[MOAB-dev] MOAB distcheck failed.
Nightly Test
kraftche at cae.wisc.edu
Tue Oct 21 02:01:20 CDT 2008
In file included from ../../mhdf/src/connectivity.c:20:
../../mhdf/include/mhdf.h:2253:3: warning: C++ style comments are not allowed in ISO C90
../../mhdf/include/mhdf.h:2253:3: warning: (this will be reported only once per input file)
In file included from ../../mhdf/src/util.h:22,
from ../../mhdf/src/connectivity.c:21:
../../mhdf/src/file-handle.h:42:3: warning: C++ style comments are not allowed in ISO C90
../../mhdf/src/file-handle.h:42:3: warning: (this will be reported only once per input file)
In file included from ../../mhdf/src/connectivity.c:21:
../../mhdf/src/util.h:158:3: warning: C++ style comments are not allowed in ISO C90
../../mhdf/src/util.h:158:3: warning: (this will be reported only once per input file)
In file included from ../../mhdf/src/sets.c:21:
from ../../mhdf/src/sets.c:22:
In file included from ../../mhdf/src/sets.c:22:
../../mhdf/src/sets.c: In function âmhdf_readwriteSetMetaâ:
../../mhdf/src/sets.c:214: warning: initializer element is not computable at load time
In file included from ../../mhdf/src/nodes.c:19:
from ../../mhdf/src/nodes.c:22:
In file included from ../../mhdf/src/nodes.c:22:
In file included from ../../mhdf/src/file.c:25:
from ../../mhdf/src/file.c:28:
In file included from ../../mhdf/src/file.c:28:
In file included from ../../mhdf/src/file-handle.h:23,
from ../../mhdf/src/file-handle.c:19:
In file included from ../../mhdf/src/file-handle.c:19:
In file included from ../../mhdf/src/file-handle.c:21:
In file included from ../../mhdf/src/status.h:19,
from ../../mhdf/src/tags.c:24:
In file included from ../../mhdf/src/tags.c:25:
In file included from ../../mhdf/src/tags.c:27:
In file included from ../../mhdf/src/adjacency.c:19:
from ../../mhdf/src/adjacency.c:20:
In file included from ../../mhdf/src/adjacency.c:20:
from ../../mhdf/src/status.c:20:
from ../../mhdf/src/util.h:21,
from ../../mhdf/src/util.c:21:
In file included from ../../mhdf/src/util.c:21:
../FileTokenizer.cpp: In member function âbool FileTokenizer::get_binary(size_t, void*)â:
../FileTokenizer.cpp:471: warning: comparison between signed and unsigned integer expressions
../DualTool.cpp: In member function âMBErrorCode DualTool::split_pair_nonmanifold(MBEntityHandle*, MBEntityHandle*, MBEntityHandle*, std::vector<long unsigned int, std::allocator<long unsigned int> >*, std::vector<long unsigned int, std::allocator<long unsigned int> >*, MBEntityHandle*, MBEntityHandle*, MBEntityHandle*, MBEntityHandle*, MBEntityHandle*)â:
../DualTool.cpp:1976: warning: unused variable âcond1â
../DualTool.cpp:1985: warning: unused variable âcond2â
../DualTool.cpp: In member function âMBErrorCode DualTool::foc_get_stars(MBEntityHandle*, MBEntityHandle*, std::vector<long unsigned int, std::allocator<long unsigned int> >*, std::vector<long unsigned int, std::allocator<long unsigned int> >*)â:
../DualTool.cpp:2096: warning: âon_bdyâ may be used uninitialized in this function
../MBAdaptiveKDTree.cpp:1688: warning: âMBErrorCode closest_to_triangles(MBInterface*, MBEntityHandle, double, const MBCartVect&, std::vector<long unsigned int, std::allocator<long unsigned int> >&, std::vector<MBCartVect, std::allocator<MBCartVect> >&)â defined but not used
../../../tools/iMesh/iMesh_MOAB.cpp:7:26: error: iMesh_MOAB.hpp: No such file or directory
../../../tools/iMesh/iMesh_MOAB.cpp:17: error: âMBiMeshâ has not been declared
../../../tools/iMesh/iMesh_MOAB.cpp:17: error: ISO C++ forbids declaration of âMBiMeshâ with no type
../../../tools/iMesh/iMesh_MOAB.cpp: In function âint MBiMesh()â:
../../../tools/iMesh/iMesh_MOAB.cpp:18: error: only constructors take base initializers
../../../tools/iMesh/iMesh_MOAB.cpp:20: error: âAdjTableâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: At global scope:
../../../tools/iMesh/iMesh_MOAB.cpp:25: error: expected constructor, destructor, or type conversion before â::â token
../../../tools/iMesh/iMesh_MOAB.cpp:27: error: âMBiMeshâ is not a class or namespace
../../../tools/iMesh/iMesh_MOAB.cpp: In function âMBErrorCode delete_mesh()â:
../../../tools/iMesh/iMesh_MOAB.cpp:28: error: âhaveDeletedEntitiesâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:29: error: cannot call member function âvirtual MBErrorCode MBCore::delete_mesh()â without object
../../../tools/iMesh/iMesh_MOAB.cpp:32: error: âMBiMeshâ is not a class or namespace
../../../tools/iMesh/iMesh_MOAB.cpp: In function âMBErrorCode delete_entities(const MBEntityHandle*, int)â:
../../../tools/iMesh/iMesh_MOAB.cpp:35: error: âhaveDeletedEntitiesâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:36: error: cannot call member function âvirtual MBErrorCode MBCore::delete_entities(const MBEntityHandle*, int)â without object
../../../tools/iMesh/iMesh_MOAB.cpp:39: error: âMBiMeshâ is not a class or namespace
../../../tools/iMesh/iMesh_MOAB.cpp: In function âMBErrorCode delete_entities(const MBRange&)â:
../../../tools/iMesh/iMesh_MOAB.cpp:42: error: âhaveDeletedEntitiesâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:43: error: cannot call member function âvirtual MBErrorCode MBCore::delete_entities(const MBRange&)â without object
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_geterrortype_(void*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:217: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getdescription_(void*, char*, int*, int)â:
../../../tools/iMesh/iMesh_MOAB.cpp:226: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid iMesh_setError(void*, int, char*, int*, int)â:
../../../tools/iMesh/iMesh_MOAB.cpp:234: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid iMesh_getError(void*, int*, char*, int*, int)â:
../../../tools/iMesh/iMesh_MOAB.cpp:243: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_newmesh_(const char*, void**, int*, int)â:
../../../tools/iMesh/iMesh_MOAB.cpp:275: error: expected type-specifier before âMBiMeshâ
../../../tools/iMesh/iMesh_MOAB.cpp:275: error: cannot convert âint*â to âMBInterface*â in assignment
../../../tools/iMesh/iMesh_MOAB.cpp:275: error: expected `;' before âMBiMeshâ
../../../tools/iMesh/iMesh_MOAB.cpp:280: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:283: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_dtor_(void*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:288: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:289: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_load_(void*, void*, const char*, const char*, int*, int, int)â:
