[MOAB-dev] r2093 - in MOAB/trunk: . parallel test/perf tools/converter tools/iMesh tools/mbperf
kraftche at mcs.anl.gov
Thu Sep 25 12:22:34 CDT 2008
Author: kraftche
Date: 2008-09-25 12:22:33 -0500 (Thu, 25 Sep 2008)
New Revision: 2093
Removed:
MOAB/trunk/MBHandleUtils.cpp
MOAB/trunk/MBHandleUtils.hpp
Modified:
MOAB/trunk/FileTokenizer.cpp
MOAB/trunk/FileTokenizer.hpp
MOAB/trunk/MBCore.cpp
MOAB/trunk/MBCore.hpp
MOAB/trunk/MBInterface.hpp
MOAB/trunk/MBInternals.hpp
MOAB/trunk/MBReadUtil.cpp
MOAB/trunk/MBReadUtil.hpp
MOAB/trunk/MBReadUtilIface.hpp
MOAB/trunk/MBTest.cpp
MOAB/trunk/Makefile.am
MOAB/trunk/ReadGmsh.cpp
MOAB/trunk/ReadHDF5.cpp
MOAB/trunk/ReadNCDF.cpp
MOAB/trunk/ReadSTL.cpp
MOAB/trunk/ReadVtk.cpp
MOAB/trunk/SequenceManager.cpp
MOAB/trunk/SequenceManager.hpp
MOAB/trunk/Tqdcfr.cpp
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/parallel/MBParallelData.cpp
MOAB/trunk/parallel/mbparallelcomm_test.cpp
MOAB/trunk/parallel/parallel_hdf5_test.cc
MOAB/trunk/scdseq_test.cpp
MOAB/trunk/test/perf/perf.cpp
MOAB/trunk/test/perf/seqperf.cpp
MOAB/trunk/tools/converter/convert.cpp
MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
MOAB/trunk/tools/mbperf/mbperf.cpp
Log:
Remove embedded parallel rank from MBEntityHandle, and all related functionality
Modified: MOAB/trunk/FileTokenizer.cpp
--- MOAB/trunk/FileTokenizer.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/FileTokenizer.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -462,3 +462,26 @@
return false;
+bool FileTokenizer::get_binary( size_t size, void* mem )
+ // if data in buffer
+ if (nextToken != bufferEnd) {
+ // if requested size is less than buffer contents,
+ // just pass back part of the buffer
+ if (bufferEnd - nextToken <= size) {
+ memcpy( mem, nextToken, size );
+ nextToken += size;
+ return true;
+ // copy buffer contents into memory and clear buffer
+ memcpy( mem, nextToken, bufferEnd - nextToken );
+ size -= bufferEnd - nextToken;
+ mem = reinterpret_cast<char*>(mem) + (bufferEnd - nextToken);
+ nextToken = bufferEnd;
+ // read any additional data from file
+ return size == fread( mem, 1, size, filePtr );
Modified: MOAB/trunk/FileTokenizer.hpp
--- MOAB/trunk/FileTokenizer.hpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/FileTokenizer.hpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -148,6 +148,14 @@
bool get_bytes( size_t count, unsigned char* array );
+ /** \brief Read binary data (interleaved with ASCII)
+ * Read a block of binary data.
+ *\param bytes Number of bytes to read
+ *\param mem Memory address at which to store data.
+ bool get_binary( size_t bytes, void* mem );
/** \brief Parse a sequence of bit or boolean values.
* Read the specified number of space-delimited values.
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/MBCore.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -41,7 +41,6 @@
#include "MBReaderWriterSet.hpp"
#include "MBReaderIface.hpp"
#include "MBWriterIface.hpp"
-#include "MBHandleUtils.hpp"
#ifdef USE_MPI
/* Leave MBParallelComm.hpp before mpi.h or MPICH2 will fail
@@ -114,8 +113,7 @@
//! Constructor
-MBCore::MBCore( int rank, int num_procs )
- : handleUtils(rank, num_procs)
+MBCore::MBCore()
#ifdef XPCOM_MB
NS_INIT_ISUPPORTS();
@@ -128,6 +126,23 @@
+//! Constructor
+MBCore::MBCore( int , int )
+ std::cerr << "Using depricated construtor: MBCore::MBCore(rank,size)" << std::endl;
+#ifdef XPCOM_MB
+ NS_INIT_ISUPPORTS();
+#endif
+ if (initialize() != MB_SUCCESS)
+ printf("Error initializing MB\n");
+ exit(1);
//! destructor
MBCore::~MBCore()
@@ -152,7 +167,7 @@
geomDimensionTag = 0;
globalIdTag = 0;
- sequenceManager = new SequenceManager( handleUtils );
+ sequenceManager = new SequenceManager;
if (!sequenceManager)
return MB_MEMORY_ALLOCATION_FAILED;
@@ -1736,24 +1751,11 @@
const int num_nodes,
MBEntityHandle &handle)
- return create_element( type, handleUtils.proc_rank(),
- connectivity, num_nodes, handle );
-MBErrorCode MBCore::create_element( const MBEntityType type,
- const unsigned processor_id,
- const MBEntityHandle* connectivity,
- const int num_nodes,
- MBEntityHandle& handle )
// make sure we have enough vertices for this entity type
if(num_nodes < MBCN::VerticesPerEntity(type))
return MB_FAILURE;
- if (processor_id >= handleUtils.proc_size())
- return MB_INDEX_OUT_OF_RANGE;
- MBErrorCode status = sequence_manager()->create_element(type, processor_id, connectivity, num_nodes, handle);
+ MBErrorCode status = sequence_manager()->create_element(type, connectivity, num_nodes, handle);
if (MB_SUCCESS == status)
status = aEntityFactory->notify_create_entity( handle, connectivity, num_nodes);
@@ -1763,31 +1765,14 @@
//! creates a vertex based on coordinates, returns a handle and error code
MBErrorCode MBCore::create_vertex(const double coords[3], MBEntityHandle &handle )
- return create_vertex( handleUtils.proc_rank(), coords, handle );
-MBErrorCode MBCore::create_vertex( const unsigned processor_id, const double* coords, MBEntityHandle& handle )
// get an available vertex handle
- return sequence_manager()->create_vertex( processor_id, coords, handle );
+ return sequence_manager()->create_vertex( coords, handle );
MBErrorCode MBCore::create_vertices(const double *coordinates,
const int nverts,
MBRange &entity_handles )
- return create_vertices(handleUtils.proc_rank(), coordinates,
- nverts, entity_handles);
-MBErrorCode MBCore::create_vertices(const unsigned processor_id,
- const double *coordinates,
- const int nverts,
- MBRange &entity_handles )
// Create vertices
void* tmp_ptr;
MBErrorCode result = this->query_interface("MBReadUtilIface", &tmp_ptr );
@@ -1797,7 +1782,6 @@
std::vector<double*> arrays;
MBEntityHandle start_handle_out = 0;
result = read_iface->get_node_arrays( 3, nverts, MB_START_ID,
- processor_id,
start_handle_out, arrays);
if (MB_SUCCESS != result) return result;
for (int i = 0; i < nverts; i++) {
@@ -2292,11 +2276,9 @@
MBErrorCode MBCore::create_meshset(const unsigned int options,
MBEntityHandle &ms_handle,
- int ,
- int start_proc)
+ int )
- if (-1 == start_proc) start_proc = handleUtils.proc_rank();
- return sequence_manager()->create_mesh_set( start_proc, options, ms_handle );
+ return sequence_manager()->create_mesh_set( options, ms_handle );
MBErrorCode MBCore::get_meshset_options( const MBEntityHandle ms_handle,
@@ -3091,24 +3073,6 @@
tag_storage, amortized_tag_storage );
- //! Return the rank of this processor
-const int MBCore::proc_rank() const
- return handleUtils.proc_rank();
- //! Return the number of processors
-const int MBCore::proc_size() const
- return handleUtils.proc_size();
- //! Return the utility for dealing with entity handles
-const MBHandleUtils &MBCore::handle_utils() const
- return handleUtils;
void MBCore::print_database() const
MBErrorCode rval;
Modified: MOAB/trunk/MBCore.hpp
--- MOAB/trunk/MBCore.hpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/MBCore.hpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -17,7 +17,6 @@
#define MB_IMPL_GENERAL_HPP
#include "MBInterface.hpp"
#include <map>
class MBWriteUtil;
@@ -27,7 +26,6 @@
class TagServer;
class MBError;
class MBReaderWriterSet;
-class MBHandleUtils;
#ifdef XPCOM_MB
@@ -45,8 +43,11 @@
public:
//!constructor
- MB_DLL_EXPORT MBCore( int rank = 0, int num_cpu = 1 );
+ MB_DLL_EXPORT MBCore();
+ //! depricated constructor -- values are ignored
+ MB_DLL_EXPORT MBCore( int rank, int num_cpu );
//!destructor
MB_DLL_EXPORT ~MBCore();
@@ -439,21 +440,6 @@
MBEntityHandle &element_handle);
- /**\brief Create element given CPU ID and connectivity.
