[MOAB-dev] MOAB check for *AMD64* failed.
Nightly Test kraftche at cae.wisc.edu
Tue Oct 21 02:02:21 CDT 2008
../src/FileTokenizer.cpp: In member function ‘bool FileTokenizer::get_binary(size_t, void*)’:
../src/FileTokenizer.cpp:471: warning: comparison between signed and unsigned integer expressions
../src/MBAdaptiveKDTree.cpp:1688: warning: ‘MBErrorCode closest_to_triangles(MBInterface*, MBEntityHandle, double, const MBCartVect&, std::vector<long unsigned int, std::allocator<long unsigned int> >&, std::vector<MBCartVect, std::allocator<MBCartVect> >&)’ defined but not used
../../../src/tools/size/size.cpp: In function ‘void print_stats(set_stats&)’:
../../../src/tools/size/size.cpp:291: warning: ISO C++ does not support the ‘%lg’ printf format
../src/VtkTest.cpp:30: error: extra ‘;’
../src/VtkTest.cpp:31: error: extra ‘;’
../src/VtkTest.cpp:32: error: extra ‘;’
../src/VtkTest.cpp:33: error: extra ‘;’
../src/VtkTest.cpp:34: error: extra ‘;’
../src/VtkTest.cpp:35: error: extra ‘;’
../src/VtkTest.cpp:36: error: extra ‘;’
../src/VtkTest.cpp:37: error: extra ‘;’
../src/VtkTest.cpp:38: error: extra ‘;’
../src/VtkTest.cpp:39: error: extra ‘;’
../src/VtkTest.cpp:40: error: extra ‘;’
../src/VtkTest.cpp:41: error: extra ‘;’
../src/VtkTest.cpp:42: error: extra ‘;’
../src/VtkTest.cpp:44: error: extra ‘;’
../src/VtkTest.cpp:45: error: extra ‘;’
../src/VtkTest.cpp:46: error: extra ‘;’
../src/VtkTest.cpp:47: error: extra ‘;’
../src/VtkTest.cpp:48: error: extra ‘;’
../src/VtkTest.cpp:49: error: extra ‘;’
../src/VtkTest.cpp:51: error: extra ‘;’
../src/VtkTest.cpp:52: error: extra ‘;’
../src/VtkTest.cpp:53: error: extra ‘;’
../src/VtkTest.cpp:54: error: extra ‘;’
../src/VtkTest.cpp:55: error: extra ‘;’
../src/VtkTest.cpp:56: error: extra ‘;’
../src/VtkTest.cpp:57: error: extra ‘;’
../src/VtkTest.cpp:58: error: extra ‘;’
../src/VtkTest.cpp:59: error: extra ‘;’
../src/VtkTest.cpp:60: error: extra ‘;’
../src/VtkTest.cpp:61: error: extra ‘;’
../src/VtkTest.cpp:63: error: extra ‘;’
../src/VtkTest.cpp:64: error: extra ‘;’
../src/VtkTest.cpp:65: error: extra ‘;’
../src/VtkTest.cpp:66: error: extra ‘;’
../src/VtkTest.cpp:67: error: extra ‘;’
../src/VtkTest.cpp:68: error: extra ‘;’
../src/VtkTest.cpp:69: error: extra ‘;’
../src/VtkTest.cpp:70: error: extra ‘;’
../src/VtkTest.cpp:71: error: extra ‘;’
../src/VtkTest.cpp:72: error: extra ‘;’
../src/VtkTest.cpp:73: error: extra ‘;’
../src/VtkTest.cpp:75: error: extra ‘;’
../src/VtkTest.cpp:76: error: extra ‘;’
../src/VtkTest.cpp:77: error: extra ‘;’
../src/VtkTest.cpp:78: error: extra ‘;’
../src/VtkTest.cpp:79: error: extra ‘;’
../src/VtkTest.cpp:80: error: extra ‘;’
../src/VtkTest.cpp:81: error: extra ‘;’
../src/VtkTest.cpp:82: error: extra ‘;’
../src/VtkTest.cpp:83: error: extra ‘;’
../src/VtkTest.cpp:84: error: extra ‘;’
../src/VtkTest.cpp:85: error: extra ‘;’
../src/VtkTest.cpp:87: error: extra ‘;’
../src/VtkTest.cpp:88: error: extra ‘;’
../src/VtkTest.cpp:89: error: extra ‘;’
../src/VtkTest.cpp:90: error: extra ‘;’
../src/VtkTest.cpp:91: error: extra ‘;’
../src/VtkTest.cpp:92: error: extra ‘;’
../src/VtkTest.cpp:93: error: extra ‘;’
../src/VtkTest.cpp:94: error: extra ‘;’
../src/VtkTest.cpp:95: error: extra ‘;’
../src/VtkTest.cpp:96: error: extra ‘;’
../src/VtkTest.cpp:98: error: extra ‘;’
make[2]: *** [VtkTest.o] Error 1
make[2]: *** Waiting for unfinished jobs....
../src/adaptive_kd_tree_tests.cpp: In function ‘bool create_simple_2d_tree(MBAdaptiveKDTree&, MBEntityHandle&, MBEntityHandle*)’:
../src/adaptive_kd_tree_tests.cpp:416: warning: unused variable ‘mb’
make[1]: *** [check-am] Error 2
make: *** [check-recursive] Error 1
... yes
checking whether the c++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
(cached) (cached) checking how to hardcode library paths into programs... immediate
appending configuration tag "F77" to libtool
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking for gfortran option to produce PIC... -fPIC
checking if gfortran PIC flag -fPIC works... yes
checking if gfortran static flag -static works... yes
checking if gfortran supports -c -o file.o... yes
checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for gunzip... gunzip -c
checking for gzip... (cached) gunzip -c
checking for zcat... (cached) gunzip -c
checking if C++ compiler supports template specialization... yes
checking how to get verbose linking output from gfortran... -v
checking for Fortran libraries of gfortran...  -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2 -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../.. -lgfortranbegin -lgfortran -lm
checking for dummy main to link with Fortran libraries... none
checking for Fortran name-mangling scheme... lower case, underscore, no extra underscore
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for sys/types.h... (cached) yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for stdlib.h... (cached) yes
checking for size_t... yes
checking for ptrdiff_t... yes
checking ieeefp.h usability... no
checking ieeefp.h presence... no
checking for ieeefp.h... no
checking valgrind/memcheck.h usability... yes
checking valgrind/memcheck.h presence... yes
checking for valgrind/memcheck.h... yes
checking for deflate in -lz... yes
checking for SZ_Decompress in -lsz... no
checking if HDF5 support is enabled... yes
checking hdf5.h usability... yes
checking hdf5.h presence... yes
checking for hdf5.h... yes
checking for H5Fopen in -lhdf5... yes
checking if NetCDF support is enabled... yes
checking strstream.h usability... no
checking strstream.h presence... no
checking for strstream.h... no
checking sstream.h usability... no
checking sstream.h presence... no
checking for sstream.h... no
checking strstream usability... yes
checking strstream presence... yes
checking for strstream... yes
checking netcdf.h usability... yes
checking netcdf.h presence... yes
checking for netcdf.h... yes
checking for netcdf.hh... yes
checking for netcdf_c++ library... yes
checking if mbconvert is to be built... yes
checking if hexmodops is to be built... yes
checking if mbchaco is to be built... no
checking if mbperf is to be built... yes
checking if qvdual is to be built... no
checking if mbsize is to be built... yes
checking if mbskin is to be built... yes
checking if mbtagprop is to be built... yes
checking if mcnpmit is to be built... no
checking if mbcoupler is to be built... no
checking if spheredecomp is to be built... yes
checking if mbsurfplot is to be built... yes
checking if mbzoltan is to be built... no
checking if dagmc is to be built... yes
checking if iMesh support is to be built... yes
checking for /opt/babel-0.10.10-64-c2/bin/babel... yes
configure: creating ./config.status
C:   cc  -Wall -pipe -pedantic -g
C++: c++  -Wall -pipe -pedantic -g
Fortran: gfortran -g -O2 -g
 /bin/sh ./config.status
config.status: creating Makefile
config.status: creating moab.make
config.status: creating testdir.h
config.status: creating parallel/Makefile
config.status: creating mhdf/Makefile
config.status: creating test/Makefile
config.status: creating test/h5file/Makefile
config.status: creating test/dual/Makefile
config.status: creating test/obb/Makefile
config.status: creating test/perf/Makefile
config.status: creating tools/Makefile
config.status: creating tools/converter/Makefile
config.status: creating tools/hexmodops/Makefile
config.status: creating tools/iMesh/Makefile
config.status: creating tools/iMesh/iMesh-Defs.inc
config.status: creating tools/iMesh/SIDL/iMesh-SIDL-Defs.inc
config.status: creating tools/iMesh/SIDL/Makefile
config.status: creating tools/iMesh/SIDL/common.make
config.status: creating tools/mbperf/Makefile
config.status: creating tools/mbchaco/Makefile
config.status: creating tools/mbcoupler/Makefile
config.status: creating tools/mbzoltan/Config.moab
config.status: creating tools/mbzoltan/Makefile
config.status: creating tools/mcnpmit/Makefile
config.status: creating tools/qvdual/Makefile
config.status: creating tools/size/Makefile
config.status: creating tools/skin/Makefile
config.status: creating tools/tagprop/Makefile
config.status: creating tools/spheredecomp/Makefile
config.status: creating tools/surfplot/Makefile
config.status: creating tools/dagmc/Makefile
config.status: creating tools/dagmc/dagmc.make
config.status: creating doc/Makefile
config.status: creating doxygen/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: creating MBVersion.h
config.status: MBVersion.h is unchanged
config.status: creating MBEntityHandle.h
config.status: MBEntityHandle.h is unchanged
config.status: creating MBCN_FCDefs.h
config.status: MBCN_FCDefs.h is unchanged
config.status: executing depfiles commands
make  all-recursive
make[1]: Entering directory `/home/jason/moab/test/AMD64'
Making all in mhdf
make[2]: Entering directory `/home/jason/moab/test/AMD64/mhdf'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/jason/moab/test/AMD64/mhdf'
Making all in .
