[MOAB-dev] MOAB check for *AMD64-32* failed.
Nightly Test
kraftche at cae.wisc.edu
Tue Oct 21 02:02:59 CDT 2008
../src/FileTokenizer.cpp: In member function âbool FileTokenizer::get_binary(size_t, void*)â:
../src/FileTokenizer.cpp:471: warning: comparison between signed and unsigned integer expressions
../src/MBAdaptiveKDTree.cpp:1688: warning: âMBErrorCode closest_to_triangles(MBInterface*, MBEntityHandle, double, const MBCartVect&, std::vector<unsigned int, std::allocator<unsigned int> >&, std::vector<MBCartVect, std::allocator<MBCartVect> >&)â defined but not used
../../../src/tools/size/size.cpp: In function âvoid print_stats(set_stats&)â:
../../../src/tools/size/size.cpp:291: warning: ISO C++ does not support the â%lgâ printf format
../src/VtkTest.cpp:30: error: extra â;â
../src/VtkTest.cpp:31: error: extra â;â
../src/VtkTest.cpp:32: error: extra â;â
../src/VtkTest.cpp:33: error: extra â;â
../src/VtkTest.cpp:34: error: extra â;â
../src/VtkTest.cpp:35: error: extra â;â
../src/VtkTest.cpp:36: error: extra â;â
../src/VtkTest.cpp:37: error: extra â;â
../src/VtkTest.cpp:38: error: extra â;â
../src/VtkTest.cpp:39: error: extra â;â
../src/VtkTest.cpp:40: error: extra â;â
../src/VtkTest.cpp:41: error: extra â;â
../src/VtkTest.cpp:42: error: extra â;â
../src/VtkTest.cpp:44: error: extra â;â
../src/VtkTest.cpp:45: error: extra â;â
../src/VtkTest.cpp:46: error: extra â;â
../src/VtkTest.cpp:47: error: extra â;â
../src/VtkTest.cpp:48: error: extra â;â
../src/VtkTest.cpp:49: error: extra â;â
../src/VtkTest.cpp:51: error: extra â;â
../src/VtkTest.cpp:52: error: extra â;â
../src/VtkTest.cpp:53: error: extra â;â
../src/VtkTest.cpp:54: error: extra â;â
../src/VtkTest.cpp:55: error: extra â;â
../src/VtkTest.cpp:56: error: extra â;â
../src/VtkTest.cpp:57: error: extra â;â
../src/VtkTest.cpp:58: error: extra â;â
../src/VtkTest.cpp:59: error: extra â;â
../src/VtkTest.cpp:60: error: extra â;â
../src/VtkTest.cpp:61: error: extra â;â
../src/VtkTest.cpp:63: error: extra â;â
../src/VtkTest.cpp:64: error: extra â;â
../src/VtkTest.cpp:65: error: extra â;â
../src/VtkTest.cpp:66: error: extra â;â
../src/VtkTest.cpp:67: error: extra â;â
../src/VtkTest.cpp:68: error: extra â;â
../src/VtkTest.cpp:69: error: extra â;â
../src/VtkTest.cpp:70: error: extra â;â
../src/VtkTest.cpp:71: error: extra â;â
../src/VtkTest.cpp:72: error: extra â;â
../src/VtkTest.cpp:73: error: extra â;â
../src/VtkTest.cpp:75: error: extra â;â
../src/VtkTest.cpp:76: error: extra â;â
../src/VtkTest.cpp:77: error: extra â;â
../src/VtkTest.cpp:78: error: extra â;â
../src/VtkTest.cpp:79: error: extra â;â
../src/VtkTest.cpp:80: error: extra â;â
../src/VtkTest.cpp:81: error: extra â;â
../src/VtkTest.cpp:82: error: extra â;â
../src/VtkTest.cpp:83: error: extra â;â
../src/VtkTest.cpp:84: error: extra â;â
../src/VtkTest.cpp:85: error: extra â;â
../src/VtkTest.cpp:87: error: extra â;â
../src/VtkTest.cpp:88: error: extra â;â
../src/VtkTest.cpp:89: error: extra â;â
../src/VtkTest.cpp:90: error: extra â;â
../src/VtkTest.cpp:91: error: extra â;â
../src/VtkTest.cpp:92: error: extra â;â
../src/VtkTest.cpp:93: error: extra â;â
../src/VtkTest.cpp:94: error: extra â;â
../src/VtkTest.cpp:95: error: extra â;â
../src/VtkTest.cpp:96: error: extra â;â
../src/VtkTest.cpp:98: error: extra â;â
make[2]: *** [VtkTest.o] Error 1
make[2]: *** Waiting for unfinished jobs....