- * Create an element with the specified processor ID
- *\param type The type of the element
- *\param processor_id The ID of the CPU on owning the element
- *\param connectivity The connectivity list for the element
- *\param num_nodes The length of the connectivity list
- *\param element_handle Output handle value.
- virtual MBErrorCode create_element (const MBEntityType type,
- const MBEntityHandle *connectivity,
- MBEntityHandle &element_handle);
//! Creates a vertex based on coordinates.
\param coordinates Array that has 3 doubles in it.
@@ -469,17 +455,6 @@
virtual MBErrorCode create_vertex(const double coordinates[3],
MBEntityHandle &entity_handle );
- /**\brief Create vertex given CPU ID and coordinates.
- * Create a vertex with the specified processor ID
- *\param coordinates The vertex coordinates
- *\param entity_handle Output handle value.
- virtual MBErrorCode create_vertex( const unsigned processor_id,
- const double coordinates[3],
- MBEntityHandle &entity_handle );
//! Create a set of vertices with the specified coordinates
\param coordinates Array that has 3*n doubles in it.
@@ -490,18 +465,6 @@
const int nverts,
MBRange &entity_handles );
- //! Create a set of vertices with the specified coordinates and proc id
- \param processor_id Processor id for these vertices
- \param coordinates Array that has 3*n doubles in it.
- \param nverts Number of vertices to create
- \param entity_handles MBRange passed back with new vertex handles
- virtual MBErrorCode create_vertices(const unsigned processor_id,
- const int nverts,
- MBRange &entity_handles );
//! merges two entities
virtual MBErrorCode merge_entities(MBEntityHandle entity_to_keep,
MBEntityHandle entity_to_remove,
@@ -833,8 +796,7 @@
//! creates a mesh set
virtual MBErrorCode create_meshset(const unsigned int options,
- int start_id = 0,
- int start_proc = -1);
+ int start_id = 0);
//! Empty a vector of mesh set
/** Empty a mesh set.
@@ -1098,16 +1060,7 @@
unsigned long* tag_storage = 0,
unsigned long* amortized_tag_storage = 0 );
- virtual const int proc_rank() const;
- virtual const int proc_size() const;
- virtual const MBHandleUtils &handle_utils() const;
void print_database() const;
private:
@@ -1144,9 +1097,6 @@
//! the overall geometric dimension of this mesh
int geometricDimension;
- //! utility for dealing with handles, proc's, etc.
- MBHandleUtils handleUtils;
MBTag materialTag;
MBTag neumannBCTag;
MBTag dirichletBCTag;
Deleted: MOAB/trunk/MBHandleUtils.cpp
--- MOAB/trunk/MBHandleUtils.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/MBHandleUtils.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -1,110 +0,0 @@
-#include "MBInternals.hpp"
-#include "assert.h"
-MBHandleUtils::MBHandleUtils(int proc_rank, int proc_size) :
- procRank((int) proc_rank),
- procSize((int) proc_size),
- procWidth( ceil_log_2(procSize)),
- idWidth( MB_ID_WIDTH - procWidth ),
- idMask( MB_ID_MASK >> procWidth ),
- procMask( ~(MB_TYPE_MASK|idMask) )
- assert(0 <= proc_rank && 0 <= proc_size);
-MBEntityHandle MBHandleUtils::create_handle( MBEntityType type,
- MBEntityID sub_id,
- unsigned proc ) const
- int err;
- return CREATE_HANDLE( type, create_id( sub_id, proc ), err );
-MBRange MBHandleUtils::subset_by_proc( unsigned proc,
- const MBRange &range) const
- int junk;
- MBRange result;
- MBRange::iterator insert_pos = result.begin();
- MBRange::const_pair_iterator iter;
- MBEntityHandle s, e;
- for (iter = range.const_pair_begin(); iter != range.const_pair_end(); ++iter)
- const MBEntityType beg_type = TYPE_FROM_HANDLE(iter->first),
- end_type = TYPE_FROM_HANDLE(iter->second);
- const unsigned beg_rank = rank_from_handle(iter->first),
- end_rank = rank_from_handle(iter->second);
- if (beg_type != end_type) {
- if (beg_rank <= proc) {
- s = beg_rank == proc ? iter->first :
- CREATE_HANDLE( beg_type, create_id(0,proc), junk );
- e = CREATE_HANDLE( beg_type, last_id(proc), junk );
- insert_pos = result.insert( insert_pos, s, e );
- MBEntityType t = beg_type;
- for (++t; t != end_type; ++t) {
- s = CREATE_HANDLE( t, create_id(0,proc), junk );
- e = CREATE_HANDLE( t, last_id(proc), junk );
- if (end_rank >= proc) {
- e = end_rank == proc ? iter->second :
- CREATE_HANDLE( end_type, last_id(proc), junk );
- s = CREATE_HANDLE( end_type, create_id(0,proc), junk );
- else if (beg_rank <= proc && end_rank >= proc) {
- s = (beg_rank == proc) ? iter->first :
- e = (end_rank == proc) ? iter->second :
- CREATE_HANDLE( beg_type, last_id(proc), junk );
- return result;
-MBRange::const_iterator MBHandleUtils::lower_bound( MBEntityType type,
- unsigned proc,
- int err;
- MBEntityHandle h = CREATE_HANDLE( type, create_id(0,proc), err );
- return err ? range.end() :
- MBRange::lower_bound(range.begin(), range.end(), h);
-MBRange::const_iterator MBHandleUtils::upper_bound( MBEntityType type,
- unsigned proc,
- int err;
- MBEntityHandle h = CREATE_HANDLE( type, last_id(proc), err );
- MBRange::upper_bound(range.begin(), range.end(), h);
-std::pair<MBRange::const_iterator,MBRange::const_iterator>
-MBHandleUtils::equal_range( MBEntityType type, unsigned proc,
- std::pair<MBRange::const_iterator, MBRange::const_iterator> iters;
- int err;
- MBEntityHandle h;
- h = CREATE_HANDLE( type, create_id(0,proc), err );
- iters.first = err ? range.end() :
- h = CREATE_HANDLE( type, last_id(proc), err );
- iters.second = err ? range.end() :
- MBRange::upper_bound( iters.first, range.end(), h );
- return iters;
Deleted: MOAB/trunk/MBHandleUtils.hpp
--- MOAB/trunk/MBHandleUtils.hpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/MBHandleUtils.hpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -1,90 +0,0 @@
-#ifndef MBHANDLEUTILS_HPP
-#define MBHANDLEUTILS_HPP
-#include "MBInterface.hpp"
-#include "MBRange.hpp"
-public:
- MBHandleUtils(int proc_rank, int proc_size);
- //! Get processor rank
- unsigned proc_rank() const {return procRank;}
- //! Get processor size
- unsigned proc_size() const {return procSize;}
- //! Get CPU number from handle
- unsigned rank_from_handle( MBEntityHandle handle ) const
- { return (handle & procMask) >> idWidth; }
- //! Get CPU number from ID
- unsigned rank_from_id( MBEntityID id ) const
- { return id >> idWidth; }
- //! Get maximum entity ID that can be stored in a
- //! a handle, allowing for the processor number
- MBEntityID max_id() const
- { return idMask; }
- //! Create the ID portion of a handle by combining
- //! an actual ID and a processor number
- MBEntityID create_id( MBEntityID sub_id, unsigned proc ) const
- { return ((MBEntityHandle)proc << idWidth) | (MBEntityHandle)sub_id; }
- //! Extract non-rank portion of entity ID from handle
- MBEntityID id_from_handle( MBEntityHandle h ) const
- { return h & idMask; }
- MBEntityID first_id( unsigned proc ) const
- { return create_id( 1, proc ); }
- MBEntityID last_id( unsigned proc ) const
- { return create_id( max_id(), proc ); }
- //! Create an entity handle given type, rank, and id
- MBEntityHandle create_handle( MBEntityType type,
- unsigned proc ) const;
- //! return a subset with corresponding proc values in handles
- MBRange subset_by_proc( unsigned proc,
- const MBRange &range) const;
- //! return a lower bound for handles with corresponding proc values
- MBRange::const_iterator lower_bound( MBEntityType type,
- unsigned proc,
- //! return an upper bound for handles with corresponding proc values
- MBRange::const_iterator upper_bound( MBEntityType type,
- unsigned proc,
- //! return an equal range for handles with corresponding proc values
- std::pair<MBRange::const_iterator,MBRange::const_iterator>
- equal_range( MBEntityType type, unsigned proc,
-private:
-/** Calculate ceiling of log 2 of a positive integer */
- static unsigned ceil_log_2( unsigned n );
- unsigned procRank; //!< ID of this processor
- unsigned procSize; //!< Total number of processors
- unsigned procWidth; //!< Number of bits in handle for processor ID
- unsigned idWidth; //!< Number of bits in handle for entity ID
- MBEntityHandle idMask;
- MBEntityHandle procMask;
-inline unsigned MBHandleUtils::ceil_log_2( unsigned n )
- unsigned result;
- for (result = 0; n > (((MBEntityHandle)1)<<result); ++result);
- return result;
-#endif
Modified: MOAB/trunk/MBInterface.hpp
--- MOAB/trunk/MBInterface.hpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/MBInterface.hpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -60,8 +60,6 @@
0xbd, 0xf6, 0xc3, 0x4e, 0xf7, 0x1f, 0x5a, 0x52 );
#if defined(XPCOM_MB)
class NS_NO_VTABLE MBInterface : public nsISupports {
#else
@@ -805,17 +803,6 @@
MBEntityHandle &entity_handle ) = 0;
- MBEntityHandle &entity_handle ) = 0;
@@ -826,18 +813,6 @@
const int nverts,
MBRange &entity_handles ) = 0;
- const int nverts,
- MBRange &entity_handles ) = 0;
//! Merge two entities into a single entity
/** Merge two entities into a single entities, with <em>entity_to_keep</em> receiving
adjacencies that were on <em>entity_to_remove</em>.