../../../tools/iMesh/iMesh_MOAB.cpp:306: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:313: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:319: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:321: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:325: error: âMBimeshâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:328: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:330: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:333: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_save_(void*, void*, const char*, const char*, int*, int, int)â:
../../../tools/iMesh/iMesh_MOAB.cpp:347: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:356: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getrootset_(void*, void**, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:364: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getgeometricdimension_(void*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:371: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:372: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getdfltstorage_(void*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:379: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getadjtable_(void*, int**, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:388: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:390: error: âMBimeshâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:391: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid iMesh_setAdjTable(void*, int*, int, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:400: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:403: error: âMBimeshâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:404: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_areehvalid_(void*, int, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:430: error: âmbiâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:430: error: expected type-specifier before âMBiMeshâ
../../../tools/iMesh/iMesh_MOAB.cpp:430: error: expected `>' before âMBiMeshâ
../../../tools/iMesh/iMesh_MOAB.cpp:430: error: expected `(' before âMBiMeshâ
../../../tools/iMesh/iMesh_MOAB.cpp:430: error: expected primary-expression before â>â token
../../../tools/iMesh/iMesh_MOAB.cpp:430: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:430: error: expected `)' before â;â token
../../../tools/iMesh/iMesh_MOAB.cpp:432: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:436: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getallvtxcoords_(void*, void*, double**, int*, int*, int**, int*, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:454: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:460: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:475: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:479: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:481: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:510: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:526: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getvtxcoordindex_(void*, void*, int, int, int, int**, int*, int*, int**, int*, int*, int**, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:557: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:561: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:568: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:577: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:579: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:587: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:592: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:605: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:608: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:614: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:623: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:630: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getvtxarrcoords_(void*, void* const*, int, int*, double**, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:658: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:664: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:671: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:690: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:692: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:697: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getadjentities_(void*, void*, int, int, int, void***, int*, int*, int**, int*, int*, int**, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:722: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:724: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:729: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:734: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:736: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:744: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:755: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:756: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:764: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:765: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:772: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:775: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:778: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:789: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:795: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:803: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:824: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_initentarriter_(void*, void*, int, int, int, void**, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:845: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:850: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:854: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:861: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:864: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:868: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getnextentarriter_(void*, void*, void***, int*, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:886: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:895: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:898: error: âMBimeshâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:904: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_resetentarriter_(void*, void*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:917: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_endentarriter_(void*, void*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:927: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getentarrtopo_(void*, void* const*, int, int**, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:938: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:943: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:947: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getentarrtype_(void*, void* const*, int, int**, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:958: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:963: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:967: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getentarradj_(void*, void* const*, int, int, void***, int*, int*, int**, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:983: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1003: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1007: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1013: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1020: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1027: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getentarr2ndadj_(void*, void* const*, int, int, int, void***, int*, int*, int**, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1045: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1054: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1067: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1075: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1083: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_createentset_(void*, int, void**, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1095: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1097: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1101: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1106: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_destroyentset_(void*, void*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1112: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1116: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_islist_(void*, void*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1124: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1131: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getnumentsets_(void*, void*, int, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1143: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1146: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1157: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getentsets_(void*, void*, int, void***, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1169: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1173: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1177: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1180: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1191: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_addentarrtoset_(void*, void* const*, int, void**, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1200: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1210: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_rmventarrfromset_(void*, void* const*, int, void**, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1227: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1237: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_addentset_(void*, void*, void**, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1251: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1261: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_rmventset_(void*, void*, void**, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1268: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1278: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_isentcontained_(void*, void*, void*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1287: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1302: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_addprntchld_(void*, void**, void**, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1318: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1329: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_rmvprntchld_(void*, void**, void**, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1336: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1346: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_ischildof_(void*, void*, void*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1356: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1364: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1376: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getnumchld_(void*, void*, int, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1385: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1393: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1396: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getnumprnt_(void*, void*, int, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1405: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1413: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1416: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getchldn_(void*, void*, int, void***, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1428: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1436: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1439: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1448: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getprnts_(void*, void*, int, void***, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1460: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1468: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1471: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1480: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_setvtxarrcoords_(void*, void**, int, int, const double*, int, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1492: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1501: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1509: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_createvtxarr_(void*, int, int, const