make[2]: Entering directory `/home/jason/moab/test/AMD64'
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT EntitySequence.lo -MD -MP -MF .deps/EntitySequence.Tpo -c -o EntitySequence.lo ../src/EntitySequence.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT ExoIIUtil.lo -MD -MP -MF .deps/ExoIIUtil.Tpo -c -o ExoIIUtil.lo ../src/ExoIIUtil.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT FileOptions.lo -MD -MP -MF .deps/FileOptions.Tpo -c -o FileOptions.lo ../src/FileOptions.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT FileTokenizer.lo -MD -MP -MF .deps/FileTokenizer.Tpo -c -o FileTokenizer.lo ../src/FileTokenizer.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT GeomTopoTool.lo -MD -MP -MF .deps/GeomTopoTool.Tpo -c -o GeomTopoTool.lo ../src/GeomTopoTool.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT HigherOrderFactory.lo -MD -MP -MF .deps/HigherOrderFactory.Tpo -c -o HigherOrderFactory.lo ../src/HigherOrderFactory.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBAdaptiveKDTree.lo -MD -MP -MF .deps/MBAdaptiveKDTree.Tpo -c -o MBAdaptiveKDTree.lo ../src/MBAdaptiveKDTree.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBAffineXform.lo -MD -MP -MF .deps/MBAffineXform.Tpo -c -o MBAffineXform.lo ../src/MBAffineXform.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT EntitySequence.lo -MD -MP -MF .deps/EntitySequence.Tpo -c ../src/EntitySequence.cpp -o EntitySequence.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT FileOptions.lo -MD -MP -MF .deps/FileOptions.Tpo -c ../src/FileOptions.cpp -o FileOptions.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT GeomTopoTool.lo -MD -MP -MF .deps/GeomTopoTool.Tpo -c ../src/GeomTopoTool.cpp -o GeomTopoTool.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT FileTokenizer.lo -MD -MP -MF .deps/FileTokenizer.Tpo -c ../src/FileTokenizer.cpp -o FileTokenizer.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBAffineXform.lo -MD -MP -MF .deps/MBAffineXform.Tpo -c ../src/MBAffineXform.cpp -o MBAffineXform.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ExoIIUtil.lo -MD -MP -MF .deps/ExoIIUtil.Tpo -c ../src/ExoIIUtil.cpp -o ExoIIUtil.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT HigherOrderFactory.lo -MD -MP -MF .deps/HigherOrderFactory.Tpo -c ../src/HigherOrderFactory.cpp -o HigherOrderFactory.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBAdaptiveKDTree.lo -MD -MP -MF .deps/MBAdaptiveKDTree.Tpo -c ../src/MBAdaptiveKDTree.cpp -o MBAdaptiveKDTree.o
mv -f .deps/FileTokenizer.Tpo .deps/FileTokenizer.Plo
mv -f .deps/EntitySequence.Tpo .deps/EntitySequence.Plo
mv -f .deps/ExoIIUtil.Tpo .deps/ExoIIUtil.Plo
mv -f .deps/MBAffineXform.Tpo .deps/MBAffineXform.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBAxisBox.lo -MD -MP -MF .deps/MBAxisBox.Tpo -c -o MBAxisBox.lo ../src/MBAxisBox.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBBits.lo -MD -MP -MF .deps/MBBits.Tpo -c -o MBBits.lo ../src/MBBits.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBBSPTree.lo -MD -MP -MF .deps/MBBSPTree.Tpo -c -o MBBSPTree.lo ../src/MBBSPTree.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBMatrix3.lo -MD -MP -MF .deps/MBMatrix3.Tpo -c -o MBMatrix3.lo ../src/MBMatrix3.cpp
mv -f .deps/FileOptions.Tpo .deps/FileOptions.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBFactory.lo -MD -MP -MF .deps/MBFactory.Tpo -c -o MBFactory.lo ../src/MBFactory.cpp
mv -f .deps/GeomTopoTool.Tpo .deps/GeomTopoTool.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBMeshSet.lo -MD -MP -MF .deps/MBMeshSet.Tpo -c -o MBMeshSet.lo ../src/MBMeshSet.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBAxisBox.lo -MD -MP -MF .deps/MBAxisBox.Tpo -c ../src/MBAxisBox.cpp -o MBAxisBox.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBBSPTree.lo -MD -MP -MF .deps/MBBSPTree.Tpo -c ../src/MBBSPTree.cpp -o MBBSPTree.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBFactory.lo -MD -MP -MF .deps/MBFactory.Tpo -c ../src/MBFactory.cpp -o MBFactory.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBBits.lo -MD -MP -MF .deps/MBBits.Tpo -c ../src/MBBits.cpp -o MBBits.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBMatrix3.lo -MD -MP -MF .deps/MBMatrix3.Tpo -c ../src/MBMatrix3.cpp -o MBMatrix3.o
mv -f .deps/HigherOrderFactory.Tpo .deps/HigherOrderFactory.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBOrientedBox.lo -MD -MP -MF .deps/MBOrientedBox.Tpo -c -o MBOrientedBox.lo ../src/MBOrientedBox.cpp
mv -f .deps/MBFactory.Tpo .deps/MBFactory.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBOrientedBoxTreeTool.lo -MD -MP -MF .deps/MBOrientedBoxTreeTool.Tpo -c -o MBOrientedBoxTreeTool.lo ../src/MBOrientedBoxTreeTool.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBMeshSet.lo -MD -MP -MF .deps/MBMeshSet.Tpo -c ../src/MBMeshSet.cpp -o MBMeshSet.o
mv -f .deps/MBAxisBox.Tpo .deps/MBAxisBox.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBRange.lo -MD -MP -MF .deps/MBRange.Tpo -c -o MBRange.lo ../src/MBRange.cpp
mv -f .deps/MBMatrix3.Tpo .deps/MBMatrix3.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBRangeSeqIntersectIter.lo -MD -MP -MF .deps/MBRangeSeqIntersectIter.Tpo -c -o MBRangeSeqIntersectIter.lo ../src/MBRangeSeqIntersectIter.cpp
mv -f .deps/MBBits.Tpo .deps/MBBits.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBReadUtil.lo -MD -MP -MF .deps/MBReadUtil.Tpo -c -o MBReadUtil.lo ../src/MBReadUtil.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBOrientedBox.lo -MD -MP -MF .deps/MBOrientedBox.Tpo -c ../src/MBOrientedBox.cpp -o MBOrientedBox.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBOrientedBoxTreeTool.lo -MD -MP -MF .deps/MBOrientedBoxTreeTool.Tpo -c ../src/MBOrientedBoxTreeTool.cpp -o MBOrientedBoxTreeTool.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBRangeSeqIntersectIter.lo -MD -MP -MF .deps/MBRangeSeqIntersectIter.Tpo -c ../src/MBRangeSeqIntersectIter.cpp -o MBRangeSeqIntersectIter.o