@@ -1307,8 +1282,7 @@
- int start_id = 0,
- int start_proc = -1) = 0;
+ int start_id = 0) = 0;
@@ -1666,16 +1640,6 @@
unsigned num_tags = 0,
unsigned long* amortized_tag_storage = 0 ) = 0;
- virtual const int proc_rank() const = 0;
- virtual const int proc_size() const = 0;
- virtual const MBHandleUtils &handle_utils() const = 0;
//! predicate for STL algorithms. Returns true if the entity handle is
Modified: MOAB/trunk/MBInternals.hpp
--- MOAB/trunk/MBInternals.hpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/MBInternals.hpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -26,6 +26,7 @@
#endif
#include "MBTypes.h"
+#include <assert.h>
/*! Define MBEntityHandle for both 32 bit and 64 bit systems.
* The decision to use 64 bit handles must be made at compile time.
@@ -62,6 +63,19 @@
return (((MBEntityHandle)type) << MB_ID_WIDTH)|id;
+inline MBEntityHandle CREATE_HANDLE( const unsigned type, const MBEntityID id )
+ // if compiling without asserts, simplify things a bit
+#ifdef NDEBUG
+ return (((MBEntityHandle)type) << MB_ID_WIDTH)|id;
+#else
+ int err;
+ MBEntityHandle result = CREATE_HANDLE( type, id, err );
+ assert(!err);
+ return result;
+#endif
inline MBEntityHandle FIRST_HANDLE( unsigned type )
{ return (((MBEntityHandle)type) << MB_ID_WIDTH)|MB_START_ID; }
Modified: MOAB/trunk/MBReadUtil.cpp
--- MOAB/trunk/MBReadUtil.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/MBReadUtil.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -36,14 +36,10 @@
-unsigned MBReadUtil::parallel_rank() const
- { return mMB->proc_rank(); }
MBErrorCode MBReadUtil::get_node_arrays(
const int /*num_arrays*/,
const int preferred_start_id,
- const int preferred_start_proc,
MBEntityHandle& actual_start_handle,
std::vector<double*>& arrays)
@@ -60,7 +56,7 @@
// create an entity sequence for these nodes
error = mMB->sequence_manager()->create_entity_sequence(
MBVERTEX, num_nodes, 0, preferred_start_id,
- preferred_start_proc, actual_start_handle,
+ actual_start_handle,
seq);
if(error != MB_SUCCESS)
@@ -86,7 +82,6 @@
const int verts_per_element,
const MBEntityType mdb_type,
- const int proc,
MBEntityHandle*& array)
@@ -104,10 +99,9 @@
// return MB_TYPE_OUT_OF_RANGE;
// make an entity sequence to hold these elements
- unsigned proc_id = proc < 0 ? parallel_rank() : proc;
mdb_type, num_elements, verts_per_element, preferred_start_id,
- proc_id, actual_start_handle, seq);
+ actual_start_handle, seq);
if (MB_SUCCESS != error)
return error;
@@ -130,7 +124,6 @@
MBErrorCode MBReadUtil::create_entity_sets( MBEntityID num_sets,
const unsigned* flags ,
MBEntityID start_id,
- int proc,
MBEntityHandle& start_handle )
if (num_sets < 1) {
@@ -142,7 +135,6 @@
EntitySequence* seq;
error = mMB->sequence_manager()->create_meshset_sequence( num_sets,
start_id,
- proc,
flags,
start_handle,
seq );
Modified: MOAB/trunk/MBReadUtil.hpp
--- MOAB/trunk/MBReadUtil.hpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/MBReadUtil.hpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -39,16 +39,12 @@
//! destructor
~MBReadUtil(){}
- //! Get Processor ID
- unsigned parallel_rank() const;
//! gets arrays for coordinate data from the MB
MBErrorCode get_node_arrays(
const int num_arrays,
@@ -59,7 +55,6 @@
@@ -81,7 +76,6 @@
const unsigned* set_flags,
MBEntityID preffered_start_id,
- int preffered_start_proc,
Modified: MOAB/trunk/MBReadUtilIface.hpp
--- MOAB/trunk/MBReadUtilIface.hpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/MBReadUtilIface.hpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -34,9 +34,6 @@
//! destructor
virtual ~MBReadUtilIface(){}
- virtual unsigned parallel_rank() const = 0;
//! Given a requested number of vertices and number of coordinates, returns
//! memory space which will be used to store vertex coordinates and information
@@ -53,7 +50,6 @@
) = 0;
@@ -73,7 +69,6 @@
) = 0;
@@ -95,7 +90,6 @@
) = 0;
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/MBTest.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -40,7 +40,6 @@
#include "MBCN.hpp"
#include "MBOrientedBox.hpp"
#include "MBCartVect.hpp"
#ifndef IS_BUILDING_MB
#define IS_BUILDING_MB
@@ -4860,7 +4859,7 @@
MBErrorCode mb_range_seq_intersect_test( MBInterface*)
MBErrorCode rval;
- SequenceManager sequences(MBHandleUtils( 0, 1 ));
+ SequenceManager sequences;
MBRangeSeqIntersectIter iter( &sequences );
MBRange range;
@@ -4868,13 +4867,13 @@
EntitySequence *ts1, *ts2, *ts3, *qs1;
MBEntityHandle th1, th2, th3, qh1;
const int nt1 = 100, nt2 = 10, nt3 = 1, nq1 = 20;
- rval = sequences.create_entity_sequence( MBTRI, nt1, 3, 5, 0, th1, ts1 );
+ rval = sequences.create_entity_sequence( MBTRI, nt1, 3, 5, th1, ts1 );
if (MB_SUCCESS != rval) return rval;
- rval = sequences.create_entity_sequence( MBTRI, nt2, 6, 0, 0, th2, ts2 );
+ rval = sequences.create_entity_sequence( MBTRI, nt2, 6, 0, th2, ts2 );
- rval = sequences.create_entity_sequence( MBTRI, nt3, 3, MB_END_ID, 0, th3, ts3 );
+ rval = sequences.create_entity_sequence( MBTRI, nt3, 3, MB_END_ID, th3, ts3 );
- rval = sequences.create_entity_sequence( MBQUAD, nq1, 4, 0, 0, qh1, qs1 );
+ rval = sequences.create_entity_sequence( MBQUAD, nq1, 4, 0, qh1, qs1 );
// we're going to assume this below, so verify it now
@@ -5471,230 +5470,10 @@
return s << *i;
-MBErrorCode mb_proc_subset_test( MBInterface* )
- MBRange range;
- MBRange::iterator i1, i2;
- std::pair<MBRange::iterator,MBRange::iterator> ip;
- MBHandleUtils handle_utils( 1, 5 ); // second of five CPUs
- // make an range containing everything
- range.insert( 1, handle_utils.create_handle( MBENTITYSET, handle_utils.max_id(), handle_utils.proc_size()-1 ) );
- // check type/proc subset stuff for each processor for each entity type
- for (unsigned proc = 0; proc < handle_utils.proc_size(); ++proc) {
- MBRange proc_range;
- for (MBEntityType t = MBVERTEX; t < MBMAXTYPE; ++t) {
- i1 = handle_utils.lower_bound( t, proc, range );
- ASSERT_NOT_EQUAL( i1, range.end() );
- ASSERT_EQUAL( TYPE_FROM_HANDLE( *i1 ), t );
- ASSERT_EQUAL( handle_utils.rank_from_handle( *i1 ), proc );
- if (!proc && t == MBVERTEX)