double*, int, void***, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1523: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1527: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1534: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1537: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1543: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_createentarr_(void*, int, void* const*, int, void***, int*, int*, int**, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1568: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1573: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1579: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1583: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1586: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1595: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1615: error: âMBimeshâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1620: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1623: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_deleteentarr_(void*, void**, int, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1631: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1634: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1639: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_createtag_(void*, const char*, int, int, void**, int*, int)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1670: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1689: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_destroytag_(void*, void*, int, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1702: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1713: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1719: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1723: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_gettagname_(void*, void*, char*, int*, int)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1732: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1740: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_gettagtype_(void*, void*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1748: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1753: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1760: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_gettagsizevalues_(void*, void*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1768: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1795: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_gettagsizebytes_(void*, void*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1802: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1809: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_gettaghandle_(void*, const char*, void**, int*, int)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1817: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1828: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_setentsetdata_(void*, void*, void*, const char*, int, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1841: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1844: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1850: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getentsetdata_(void*, void*, void*, char**, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1904: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1910: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1924: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getallentsettags_(void*, void*, void***, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:1980: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1985: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:1992: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_rmventsettag_(void*, void*, void*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2002: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2004: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2008: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_createent_(void*, int, void* const*, int, void**, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2044: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2051: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getarrdata_(void*, void* const*, int, void*, char**, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2081: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2088: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2092: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2095: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2119: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_setarrdata_(void*, void**, int, void*, const char*, int, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2204: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2207: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2217: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_rmvarrtag_(void*, void**, int, void*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2277: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2282: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getalltags_(void*, void*, void***, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2405: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2410: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2417: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getenttopo_(void*, void*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2466: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2467: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getenttype_(void*, void*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2474: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2475: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_subtract_(void*, void*, void*, void**, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2541: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2555: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_intersect_(void*, void*, void*, void**, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2566: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2580: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_unite_(void*, void*, void*, void**, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2591: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2605: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getentitiesrec_(void*, void*, int