mv -f .deps/MBBSPTree.Tpo .deps/MBBSPTree.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBReaderWriterSet.lo -MD -MP -MF .deps/MBReaderWriterSet.Tpo -c -o MBReaderWriterSet.lo ../src/MBReaderWriterSet.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBRange.lo -MD -MP -MF .deps/MBRange.Tpo -c ../src/MBRange.cpp -o MBRange.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBReaderWriterSet.lo -MD -MP -MF .deps/MBReaderWriterSet.Tpo -c ../src/MBReaderWriterSet.cpp -o MBReaderWriterSet.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBReadUtil.lo -MD -MP -MF .deps/MBReadUtil.Tpo -c ../src/MBReadUtil.cpp -o MBReadUtil.o
mv -f .deps/MBMeshSet.Tpo .deps/MBMeshSet.Plo
mv -f .deps/MBRangeSeqIntersectIter.Tpo .deps/MBRangeSeqIntersectIter.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBSkinner.lo -MD -MP -MF .deps/MBSkinner.Tpo -c -o MBSkinner.lo ../src/MBSkinner.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBUtil.lo -MD -MP -MF .deps/MBUtil.Tpo -c -o MBUtil.lo ../src/MBUtil.cpp
mv -f .deps/MBAdaptiveKDTree.Tpo .deps/MBAdaptiveKDTree.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBWriteUtil.lo -MD -MP -MF .deps/MBWriteUtil.Tpo -c -o MBWriteUtil.lo ../src/MBWriteUtil.cpp
mv -f .deps/MBOrientedBox.Tpo .deps/MBOrientedBox.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MeshSetSequence.lo -MD -MP -MF .deps/MeshSetSequence.Tpo -c -o MeshSetSequence.lo ../src/MeshSetSequence.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBUtil.lo -MD -MP -MF .deps/MBUtil.Tpo -c ../src/MBUtil.cpp -o MBUtil.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MeshSetSequence.lo -MD -MP -MF .deps/MeshSetSequence.Tpo -c ../src/MeshSetSequence.cpp -o MeshSetSequence.o
mv -f .deps/MBRange.Tpo .deps/MBRange.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MeshTopoUtil.lo -MD -MP -MF .deps/MeshTopoUtil.Tpo -c -o MeshTopoUtil.lo ../src/MeshTopoUtil.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBWriteUtil.lo -MD -MP -MF .deps/MBWriteUtil.Tpo -c ../src/MBWriteUtil.cpp -o MBWriteUtil.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBSkinner.lo -MD -MP -MF .deps/MBSkinner.Tpo -c ../src/MBSkinner.cpp -o MBSkinner.o
mv -f .deps/MBUtil.Tpo .deps/MBUtil.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT PolyElementSeq.lo -MD -MP -MF .deps/PolyElementSeq.Tpo -c -o PolyElementSeq.lo ../src/PolyElementSeq.cpp
mv -f .deps/MBReadUtil.Tpo .deps/MBReadUtil.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT ReadGmsh.lo -MD -MP -MF .deps/ReadGmsh.Tpo -c -o ReadGmsh.lo ../src/ReadGmsh.cpp
mv -f .deps/MBReaderWriterSet.Tpo .deps/MBReaderWriterSet.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT ReadSTL.lo -MD -MP -MF .deps/ReadSTL.Tpo -c -o ReadSTL.lo ../src/ReadSTL.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MeshTopoUtil.lo -MD -MP -MF .deps/MeshTopoUtil.Tpo -c ../src/MeshTopoUtil.cpp -o MeshTopoUtil.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT PolyElementSeq.lo -MD -MP -MF .deps/PolyElementSeq.Tpo -c ../src/PolyElementSeq.cpp -o PolyElementSeq.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadSTL.lo -MD -MP -MF .deps/ReadSTL.Tpo -c ../src/ReadSTL.cpp -o ReadSTL.o
mv -f .deps/MBSkinner.Tpo .deps/MBSkinner.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT ReadVtk.lo -MD -MP -MF .deps/ReadVtk.Tpo -c -o ReadVtk.lo ../src/ReadVtk.cpp
mv -f .deps/MBWriteUtil.Tpo .deps/MBWriteUtil.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT ReadIDEAS.lo -MD -MP -MF .deps/ReadIDEAS.Tpo -c -o ReadIDEAS.lo ../src/ReadIDEAS.cpp
mv -f .deps/PolyElementSeq.Tpo .deps/PolyElementSeq.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT ScdElementData.lo -MD -MP -MF .deps/ScdElementData.Tpo -c -o ScdElementData.lo ../src/ScdElementData.cpp
mv -f .deps/MBOrientedBoxTreeTool.Tpo .deps/MBOrientedBoxTreeTool.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT ScdVertexData.lo -MD -MP -MF .deps/ScdVertexData.Tpo -c -o ScdVertexData.lo ../src/ScdVertexData.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadGmsh.lo -MD -MP -MF .deps/ReadGmsh.Tpo -c ../src/ReadGmsh.cpp -o ReadGmsh.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadVtk.lo -MD -MP -MF .deps/ReadVtk.Tpo -c ../src/ReadVtk.cpp -o ReadVtk.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadIDEAS.lo -MD -MP -MF .deps/ReadIDEAS.Tpo -c ../src/ReadIDEAS.cpp -o ReadIDEAS.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ScdElementData.lo -MD -MP -MF .deps/ScdElementData.Tpo -c ../src/ScdElementData.cpp -o ScdElementData.o
mv -f .deps/MeshSetSequence.Tpo .deps/MeshSetSequence.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT SequenceData.lo -MD -MP -MF .deps/SequenceData.Tpo -c -o SequenceData.lo ../src/SequenceData.cpp
mv -f .deps/MeshTopoUtil.Tpo .deps/MeshTopoUtil.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT SequenceManager.lo -MD -MP -MF .deps/SequenceManager.Tpo -c -o SequenceManager.lo ../src/SequenceManager.cpp
mv -f .deps/ReadSTL.Tpo .deps/ReadSTL.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT SparseTagSuperCollection.lo -MD -MP -MF .deps/SparseTagSuperCollection.Tpo -c -o SparseTagSuperCollection.lo ../src/SparseTagSuperCollection.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ScdVertexData.lo -MD -MP -MF .deps/ScdVertexData.Tpo -c ../src/ScdVertexData.cpp -o ScdVertexData.o
mv -f .deps/ReadIDEAS.Tpo .deps/ReadIDEAS.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT SparseTagCollection.lo -MD -MP -MF .deps/SparseTagCollection.Tpo -c -o SparseTagCollection.lo ../src/SparseTagCollection.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT SequenceData.lo -MD -MP -MF .deps/SequenceData.Tpo -c ../src/SequenceData.cpp -o SequenceData.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT SparseTagSuperCollection.lo -MD -MP -MF .deps/SparseTagSuperCollection.Tpo -c ../src/SparseTagSuperCollection.cpp -o SparseTagSuperCollection.o