- ASSERT_EQUAL( handle_utils.id_from_handle( *i1 ), (MBEntityID)1 );
- else
- ASSERT_EQUAL( handle_utils.id_from_handle( *i1 ), (MBEntityID)0 );
- i2 = handle_utils.upper_bound( t, proc, range );
- // Because the number of processors is not a power
- // of two, we've inserted handles w/ invalid processor
- // IDs into the range for all types except MBENTITYSET
- //if (proc + 1 == handle_utils.proc_size()) {
- // if (t == MBENTITYSET)
- // ASSERT_EQUAL( i2, range.end() );
- // else {
- // ASSERT_NOT_EQUAL( i2, range.end() );
- // MBEntityType n = t; ++n;
- // ASSERT_EQUAL( TYPE_FROM_HANDLE( *i2 ), n );
- // ASSERT_EQUAL( handle_utils.rank_from_handle( *i2 ), (unsigned)0 );
- // ASSERT_EQUAL( handle_utils.id_from_handle( *i2 ), (MBEntityHandle)0 );
- if (proc + 1 == handle_utils.proc_size() && t == MBENTITYSET)
- ASSERT_EQUAL( i2, range.end() );
- else {
- ASSERT_NOT_EQUAL( i2, range.end() );
- ASSERT_EQUAL( TYPE_FROM_HANDLE( *i2 ), t );
- ASSERT_EQUAL( handle_utils.rank_from_handle( *i2 ), proc+1 );
- ASSERT_EQUAL( handle_utils.id_from_handle( *i2 ), (MBEntityID)0 );
- ip = handle_utils.equal_range( t, proc, range );
- ASSERT_EQUAL( i1, ip.first );
- ASSERT_EQUAL( i2, ip.second );
- proc_range.merge( i1, i2 );
- // get subset by processor ID and check results
- MBRange proc_range2 = handle_utils.subset_by_proc( proc, range );
- ASSERT_EQUAL( proc_range, proc_range2 );
- // make a range containing some entities, but not all handles
- range.clear();
- range.insert( handle_utils.create_handle( MBVERTEX, 100, 0 ),
- handle_utils.create_handle( MBVERTEX, 110, 0 ) );
- range.insert( handle_utils.create_handle( MBVERTEX, 100, 2 ),
- handle_utils.create_handle( MBVERTEX, 110, 2 ) );
- range.insert( handle_utils.create_handle( MBENTITYSET, 5, 0 ),
- handle_utils.create_handle( MBENTITYSET, 9, 0 ) );
- range.insert( handle_utils.create_handle( MBENTITYSET, 1, 3 ),
- handle_utils.create_handle( MBENTITYSET, 1, 3 ) );
- // test lower_bound
- i1 = handle_utils.lower_bound( MBVERTEX, 0, range );
- ASSERT_EQUAL( *i1, handle_utils.create_handle( MBVERTEX, 100, 0 ) );
- i1 = handle_utils.lower_bound( MBVERTEX, 1, range );
- ASSERT_EQUAL( *i1, handle_utils.create_handle( MBVERTEX, 100, 2 ) );
- i1 = handle_utils.lower_bound( MBVERTEX, 2, range );
- i1 = handle_utils.lower_bound( MBVERTEX, 3, range );
- ASSERT_EQUAL( *i1, handle_utils.create_handle( MBENTITYSET, 5, 0 ) );
- i1 = handle_utils.lower_bound( MBEDGE, 0, range );
- i1 = handle_utils.lower_bound( MBTRI, 0, range );
- i1 = handle_utils.lower_bound( MBENTITYSET, 0, range );
- i1 = handle_utils.lower_bound( MBENTITYSET, 1, range );
- ASSERT_EQUAL( *i1, handle_utils.create_handle( MBENTITYSET, 1, 3 ) );
- i1 = handle_utils.lower_bound( MBENTITYSET, 3, range );
- i1 = handle_utils.lower_bound( MBENTITYSET, 4, range );
- ASSERT_EQUAL( i1, range.end() );
- // test upper_bound
- i1 = handle_utils.upper_bound( MBVERTEX, 0, range );
- i1 = handle_utils.upper_bound( MBVERTEX, 1, range );
- i1 = handle_utils.upper_bound( MBVERTEX, 2, range );
- i1 = handle_utils.upper_bound( MBVERTEX, 3, range );
- i1 = handle_utils.upper_bound( MBEDGE, 0, range );
- i1 = handle_utils.upper_bound( MBTRI, 0, range );
- i1 = handle_utils.upper_bound( MBENTITYSET, 0, range );
- i1 = handle_utils.upper_bound( MBENTITYSET, 1, range );
- i1 = handle_utils.upper_bound( MBENTITYSET, 3, range );
- i1 = handle_utils.upper_bound( MBENTITYSET, 4, range );
- // test equal_range
- ip = handle_utils.equal_range( MBVERTEX, 0, range );
- ASSERT_EQUAL( handle_utils.lower_bound( MBVERTEX, 0, range ), ip.first );
- ASSERT_EQUAL( handle_utils.upper_bound( MBVERTEX, 0, range ), ip.second );
- ip = handle_utils.equal_range( MBVERTEX, 1, range );
- ASSERT_EQUAL( handle_utils.lower_bound( MBVERTEX, 1, range ), ip.first );
- ASSERT_EQUAL( handle_utils.upper_bound( MBVERTEX, 1, range ), ip.second );
- ip = handle_utils.equal_range( MBVERTEX, 2, range );
- ASSERT_EQUAL( handle_utils.lower_bound( MBVERTEX, 2, range ), ip.first );
- ASSERT_EQUAL( handle_utils.upper_bound( MBVERTEX, 2, range ), ip.second );
- ip = handle_utils.equal_range( MBVERTEX, 3, range );
- ASSERT_EQUAL( handle_utils.lower_bound( MBVERTEX, 3, range ), ip.first );
- ASSERT_EQUAL( handle_utils.upper_bound( MBVERTEX, 3, range ), ip.second );
- ip = handle_utils.equal_range( MBEDGE, 0, range );
- ASSERT_EQUAL( handle_utils.lower_bound( MBEDGE, 0, range ), ip.first );
- ASSERT_EQUAL( handle_utils.upper_bound( MBEDGE, 0, range ), ip.second );
- ip = handle_utils.equal_range( MBTRI, 0, range );
- ASSERT_EQUAL( handle_utils.lower_bound( MBTRI, 0, range ), ip.first );
- ASSERT_EQUAL( handle_utils.upper_bound( MBTRI, 0, range ), ip.second );
- ip = handle_utils.equal_range( MBENTITYSET, 0, range );
- ASSERT_EQUAL( handle_utils.lower_bound( MBENTITYSET, 0, range ), ip.first );
- ASSERT_EQUAL( handle_utils.upper_bound( MBENTITYSET, 0, range ), ip.second );
- ip = handle_utils.equal_range( MBENTITYSET, 1, range );
- ASSERT_EQUAL( handle_utils.lower_bound( MBENTITYSET, 1, range ), ip.first );
- ASSERT_EQUAL( handle_utils.upper_bound( MBENTITYSET, 1, range ), ip.second );
- ip = handle_utils.equal_range( MBENTITYSET, 3, range );
- ASSERT_EQUAL( handle_utils.lower_bound( MBENTITYSET, 3, range ), ip.first );
- ASSERT_EQUAL( handle_utils.upper_bound( MBENTITYSET, 3, range ), ip.second );
- ip = handle_utils.equal_range( MBENTITYSET, 4, range );
- ASSERT_EQUAL( handle_utils.lower_bound( MBENTITYSET, 4, range ), ip.first );
- ASSERT_EQUAL( handle_utils.upper_bound( MBENTITYSET, 4, range ), ip.second );
- MBRange sub, expected;
- sub.clear(); expected.clear();
- sub = handle_utils.subset_by_proc( 0, range );
- expected.insert( handle_utils.create_handle( MBVERTEX, 100, 0 ),
- expected.insert( handle_utils.create_handle( MBENTITYSET, 5, 0 ),
- ASSERT_EQUAL( sub, expected );
- sub.clear();
- sub = handle_utils.subset_by_proc( 1, range );
- ASSERT_EQUAL( sub.empty(), true );
- sub = handle_utils.subset_by_proc( 2, range );
- expected.insert( handle_utils.create_handle( MBVERTEX, 100, 2 ),
- sub = handle_utils.subset_by_proc( 3, range );