../src/adaptive_kd_tree_tests.cpp: In function âbool create_simple_2d_tree(MBAdaptiveKDTree&, MBEntityHandle&, MBEntityHandle*)â:
../src/adaptive_kd_tree_tests.cpp:416: warning: unused variable âmbâ
make[1]: *** [check-am] Error 2
make: *** [check-recursive] Error 1
c -o file.o... yes
checking whether the c++ linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking dynamic linker characteristics... GNU/Linux ld.so
(cached) (cached) checking how to hardcode library paths into programs... immediate
appending configuration tag "F77" to libtool
checking if libtool supports shared libraries... yes
checking whether to build shared libraries... no
checking whether to build static libraries... yes
checking for gfortran option to produce PIC... -fPIC
checking if gfortran PIC flag -fPIC works... yes
checking if gfortran static flag -static works... yes
checking if gfortran supports -c -o file.o... yes
checking whether the gfortran linker (/usr/bin/ld -m elf_x86_64) supports shared libraries... yes
checking for gunzip... gunzip -c
checking for gzip... (cached) gunzip -c
checking for zcat... (cached) gunzip -c
checking if C++ compiler supports template specialization... yes
checking how to get verbose linking output from gfortran... -v
checking for Fortran libraries of gfortran... -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2 -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../../../lib -L/lib/../lib -L/usr/lib/../lib -L/usr/lib/gcc/x86_64-linux-gnu/4.3.2/../../.. -lgfortranbegin -lgfortran -lm
checking for dummy main to link with Fortran libraries... none
checking for Fortran name-mangling scheme... lower case, underscore, no extra underscore
checking for inttypes.h... (cached) yes
checking for stdint.h... (cached) yes
checking for sys/types.h... (cached) yes
checking stddef.h usability... yes
checking stddef.h presence... yes
checking for stddef.h... yes
checking for stdlib.h... (cached) yes
checking for uint32_t... yes
checking for size_t... yes
checking for ptrdiff_t... yes
checking ieeefp.h usability... no
checking ieeefp.h presence... no
checking for ieeefp.h... no
checking valgrind/memcheck.h usability... yes
checking valgrind/memcheck.h presence... yes
checking for valgrind/memcheck.h... yes
checking for deflate in -lz... yes
checking for SZ_Decompress in -lsz... no
checking if HDF5 support is enabled... yes
checking hdf5.h usability... yes
checking hdf5.h presence... yes
checking for hdf5.h... yes
checking for H5Fopen in -lhdf5... yes
checking if NetCDF support is enabled... yes
checking strstream.h usability... no
checking strstream.h presence... no
checking for strstream.h... no
checking sstream.h usability... no
checking sstream.h presence... no
checking for sstream.h... no
checking strstream usability... yes
checking strstream presence... yes
checking for strstream... yes
checking netcdf.h usability... yes
checking netcdf.h presence... yes
checking for netcdf.h... yes
checking for netcdf.hh... yes
checking for netcdf_c++ library... yes
checking if mbconvert is to be built... yes
checking if hexmodops is to be built... yes
checking if mbchaco is to be built... no
checking if mbperf is to be built... yes
checking if qvdual is to be built... no
checking if mbsize is to be built... yes
checking if mbskin is to be built... yes
checking if mbtagprop is to be built... yes
checking if mcnpmit is to be built... no
checking if mbcoupler is to be built... no
checking if spheredecomp is to be built... yes
checking if mbsurfplot is to be built... yes
checking if mbzoltan is to be built... no
checking if dagmc is to be built... yes
checking if iMesh support is to be built... no
configure: creating ./config.status
C: cc -Wall -pipe -pedantic -g
C++: c++ -Wall -pipe -pedantic -g
Fortran: gfortran -g -O2 -g
/bin/sh ./config.status
config.status: creating Makefile
config.status: creating moab.make
config.status: creating testdir.h
config.status: creating parallel/Makefile
config.status: creating mhdf/Makefile
config.status: creating test/Makefile
config.status: creating test/h5file/Makefile
config.status: creating test/dual/Makefile
config.status: creating test/obb/Makefile
config.status: creating test/perf/Makefile
config.status: creating tools/Makefile
config.status: creating tools/converter/Makefile
config.status: creating tools/hexmodops/Makefile
config.status: creating tools/iMesh/Makefile
config.status: creating tools/iMesh/iMesh-Defs.inc
config.status: creating tools/iMesh/SIDL/iMesh-SIDL-Defs.inc
config.status: creating tools/iMesh/SIDL/Makefile
config.status: creating tools/iMesh/SIDL/common.make
config.status: creating tools/mbperf/Makefile
config.status: creating tools/mbchaco/Makefile
config.status: creating tools/mbcoupler/Makefile
config.status: creating tools/mbzoltan/Config.moab
config.status: creating tools/mbzoltan/Makefile
config.status: creating tools/mcnpmit/Makefile
config.status: creating tools/qvdual/Makefile
config.status: creating tools/size/Makefile
config.status: creating tools/skin/Makefile
config.status: creating tools/tagprop/Makefile
config.status: creating tools/spheredecomp/Makefile
config.status: creating tools/surfplot/Makefile
config.status: creating tools/dagmc/Makefile
config.status: creating tools/dagmc/dagmc.make
config.status: creating doc/Makefile
config.status: creating doxygen/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: creating MBVersion.h
config.status: MBVersion.h is unchanged
config.status: creating MBEntityHandle.h
config.status: MBEntityHandle.h is unchanged
config.status: creating MBCN_FCDefs.h
config.status: MBCN_FCDefs.h is unchanged
config.status: executing depfiles commands
make all-recursive
make[1]: Entering directory `/home/jason/moab/test/AMD64-32'
Making all in mhdf
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/mhdf'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/mhdf'
Making all in .