, int, int, void***, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2635: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2645: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2648: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2650: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2654: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2656: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2661: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2670: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2682: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getnumoftyperec_(void*, void*, int, int, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2710: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2719: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2726: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2729: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2732: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getnumoftoporec_(void*, void*, int, int, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2760: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2766: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2777: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2785: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2788: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2791: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getentsbytagsrec_(void*, void*, int, int, void* const*, const char* const*, int, int, void***, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2845: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2855: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2865: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2874: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2881: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2883: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2886: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2895: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2907: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âvoid imesh_getentsetsbytagsrec_(void*, void*, void* const*, const char* const*, int, int, void***, int*, int*, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2926: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2934: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2937: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:2946: error: âRETURNâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âMBErrorCode iMesh_tag_set_vertices(void*, MBEntityHandle, int, MBEntityType, void**&, MBRange&, int&, int*)â:
../../../tools/iMesh/iMesh_MOAB.cpp:2973: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp: In function âMBErrorCode create_int_ents(MBInterface*, MBRange&, MBEntityHandle)â:
../../../tools/iMesh/iMesh_MOAB.cpp:3047: error: âMBimeshâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:3048: error: âMBIâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:3059: error: âMBimeshâ was not declared in this scope
../../../tools/iMesh/iMesh_MOAB.cpp:3061: error: âMBIâ was not declared in this scope
make[5]: *** [iMesh_MOAB.lo] Error 1
make[4]: *** [all-recursive] Error 1
make[3]: *** [all-recursive] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all] Error 2
make: *** [distcheck] Error 2
dantic -O2 -DNDEBUG -MT MBMeshSet.lo -MD -MP -MF .deps/MBMeshSet.Tpo -c -o MBMeshSet.lo ../MBMeshSet.cpp
mv -f .deps/MBCN.Tpo .deps/MBCN.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBOrientedBox.lo -MD -MP -MF .deps/MBOrientedBox.Tpo -c -o MBOrientedBox.lo ../MBOrientedBox.cpp
mv -f .deps/MBFactory.Tpo .deps/MBFactory.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBOrientedBoxTreeTool.lo -MD -MP -MF .deps/MBOrientedBoxTreeTool.Tpo -c -o MBOrientedBoxTreeTool.lo ../MBOrientedBoxTreeTool.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBGeomUtil.lo -MD -MP -MF .deps/MBGeomUtil.Tpo -c ../MBGeomUtil.cpp -o MBGeomUtil.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBMeshSet.lo -MD -MP -MF .deps/MBMeshSet.Tpo -c ../MBMeshSet.cpp -o MBMeshSet.o
mv -f .deps/MBBSPTree.Tpo .deps/MBBSPTree.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBRange.lo -MD -MP -MF .deps/MBRange.Tpo -c -o MBRange.lo ../MBRange.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBOrientedBoxTreeTool.lo -MD -MP -MF .deps/MBOrientedBoxTreeTool.Tpo -c ../MBOrientedBoxTreeTool.cpp -o MBOrientedBoxTreeTool.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBOrientedBox.lo -MD -MP -MF .deps/MBOrientedBox.Tpo -c ../MBOrientedBox.cpp -o MBOrientedBox.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBRange.lo -MD -MP -MF .deps/MBRange.Tpo -c ../MBRange.cpp -o MBRange.o
mv -f .deps/MBGeomUtil.Tpo .deps/MBGeomUtil.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBRangeSeqIntersectIter.lo -MD -MP -MF .deps/MBRangeSeqIntersectIter.Tpo -c -o MBRangeSeqIntersectIter.lo ../MBRangeSeqIntersectIter.cpp
mv -f .deps/MBAdaptiveKDTree.Tpo .deps/MBAdaptiveKDTree.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBReadUtil.lo -MD -MP -MF .deps/MBReadUtil.Tpo -c -o MBReadUtil.lo ../MBReadUtil.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBReadUtil.lo -MD -MP -MF .deps/MBReadUtil.Tpo -c ../MBReadUtil.cpp -o MBReadUtil.o
mv -f .deps/DualTool.Tpo .deps/DualTool.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBReaderWriterSet.lo -MD -MP -MF .deps/MBReaderWriterSet.Tpo -c -o MBReaderWriterSet.lo ../MBReaderWriterSet.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBRangeSeqIntersectIter.lo -MD -MP -MF .deps/MBRangeSeqIntersectIter.Tpo -c ../MBRangeSeqIntersectIter.cpp -o MBRangeSeqIntersectIter.o
mv -f .deps/MBOrientedBox.Tpo .deps/MBOrientedBox.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBSkinner.lo -MD -MP -MF .deps/MBSkinner.Tpo -c -o MBSkinner.lo ../MBSkinner.cpp
mv -f .deps/MBMeshSet.Tpo .deps/MBMeshSet.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBSysUtil.lo -MD -MP -MF .deps/MBSysUtil.Tpo -c -o MBSysUtil.lo ../MBSysUtil.cpp
mv -f .deps/MBRange.Tpo .deps/MBRange.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBUtil.lo -MD -MP -MF .deps/MBUtil.Tpo -c -o MBUtil.lo ../MBUtil.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBSkinner.lo -MD -MP -MF .deps/MBSkinner.Tpo -c ../MBSkinner.cpp -o MBSkinner.o