mv -f .deps/ScdVertexData.Tpo .deps/ScdVertexData.Plo
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT SequenceManager.lo -MD -MP -MF .deps/SequenceManager.Tpo -c ../src/SequenceManager.cpp -o SequenceManager.o
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT StructuredElementSeq.lo -MD -MP -MF .deps/StructuredElementSeq.Tpo -c -o StructuredElementSeq.lo ../src/StructuredElementSeq.cpp
mv -f .deps/ScdElementData.Tpo .deps/ScdElementData.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT TagInfo.lo -MD -MP -MF .deps/TagInfo.Tpo -c -o TagInfo.lo ../src/TagInfo.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT SparseTagCollection.lo -MD -MP -MF .deps/SparseTagCollection.Tpo -c ../src/SparseTagCollection.cpp -o SparseTagCollection.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT StructuredElementSeq.lo -MD -MP -MF .deps/StructuredElementSeq.Tpo -c ../src/StructuredElementSeq.cpp -o StructuredElementSeq.o
mv -f .deps/SequenceData.Tpo .deps/SequenceData.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT TagServer.lo -MD -MP -MF .deps/TagServer.Tpo -c -o TagServer.lo ../src/TagServer.cpp
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT Tqdcfr.lo -MD -MP -MF .deps/Tqdcfr.Tpo -c -o Tqdcfr.lo ../src/Tqdcfr.cpp
mv -f .deps/ReadVtk.Tpo .deps/ReadVtk.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT TypeSequenceManager.lo -MD -MP -MF .deps/TypeSequenceManager.Tpo -c -o TypeSequenceManager.lo ../src/TypeSequenceManager.cpp
mv -f .deps/SparseTagSuperCollection.Tpo .deps/SparseTagSuperCollection.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT UnstructuredElemSeq.lo -MD -MP -MF .deps/UnstructuredElemSeq.Tpo -c -o UnstructuredElemSeq.lo ../src/UnstructuredElemSeq.cpp
mv -f .deps/SparseTagCollection.Tpo .deps/SparseTagCollection.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT VertexSequence.lo -MD -MP -MF .deps/VertexSequence.Tpo -c -o VertexSequence.lo ../src/VertexSequence.cpp
mv -f .deps/TagInfo.Tpo .deps/TagInfo.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT WriteAns.lo -MD -MP -MF .deps/WriteAns.Tpo -c -o WriteAns.lo ../src/WriteAns.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT TagServer.lo -MD -MP -MF .deps/TagServer.Tpo -c ../src/TagServer.cpp -o TagServer.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT TypeSequenceManager.lo -MD -MP -MF .deps/TypeSequenceManager.Tpo -c ../src/TypeSequenceManager.cpp -o TypeSequenceManager.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT VertexSequence.lo -MD -MP -MF .deps/VertexSequence.Tpo -c ../src/VertexSequence.cpp -o VertexSequence.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT UnstructuredElemSeq.lo -MD -MP -MF .deps/UnstructuredElemSeq.Tpo -c ../src/UnstructuredElemSeq.cpp -o UnstructuredElemSeq.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT Tqdcfr.lo -MD -MP -MF .deps/Tqdcfr.Tpo -c ../src/Tqdcfr.cpp -o Tqdcfr.o
mv -f .deps/SequenceManager.Tpo .deps/SequenceManager.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT WriteGMV.lo -MD -MP -MF .deps/WriteGMV.Tpo -c -o WriteGMV.lo ../src/WriteGMV.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteAns.lo -MD -MP -MF .deps/WriteAns.Tpo -c ../src/WriteAns.cpp -o WriteAns.o
mv -f .deps/StructuredElementSeq.Tpo .deps/StructuredElementSeq.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT WriteGmsh.lo -MD -MP -MF .deps/WriteGmsh.Tpo -c -o WriteGmsh.lo ../src/WriteGmsh.cpp
mv -f .deps/VertexSequence.Tpo .deps/VertexSequence.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT WriteSTL.lo -MD -MP -MF .deps/WriteSTL.Tpo -c -o WriteSTL.lo ../src/WriteSTL.cpp
mv -f .deps/UnstructuredElemSeq.Tpo .deps/UnstructuredElemSeq.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT WriteTemplate.lo -MD -MP -MF .deps/WriteTemplate.Tpo -c -o WriteTemplate.lo ../src/WriteTemplate.cpp
mv -f .deps/TagServer.Tpo .deps/TagServer.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT WriteVtk.lo -MD -MP -MF .deps/WriteVtk.Tpo -c -o WriteVtk.lo ../src/WriteVtk.cpp
mv -f .deps/TypeSequenceManager.Tpo .deps/TypeSequenceManager.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT ReadNCDF.lo -MD -MP -MF .deps/ReadNCDF.Tpo -c -o ReadNCDF.lo ../src/ReadNCDF.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteGMV.lo -MD -MP -MF .deps/WriteGMV.Tpo -c ../src/WriteGMV.cpp -o WriteGMV.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteTemplate.lo -MD -MP -MF .deps/WriteTemplate.Tpo -c ../src/WriteTemplate.cpp -o WriteTemplate.o
mv -f .deps/WriteAns.Tpo .deps/WriteAns.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT WriteNCDF.lo -MD -MP -MF .deps/WriteNCDF.Tpo -c -o WriteNCDF.lo ../src/WriteNCDF.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteGmsh.lo -MD -MP -MF .deps/WriteGmsh.Tpo -c ../src/WriteGmsh.cpp -o WriteGmsh.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteSTL.lo -MD -MP -MF .deps/WriteSTL.Tpo -c ../src/WriteSTL.cpp -o WriteSTL.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteVtk.lo -MD -MP -MF .deps/WriteVtk.Tpo -c ../src/WriteVtk.cpp -o WriteVtk.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteNCDF.lo -MD -MP -MF .deps/WriteNCDF.Tpo -c ../src/WriteNCDF.cpp -o WriteNCDF.o
mv -f .deps/WriteSTL.Tpo .deps/WriteSTL.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT WriteSLAC.lo -MD -MP -MF .deps/WriteSLAC.Tpo -c -o WriteSLAC.lo ../src/WriteSLAC.cpp
mv -f .deps/WriteGMV.Tpo .deps/WriteGMV.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT ReadHDF5.lo -MD -MP -MF .deps/ReadHDF5.Tpo -c -o ReadHDF5.lo ../src/ReadHDF5.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadNCDF.lo -MD -MP -MF .deps/ReadNCDF.Tpo -c ../src/ReadNCDF.cpp -o ReadNCDF.o