make[2]: Entering directory `/home/jason/moab/test/AMD64-32'
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT EntitySequence.lo -MD -MP -MF .deps/EntitySequence.Tpo -c -o EntitySequence.lo ../src/EntitySequence.cpp
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ExoIIUtil.lo -MD -MP -MF .deps/ExoIIUtil.Tpo -c -o ExoIIUtil.lo ../src/ExoIIUtil.cpp
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT FileOptions.lo -MD -MP -MF .deps/FileOptions.Tpo -c -o FileOptions.lo ../src/FileOptions.cpp
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT FileTokenizer.lo -MD -MP -MF .deps/FileTokenizer.Tpo -c -o FileTokenizer.lo ../src/FileTokenizer.cpp
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT GeomTopoTool.lo -MD -MP -MF .deps/GeomTopoTool.Tpo -c -o GeomTopoTool.lo ../src/GeomTopoTool.cpp
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT HigherOrderFactory.lo -MD -MP -MF .deps/HigherOrderFactory.Tpo -c -o HigherOrderFactory.lo ../src/HigherOrderFactory.cpp
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBAdaptiveKDTree.lo -MD -MP -MF .deps/MBAdaptiveKDTree.Tpo -c -o MBAdaptiveKDTree.lo ../src/MBAdaptiveKDTree.cpp
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBAffineXform.lo -MD -MP -MF .deps/MBAffineXform.Tpo -c -o MBAffineXform.lo ../src/MBAffineXform.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ExoIIUtil.lo -MD -MP -MF .deps/ExoIIUtil.Tpo -c ../src/ExoIIUtil.cpp -o ExoIIUtil.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT FileOptions.lo -MD -MP -MF .deps/FileOptions.Tpo -c ../src/FileOptions.cpp -o FileOptions.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT HigherOrderFactory.lo -MD -MP -MF .deps/HigherOrderFactory.Tpo -c ../src/HigherOrderFactory.cpp -o HigherOrderFactory.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT FileTokenizer.lo -MD -MP -MF .deps/FileTokenizer.Tpo -c ../src/FileTokenizer.cpp -o FileTokenizer.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBAdaptiveKDTree.lo -MD -MP -MF .deps/MBAdaptiveKDTree.Tpo -c ../src/MBAdaptiveKDTree.cpp -o MBAdaptiveKDTree.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT GeomTopoTool.lo -MD -MP -MF .deps/GeomTopoTool.Tpo -c ../src/GeomTopoTool.cpp -o GeomTopoTool.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT EntitySequence.lo -MD -MP -MF .deps/EntitySequence.Tpo -c ../src/EntitySequence.cpp -o EntitySequence.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBAffineXform.lo -MD -MP -MF .deps/MBAffineXform.Tpo -c ../src/MBAffineXform.cpp -o MBAffineXform.o
mv -f .deps/ExoIIUtil.Tpo .deps/ExoIIUtil.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBAxisBox.lo -MD -MP -MF .deps/MBAxisBox.Tpo -c -o MBAxisBox.lo ../src/MBAxisBox.cpp
mv -f .deps/FileTokenizer.Tpo .deps/FileTokenizer.Plo
mv -f .deps/MBAffineXform.Tpo .deps/MBAffineXform.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBBits.lo -MD -MP -MF .deps/MBBits.Tpo -c -o MBBits.lo ../src/MBBits.cpp
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBBSPTree.lo -MD -MP -MF .deps/MBBSPTree.Tpo -c -o MBBSPTree.lo ../src/MBBSPTree.cpp
mv -f .deps/FileOptions.Tpo .deps/FileOptions.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBMatrix3.lo -MD -MP -MF .deps/MBMatrix3.Tpo -c -o MBMatrix3.lo ../src/MBMatrix3.cpp
mv -f .deps/EntitySequence.Tpo .deps/EntitySequence.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBFactory.lo -MD -MP -MF .deps/MBFactory.Tpo -c -o MBFactory.lo ../src/MBFactory.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBAxisBox.lo -MD -MP -MF .deps/MBAxisBox.Tpo -c ../src/MBAxisBox.cpp -o MBAxisBox.o
mv -f .deps/GeomTopoTool.Tpo .deps/GeomTopoTool.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBMeshSet.lo -MD -MP -MF .deps/MBMeshSet.Tpo -c -o MBMeshSet.lo ../src/MBMeshSet.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBBits.lo -MD -MP -MF .deps/MBBits.Tpo -c ../src/MBBits.cpp -o MBBits.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBFactory.lo -MD -MP -MF .deps/MBFactory.Tpo -c ../src/MBFactory.cpp -o MBFactory.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBBSPTree.lo -MD -MP -MF .deps/MBBSPTree.Tpo -c ../src/MBBSPTree.cpp -o MBBSPTree.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBMatrix3.lo -MD -MP -MF .deps/MBMatrix3.Tpo -c ../src/MBMatrix3.cpp -o MBMatrix3.o