mv -f .deps/MBRangeSeqIntersectIter.Tpo .deps/MBRangeSeqIntersectIter.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBWriteUtil.lo -MD -MP -MF .deps/MBWriteUtil.Tpo -c -o MBWriteUtil.lo ../MBWriteUtil.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBReaderWriterSet.lo -MD -MP -MF .deps/MBReaderWriterSet.Tpo -c ../MBReaderWriterSet.cpp -o MBReaderWriterSet.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBUtil.lo -MD -MP -MF .deps/MBUtil.Tpo -c ../MBUtil.cpp -o MBUtil.o
mv -f .deps/MBReadUtil.Tpo .deps/MBReadUtil.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MeshSetSequence.lo -MD -MP -MF .deps/MeshSetSequence.Tpo -c -o MeshSetSequence.lo ../MeshSetSequence.cpp
mv -f .deps/MBUtil.Tpo .deps/MBUtil.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MeshTopoUtil.lo -MD -MP -MF .deps/MeshTopoUtil.Tpo -c -o MeshTopoUtil.lo ../MeshTopoUtil.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBSysUtil.lo -MD -MP -MF .deps/MBSysUtil.Tpo -c ../MBSysUtil.cpp -o MBSysUtil.o
mv -f .deps/MBSysUtil.Tpo .deps/MBSysUtil.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT PolyElementSeq.lo -MD -MP -MF .deps/PolyElementSeq.Tpo -c -o PolyElementSeq.lo ../PolyElementSeq.cpp
mv -f .deps/MBSkinner.Tpo .deps/MBSkinner.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ReadGmsh.lo -MD -MP -MF .deps/ReadGmsh.Tpo -c -o ReadGmsh.lo ../ReadGmsh.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MeshSetSequence.lo -MD -MP -MF .deps/MeshSetSequence.Tpo -c ../MeshSetSequence.cpp -o MeshSetSequence.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MeshTopoUtil.lo -MD -MP -MF .deps/MeshTopoUtil.Tpo -c ../MeshTopoUtil.cpp -o MeshTopoUtil.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT PolyElementSeq.lo -MD -MP -MF .deps/PolyElementSeq.Tpo -c ../PolyElementSeq.cpp -o PolyElementSeq.o
mv -f .deps/MBReaderWriterSet.Tpo .deps/MBReaderWriterSet.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ReadSTL.lo -MD -MP -MF .deps/ReadSTL.Tpo -c -o ReadSTL.lo ../ReadSTL.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT MBWriteUtil.lo -MD -MP -MF .deps/MBWriteUtil.Tpo -c ../MBWriteUtil.cpp -o MBWriteUtil.o
mv -f .deps/PolyElementSeq.Tpo .deps/PolyElementSeq.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ReadVtk.lo -MD -MP -MF .deps/ReadVtk.Tpo -c -o ReadVtk.lo ../ReadVtk.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ReadGmsh.lo -MD -MP -MF .deps/ReadGmsh.Tpo -c ../ReadGmsh.cpp -o ReadGmsh.o
mv -f .deps/MBCore.Tpo .deps/MBCore.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ReadIDEAS.lo -MD -MP -MF .deps/ReadIDEAS.Tpo -c -o ReadIDEAS.lo ../ReadIDEAS.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ReadSTL.lo -MD -MP -MF .deps/ReadSTL.Tpo -c ../ReadSTL.cpp -o ReadSTL.o
mv -f .deps/MBOrientedBoxTreeTool.Tpo .deps/MBOrientedBoxTreeTool.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ScdElementData.lo -MD -MP -MF .deps/ScdElementData.Tpo -c -o ScdElementData.lo ../ScdElementData.cpp
mv -f .deps/MeshTopoUtil.Tpo .deps/MeshTopoUtil.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ScdVertexData.lo -MD -MP -MF .deps/ScdVertexData.Tpo -c -o ScdVertexData.lo ../ScdVertexData.cpp
mv -f .deps/MBWriteUtil.Tpo .deps/MBWriteUtil.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT SequenceData.lo -MD -MP -MF .deps/SequenceData.Tpo -c -o SequenceData.lo ../SequenceData.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ReadIDEAS.lo -MD -MP -MF .deps/ReadIDEAS.Tpo -c ../ReadIDEAS.cpp -o ReadIDEAS.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ScdElementData.lo -MD -MP -MF .deps/ScdElementData.Tpo -c ../ScdElementData.cpp -o ScdElementData.o
mv -f .deps/MeshSetSequence.Tpo .deps/MeshSetSequence.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT SequenceManager.lo -MD -MP -MF .deps/SequenceManager.Tpo -c -o SequenceManager.lo ../SequenceManager.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT SequenceData.lo -MD -MP -MF .deps/SequenceData.Tpo -c ../SequenceData.cpp -o SequenceData.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ReadVtk.lo -MD -MP -MF .deps/ReadVtk.Tpo -c ../ReadVtk.cpp -o ReadVtk.o
mv -f .deps/ReadGmsh.Tpo .deps/ReadGmsh.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT SparseTagSuperCollection.lo -MD -MP -MF .deps/SparseTagSuperCollection.Tpo -c -o SparseTagSuperCollection.lo ../SparseTagSuperCollection.cpp
mv -f .deps/ReadSTL.Tpo .deps/ReadSTL.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT SparseTagCollection.lo -MD -MP -MF .deps/SparseTagCollection.Tpo -c -o SparseTagCollection.lo ../SparseTagCollection.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ScdVertexData.lo -MD -MP -MF .deps/ScdVertexData.Tpo -c ../ScdVertexData.cpp -o ScdVertexData.o
mv -f .deps/ReadIDEAS.Tpo .deps/ReadIDEAS.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT StructuredElementSeq.lo -MD -MP -MF .deps/StructuredElementSeq.Tpo -c -o StructuredElementSeq.lo ../StructuredElementSeq.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT SequenceManager.lo -MD -MP -MF .deps/SequenceManager.Tpo -c ../SequenceManager.cpp -o SequenceManager.o
mv -f .deps/SequenceData.Tpo .deps/SequenceData.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT TagInfo.lo -MD -MP -MF .deps/TagInfo.Tpo -c -o TagInfo.lo ../TagInfo.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT SparseTagSuperCollection.lo -MD -MP -MF .deps/SparseTagSuperCollection.Tpo -c ../SparseTagSuperCollection.cpp -o SparseTagSuperCollection.o
mv -f .deps/ScdElementData.Tpo .deps/ScdElementData.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT TagServer.lo -MD -MP -MF .deps/TagServer.Tpo -c -o TagServer.lo ../TagServer.cpp
mv -f .deps/ScdVertexData.Tpo .deps/ScdVertexData.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT Tqdcfr.lo -MD -MP -MF .deps/Tqdcfr.Tpo -c -o Tqdcfr.lo ../Tqdcfr.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT TagInfo.lo -MD -MP -MF .deps/TagInfo.Tpo -c ../TagInfo.cpp -o TagInfo.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT SparseTagCollection.lo -MD -MP -MF .deps/SparseTagCollection.Tpo -c ../SparseTagCollection.cpp -o SparseTagCollection.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT StructuredElementSeq.lo -MD -MP -MF .deps/StructuredElementSeq.Tpo -c ../StructuredElementSeq.cpp -o StructuredElementSeq.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT Tqdcfr.lo -MD -MP -MF .deps/Tqdcfr.Tpo -c ../Tqdcfr.cpp -o Tqdcfr.o