- expected.insert( handle_utils.create_handle( MBENTITYSET, 1, 3 ),
- return MB_SUCCESS;
MBErrorCode mb_poly_adjacency_test( MBInterface* )
MBErrorCode rval;
- MBCore moab(0,1);
+ MBCore moab;
MBInterface *mbImpl = &moab;
// make a couple polygons and a polyhedron
@@ -5908,7 +5687,6 @@
RUN_TEST( mb_topo_util_test );
RUN_TEST( mb_split_test );
RUN_TEST( mb_range_seq_intersect_test );
- RUN_TEST( mb_proc_subset_test );
RUN_TEST( mb_poly_adjacency_test );
RUN_TEST( mb_memory_use_test );
RUN_TEST( mb_merge_test );
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/Makefile.am 2008-09-25 17:22:33 UTC (rev 2093)
@@ -22,7 +22,6 @@
tqdcfr \
test_adj \
seq_man_test \
- internals_test \
geom_util_test \
xform_test \
obb_test \
@@ -121,7 +120,6 @@
MBCN.cpp \
MBCNArrays.hpp \
MBCartVect.cpp \
- MBHandleUtils.cpp \
MBMatrix3.cpp \
MBMatrix3.hpp \
MBCore.cpp \
@@ -222,7 +220,6 @@
MBError.hpp \
MBForward.hpp \
MBGeomUtil.hpp \
- MBHandleUtils.hpp \
MBInterface.hpp \
MBOrientedBox.hpp \
MBOrientedBoxTreeTool.hpp \
@@ -250,9 +247,6 @@
moab_test_LDADD = $(top_builddir)/libMOAB.la
moab_test_DEPENDENCIES = test/mb_big_test.g test/cell1.gen test/cell2.gen $(top_builddir)/libMOAB.la
-internals_test_SOURCES = internals_test.cpp
-internals_test_LDADD = $(top_builddir)/libMOAB.la
homxform_test_SOURCES = HomXform.cpp
homxform_test_LDADD = $(top_builddir)/libMOAB.la
homxform_test_CXXFLAGS = -DTEST $(CXXFLAGS)
Modified: MOAB/trunk/ReadGmsh.cpp
--- MOAB/trunk/ReadGmsh.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/ReadGmsh.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -176,7 +176,6 @@
std::vector<double*> coord_arrays;
MBEntityHandle handle = 0;
result = readMeshIface->get_node_arrays( 3, num_nodes, MB_START_ID,
- readMeshIface->parallel_rank(),
handle, coord_arrays );
return result;
@@ -381,7 +380,6 @@
MBEntityHandle* conn_array;
result = readMeshIface->get_element_array( num_elem, node_per_elem, type.mbtype,
MB_START_ID,
handle, conn_array );
return result;
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/ReadHDF5.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -381,7 +381,7 @@
MBEntityHandle handle;
std::vector<double*> arrays(dim);
rval = readUtil->get_node_arrays( dim, (int)count, (int)first_id,
- readUtil->parallel_rank(), handle, arrays );
+ handle, arrays );
mhdf_closeData( filePtr, data_id, &status );
@@ -465,7 +465,7 @@
rval = readUtil->get_element_array( (int)count,
nodes_per_elem,
elems.type,
- (int)first_id, -1,
+ (int)first_id,
handle,
array );
@@ -1006,7 +1006,6 @@
rval = readUtil->create_entity_sets( count,
buffer,
ID_FROM_HANDLE(start_handle),
handle );
if (MB_SUCCESS != rval) {
mhdf_closeData( filePtr, meta_id, &status );
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/ReadNCDF.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -562,7 +562,7 @@
MBEntityHandle node_handle = 0;
readMeshIface->get_node_arrays(3, numberNodes_loading,
- MB_START_ID, readMeshIface->parallel_rank(), node_handle, arrays);
+ MB_START_ID, node_handle, arrays);
vertexOffset = ID_FROM_HANDLE( node_handle ) - MB_START_ID;
@@ -866,7 +866,7 @@
(*this_it).numElements,
verts_per_element,
ExoIIUtil::ExoIIElementMBEntity[(*this_it).elemType],
- (*this_it).startExoId, readMeshIface->parallel_rank(),
+ (*this_it).startExoId,
(*this_it).startMBId,
conn);
Modified: MOAB/trunk/ReadSTL.cpp
--- MOAB/trunk/ReadSTL.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/ReadSTL.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -164,7 +164,7 @@
// Create vertices
- result = readMeshIface->get_node_arrays( 3, vertex_map.size(), MB_START_ID, -1,
+ result = readMeshIface->get_node_arrays( 3, vertex_map.size(), MB_START_ID,
return result;
@@ -193,7 +193,7 @@
result = readMeshIface->get_element_array( triangles.size(),
3,
MBTRI,
- MB_START_ID, -1,
+ MB_START_ID,
handle,
connectivity );
Modified: MOAB/trunk/ReadVtk.cpp
--- MOAB/trunk/ReadVtk.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/ReadVtk.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -325,7 +325,7 @@
// Create vertices
- result = readMeshIface->get_node_arrays( 3, num_verts, MB_START_ID, 0,
+ result = readMeshIface->get_node_arrays( 3, num_verts, MB_START_ID,
start_handle_out, arrays );
return result;
@@ -375,7 +375,7 @@
result = readMeshIface->get_element_array( num_elements,
vert_per_element,
type,
- MB_START_ID, 0,
+ MB_START_ID,
start_handle_out,
conn_array_out );
Modified: MOAB/trunk/SequenceManager.cpp
--- MOAB/trunk/SequenceManager.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/SequenceManager.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -187,15 +187,11 @@
return result;
-MBErrorCode SequenceManager::create_vertex( unsigned proc_id,
- const double coords[3],
+MBErrorCode SequenceManager::create_vertex( const double coords[3],
- if (proc_id == (unsigned)-1)
- proc_id = handleUtils.proc_rank();
- const MBEntityHandle start = handleUtils.create_handle( MBVERTEX, handleUtils.first_id(proc_id), proc_id );
- const MBEntityHandle end = handleUtils.create_handle( MBVERTEX, handleUtils. last_id(proc_id), proc_id );
+ const MBEntityHandle start = CREATE_HANDLE( MBVERTEX, MB_START_ID );
+ const MBEntityHandle end = CREATE_HANDLE( MBVERTEX, MB_END_ID );
bool append;
TypeSequenceManager::iterator seq = typeData[MBVERTEX].find_free_handle( start, end, append );
VertexSequence* vseq;
@@ -241,19 +237,15 @@
MBErrorCode SequenceManager::create_element( MBEntityType type,
- unsigned proc_id,
const MBEntityHandle* conn,
unsigned conn_len,
if (type <= MBVERTEX || type >= MBENTITYSET)
- const MBEntityHandle start = handleUtils.create_handle( type, handleUtils.first_id(proc_id), proc_id );
- const MBEntityHandle end = handleUtils.create_handle( type, handleUtils. last_id(proc_id), proc_id );
+ const MBEntityHandle start = CREATE_HANDLE( type, MB_START_ID );
+ const MBEntityHandle end = CREATE_HANDLE( type, MB_END_ID );
bool append;
TypeSequenceManager::iterator seq = typeData[type].find_free_handle( start, end, append, conn_len );
UnstructuredElemSeq* eseq;
@@ -311,15 +303,11 @@
-MBErrorCode SequenceManager::create_mesh_set( unsigned proc_id,