mv -f .deps/WriteGmsh.Tpo .deps/WriteGmsh.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT WriteHDF5.lo -MD -MP -MF .deps/WriteHDF5.Tpo -c -o WriteHDF5.lo ../src/WriteHDF5.cpp
mv -f .deps/WriteTemplate.Tpo .deps/WriteTemplate.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT AEntityFactory.lo -MD -MP -MF .deps/AEntityFactory.Tpo -c -o AEntityFactory.lo ../src/AEntityFactory.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteSLAC.lo -MD -MP -MF .deps/WriteSLAC.Tpo -c ../src/WriteSLAC.cpp -o WriteSLAC.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadHDF5.lo -MD -MP -MF .deps/ReadHDF5.Tpo -c ../src/ReadHDF5.cpp -o ReadHDF5.o
mv -f .deps/Tqdcfr.Tpo .deps/Tqdcfr.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT DualTool.lo -MD -MP -MF .deps/DualTool.Tpo -c -o DualTool.lo ../src/DualTool.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteHDF5.lo -MD -MP -MF .deps/WriteHDF5.Tpo -c ../src/WriteHDF5.cpp -o WriteHDF5.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT AEntityFactory.lo -MD -MP -MF .deps/AEntityFactory.Tpo -c ../src/AEntityFactory.cpp -o AEntityFactory.o
mv -f .deps/WriteVtk.Tpo .deps/WriteVtk.Plo
/bin/sh ./libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT MBCore.lo -MD -MP -MF .deps/MBCore.Tpo -c -o MBCore.lo ../src/MBCore.cpp
mv -f .deps/WriteNCDF.Tpo .deps/WriteNCDF.Plo
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT DualTool.lo -MD -MP -MF .deps/DualTool.Tpo -c ../src/DualTool.cpp -o DualTool.o
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBCore.lo -MD -MP -MF .deps/MBCore.Tpo -c ../src/MBCore.cpp -o MBCore.o
mv -f .deps/ReadNCDF.Tpo .deps/ReadNCDF.Plo
mv -f .deps/ReadHDF5.Tpo .deps/ReadHDF5.Plo
mv -f .deps/WriteSLAC.Tpo .deps/WriteSLAC.Plo
mv -f .deps/AEntityFactory.Tpo .deps/AEntityFactory.Plo
mv -f .deps/WriteHDF5.Tpo .deps/WriteHDF5.Plo
mv -f .deps/DualTool.Tpo .deps/DualTool.Plo
mv -f .deps/MBCore.Tpo .deps/MBCore.Plo
/bin/sh ./libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g  -lm -o libMOAB.la -rpath /usr/local/lib AEntityFactory.lo DualTool.lo EntitySequence.lo ExoIIUtil.lo FileOptions.lo FileTokenizer.lo GeomTopoTool.lo HigherOrderFactory.lo HomXform.lo MBAdaptiveKDTree.lo MBAffineXform.lo MBAlloc.lo MBAxisBox.lo MBBits.lo MBBSPTree.lo MBCN.lo MBCartVect.lo MBMatrix3.lo MBCore.lo MBFactory.lo MBGeomUtil.lo MBMeshSet.lo MBOrientedBox.lo MBOrientedBoxTreeTool.lo MBRange.lo MBRangeSeqIntersectIter.lo MBReadUtil.lo MBReaderWriterSet.lo MBSkinner.lo MBSysUtil.lo MBUtil.lo MBWriteUtil.lo MeshSetSequence.lo MeshTopoUtil.lo PolyElementSeq.lo ReadGmsh.lo ReadSTL.lo ReadVtk.lo ReadIDEAS.lo ScdElementData.lo ScdVertexData.lo SequenceData.lo SequenceManager.lo SparseTagSuperCollection.lo SparseTagCollection.lo StructuredElementSeq.lo TagInfo.lo TagServer.lo Tqdcfr.lo TypeSequenceManager.lo UnstructuredElemSeq.lo VertexSequence.lo VtkUtil.lo WriteAns.lo WriteGMV.lo WriteGmsh.lo WriteST!
 L.lo WriteTemplate.lo WriteVtk.lo ReadNCDF.lo WriteNCDF.lo WriteSLAC.lo ReadHDF5.lo WriteHDF5.lo -lnetcdf_c++ -lnetcdf -lhdf5 ./mhdf/libmhdf.la  -lm
rm -fr  .libs/libMOAB.a .libs/libMOAB.la .libs/libMOAB.lai
rm -fr .libs/libMOAB.lax
mkdir .libs/libMOAB.lax
rm -fr .libs/libMOAB.lax/libmhdf.a
mkdir .libs/libMOAB.lax/libmhdf.a
(cd .libs/libMOAB.lax/libmhdf.a && ar x /home/jason/moab/test/AMD64/./mhdf/.libs/libmhdf.a)
ar cru .libs/libMOAB.a  AEntityFactory.o DualTool.o EntitySequence.o ExoIIUtil.o FileOptions.o FileTokenizer.o GeomTopoTool.o HigherOrderFactory.o HomXform.o MBAdaptiveKDTree.o MBAffineXform.o MBAlloc.o MBAxisBox.o MBBits.o MBBSPTree.o MBCN.o MBCartVect.o MBMatrix3.o MBCore.o MBFactory.o MBGeomUtil.o MBMeshSet.o MBOrientedBox.o MBOrientedBoxTreeTool.o MBRange.o MBRangeSeqIntersectIter.o MBReadUtil.o MBReaderWriterSet.o MBSkinner.o MBSysUtil.o MBUtil.o MBWriteUtil.o MeshSetSequence.o MeshTopoUtil.o PolyElementSeq.o ReadGmsh.o ReadSTL.o ReadVtk.o ReadIDEAS.o ScdElementData.o ScdVertexData.o SequenceData.o SequenceManager.o SparseTagSuperCollection.o SparseTagCollection.o StructuredElementSeq.o TagInfo.o TagServer.o Tqdcfr.o TypeSequenceManager.o UnstructuredElemSeq.o VertexSequence.o VtkUtil.o WriteAns.o WriteGMV.o WriteGmsh.o WriteSTL.o WriteTemplate.o WriteVtk.o ReadNCDF.o WriteNCDF.o WriteSLAC.o ReadHDF5.o WriteHDF5.o  .libs/libMOAB.lax/libmhdf.a/adjacency.o .libs/libMOAB.l!
 ax/libmhdf.a/file-handle.o .libs/libMOAB.lax/libmhdf.a/status.o .libs/libMOAB.lax/libmhdf.a/tags.o .libs/libMOAB.lax/libmhdf.a/file.o .libs/libMOAB.lax/libmhdf.a/nodes.o .libs/libMOAB.lax/libmhdf.a/sets.o .libs/libMOAB.lax/libmhdf.a/connectivity.o .libs/libMOAB.lax/libmhdf.a/util.o
ranlib .libs/libMOAB.a
creating libMOAB.la
(cd .libs && rm -f libMOAB.la && ln -s ../libMOAB.la libMOAB.la)
make[2]: Leaving directory `/home/jason/moab/test/AMD64'
Making all in test
make[2]: Entering directory `/home/jason/moab/test/AMD64/test'
Making all in dual
make[3]: Entering directory `/home/jason/moab/test/AMD64/test/dual'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/jason/moab/test/AMD64/test/dual'
Making all in h5file
make[3]: Entering directory `/home/jason/moab/test/AMD64/test/h5file'
make[3]: Leaving directory `/home/jason/moab/test/AMD64/test/h5file'
Making all in obb
make[3]: Entering directory `/home/jason/moab/test/AMD64/test/obb'
make[3]: Leaving directory `/home/jason/moab/test/AMD64/test/obb'
Making all in perf
make[3]: Entering directory `/home/jason/moab/test/AMD64/test/perf'
make[3]: Leaving directory `/home/jason/moab/test/AMD64/test/perf'
make[3]: Entering directory `/home/jason/moab/test/AMD64/test'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/home/jason/moab/test/AMD64/test'
make[2]: Leaving directory `/home/jason/moab/test/AMD64/test'
Making all in tools
make[2]: Entering directory `/home/jason/moab/test/AMD64/tools'
Making all in iMesh
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools/iMesh'
Making all in .