mv -f .deps/TagInfo.Tpo .deps/TagInfo.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT TypeSequenceManager.lo -MD -MP -MF .deps/TypeSequenceManager.Tpo -c -o TypeSequenceManager.lo ../TypeSequenceManager.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT TagServer.lo -MD -MP -MF .deps/TagServer.Tpo -c ../TagServer.cpp -o TagServer.o
mv -f .deps/SparseTagSuperCollection.Tpo .deps/SparseTagSuperCollection.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT UnstructuredElemSeq.lo -MD -MP -MF .deps/UnstructuredElemSeq.Tpo -c -o UnstructuredElemSeq.lo ../UnstructuredElemSeq.cpp
mv -f .deps/SparseTagCollection.Tpo .deps/SparseTagCollection.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT VertexSequence.lo -MD -MP -MF .deps/VertexSequence.Tpo -c -o VertexSequence.lo ../VertexSequence.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT UnstructuredElemSeq.lo -MD -MP -MF .deps/UnstructuredElemSeq.Tpo -c ../UnstructuredElemSeq.cpp -o UnstructuredElemSeq.o
mv -f .deps/StructuredElementSeq.Tpo .deps/StructuredElementSeq.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT VtkUtil.lo -MD -MP -MF .deps/VtkUtil.Tpo -c -o VtkUtil.lo ../VtkUtil.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT TypeSequenceManager.lo -MD -MP -MF .deps/TypeSequenceManager.Tpo -c ../TypeSequenceManager.cpp -o TypeSequenceManager.o
mv -f .deps/ReadVtk.Tpo .deps/ReadVtk.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteAns.lo -MD -MP -MF .deps/WriteAns.Tpo -c -o WriteAns.lo ../WriteAns.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT VertexSequence.lo -MD -MP -MF .deps/VertexSequence.Tpo -c ../VertexSequence.cpp -o VertexSequence.o
mv -f .deps/UnstructuredElemSeq.Tpo .deps/UnstructuredElemSeq.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteGMV.lo -MD -MP -MF .deps/WriteGMV.Tpo -c -o WriteGMV.lo ../WriteGMV.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT VtkUtil.lo -MD -MP -MF .deps/VtkUtil.Tpo -c ../VtkUtil.cpp -o VtkUtil.o
mv -f .deps/VtkUtil.Tpo .deps/VtkUtil.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteGmsh.lo -MD -MP -MF .deps/WriteGmsh.Tpo -c -o WriteGmsh.lo ../WriteGmsh.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteAns.lo -MD -MP -MF .deps/WriteAns.Tpo -c ../WriteAns.cpp -o WriteAns.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteGMV.lo -MD -MP -MF .deps/WriteGMV.Tpo -c ../WriteGMV.cpp -o WriteGMV.o
mv -f .deps/VertexSequence.Tpo .deps/VertexSequence.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteSTL.lo -MD -MP -MF .deps/WriteSTL.Tpo -c -o WriteSTL.lo ../WriteSTL.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteGmsh.lo -MD -MP -MF .deps/WriteGmsh.Tpo -c ../WriteGmsh.cpp -o WriteGmsh.o
mv -f .deps/SequenceManager.Tpo .deps/SequenceManager.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteTemplate.lo -MD -MP -MF .deps/WriteTemplate.Tpo -c -o WriteTemplate.lo ../WriteTemplate.cpp
mv -f .deps/TagServer.Tpo .deps/TagServer.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteVtk.lo -MD -MP -MF .deps/WriteVtk.Tpo -c -o WriteVtk.lo ../WriteVtk.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteSTL.lo -MD -MP -MF .deps/WriteSTL.Tpo -c ../WriteSTL.cpp -o WriteSTL.o
mv -f .deps/TypeSequenceManager.Tpo .deps/TypeSequenceManager.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ReadNCDF.lo -MD -MP -MF .deps/ReadNCDF.Tpo -c -o ReadNCDF.lo ../ReadNCDF.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteVtk.lo -MD -MP -MF .deps/WriteVtk.Tpo -c ../WriteVtk.cpp -o WriteVtk.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteTemplate.lo -MD -MP -MF .deps/WriteTemplate.Tpo -c ../WriteTemplate.cpp -o WriteTemplate.o
mv -f .deps/WriteGMV.Tpo .deps/WriteGMV.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteNCDF.lo -MD -MP -MF .deps/WriteNCDF.Tpo -c -o WriteNCDF.lo ../WriteNCDF.cpp
mv -f .deps/WriteSTL.Tpo .deps/WriteSTL.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteSLAC.lo -MD -MP -MF .deps/WriteSLAC.Tpo -c -o WriteSLAC.lo ../WriteSLAC.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ReadNCDF.lo -MD -MP -MF .deps/ReadNCDF.Tpo -c ../ReadNCDF.cpp -o ReadNCDF.o
mv -f .deps/WriteGmsh.Tpo .deps/WriteGmsh.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ReadHDF5.lo -MD -MP -MF .deps/ReadHDF5.Tpo -c -o ReadHDF5.lo ../ReadHDF5.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteNCDF.lo -MD -MP -MF .deps/WriteNCDF.Tpo -c ../WriteNCDF.cpp -o WriteNCDF.o
mv -f .deps/WriteAns.Tpo .deps/WriteAns.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteHDF5.lo -MD -MP -MF .deps/WriteHDF5.Tpo -c -o WriteHDF5.lo ../WriteHDF5.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT ReadHDF5.lo -MD -MP -MF .deps/ReadHDF5.Tpo -c ../ReadHDF5.cpp -o ReadHDF5.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteSLAC.lo -MD -MP -MF .deps/WriteSLAC.Tpo -c ../WriteSLAC.cpp -o WriteSLAC.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I.. -I. -I../mhdf/include -DSRCDIR=.. -Wall -pipe -pedantic -O2 -DNDEBUG -MT WriteHDF5.lo -MD -MP -MF .deps/WriteHDF5.Tpo -c ../WriteHDF5.cpp -o WriteHDF5.o
mv -f .deps/WriteVtk.Tpo .deps/WriteVtk.Plo
mv -f .deps/WriteTemplate.Tpo .deps/WriteTemplate.Plo
mv -f .deps/Tqdcfr.Tpo .deps/Tqdcfr.Plo
mv -f .deps/ReadHDF5.Tpo .deps/ReadHDF5.Plo
mv -f .deps/ReadNCDF.Tpo .deps/ReadNCDF.Plo
mv -f .deps/WriteSLAC.Tpo .deps/WriteSLAC.Plo
mv -f .deps/WriteNCDF.Tpo .deps/WriteNCDF.Plo
mv -f .deps/WriteHDF5.Tpo .deps/WriteHDF5.Plo
/bin/sh ./libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -O2 -DNDEBUG -lm -o libMOAB.la -rpath /home/jason/moab/test/dist/moab-3.99/_inst/lib AEntityFactory.lo DualTool.lo EntitySequence.lo ExoIIUtil.lo FileOptions.lo FileTokenizer.lo GeomTopoTool.lo HigherOrderFactory.lo HomXform.lo MBAdaptiveKDTree.lo MBAffineXform.lo MBAlloc.lo MBAxisBox.lo MBBits.lo MBBSPTree.lo MBCN.lo MBCartVect.lo MBMatrix3.lo MBCore.lo MBFactory.lo MBGeomUtil.lo MBMeshSet.lo MBOrientedBox.lo MBOrientedBoxTreeTool.lo MBRange.lo MBRangeSeqIntersectIter.lo MBReadUtil.lo MBReaderWriterSet.lo MBSkinner.lo MBSysUtil.lo MBUtil.lo MBWriteUtil.lo MeshSetSequence.lo MeshTopoUtil.lo PolyElementSeq.lo ReadGmsh.lo ReadSTL.lo ReadVtk.lo ReadIDEAS.lo ScdElementData.lo ScdVertexData.lo SequenceData.lo SequenceManager.lo SparseTagSuperCollection.lo SparseTagCollection.lo StructuredElementSeq.lo TagInfo.lo TagServer.lo Tqdcfr.lo TypeSequenceManager.lo UnstructuredElemSeq.lo VertexSequence.lo VtkUtil.lo Wr!