- unsigned flags,
+MBErrorCode SequenceManager::create_mesh_set( unsigned flags,
- const MBEntityHandle start = handleUtils.create_handle( MBENTITYSET, handleUtils.first_id(proc_id), proc_id );
- const MBEntityHandle end = handleUtils.create_handle( MBENTITYSET, handleUtils. last_id(proc_id), proc_id );
+ const MBEntityHandle start = CREATE_HANDLE( MBENTITYSET, MB_START_ID );
+ const MBEntityHandle end = CREATE_HANDLE( MBENTITYSET, MB_END_ID );
bool append;
TypeSequenceManager::iterator seq = typeData[MBENTITYSET].find_free_handle( start, end, append );
MeshSetSequence* msseq;
@@ -431,13 +419,6 @@
// if input range is larger than preferred size, trim it
if (end_handle - start_handle >= max_size)
end_handle = start_handle + max_size - 1;
- // if range spans more than one proc, trim it to one
- const unsigned rank = handleUtils.rank_from_handle( start_handle );
- if (handleUtils.rank_from_handle(end_handle) != rank)
- end_handle = handleUtils.create_handle( TYPE_FROM_HANDLE(start_handle),
- handleUtils.max_id(),
- rank );
MBEntityHandle
@@ -445,17 +426,16 @@
MBEntityID count,
int size,
MBEntityID start,
- int proc,
SequenceData*& data,
MBEntityID &data_size)
TypeSequenceManager &tsm = typeData[type];
data = 0;
- MBEntityHandle handle = handleUtils.create_handle( type, start, proc );
+ MBEntityHandle handle = CREATE_HANDLE( type, start );
if (start < MB_START_ID ||
!tsm.is_free_sequence( handle, count, data, size )) {
- MBEntityHandle pstart = handleUtils.create_handle( type, MB_START_ID, proc );
- MBEntityHandle pend = handleUtils.create_handle( type, handleUtils.max_id(), proc );
+ MBEntityHandle pstart = CREATE_HANDLE( type, MB_START_ID );
+ MBEntityHandle pend = CREATE_HANDLE( type, MB_END_ID );
handle = tsm.find_free_sequence( count, pstart, pend, data, data_size, size);
return handle;
@@ -489,16 +469,12 @@
MBEntityID count,
int size,
MBEntityID start,
- int proc,
MBEntityHandle& handle,
EntitySequence*& sequence )
- if (proc == -1)
- proc = handleUtils.proc_rank();
SequenceData* data = 0;
MBEntityID data_size = 0;
- handle = sequence_start_handle( type, count, size, start, proc, data, data_size );
+ handle = sequence_start_handle( type, count, size, start, data, data_size );
if (!handle)
@@ -571,17 +547,13 @@
MBErrorCode
SequenceManager::create_meshset_sequence( MBEntityID count,
MBEntityID start,
- int proc,
const unsigned* flags,
- if (proc == -1)
- handle = sequence_start_handle( MBENTITYSET, count, 0, start, proc, data, data_size );
+ handle = sequence_start_handle( MBENTITYSET, count, 0, start, data, data_size );
if (!handle)
@@ -610,17 +582,13 @@
MBErrorCode
MBEntityID start,
- int proc,
unsigned flags,
- if (proc == -1)
if (!handle)
@@ -649,13 +617,9 @@
int imax, int jmax, int kmax,
MBEntityType type,
MBEntityID start_id_hint,
- int processor_id,
- if (processor_id == -1)
- processor_id = handleUtils.proc_rank();
int this_dim = MBCN::Dimension(type);
// use > instead of != in the following assert to also catch cases where imin > imax, etc.
@@ -676,7 +640,7 @@
// get a start handle
- handle = sequence_start_handle( type, num_ent, -1, start_id_hint, processor_id, data, data_size );
+ handle = sequence_start_handle( type, num_ent, -1, start_id_hint, data, data_size );
if (!handle)
@@ -712,13 +676,12 @@
const HomCoord& coord_max,
MBEntityType type,
- int processor_id,
MBEntityHandle& first_handle_out,
EntitySequence*& sequence_out )
return create_scd_sequence( coord_min.i(), coord_min.j(), coord_min.k(),
coord_max.i(), coord_max.j(), coord_max.k(),
- type, start_id_hint, processor_id,
+ type, start_id_hint,
first_handle_out, sequence_out );
Modified: MOAB/trunk/SequenceManager.hpp
--- MOAB/trunk/SequenceManager.hpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/SequenceManager.hpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -2,8 +2,8 @@
#define SEQUENCE_MANAGER_HPP
#include "TypeSequenceManager.hpp"
#include "TagInfo.hpp"
+#include <vector>
class HomCoord;
class TagServer;
@@ -11,10 +11,6 @@
class SequenceManager
public:
- SequenceManager( const MBHandleUtils& handle_utils )
- : handleUtils(handle_utils)
~SequenceManager();
@@ -75,22 +71,19 @@
/** Allocate a vertex (possibly in an existing sequence) and
* assign it the passed coordinate values.
- MBErrorCode create_vertex( unsigned processor_id,
+ MBErrorCode create_vertex( const double coords[3],
MBEntityHandle& handle_out );
/** Allocate a element (possibly in an existing sequence) and
* assign it the passed connectivity.
MBErrorCode create_element( MBEntityType type,
- unsigned processor_id,
const MBEntityHandle* conn_array,
unsigned num_vertices,
/** Allocate an entity set (possibly in an existing sequence) */
- MBErrorCode create_mesh_set( unsigned processor_id,
- unsigned flags,
+ MBErrorCode create_mesh_set( unsigned flags,
/** Allocate an entity set with the specified handle.
*\return MB_ALREADY_ALLOCATED if handle is in use, MB_SUCCESS otherwise.
@@ -109,7 +102,6 @@
* MBENTITYSET types.
*\param start_id_hint Preferred ID portion for first handle.
* May be ignored if not available.
- *\param processor_id Processor ID to embed in handles
*\param first_handle_out First allocated handle. Allocated handles
* are [first_handle_out, first_handle_out+num_entities-1].
*\param sequence_out The sequence in which the entities were allocated.
@@ -120,11 +112,10 @@
MBEntityID num_entities,
int nodes_per_entity,
- int processor_id,
EntitySequence*& sequence_out );
- /**\brief Allocate a block of consecutive mesh sets
+ /**\brief Allocate a block of consecutive mesh sets
* Allocate a block of consecutive entity handles. Handles
* may be appended or prepended to an existing entity sequence.
@@ -143,7 +134,6 @@
MBErrorCode create_meshset_sequence( MBEntityID num_sets,
- int processor_id,
@@ -154,7 +144,6 @@
- int processor_id,
unsigned flags,
@@ -164,7 +153,6 @@
MBEntityType type,
- int processor_id,
@@ -173,7 +161,6 @@
MBEntityType type,
- int processor_id,
@@ -421,15 +408,13 @@
* the handle range.
*\return zero if no available handle range, start handle otherwise.