make[4]: Entering directory `/home/jason/moab/test/AMD64/tools/iMesh'
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DHAVE_CONFIG_H -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/iMesh -I../.. -I../../../src -I../.. -I.   -DVALGRIND  -Wall -pipe -pedantic -g -MT iMesh_MOAB.lo -MD -MP -MF .deps/iMesh_MOAB.Tpo -c -o iMesh_MOAB.lo ../../../src/tools/iMesh/iMesh_MOAB.cpp
 c++ -DHAVE_CONFIG_H -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/iMesh -I../.. -I../../../src -I../.. -I. -DVALGRIND -Wall -pipe -pedantic -g -MT iMesh_MOAB.lo -MD -MP -MF .deps/iMesh_MOAB.Tpo -c ../../../src/tools/iMesh/iMesh_MOAB.cpp -o iMesh_MOAB.o
mv -f .deps/iMesh_MOAB.Tpo .deps/iMesh_MOAB.Plo
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g  -lm -o libiMesh.la -rpath /usr/local/lib iMesh_MOAB.lo  ../../libMOAB.la -lm
rm -fr  .libs/libiMesh.a .libs/libiMesh.la .libs/libiMesh.lai
ar cru .libs/libiMesh.a  iMesh_MOAB.o
ranlib .libs/libiMesh.a
creating libiMesh.la
(cd .libs && rm -f libiMesh.la && ln -s ../libiMesh.la libiMesh.la)
make[4]: Leaving directory `/home/jason/moab/test/AMD64/tools/iMesh'
Making all in SIDL
make[4]: Entering directory `/home/jason/moab/test/AMD64/tools/iMesh/SIDL'
if test "xyes" = "xyes"; then \
	  (cd mserver && make -f ../../../../../src/tools/iMesh/SIDL/mserver.make all) && \
	  (cd Cclient && make -f ../../../../../src/tools/iMesh/SIDL/Cclient.make all) && \
	  (cd Fclient && make -f ../../../../../src/tools/iMesh/SIDL/Fclient.make all) ; \
	fi
make[5]: Entering directory `/home/jason/moab/test/AMD64/tools/iMesh/SIDL/mserver'
/bin/sh ../../../../libtool --tag=CXX --mode=link c++  -Wall -pipe -pedantic -g  -lm -o libiMeshserver.la -rpath /usr/local/lib -lm iBase_Error_IOR.lo iMesh_Factory_IOR.lo iMesh_SIDL_MeshSidl_IOR.lo iBase_Error_Impl.lo iMesh_Factory_Impl.lo iMesh_SIDL_MeshSidl_Impl.lo iBase_Error_Skel.lo iMesh_Factory_Skel.lo iMesh_SIDL_MeshSidl_Skel.lo iBase_ArrTag.lo iBase_EntSet.lo iBase_EntTag.lo iBase_Error.lo iBase_SetBoolOps.lo iBase_SetRelation.lo iBase_SetTag.lo iBase_Tag.lo iMesh_Arr.lo iMesh_ArrMod.lo iMesh_Entity.lo iMesh_Factory.lo iMesh_Mesh.lo iMesh_Modify.lo iMesh_SIDL_MeshSidl.lo sidl_BaseClass.lo sidl_BaseException.lo sidl_BaseInterface.lo sidl_ClassInfo.lo sidl_ClassInfoI.lo sidl_DFinder.lo sidl_DLL.lo sidl_Finder.lo sidl_InvViolation.lo sidl_Loader.lo sidl_PostViolation.lo sidl_PreViolation.lo sidl_SIDLException.lo sidl_io_Deserializer.lo sidl_io_IOException.lo sidl_io_Serializeable.lo sidl_io_Serializer.lo sidl_rmi_ConnectRegistry.lo sidl_rmi_InstanceHandle.lo sidl_rmi_I!
 nstanceRegistry.lo sidl_rmi_Invocation.lo sidl_rmi_NetworkException.lo sidl_rmi_ProtocolFactory.lo sidl_rmi_Response.lo  ../../libiMesh.la -L/opt/babel-0.10.10-64-c2/lib -lsidl
rm -fr  .libs/libiMeshserver.a .libs/libiMeshserver.la .libs/libiMeshserver.lai
ar cru .libs/libiMeshserver.a  iBase_Error_IOR.o iMesh_Factory_IOR.o iMesh_SIDL_MeshSidl_IOR.o iBase_Error_Impl.o iMesh_Factory_Impl.o iMesh_SIDL_MeshSidl_Impl.o iBase_Error_Skel.o iMesh_Factory_Skel.o iMesh_SIDL_MeshSidl_Skel.o iBase_ArrTag.o iBase_EntSet.o iBase_EntTag.o iBase_Error.o iBase_SetBoolOps.o iBase_SetRelation.o iBase_SetTag.o iBase_Tag.o iMesh_Arr.o iMesh_ArrMod.o iMesh_Entity.o iMesh_Factory.o iMesh_Mesh.o iMesh_Modify.o iMesh_SIDL_MeshSidl.o sidl_BaseClass.o sidl_BaseException.o sidl_BaseInterface.o sidl_ClassInfo.o sidl_ClassInfoI.o sidl_DFinder.o sidl_DLL.o sidl_Finder.o sidl_InvViolation.o sidl_Loader.o sidl_PostViolation.o sidl_PreViolation.o sidl_SIDLException.o sidl_io_Deserializer.o sidl_io_IOException.o sidl_io_Serializeable.o sidl_io_Serializer.o sidl_rmi_ConnectRegistry.o sidl_rmi_InstanceHandle.o sidl_rmi_InstanceRegistry.o sidl_rmi_Invocation.o sidl_rmi_NetworkException.o sidl_rmi_ProtocolFactory.o sidl_rmi_Response.o
ranlib .libs/libiMeshserver.a
creating libiMeshserver.la
(cd .libs && rm -f libiMeshserver.la && ln -s ../libiMeshserver.la libiMeshserver.la)
make[5]: Leaving directory `/home/jason/moab/test/AMD64/tools/iMesh/SIDL/mserver'
make[5]: Entering directory `/home/jason/moab/test/AMD64/tools/iMesh/SIDL/Cclient'
/bin/sh ../../../../libtool --tag=CC --mode=link cc  -Wall -pipe -pedantic -g  -lm -o libiMeshCclient.la -rpath /usr/local/lib -lm iBase_ArrTag_Stub.lo iBase_CreationStatus_Stub.lo iBase_EntSet_Stub.lo iBase_EntTag_Stub.lo iBase_EntityType_Stub.lo iBase_ErrorActions_Stub.lo iBase_ErrorType_Stub.lo iBase_Error_Stub.lo iBase_SetBoolOps_Stub.lo iBase_SetRelation_Stub.lo iBase_SetTag_Stub.lo iBase_StorageOrder_Stub.lo iBase_TagValueType_Stub.lo iBase_Tag_Stub.lo iMesh_AdjacencyInfo_Stub.lo iMesh_ArrMod_Stub.lo iMesh_Arr_Stub.lo iMesh_EntityTopology_Stub.lo iMesh_Entity_Stub.lo iMesh_Factory_Stub.lo iMesh_Mesh_Stub.lo iMesh_Modify_Stub.lo iMesh_SIDL_MeshSidl_Stub.lo   ../mserver/libiMeshserver.la -L/opt/babel-0.10.10-64-c2/lib -lsidl
rm -fr  .libs/libiMeshCclient.a .libs/libiMeshCclient.la .libs/libiMeshCclient.lai
ar cru .libs/libiMeshCclient.a  iBase_ArrTag_Stub.o iBase_CreationStatus_Stub.o iBase_EntSet_Stub.o iBase_EntTag_Stub.o iBase_EntityType_Stub.o iBase_ErrorActions_Stub.o iBase_ErrorType_Stub.o iBase_Error_Stub.o iBase_SetBoolOps_Stub.o iBase_SetRelation_Stub.o iBase_SetTag_Stub.o iBase_StorageOrder_Stub.o iBase_TagValueType_Stub.o iBase_Tag_Stub.o iMesh_AdjacencyInfo_Stub.o iMesh_ArrMod_Stub.o iMesh_Arr_Stub.o iMesh_EntityTopology_Stub.o iMesh_Entity_Stub.o iMesh_Factory_Stub.o iMesh_Mesh_Stub.o iMesh_Modify_Stub.o iMesh_SIDL_MeshSidl_Stub.o
ranlib .libs/libiMeshCclient.a
creating libiMeshCclient.la
(cd .libs && rm -f libiMeshCclient.la && ln -s ../libiMeshCclient.la libiMeshCclient.la)
make[5]: Leaving directory `/home/jason/moab/test/AMD64/tools/iMesh/SIDL/Cclient'
make[5]: Entering directory `/home/jason/moab/test/AMD64/tools/iMesh/SIDL/Fclient'
/bin/sh ../../../../libtool --tag=CC --mode=link cc  -Wall -pipe -pedantic -g  -lm -o libiMeshFclient.la -rpath /usr/local/lib -lm iBase_ArrTag_fStub.lo iBase_CreationStatus_fStub.lo iBase_EntSet_fStub.lo iBase_EntTag_fStub.lo iBase_EntityType_fStub.lo iBase_ErrorActions_fStub.lo iBase_ErrorType_fStub.lo iBase_Error_fStub.lo iBase_SetBoolOps_fStub.lo iBase_SetRelation_fStub.lo iBase_SetTag_fStub.lo iBase_StorageOrder_fStub.lo iBase_TagValueType_fStub.lo iBase_Tag_fStub.lo iMesh_AdjacencyInfo_fStub.lo iMesh_ArrMod_fStub.lo iMesh_Arr_fStub.lo iMesh_EntityTopology_fStub.lo iMesh_Entity_fStub.lo iMesh_Factory_fStub.lo iMesh_Mesh_fStub.lo iMesh_Modify_fStub.lo iMesh_SIDL_MeshSidl_fStub.lo sidl_BaseClass_fStub.lo sidl_BaseException_fStub.lo sidl_BaseInterface_fStub.lo sidl_ClassInfoI_fStub.lo sidl_ClassInfo_fStub.lo sidl_DFinder_fStub.lo sidl_DLL_fStub.lo sidl_Finder_fStub.lo sidl_InvViolation_fStub.lo sidl_Loader_fStub.lo sidl_PostViolation_fStub.lo sidl_PreViolation_fStub.lo sid!