mv -f .deps/HigherOrderFactory.Tpo .deps/HigherOrderFactory.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBOrientedBox.lo -MD -MP -MF .deps/MBOrientedBox.Tpo -c -o MBOrientedBox.lo ../src/MBOrientedBox.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBMeshSet.lo -MD -MP -MF .deps/MBMeshSet.Tpo -c ../src/MBMeshSet.cpp -o MBMeshSet.o
mv -f .deps/MBAxisBox.Tpo .deps/MBAxisBox.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBOrientedBoxTreeTool.lo -MD -MP -MF .deps/MBOrientedBoxTreeTool.Tpo -c -o MBOrientedBoxTreeTool.lo ../src/MBOrientedBoxTreeTool.cpp
mv -f .deps/MBBits.Tpo .deps/MBBits.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBRange.lo -MD -MP -MF .deps/MBRange.Tpo -c -o MBRange.lo ../src/MBRange.cpp
mv -f .deps/MBFactory.Tpo .deps/MBFactory.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBRangeSeqIntersectIter.lo -MD -MP -MF .deps/MBRangeSeqIntersectIter.Tpo -c -o MBRangeSeqIntersectIter.lo ../src/MBRangeSeqIntersectIter.cpp
mv -f .deps/MBMatrix3.Tpo .deps/MBMatrix3.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBReadUtil.lo -MD -MP -MF .deps/MBReadUtil.Tpo -c -o MBReadUtil.lo ../src/MBReadUtil.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBOrientedBoxTreeTool.lo -MD -MP -MF .deps/MBOrientedBoxTreeTool.Tpo -c ../src/MBOrientedBoxTreeTool.cpp -o MBOrientedBoxTreeTool.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBOrientedBox.lo -MD -MP -MF .deps/MBOrientedBox.Tpo -c ../src/MBOrientedBox.cpp -o MBOrientedBox.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBRangeSeqIntersectIter.lo -MD -MP -MF .deps/MBRangeSeqIntersectIter.Tpo -c ../src/MBRangeSeqIntersectIter.cpp -o MBRangeSeqIntersectIter.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBReadUtil.lo -MD -MP -MF .deps/MBReadUtil.Tpo -c ../src/MBReadUtil.cpp -o MBReadUtil.o
mv -f .deps/MBBSPTree.Tpo .deps/MBBSPTree.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBReaderWriterSet.lo -MD -MP -MF .deps/MBReaderWriterSet.Tpo -c -o MBReaderWriterSet.lo ../src/MBReaderWriterSet.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBRange.lo -MD -MP -MF .deps/MBRange.Tpo -c ../src/MBRange.cpp -o MBRange.o
mv -f .deps/MBAdaptiveKDTree.Tpo .deps/MBAdaptiveKDTree.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBSkinner.lo -MD -MP -MF .deps/MBSkinner.Tpo -c -o MBSkinner.lo ../src/MBSkinner.cpp
mv -f .deps/MBMeshSet.Tpo .deps/MBMeshSet.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBUtil.lo -MD -MP -MF .deps/MBUtil.Tpo -c -o MBUtil.lo ../src/MBUtil.cpp
mv -f .deps/MBRangeSeqIntersectIter.Tpo .deps/MBRangeSeqIntersectIter.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBWriteUtil.lo -MD -MP -MF .deps/MBWriteUtil.Tpo -c -o MBWriteUtil.lo ../src/MBWriteUtil.cpp
mv -f .deps/MBOrientedBox.Tpo .deps/MBOrientedBox.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MeshSetSequence.lo -MD -MP -MF .deps/MeshSetSequence.Tpo -c -o MeshSetSequence.lo ../src/MeshSetSequence.cpp
mv -f .deps/MBReadUtil.Tpo .deps/MBReadUtil.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MeshTopoUtil.lo -MD -MP -MF .deps/MeshTopoUtil.Tpo -c -o MeshTopoUtil.lo ../src/MeshTopoUtil.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBSkinner.lo -MD -MP -MF .deps/MBSkinner.Tpo -c ../src/MBSkinner.cpp -o MBSkinner.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBWriteUtil.lo -MD -MP -MF .deps/MBWriteUtil.Tpo -c ../src/MBWriteUtil.cpp -o MBWriteUtil.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBReaderWriterSet.lo -MD -MP -MF .deps/MBReaderWriterSet.Tpo -c ../src/MBReaderWriterSet.cpp -o MBReaderWriterSet.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBUtil.lo -MD -MP -MF .deps/MBUtil.Tpo -c ../src/MBUtil.cpp -o MBUtil.o