- MBEntityHandle sequence_start_handle( MBEntityType type,
- MBEntityID entity_count,
- int values_per_entity,
- MBEntityID start_id_hint,
- int processor_rank,
- SequenceData*& data_out,
- MBEntityID &data_size );
+ MBEntityHandle sequence_start_handle( MBEntityType type,
+ MBEntityID entity_count,
+ int values_per_entity,
+ MBEntityID start_id_hint,
+ SequenceData*& data_out,
+ MBEntityID &data_size );
- const MBHandleUtils handleUtils;
TypeSequenceManager typeData[MBMAXTYPE];
std::vector<int> tagSizes;
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/Tqdcfr.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -992,7 +992,6 @@
readUtilIface->get_node_arrays(3, entity->nodeCt,
uint_buf[0],
- readUtilIface->parallel_rank(),
vhandle, arrays);
// get node x's in arrays[0]
@@ -1181,7 +1180,6 @@
result = readUtilIface->get_element_array(num_elem, nodes_per_elem,
elem_type, int_buf[0],
start_handle, conn);
return result;
@@ -2555,7 +2553,7 @@
delete my_impl;
// now check for multiple procs
- my_impl = new MBCore(1, 2);
+ my_impl = new MBCore;
my_tqd = new Tqdcfr(my_impl);
result = my_tqd->load_file(file, file_set, opts, 0, 0);
@@ -2580,7 +2578,7 @@
err = MPI_Comm_rank(MPI_COMM_WORLD, &rank);
// create MOAB instance based on that
- my_impl = new MBCore(rank, nprocs);
+ my_impl = new MBCore ;//(rank, nprocs);
if (NULL == my_impl) return 1;
std::string options = "PARALLEL=READ_DELETE;PARTITION=MATERIAL_SET;PARTITION_DISTRIBUTE";
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -1227,7 +1227,7 @@
// unpack coords
if (num_ents) {
std::vector<double*> coords(3);
- result = ru->get_node_arrays(3, num_ents, 0, proc_config().proc_rank(),
+ result = ru->get_node_arrays(3, num_ents, 0,
actual_start, coords);
RRA("Failed to allocate node arrays.");
@@ -1260,7 +1260,7 @@
MBEntityHandle *connect;
result = ru->get_element_array(num_ents, verts_per_entity, this_type,
- 0, proc_config().proc_rank(), actual_start,
+ 0, actual_start,
connect);
RRA("Failed to allocate element arrays.");
Modified: MOAB/trunk/parallel/MBParallelData.cpp
--- MOAB/trunk/parallel/MBParallelData.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/parallel/MBParallelData.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -40,8 +40,10 @@
MBTag proc_tag = 0, procs_tag = 0;
MBErrorCode result = MB_SUCCESS;
int my_rank;
- if (parallelComm) my_rank = parallelComm->proc_config().proc_rank();
- else my_rank = mbImpl->proc_rank();
+ if (parallelComm)
+ my_rank = parallelComm->proc_config().proc_rank();
+ else
+ return MB_FAILURE;
std::multimap<int, MBEntityHandle> iface_data;
Modified: MOAB/trunk/parallel/mbparallelcomm_test.cpp
--- MOAB/trunk/parallel/mbparallelcomm_test.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/parallel/mbparallelcomm_test.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -72,7 +72,7 @@
if (0 == rank) stime = MPI_Wtime();
- MBInterface *mbImpl = new MBCore(rank, nprocs);
+ MBInterface *mbImpl = new MBCore;
if (NULL == mbImpl) return 1;
@@ -224,7 +224,8 @@
MBErrorCode report_nsets(MBInterface *mbImpl)
// get and report various numbers...
- int rank = mbImpl->proc_rank();
+ int rank;
+ MPI_Comm_rank(MPI_COMM_WORLD, &rank);
MBRange matsets, geomsets, parsets;
int nsets;
Modified: MOAB/trunk/parallel/parallel_hdf5_test.cc
--- MOAB/trunk/parallel/parallel_hdf5_test.cc 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/parallel/parallel_hdf5_test.cc 2008-09-25 17:22:33 UTC (rev 2093)
@@ -191,14 +191,12 @@
void test_write_elements()
int proc_counts[MBENTITYSET], all_counts[MBENTITYSET], file_counts[MBENTITYSET];
- int err, rank, size;
+ int err, rank;
MBErrorCode rval;
err = MPI_Comm_rank( MPI_COMM_WORLD, &rank );
CHECK(!err);
- err = MPI_Comm_size( MPI_COMM_WORLD, &size );
- CHECK(!err);
- MBCore moab_instance( rank, size );
+ MBCore moab_instance;
MBInterface& moab = moab_instance;
load_and_partition( moab, InputFile );
Modified: MOAB/trunk/scdseq_test.cpp
--- MOAB/trunk/scdseq_test.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/scdseq_test.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -293,7 +293,7 @@
// make a 1d sequence
MBErrorCode result = seq_mgr->create_scd_sequence(-10, 0, 0, 10, 0, 0,
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
oned_start, dum_seq);
if (NULL != dum_seq) oned_seq = dynamic_cast<ScdVertexData*>(dum_seq->data());
if (MB_FAILURE == result || oned_start == 0 || dum_seq == NULL ||
@@ -320,7 +320,7 @@
// make a 2d sequence
dum_seq = NULL;
result = seq_mgr->create_scd_sequence(-10, -10, 0, 10, 10, 0,
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
twod_start, dum_seq);
if (NULL != dum_seq) twod_seq = dynamic_cast<ScdVertexData*>(dum_seq->data());
if (MB_FAILURE == result || twod_start == 0 || dum_seq == NULL ||
@@ -347,7 +347,7 @@
// make a 3d sequence
dum_seq = NULL;
result = seq_mgr->create_scd_sequence(-10, -10, -10, 10, 10, 10,
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
threed_start, dum_seq);
if (NULL != dum_seq) threed_seq = dynamic_cast<ScdVertexData*>(dum_seq->data());
if (MB_FAILURE == result || threed_start == 0 || dum_seq == NULL ||
@@ -412,7 +412,7 @@
EntitySequence *dum_seq;
ScdVertexData *oned_seq = NULL;
MBErrorCode result = seq_mgr->create_scd_sequence(tmp_min, tmp_max,
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
assert (MB_FAILURE != result && oned_start != 0 && dum_seq != NULL && oned_seq != NULL);
@@ -421,7 +421,7 @@
MBEntityHandle eseq_start;
StructuredElementSeq *eseq = NULL;
- MBEDGE, 1, 0,
+ MBEDGE, 1,
eseq_start, dum_seq);
if (NULL != dum_seq) eseq = dynamic_cast<StructuredElementSeq*>(dum_seq);
assert (MB_FAILURE != result && eseq_start != 0 && dum_seq != NULL && eseq != NULL);
@@ -469,7 +469,7 @@
ScdVertexData *twod_seq = NULL;
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
assert (MB_FAILURE != result && twod_start != 0 && dum_seq != NULL && twod_seq != NULL);
@@ -478,7 +478,7 @@
- MBQUAD, 1, 0,
+ MBQUAD, 1,
@@ -524,7 +524,7 @@
ScdVertexData *threed_seq = NULL;
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
assert (MB_FAILURE != result && threed_start != 0 && dum_seq != NULL && threed_seq != NULL);
@@ -533,7 +533,7 @@
- MBHEX, 1, 0,
+ MBHEX, 1,
@@ -746,21 +746,21 @@
// first vertex sequence
MBErrorCode result = seq_mgr->create_scd_sequence(vseq0_minmax[0], vseq0_minmax[1],
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
vstart[0], dum_seq);
if (NULL != dum_seq) vseq[0] = dynamic_cast<ScdVertexData*>(dum_seq->data());
assert (MB_FAILURE != result && vstart[0] != 0 && dum_seq != NULL && vseq[0] != NULL);
// second vertex sequence
result = seq_mgr->create_scd_sequence(vseq1_minmax[0], vseq1_minmax[1],
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
vstart[1], dum_seq);
if (NULL != dum_seq) vseq[1] = dynamic_cast<ScdVertexData*>(dum_seq->data());
assert (MB_FAILURE != result && vstart[1] != 0 && dum_seq != NULL && vseq[1] != NULL);
// third vertex sequence
result = seq_mgr->create_scd_sequence(vseq2_minmax[0], vseq2_minmax[1],