iteAns.lo WriteGMV.lo WriteGmsh.lo WriteSTL.lo WriteTemplate.lo WriteVtk.lo ReadNCDF.lo WriteNCDF.lo WriteSLAC.lo ReadHDF5.lo WriteHDF5.lo -lnetcdf_c++ -lnetcdf -lhdf5 ./mhdf/libmhdf.la -lm
mkdir .libs
rm -fr .libs/libMOAB.lax
mkdir .libs/libMOAB.lax
rm -fr .libs/libMOAB.lax/libmhdf.a
mkdir .libs/libMOAB.lax/libmhdf.a
(cd .libs/libMOAB.lax/libmhdf.a && ar x /home/jason/moab/test/dist/moab-3.99/_build/./mhdf/.libs/libmhdf.a)
ar cru .libs/libMOAB.a AEntityFactory.o DualTool.o EntitySequence.o ExoIIUtil.o FileOptions.o FileTokenizer.o GeomTopoTool.o HigherOrderFactory.o HomXform.o MBAdaptiveKDTree.o MBAffineXform.o MBAlloc.o MBAxisBox.o MBBits.o MBBSPTree.o MBCN.o MBCartVect.o MBMatrix3.o MBCore.o MBFactory.o MBGeomUtil.o MBMeshSet.o MBOrientedBox.o MBOrientedBoxTreeTool.o MBRange.o MBRangeSeqIntersectIter.o MBReadUtil.o MBReaderWriterSet.o MBSkinner.o MBSysUtil.o MBUtil.o MBWriteUtil.o MeshSetSequence.o MeshTopoUtil.o PolyElementSeq.o ReadGmsh.o ReadSTL.o ReadVtk.o ReadIDEAS.o ScdElementData.o ScdVertexData.o SequenceData.o SequenceManager.o SparseTagSuperCollection.o SparseTagCollection.o StructuredElementSeq.o TagInfo.o TagServer.o Tqdcfr.o TypeSequenceManager.o UnstructuredElemSeq.o VertexSequence.o VtkUtil.o WriteAns.o WriteGMV.o WriteGmsh.o WriteSTL.o WriteTemplate.o WriteVtk.o ReadNCDF.o WriteNCDF.o WriteSLAC.o ReadHDF5.o WriteHDF5.o .libs/libMOAB.lax/libmhdf.a/adjacency.o .libs/libMOAB.l!
ax/libmhdf.a/file-handle.o .libs/libMOAB.lax/libmhdf.a/status.o .libs/libMOAB.lax/libmhdf.a/tags.o .libs/libMOAB.lax/libmhdf.a/file.o .libs/libMOAB.lax/libmhdf.a/nodes.o .libs/libMOAB.lax/libmhdf.a/sets.o .libs/libMOAB.lax/libmhdf.a/connectivity.o .libs/libMOAB.lax/libmhdf.a/util.o
ranlib .libs/libMOAB.a
creating libMOAB.la
(cd .libs && rm -f libMOAB.la && ln -s ../libMOAB.la libMOAB.la)
make[3]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build'
Making all in test
make[3]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/test'
Making all in dual
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/test/dual'
make[4]: Nothing to be done for `all'.
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/test/dual'
Making all in h5file
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/test/h5file'
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/test/h5file'
Making all in obb
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/test/obb'
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/test/obb'
Making all in perf
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/test/perf'
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/test/perf'
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/test'
make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/test'
make[3]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/test'
Making all in tools
make[3]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/tools'
Making all in iMesh
make[4]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/iMesh'
Making all in .
make[5]: Entering directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/iMesh'
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DHAVE_CONFIG_H -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../tools/iMesh -I../.. -I../../.. -I../.. -I. -Wall -pipe -pedantic -O2 -DNDEBUG -MT iMesh_MOAB.lo -MD -MP -MF .deps/iMesh_MOAB.Tpo -c -o iMesh_MOAB.lo ../../../tools/iMesh/iMesh_MOAB.cpp
c++ -DHAVE_CONFIG_H -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../tools/iMesh -I../.. -I../../.. -I../.. -I. -Wall -pipe -pedantic -O2 -DNDEBUG -MT iMesh_MOAB.lo -MD -MP -MF .deps/iMesh_MOAB.Tpo -c ../../../tools/iMesh/iMesh_MOAB.cpp -o iMesh_MOAB.o
make[5]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/iMesh'
make[4]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/tools/iMesh'
make[3]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build/tools'
make[2]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build'
make[1]: Leaving directory `/home/jason/moab/test/dist/moab-3.99/_build'
