[MOAB-dev] r2097 - in MOAB/trunk: parallel tools/iMesh
tautges at mcs.anl.gov tautges at mcs.anl.gov
Sun Sep 28 11:08:58 CDT 2008
Author: tautges
Date: 2008-09-28 11:08:58 -0500 (Sun, 28 Sep 2008)
New Revision: 2097
Modified:
   MOAB/trunk/parallel/Makefile.am
   MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
Adding a couple of source/header files to non-installed set so that make dist works.
Making implementation of getEntAdj more efficient for vertices in iMesh.
Modified: MOAB/trunk/parallel/Makefile.am
--- MOAB/trunk/parallel/Makefile.am	2008-09-26 16:39:57 UTC (rev 2096)
+++ MOAB/trunk/parallel/Makefile.am	2008-09-28 16:08:58 UTC (rev 2097)
@@ -21,6 +21,7 @@
 MOAB_PARALLEL_TEST =
 MOAB_PARALLEL_CHECK =
 if PARALLEL
+# The list of source files, and any header files that do not need to be installed
   MOAB_PARALLEL_SRCS += \
      MBParallelComm.cpp \
      MBProcConfig.cpp \
@@ -29,8 +30,9 @@
      crystal.c errmem.c \
      transfer.c gs.c gs.h tuple_list.c \
      tuple_list.h \
-     sort.c sort.h
+     sort.c sort.h minmax.h transfer.h sort_imp.c
+# The list of header files which are to be installed
   MOAB_PARALLEL_HDRS += \
      MBParallelComm.hpp \
      MBProcConfig.hpp \
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2008-09-26 16:39:57 UTC (rev 2096)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2008-09-28 16:08:58 UTC (rev 2097)
@@ -1006,22 +1006,31 @@
     int prev_off = 0;
     std::vector<MBEntityHandle> all_adj_ents;
+    std::vector<MBEntityHandle> adj_ents;
+    const MBEntityHandle *connect;
+    int num_connect;
     for ( ; entity_iter != entity_end; ++entity_iter)
       *off_iter = prev_off;
       off_iter++;
-      std::vector<MBEntityHandle> adj_ents;
-      result = MBI->get_adjacencies( entity_iter, 1,
-                                     entity_type_requested, false, adj_ents );
-      if (MB_SUCCESS != result) {
-        iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getEntArrAdj: trouble getting adjacency list.");
-        RETURN(iBase_ERROR_MAP[result]);
+      if (iBase_VERTEX != entity_type_requested) {
+        adj_ents.clear();
+        result = MBI->get_adjacencies( entity_iter, 1,
+                                       entity_type_requested, false, adj_ents );
+        if (MB_SUCCESS != result) {
+          iMesh_processError(iBase_ERROR_MAP[result], "iMesh_getEntArrAdj: trouble getting adjacency list.");
+          RETURN(iBase_ERROR_MAP[result]);
+        std::copy(adj_ents.begin(), adj_ents.end(), std::back_inserter(all_adj_ents));
+        prev_off += adj_ents.size();
-      std::copy(adj_ents.begin(), adj_ents.end(), std::back_inserter(all_adj_ents));
-      prev_off += adj_ents.size();
+      else {
+        result = MBI->get_connectivity(*entity_iter, connect, num_connect);
+        std::copy(connect, connect+num_connect, std::back_inserter(all_adj_ents));
+        prev_off += num_connect;