mv -f .deps/MBRange.Tpo .deps/MBRange.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT PolyElementSeq.lo -MD -MP -MF .deps/PolyElementSeq.Tpo -c -o PolyElementSeq.lo ../src/PolyElementSeq.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MeshTopoUtil.lo -MD -MP -MF .deps/MeshTopoUtil.Tpo -c ../src/MeshTopoUtil.cpp -o MeshTopoUtil.o
mv -f .deps/MBUtil.Tpo .deps/MBUtil.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadGmsh.lo -MD -MP -MF .deps/ReadGmsh.Tpo -c -o ReadGmsh.lo ../src/ReadGmsh.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MeshSetSequence.lo -MD -MP -MF .deps/MeshSetSequence.Tpo -c ../src/MeshSetSequence.cpp -o MeshSetSequence.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT PolyElementSeq.lo -MD -MP -MF .deps/PolyElementSeq.Tpo -c ../src/PolyElementSeq.cpp -o PolyElementSeq.o
mv -f .deps/MBSkinner.Tpo .deps/MBSkinner.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadSTL.lo -MD -MP -MF .deps/ReadSTL.Tpo -c -o ReadSTL.lo ../src/ReadSTL.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadGmsh.lo -MD -MP -MF .deps/ReadGmsh.Tpo -c ../src/ReadGmsh.cpp -o ReadGmsh.o
mv -f .deps/MBReaderWriterSet.Tpo .deps/MBReaderWriterSet.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadVtk.lo -MD -MP -MF .deps/ReadVtk.Tpo -c -o ReadVtk.lo ../src/ReadVtk.cpp
mv -f .deps/MBWriteUtil.Tpo .deps/MBWriteUtil.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadIDEAS.lo -MD -MP -MF .deps/ReadIDEAS.Tpo -c -o ReadIDEAS.lo ../src/ReadIDEAS.cpp
mv -f .deps/MBOrientedBoxTreeTool.Tpo .deps/MBOrientedBoxTreeTool.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ScdElementData.lo -MD -MP -MF .deps/ScdElementData.Tpo -c -o ScdElementData.lo ../src/ScdElementData.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadSTL.lo -MD -MP -MF .deps/ReadSTL.Tpo -c ../src/ReadSTL.cpp -o ReadSTL.o
mv -f .deps/PolyElementSeq.Tpo .deps/PolyElementSeq.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ScdVertexData.lo -MD -MP -MF .deps/ScdVertexData.Tpo -c -o ScdVertexData.lo ../src/ScdVertexData.cpp
mv -f .deps/MeshTopoUtil.Tpo .deps/MeshTopoUtil.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT SequenceData.lo -MD -MP -MF .deps/SequenceData.Tpo -c -o SequenceData.lo ../src/SequenceData.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadVtk.lo -MD -MP -MF .deps/ReadVtk.Tpo -c ../src/ReadVtk.cpp -o ReadVtk.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadIDEAS.lo -MD -MP -MF .deps/ReadIDEAS.Tpo -c ../src/ReadIDEAS.cpp -o ReadIDEAS.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ScdVertexData.lo -MD -MP -MF .deps/ScdVertexData.Tpo -c ../src/ScdVertexData.cpp -o ScdVertexData.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT SequenceData.lo -MD -MP -MF .deps/SequenceData.Tpo -c ../src/SequenceData.cpp -o SequenceData.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ScdElementData.lo -MD -MP -MF .deps/ScdElementData.Tpo -c ../src/ScdElementData.cpp -o ScdElementData.o
mv -f .deps/MeshSetSequence.Tpo .deps/MeshSetSequence.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT SequenceManager.lo -MD -MP -MF .deps/SequenceManager.Tpo -c -o SequenceManager.lo ../src/SequenceManager.cpp
mv -f .deps/ReadSTL.Tpo .deps/ReadSTL.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT SparseTagSuperCollection.lo -MD -MP -MF .deps/SparseTagSuperCollection.Tpo -c -o SparseTagSuperCollection.lo ../src/SparseTagSuperCollection.cpp
mv -f .deps/ScdVertexData.Tpo .deps/ScdVertexData.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT SparseTagCollection.lo -MD -MP -MF .deps/SparseTagCollection.Tpo -c -o SparseTagCollection.lo ../src/SparseTagCollection.cpp
mv -f .deps/ReadIDEAS.Tpo .deps/ReadIDEAS.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT StructuredElementSeq.lo -MD -MP -MF .deps/StructuredElementSeq.Tpo -c -o StructuredElementSeq.lo ../src/StructuredElementSeq.cpp
mv -f .deps/SequenceData.Tpo .deps/SequenceData.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT TagInfo.lo -MD -MP -MF .deps/TagInfo.Tpo -c -o TagInfo.lo ../src/TagInfo.cpp