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
vstart[2], dum_seq);
if (NULL != dum_seq) vseq[2] = dynamic_cast<ScdVertexData*>(dum_seq->data());
assert (MB_FAILURE != result && vstart[2] != 0 && dum_seq != NULL && vseq[2] != NULL);
@@ -770,7 +770,7 @@
// create the first element sequence
- MBEDGE, 1, 0,
+ MBEDGE, 1,
estart[0], dum_seq);
if (NULL != dum_seq) eseq[0] = dynamic_cast<StructuredElementSeq*>(dum_seq);
assert (MB_FAILURE != result && estart[0] != 0 && dum_seq != NULL && eseq[0] != NULL);
@@ -790,7 +790,7 @@
// end of the previous eseq
result = seq_mgr->create_scd_sequence(HomCoord(vseq0_minmax[1].i(), 0, 0),
HomCoord(1+vseq0_minmax[1].i()+vseq1_minmax[1].i()-vseq1_minmax[0].i(), 0, 0),
- MBEDGE, 1, 0,
+ MBEDGE, 1,
estart[1], dum_seq);
if (NULL != dum_seq) eseq[1] = dynamic_cast<StructuredElementSeq*>(dum_seq);
assert (MB_FAILURE != result && estart[1] != 0 && dum_seq != NULL && eseq[1] != NULL);
@@ -825,7 +825,7 @@
result = seq_mgr->create_scd_sequence(eseq[1]->max_params(),
HomCoord(eseq[1]->max_params().i()+1+vseq2_minmax[1].i()-vseq2_minmax[0].i(),0,0),
- MBEDGE, 1, 0,
+ MBEDGE, 1,
estart[2], dum_seq);
if (NULL != dum_seq) eseq[2] = dynamic_cast<StructuredElementSeq*>(dum_seq);
assert (MB_FAILURE != result && estart[2] != 0 && dum_seq != NULL && eseq[2] != NULL);
@@ -879,21 +879,21 @@
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
@@ -903,7 +903,7 @@
- MBQUAD, 1, 0,
+ MBQUAD, 1,
@@ -929,7 +929,7 @@
result = seq_mgr->create_scd_sequence(HomCoord(eseq[0]->max_params().i(), eseq[0]->min_params().j(), 0),
HomCoord(vseq0_minmax[1].i()+1+vseq1_minmax[1].i()-vseq1_minmax[0].i(),
eseq[0]->max_params().j(), 0),
- MBQUAD, 1, 0,
+ MBQUAD, 1,
@@ -972,7 +972,7 @@
// add one extra for each of left and right sides
HomCoord(eseq[1]->max_params().i()+1+vseq2_minmax[1].i()-vseq2_minmax[0].i()+1,
eseq[1]->max_params().j(),0),
- MBEDGE, 1, 0,
+ MBEDGE, 1,
@@ -1065,21 +1065,21 @@
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
@@ -1098,7 +1098,7 @@
result = seq_mgr->create_scd_sequence(eseq0_minmax[0], eseq0_minmax[1],
- MBQUAD, 1, 0,
+ MBQUAD, 1,
@@ -1118,7 +1118,7 @@
// create the second element sequence
result = seq_mgr->create_scd_sequence(eseq1_minmax[0], eseq1_minmax[1],
- MBQUAD, 1, 0,
+ MBQUAD, 1,
@@ -1157,7 +1157,7 @@
// create the third element sequence
result = seq_mgr->create_scd_sequence(eseq2_minmax[0], eseq2_minmax[1],
- MBQUAD, 1, 0,
+ MBQUAD, 1,
@@ -1245,21 +1245,21 @@
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
- MBVERTEX, 1, 0,
+ MBVERTEX, 1,
@@ -1278,7 +1278,7 @@
- MBHEX, 1, 0,
+ MBHEX, 1,
@@ -1298,7 +1298,7 @@
- MBHEX, 1, 0,
+ MBHEX, 1,
@@ -1338,7 +1338,7 @@
- MBHEX, 1, 0,
+ MBHEX, 1,
Modified: MOAB/trunk/test/perf/perf.cpp
--- MOAB/trunk/test/perf/perf.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/test/perf/perf.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -406,12 +406,12 @@
MBEntityHandle vstart, estart;
MBErrorCode result = seq_mgr->create_scd_sequence(vseq_minmax[0], vseq_minmax[1],
- MBVERTEX, 1, -1, vstart, dum_seq);
+ MBVERTEX, 1, vstart, dum_seq);
if (NULL != dum_seq) vseq = dynamic_cast<ScdVertexData*>(dum_seq->data());
assert (MB_FAILURE != result && vstart != 0 && dum_seq != NULL && vseq != NULL);
// now the element sequence
- MBHEX, 1, -1, estart, dum_seq);
+ MBHEX, 1, estart, dum_seq);
assert (MB_FAILURE != result && estart != 0 && dum_seq != NULL && eseq != NULL);
@@ -468,7 +468,7 @@
// create a sequence to hold the node coordinates
// get the current number of entities and start at the next slot
- MBErrorCode result = readMeshIface->get_node_arrays(3, num_verts, 1, -1, vstart, coord_arrays);
+ MBErrorCode result = readMeshIface->get_node_arrays(3, num_verts, 1, vstart, coord_arrays);
assert(MB_SUCCESS == result && 1 == vstart &&
coord_arrays[0] && coord_arrays[1] && coord_arrays[2]);
// memcpy the coordinate data into place
@@ -477,7 +477,7 @@
memcpy(coord_arrays[2], &coords[2*num_verts], sizeof(double)*num_verts);
MBEntityHandle *conn = 0;
- result = readMeshIface->get_element_array(num_elems, 8, MBHEX, 1, -1, estart, conn);
+ result = readMeshIface->get_element_array(num_elems, 8, MBHEX, 1, estart, conn);
assert(MB_SUCCESS == result);
memcpy(conn, connect, num_elems*8*sizeof(MBEntityHandle));
result = readMeshIface->update_adjacencies(estart, num_elems, 8, conn);
Modified: MOAB/trunk/test/perf/seqperf.cpp
--- MOAB/trunk/test/perf/seqperf.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/test/perf/seqperf.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -435,7 +435,7 @@
void create_vertices_block( )
- MBErrorCode rval = readTool->get_node_arrays( 3, numVert, 0, 0, vertStart, arrays );
+ MBErrorCode rval = readTool->get_node_arrays( 3, numVert, 0, vertStart, arrays );
assert(!rval && arrays.size() == 3);
double *x = arrays[0], *y = arrays[1], *z = arrays[2];
assert( x && y && z );
@@ -464,7 +464,7 @@
void create_elements_block( )
MBEntityHandle* conn = 0;
- MBErrorCode rval = readTool->get_element_array( numElem, 8, MBHEX, 0, 0, elemStart, conn );
+ MBErrorCode rval = readTool->get_element_array( numElem, 8, MBHEX, 0, elemStart, conn );
assert(!rval && conn);
for (long i = 0; i < numElem; ++i)
Modified: MOAB/trunk/tools/converter/convert.cpp
--- MOAB/trunk/tools/converter/convert.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/tools/converter/convert.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -132,16 +132,8 @@
MBErrorCode result;
MBRange range;
-#ifdef USE_MPI
- MPI_Init( &argc, &argv );
- int proc_id, num_proc;
- MPI_Comm_rank( MPI_COMM_WORLD, &proc_id );
- MPI_Comm_size( MPI_COMM_WORLD, &num_proc );
- gMB = new MBCore( proc_id, num_proc );
-#else
int proc_id = 0;
gMB = new MBCore();
-#endif
bool append_rank = false;
int i, dim;
Modified: MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -164,7 +164,10 @@
/*out*/ int *part_handles_size,
int *err)
- if (rank[0] != MBI->proc_rank() || rank_size > 1) {
+ MBParallelComm *pc = MBParallelComm::get_pcomm(MBI, 0);
+ if (!pc) RETURN(iBase_ERROR_MAP[MB_FAILURE]);
+ if (rank[0] != pc->proc_config().proc_rank() || rank_size > 1) {
RETURN(iBase_ERROR_MAP[MB_NOT_IMPLEMENTED]);
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -34,8 +34,8 @@
int AdjTable[16];
-MBiMesh::MBiMesh(int proc_rank, int proc_size)
- : MBCore(proc_rank, proc_size), haveDeletedEntities(false)
+MBiMesh::MBiMesh(int , int )
+ : haveDeletedEntities(false)
memset(AdjTable, 0, 16*sizeof(int));
for (int i = 0; i < 4; i++) AdjTable[4*i] = AdjTable[i] = 1;
Modified: MOAB/trunk/tools/mbperf/mbperf.cpp
--- MOAB/trunk/tools/mbperf/mbperf.cpp 2008-09-25 17:17:33 UTC (rev 2092)
+++ MOAB/trunk/tools/mbperf/mbperf.cpp 2008-09-25 17:22:33 UTC (rev 2093)
@@ -461,12 +461,12 @@
- MBVERTEX, 1, 0, vstart, dum_seq);
- MBHEX, 1, 0, estart, dum_seq);
@@ -528,7 +528,7 @@
- MBErrorCode result = readMeshIface->get_node_arrays(3, num_verts, 1, 0, vstart, coord_arrays);
@@ -537,7 +537,7 @@
- result = readMeshIface->get_element_array(num_elems, 8, MBHEX, 1, 0, estart, conn);