 l_Resolve_fStub.lo sidl_SIDLException_fStub.lo sidl_Scope_fStub.lo sidl_array_fStub.lo sidl_bool_fStub.lo sidl_char_fStub.lo sidl_dcomplex_fStub.lo sidl_double_fStub.lo sidl_fcomplex_fStub.lo sidl_float_fStub.lo sidl_int_fStub.lo sidl_io_Deserializer_fStub.lo sidl_io_IOException_fStub.lo sidl_io_Serializeable_fStub.lo sidl_io_Serializer_fStub.lo sidl_long_fStub.lo sidl_opaque_fStub.lo sidl_rmi_ConnectRegistry_fStub.lo sidl_rmi_InstanceHandle_fStub.lo sidl_rmi_InstanceRegistry_fStub.lo sidl_rmi_Invocation_fStub.lo sidl_rmi_NetworkException_fStub.lo sidl_rmi_ProtocolFactory_fStub.lo sidl_rmi_Response_fStub.lo sidl_string_fStub.lo   ../mserver/libiMeshserver.la -L/opt/babel-0.10.10-64-c2/lib -lsidl
rm -fr  .libs/libiMeshFclient.a .libs/libiMeshFclient.la .libs/libiMeshFclient.lai
ar cru .libs/libiMeshFclient.a  iBase_ArrTag_fStub.o iBase_CreationStatus_fStub.o iBase_EntSet_fStub.o iBase_EntTag_fStub.o iBase_EntityType_fStub.o iBase_ErrorActions_fStub.o iBase_ErrorType_fStub.o iBase_Error_fStub.o iBase_SetBoolOps_fStub.o iBase_SetRelation_fStub.o iBase_SetTag_fStub.o iBase_StorageOrder_fStub.o iBase_TagValueType_fStub.o iBase_Tag_fStub.o iMesh_AdjacencyInfo_fStub.o iMesh_ArrMod_fStub.o iMesh_Arr_fStub.o iMesh_EntityTopology_fStub.o iMesh_Entity_fStub.o iMesh_Factory_fStub.o iMesh_Mesh_fStub.o iMesh_Modify_fStub.o iMesh_SIDL_MeshSidl_fStub.o sidl_BaseClass_fStub.o sidl_BaseException_fStub.o sidl_BaseInterface_fStub.o sidl_ClassInfoI_fStub.o sidl_ClassInfo_fStub.o sidl_DFinder_fStub.o sidl_DLL_fStub.o sidl_Finder_fStub.o sidl_InvViolation_fStub.o sidl_Loader_fStub.o sidl_PostViolation_fStub.o sidl_PreViolation_fStub.o sidl_Resolve_fStub.o sidl_SIDLException_fStub.o sidl_Scope_fStub.o sidl_array_fStub.o sidl_bool_fStub.o sidl_char_fStub.o sidl_dcomplex_f!
 Stub.o sidl_double_fStub.o sidl_fcomplex_fStub.o sidl_float_fStub.o sidl_int_fStub.o sidl_io_Deserializer_fStub.o sidl_io_IOException_fStub.o sidl_io_Serializeable_fStub.o sidl_io_Serializer_fStub.o sidl_long_fStub.o sidl_opaque_fStub.o sidl_rmi_ConnectRegistry_fStub.o sidl_rmi_InstanceHandle_fStub.o sidl_rmi_InstanceRegistry_fStub.o sidl_rmi_Invocation_fStub.o sidl_rmi_NetworkException_fStub.o sidl_rmi_ProtocolFactory_fStub.o sidl_rmi_Response_fStub.o sidl_string_fStub.o
ranlib .libs/libiMeshFclient.a
creating libiMeshFclient.la
(cd .libs && rm -f libiMeshFclient.la && ln -s ../libiMeshFclient.la libiMeshFclient.la)
make[5]: Leaving directory `/home/jason/moab/test/AMD64/tools/iMesh/SIDL/Fclient'
make[4]: Leaving directory `/home/jason/moab/test/AMD64/tools/iMesh/SIDL'
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools/iMesh'
Making all in converter
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools/converter'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/converter -I../.. -I../../../src -I../..  -DVALGRIND  -Wall -pipe -pedantic -g -MT convert.o -MD -MP -MF .deps/convert.Tpo -c -o convert.o ../../../src/tools/converter/convert.cpp
mv -f .deps/convert.Tpo .deps/convert.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g  -lm -o mbconvert convert.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o mbconvert convert.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools/converter'
Making all in hexmodops
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools/hexmodops'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/hexmodops -I../.. -I../../../src -I../..  -DVALGRIND  -Wall -pipe -pedantic -g -MT makeops.o -MD -MP -MF .deps/makeops.Tpo -c -o makeops.o ../../../src/tools/hexmodops/makeops.cpp
mv -f .deps/makeops.Tpo .deps/makeops.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g  -lm -o hexmodops makeops.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o hexmodops makeops.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools/hexmodops'
Making all in mbperf
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools/mbperf'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../../src/tools/mbperf -I../.. -I../../../src -I../.. -I../../../src/tools/iMesh -I../../../src/tools/iMesh/SIDL/mserver -I../iMesh/SIDL/mserver -I/opt/babel-0.10.10-64-c2/include  -DVALGRIND  -Wall -pipe -pedantic -g -MT mbperf.o -MD -MP -MF .deps/mbperf.Tpo -c -o mbperf.o ../../../src/tools/mbperf/mbperf.cpp
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g  -lm -o mbperf_SIDL mbperf_SIDL.o ../../libMOAB.la ../iMesh/libiMesh.la  ../iMesh/SIDL/mserver/libiMeshserver.la -lm
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g  -lm -o mbperf_iMesh mbperf_iMesh.o ../../libMOAB.la ../iMesh/libiMesh.la  -lm
c++ -Wall -pipe -pedantic -g -o mbperf_iMesh mbperf_iMesh.o  ../../.libs/libMOAB.a ../iMesh/.libs/libiMesh.a /home/jason/moab/test/AMD64/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
c++ -Wall -pipe -pedantic -g -o mbperf_SIDL mbperf_SIDL.o  ../../.libs/libMOAB.a ../iMesh/.libs/libiMesh.a ../iMesh/SIDL/mserver/.libs/libiMeshserver.a /home/jason/moab/test/AMD64/tools/iMesh/.libs/libiMesh.a /home/jason/moab/test/AMD64/.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -L/opt/babel-0.10.10-64-c2/lib /opt/babel-0.10.10-64-c2/lib/libsidl.so -ldl -lm   -Wl,--rpath -Wl,/opt/babel-0.10.10-64-c2/lib -Wl,--rpath -Wl,/opt/babel-0.10.10-64-c2/lib
mv -f .deps/mbperf.Tpo .deps/mbperf.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g  -lm -o mbperf mbperf.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o mbperf mbperf.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools/mbperf'
Making all in size
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools/size'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/size -I../.. -I../../../src -I../..  -DVALGRIND  -Wall -pipe -pedantic -g -MT size.o -MD -MP -MF .deps/size.Tpo -c -o size.o ../../../src/tools/size/size.cpp
mv -f .deps/size.Tpo .deps/size.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g  -lm -o mbsize measure.o size.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o mbsize measure.o size.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools/size'
Making all in skin
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools/skin'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/skin -I../.. -I../../../src -I../..  -DVALGRIND  -Wall -pipe -pedantic -g -MT skin.o -MD -MP -MF .deps/skin.Tpo -c -o skin.o ../../../src/tools/skin/skin.cpp
mv -f .deps/skin.Tpo .deps/skin.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g  -lm -o mbskin skin.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o mbskin skin.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools/skin'
