4, MPI_INT, 0, MPI_COMM_WORLD);
     fprintf(stdout,"======%s======\n",s);
-    for (i=0, v=v2; i<mbImpl->proc_size(); i++, v+=4){
+    for (i=0, v=v2; i<mbpc->proc_config().proc_size(); i++, v+=4){
       fprintf(stdout,"%d: originally had %d, import %d, exp %d, %s\n",
         i, v[0], v[1], v[2],
         v[3] ? "a change of partitioning" : "no change");
@@ -774,19 +773,19 @@
   switch (val)
     case ZOLTAN_OK:
-      printf("%d: SUCCESSFUL\n", mbImpl->proc_rank());
+      printf("%d: SUCCESSFUL\n", mbpc->proc_config().proc_rank());
       break;
     case ZOLTAN_WARN:
-      printf("%d: WARNING\n", mbImpl->proc_rank());
+      printf("%d: WARNING\n", mbpc->proc_config().proc_rank());
       break;
     case ZOLTAN_FATAL:
-      printf("%d: FATAL ERROR\n", mbImpl->proc_rank());
+      printf("%d: FATAL ERROR\n", mbpc->proc_config().proc_rank());
       break;
     case ZOLTAN_MEMERR:
-      printf("%d: MEMORY ALLOCATION ERROR\n", mbImpl->proc_rank());
+      printf("%d: MEMORY ALLOCATION ERROR\n", mbpc->proc_config().proc_rank());
       break;
     default:
-      printf("%d: INVALID RETURN CODE\n", mbImpl->proc_rank());
+      printf("%d: INVALID RETURN CODE\n", mbpc->proc_config().proc_rank());
       break;
   return;
Modified: MOAB/trunk/tools/mbzoltan/MBZoltan.hpp
--- MOAB/trunk/tools/mbzoltan/MBZoltan.hpp	2008-09-29 20:54:32 UTC (rev 2104)
+++ MOAB/trunk/tools/mbzoltan/MBZoltan.hpp	2008-09-29 20:57:42 UTC (rev 2105)
@@ -57,6 +57,7 @@
 #include <vector>
 #include "MBInterface.hpp"
+#include "MBParallelComm.hpp"
   class MBZoltan
@@ -66,7 +67,9 @@
              int argc = 0, char **argv = NULL)
         : mbImpl(impl), myZZ(NULL), newMoab(false), useCoords(use_coords),
           argcArg(argc), argvArg(argv)
+        mbpc = MBParallelComm::get_pcomm(mbImpl, 0);
     ~MBZoltan();
@@ -111,6 +114,8 @@
     MBInterface *mbImpl;
+    MBParallelComm *mbpc;
     Zoltan *myZZ;
     bool newMoab;