mv -f .deps/ReadGmsh.Tpo .deps/ReadGmsh.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT TagServer.lo -MD -MP -MF .deps/TagServer.Tpo -c -o TagServer.lo ../src/TagServer.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT SparseTagCollection.lo -MD -MP -MF .deps/SparseTagCollection.Tpo -c ../src/SparseTagCollection.cpp -o SparseTagCollection.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT SparseTagSuperCollection.lo -MD -MP -MF .deps/SparseTagSuperCollection.Tpo -c ../src/SparseTagSuperCollection.cpp -o SparseTagSuperCollection.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT StructuredElementSeq.lo -MD -MP -MF .deps/StructuredElementSeq.Tpo -c ../src/StructuredElementSeq.cpp -o StructuredElementSeq.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT SequenceManager.lo -MD -MP -MF .deps/SequenceManager.Tpo -c ../src/SequenceManager.cpp -o SequenceManager.o
mv -f .deps/ScdElementData.Tpo .deps/ScdElementData.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT Tqdcfr.lo -MD -MP -MF .deps/Tqdcfr.Tpo -c -o Tqdcfr.lo ../src/Tqdcfr.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT TagServer.lo -MD -MP -MF .deps/TagServer.Tpo -c ../src/TagServer.cpp -o TagServer.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT TagInfo.lo -MD -MP -MF .deps/TagInfo.Tpo -c ../src/TagInfo.cpp -o TagInfo.o
mv -f .deps/TagInfo.Tpo .deps/TagInfo.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT TypeSequenceManager.lo -MD -MP -MF .deps/TypeSequenceManager.Tpo -c -o TypeSequenceManager.lo ../src/TypeSequenceManager.cpp
mv -f .deps/SparseTagCollection.Tpo .deps/SparseTagCollection.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT UnstructuredElemSeq.lo -MD -MP -MF .deps/UnstructuredElemSeq.Tpo -c -o UnstructuredElemSeq.lo ../src/UnstructuredElemSeq.cpp
mv -f .deps/SparseTagSuperCollection.Tpo .deps/SparseTagSuperCollection.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT VertexSequence.lo -MD -MP -MF .deps/VertexSequence.Tpo -c -o VertexSequence.lo ../src/VertexSequence.cpp
mv -f .deps/ReadVtk.Tpo .deps/ReadVtk.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteAns.lo -MD -MP -MF .deps/WriteAns.Tpo -c -o WriteAns.lo ../src/WriteAns.cpp
mv -f .deps/StructuredElementSeq.Tpo .deps/StructuredElementSeq.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteGMV.lo -MD -MP -MF .deps/WriteGMV.Tpo -c -o WriteGMV.lo ../src/WriteGMV.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT Tqdcfr.lo -MD -MP -MF .deps/Tqdcfr.Tpo -c ../src/Tqdcfr.cpp -o Tqdcfr.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT TypeSequenceManager.lo -MD -MP -MF .deps/TypeSequenceManager.Tpo -c ../src/TypeSequenceManager.cpp -o TypeSequenceManager.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT UnstructuredElemSeq.lo -MD -MP -MF .deps/UnstructuredElemSeq.Tpo -c ../src/UnstructuredElemSeq.cpp -o UnstructuredElemSeq.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteAns.lo -MD -MP -MF .deps/WriteAns.Tpo -c ../src/WriteAns.cpp -o WriteAns.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteGMV.lo -MD -MP -MF .deps/WriteGMV.Tpo -c ../src/WriteGMV.cpp -o WriteGMV.o
mv -f .deps/TagServer.Tpo .deps/TagServer.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteGmsh.lo -MD -MP -MF .deps/WriteGmsh.Tpo -c -o WriteGmsh.lo ../src/WriteGmsh.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT VertexSequence.lo -MD -MP -MF .deps/VertexSequence.Tpo -c ../src/VertexSequence.cpp -o VertexSequence.o
mv -f .deps/SequenceManager.Tpo .deps/SequenceManager.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteSTL.lo -MD -MP -MF .deps/WriteSTL.Tpo -c -o WriteSTL.lo ../src/WriteSTL.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteGmsh.lo -MD -MP -MF .deps/WriteGmsh.Tpo -c ../src/WriteGmsh.cpp -o WriteGmsh.o
mv -f .deps/UnstructuredElemSeq.Tpo .deps/UnstructuredElemSeq.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteTemplate.lo -MD -MP -MF .deps/WriteTemplate.Tpo -c -o WriteTemplate.lo ../src/WriteTemplate.cpp
mv -f .deps/VertexSequence.Tpo .deps/VertexSequence.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteVtk.lo -MD -MP -MF .deps/WriteVtk.Tpo -c -o WriteVtk.lo ../src/WriteVtk.cpp