Making all in tagprop
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools/tagprop'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/tagprop -I../.. -I../../../src -I../..  -DVALGRIND  -Wall -pipe -pedantic -g -MT parse.o -MD -MP -MF .deps/parse.Tpo -c -o parse.o ../../../src/tools/tagprop/parse.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/tagprop -I../.. -I../../../src -I../..  -DVALGRIND  -Wall -pipe -pedantic -g -MT propagate_tags.o -MD -MP -MF .deps/propagate_tags.Tpo -c -o propagate_tags.o ../../../src/tools/tagprop/propagate_tags.cpp
mv -f .deps/parse.Tpo .deps/parse.Po
mv -f .deps/propagate_tags.Tpo .deps/propagate_tags.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g  -lm -o mbtagprop parse.o propagate_tags.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o mbtagprop parse.o propagate_tags.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools/tagprop'
Making all in spheredecomp
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools/spheredecomp'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/spheredecomp -I../.. -I../../../src -I../..  -DVALGRIND  -Wall -pipe -pedantic -g -MT SphereDecomp.o -MD -MP -MF .deps/SphereDecomp.Tpo -c -o SphereDecomp.o ../../../src/tools/spheredecomp/SphereDecomp.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/spheredecomp -I../.. -I../../../src -I../..  -DVALGRIND  -Wall -pipe -pedantic -g -MT main.o -MD -MP -MF .deps/main.Tpo -c -o main.o ../../../src/tools/spheredecomp/main.cpp
mv -f .deps/main.Tpo .deps/main.Po
mv -f .deps/SphereDecomp.Tpo .deps/SphereDecomp.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g  -lm -o spheredecomp SphereDecomp.o main.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o spheredecomp SphereDecomp.o main.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools/spheredecomp'
Making all in surfplot
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools/surfplot'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/surfplot -I../.. -I../../../src -I../..  -DVALGRIND  -Wall -pipe -pedantic -g -MT surfplot.o -MD -MP -MF .deps/surfplot.Tpo -c -o surfplot.o ../../../src/tools/surfplot/surfplot.cpp
mv -f .deps/surfplot.Tpo .deps/surfplot.Po
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g  -lm -o mbsurfplot surfplot.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o mbsurfplot surfplot.o  ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools/surfplot'
Making all in dagmc
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools/dagmc'
/bin/sh ../../libtool --tag=CXX   --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/dagmc -I../.. -I../../../src -I../..   -DVALGRIND   -Wall -pipe -pedantic -g  -MT DagMC.lo -MD -MP -MF .deps/DagMC.Tpo -c -o DagMC.lo ../../../src/tools/dagmc/DagMC.cpp
 c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/dagmc -I../.. -I../../../src -I../.. -DVALGRIND -Wall -pipe -pedantic -g -MT DagMC.lo -MD -MP -MF .deps/DagMC.Tpo -c ../../../src/tools/dagmc/DagMC.cpp -o DagMC.o
mv -f .deps/DagMC.Tpo .deps/DagMC.Plo
/bin/sh ../../libtool --tag=CXX   --mode=link c++  -Wall -pipe -pedantic -g   -lm -o libdagmc.la -rpath /usr/local/lib DagMC.lo   -lm
rm -fr  .libs/libdagmc.a .libs/libdagmc.la .libs/libdagmc.lai
ar cru .libs/libdagmc.a  DagMC.o
ranlib .libs/libdagmc.a
creating libdagmc.la
(cd .libs && rm -f libdagmc.la && ln -s ../libdagmc.la libdagmc.la)
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools/dagmc'
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools'
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools'
make[2]: Leaving directory `/home/jason/moab/test/AMD64/tools'
Making all in doc
make[2]: Entering directory `/home/jason/moab/test/AMD64/doc'
make[2]: Leaving directory `/home/jason/moab/test/AMD64/doc'
Making all in doxygen
make[2]: Entering directory `/home/jason/moab/test/AMD64/doxygen'
make[2]: Leaving directory `/home/jason/moab/test/AMD64/doxygen'
make[1]: Leaving directory `/home/jason/moab/test/AMD64'
Making check in mhdf
make[1]: Entering directory `/home/jason/moab/test/AMD64/mhdf'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/moab/test/AMD64/mhdf'
Making check in .
make  moab_test homxform_test scdseq_test tqdcfr test_adj seq_man_test geom_util_test xform_test obb_test vtk_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test cub_file_test kd_tree_tool kd_tree_time
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT scdseq_test.o -MD -MP -MF .deps/scdseq_test.Tpo -c -o scdseq_test.o ../src/scdseq_test.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src -DTEST_TQDCFR -Wall -pipe -pedantic -g -Wall -pipe -pedantic -g -MT tqdcfr-Tqdcfr.o -MD -MP -MF .deps/tqdcfr-Tqdcfr.Tpo -c -o tqdcfr-Tqdcfr.o `test -f 'Tqdcfr.cpp' || echo '../src/'`Tqdcfr.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT test_adj.o -MD -MP -MF .deps/test_adj.Tpo -c -o test_adj.o ../src/test_adj.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT TestTypeSequenceManager.o -MD -MP -MF .deps/TestTypeSequenceManager.Tpo -c -o TestTypeSequenceManager.o ../src/TestTypeSequenceManager.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT GeomUtilTests.o -MD -MP -MF .deps/GeomUtilTests.Tpo -c -o GeomUtilTests.o ../src/GeomUtilTests.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src -DTEST -Wall -pipe -pedantic -g -Wall -pipe -pedantic -g -MT xform_test-MBAffineXform.o -MD -MP -MF .deps/xform_test-MBAffineXform.Tpo -c -o xform_test-MBAffineXform.o `test -f 'MBAffineXform.cpp' || echo '../src/'`MBAffineXform.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT OBBTest.o -MD -MP -MF .deps/OBBTest.Tpo -c -o OBBTest.o ../src/OBBTest.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT VtkTest.o -MD -MP -MF .deps/VtkTest.Tpo -c -o VtkTest.o ../src/VtkTest.cpp
mv -f .deps/test_adj.Tpo .deps/test_adj.Po
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include   -DVALGRIND -DSRCDIR=../src  -Wall -pipe -pedantic -g -MT adaptive_kd_tree_tests.o -MD -MP -MF .deps/adaptive_kd_tree_tests.Tpo -c -o adaptive_kd_tree_tests.o ../src/adaptive_kd_tree_tests.cpp
mv -f .deps/xform_test-MBAffineXform.Tpo .deps/xform_test-MBAffineXform.Po
mv -f .deps/TestTypeSequenceManager.Tpo .deps/TestTypeSequenceManager.Po
mv -f .deps/GeomUtilTests.Tpo .deps/GeomUtilTests.Po
mv -f .deps/scdseq_test.Tpo .deps/scdseq_test.Po
mv -f .deps/OBBTest.Tpo .deps/OBBTest.Po
mv -f .deps/adaptive_kd_tree_tests.Tpo .deps/adaptive_kd_tree_tests.Po
mv -f .deps/tqdcfr-Tqdcfr.Tpo .deps/tqdcfr-Tqdcfr.Po