mv -f .deps/TypeSequenceManager.Tpo .deps/TypeSequenceManager.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadNCDF.lo -MD -MP -MF .deps/ReadNCDF.Tpo -c -o ReadNCDF.lo ../src/ReadNCDF.cpp
mv -f .deps/WriteAns.Tpo .deps/WriteAns.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteNCDF.lo -MD -MP -MF .deps/WriteNCDF.Tpo -c -o WriteNCDF.lo ../src/WriteNCDF.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteTemplate.lo -MD -MP -MF .deps/WriteTemplate.Tpo -c ../src/WriteTemplate.cpp -o WriteTemplate.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteSTL.lo -MD -MP -MF .deps/WriteSTL.Tpo -c ../src/WriteSTL.cpp -o WriteSTL.o
mv -f .deps/WriteGMV.Tpo .deps/WriteGMV.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteSLAC.lo -MD -MP -MF .deps/WriteSLAC.Tpo -c -o WriteSLAC.lo ../src/WriteSLAC.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteVtk.lo -MD -MP -MF .deps/WriteVtk.Tpo -c ../src/WriteVtk.cpp -o WriteVtk.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteNCDF.lo -MD -MP -MF .deps/WriteNCDF.Tpo -c ../src/WriteNCDF.cpp -o WriteNCDF.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteSLAC.lo -MD -MP -MF .deps/WriteSLAC.Tpo -c ../src/WriteSLAC.cpp -o WriteSLAC.o
mv -f .deps/WriteSTL.Tpo .deps/WriteSTL.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadHDF5.lo -MD -MP -MF .deps/ReadHDF5.Tpo -c -o ReadHDF5.lo ../src/ReadHDF5.cpp
mv -f .deps/WriteGmsh.Tpo .deps/WriteGmsh.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteHDF5.lo -MD -MP -MF .deps/WriteHDF5.Tpo -c -o WriteHDF5.lo ../src/WriteHDF5.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT ReadNCDF.lo -MD -MP -MF .deps/ReadNCDF.Tpo -c ../src/ReadNCDF.cpp -o ReadNCDF.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT WriteHDF5.lo -MD -MP -MF .deps/WriteHDF5.Tpo -c ../src/WriteHDF5.cpp -o WriteHDF5.o
mv -f .deps/WriteTemplate.Tpo .deps/WriteTemplate.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT AEntityFactory.lo -MD -MP -MF .deps/AEntityFactory.Tpo -c -o AEntityFactory.lo ../src/AEntityFactory.cpp
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT DualTool.lo -MD -MP -MF .deps/DualTool.Tpo -c -o DualTool.lo ../src/DualTool.cpp
mv -f .deps/WriteVtk.Tpo .deps/WriteVtk.Plo
/bin/sh ./libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBCore.lo -MD -MP -MF .deps/MBCore.Tpo -c -o MBCore.lo ../src/MBCore.cpp
mv -f .deps/WriteSLAC.Tpo .deps/WriteSLAC.Plo
mv -f .deps/WriteNCDF.Tpo .deps/WriteNCDF.Plo
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT DualTool.lo -MD -MP -MF .deps/DualTool.Tpo -c ../src/DualTool.cpp -o DualTool.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT AEntityFactory.lo -MD -MP -MF .deps/AEntityFactory.Tpo -c ../src/AEntityFactory.cpp -o AEntityFactory.o
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT MBCore.lo -MD -MP -MF .deps/MBCore.Tpo -c ../src/MBCore.cpp -o MBCore.o
mv -f .deps/ReadNCDF.Tpo .deps/ReadNCDF.Plo
mv -f .deps/ReadHDF5.Tpo .deps/ReadHDF5.Plo
mv -f .deps/WriteHDF5.Tpo .deps/WriteHDF5.Plo
mv -f .deps/AEntityFactory.Tpo .deps/AEntityFactory.Plo
mv -f .deps/DualTool.Tpo .deps/DualTool.Plo
mv -f .deps/MBCore.Tpo .deps/MBCore.Plo
/bin/sh ./libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -lm -o libMOAB.la -rpath /usr/local/lib AEntityFactory.lo DualTool.lo EntitySequence.lo ExoIIUtil.lo FileOptions.lo FileTokenizer.lo GeomTopoTool.lo HigherOrderFactory.lo HomXform.lo MBAdaptiveKDTree.lo MBAffineXform.lo MBAlloc.lo MBAxisBox.lo MBBits.lo MBBSPTree.lo MBCN.lo MBCartVect.lo MBMatrix3.lo MBCore.lo MBFactory.lo MBGeomUtil.lo MBMeshSet.lo MBOrientedBox.lo MBOrientedBoxTreeTool.lo MBRange.lo MBRangeSeqIntersectIter.lo MBReadUtil.lo MBReaderWriterSet.lo MBSkinner.lo MBSysUtil.lo MBUtil.lo MBWriteUtil.lo MeshSetSequence.lo MeshTopoUtil.lo PolyElementSeq.lo ReadGmsh.lo ReadSTL.lo ReadVtk.lo ReadIDEAS.lo ScdElementData.lo ScdVertexData.lo SequenceData.lo SequenceManager.lo SparseTagSuperCollection.lo SparseTagCollection.lo StructuredElementSeq.lo TagInfo.lo TagServer.lo Tqdcfr.lo TypeSequenceManager.lo UnstructuredElemSeq.lo VertexSequence.lo VtkUtil.lo WriteAns.lo WriteGMV.lo WriteGmsh.lo WriteST!
L.lo WriteTemplate.lo WriteVtk.lo ReadNCDF.lo WriteNCDF.lo WriteSLAC.lo ReadHDF5.lo WriteHDF5.lo -lnetcdf_c++ -lnetcdf -lhdf5 ./mhdf/libmhdf.la -lm
rm -fr .libs/libMOAB.a .libs/libMOAB.la .libs/libMOAB.lai
rm -fr .libs/libMOAB.lax
mkdir .libs/libMOAB.lax
rm -fr .libs/libMOAB.lax/libmhdf.a
mkdir .libs/libMOAB.lax/libmhdf.a
(cd .libs/libMOAB.lax/libmhdf.a && ar x /home/jason/moab/test/AMD64-32/./mhdf/.libs/libmhdf.a)
ar cru .libs/libMOAB.a AEntityFactory.o DualTool.o EntitySequence.o ExoIIUtil.o FileOptions.o FileTokenizer.o GeomTopoTool.o HigherOrderFactory.o HomXform.o MBAdaptiveKDTree.o MBAffineXform.o MBAlloc.o MBAxisBox.o MBBits.o MBBSPTree.o MBCN.o MBCartVect.o MBMatrix3.o MBCore.o MBFactory.o MBGeomUtil.o MBMeshSet.o MBOrientedBox.o MBOrientedBoxTreeTool.o MBRange.o MBRangeSeqIntersectIter.o MBReadUtil.o MBReaderWriterSet.o MBSkinner.o MBSysUtil.o MBUtil.o MBWriteUtil.o MeshSetSequence.o MeshTopoUtil.o PolyElementSeq.o ReadGmsh.o ReadSTL.o ReadVtk.o ReadIDEAS.o ScdElementData.o ScdVertexData.o SequenceData.o SequenceManager.o SparseTagSuperCollection.o SparseTagCollection.o StructuredElementSeq.o TagInfo.o TagServer.o Tqdcfr.o TypeSequenceManager.o UnstructuredElemSeq.o VertexSequence.o VtkUtil.o WriteAns.o WriteGMV.o WriteGmsh.o WriteSTL.o WriteTemplate.o WriteVtk.o ReadNCDF.o WriteNCDF.o WriteSLAC.o ReadHDF5.o WriteHDF5.o .libs/libMOAB.lax/libmhdf.a/adjacency.o .libs/libMOAB.l!
ax/libmhdf.a/file-handle.o .libs/libMOAB.lax/libmhdf.a/status.o .libs/libMOAB.lax/libmhdf.a/tags.o .libs/libMOAB.lax/libmhdf.a/file.o .libs/libMOAB.lax/libmhdf.a/nodes.o .libs/libMOAB.lax/libmhdf.a/sets.o .libs/libMOAB.lax/libmhdf.a/connectivity.o .libs/libMOAB.lax/libmhdf.a/util.o
ranlib .libs/libMOAB.a
creating libMOAB.la
(cd .libs && rm -f libMOAB.la && ln -s ../libMOAB.la libMOAB.la)
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32'
Making all in test
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/test'
Making all in dual
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/dual'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/dual'
Making all in h5file
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/h5file'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/h5file'
Making all in obb
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/obb'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/obb'
Making all in perf
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/perf'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/perf'
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/test'
Making all in tools
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/tools'
Making all in converter
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/converter'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/converter -I../.. -I../../../src -I../.. -DVALGRIND -Wall -pipe -pedantic -g -MT convert.o -MD -MP -MF .deps/convert.Tpo -c -o convert.o ../../../src/tools/converter/convert.cpp
mv -f .deps/convert.Tpo .deps/convert.Po
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -lm -o mbconvert convert.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o mbconvert convert.o ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/converter'
Making all in hexmodops
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/hexmodops'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/hexmodops -I../.. -I../../../src -I../.. -DVALGRIND -Wall -pipe -pedantic -g -MT makeops.o -MD -MP -MF .deps/makeops.Tpo -c -o makeops.o ../../../src/tools/hexmodops/makeops.cpp
mv -f .deps/makeops.Tpo .deps/makeops.Po
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -lm -o hexmodops makeops.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o hexmodops makeops.o ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/hexmodops'
Making all in mbperf
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/mbperf'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../../src/tools/mbperf -I../.. -I../../../src -I../.. -I../../../src/tools/iMesh -I../../../src/tools/iMesh/SIDL/mserver -I../iMesh/SIDL/mserver -DVALGRIND -Wall -pipe -pedantic -g -MT mbperf.o -MD -MP -MF .deps/mbperf.Tpo -c -o mbperf.o ../../../src/tools/mbperf/mbperf.cpp
mv -f .deps/mbperf.Tpo .deps/mbperf.Po
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -lm -o mbperf mbperf.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o mbperf mbperf.o ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/mbperf'
Making all in size
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/size'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/size -I../.. -I../../../src -I../.. -DVALGRIND -Wall -pipe -pedantic -g -MT size.o -MD -MP -MF .deps/size.Tpo -c -o size.o ../../../src/tools/size/size.cpp
mv -f .deps/size.Tpo .deps/size.Po
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -lm -o mbsize measure.o size.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o mbsize measure.o size.o ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/size'
Making all in skin
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/skin'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/skin -I../.. -I../../../src -I../.. -DVALGRIND -Wall -pipe -pedantic -g -MT skin.o -MD -MP -MF .deps/skin.Tpo -c -o skin.o ../../../src/tools/skin/skin.cpp
mv -f .deps/skin.Tpo .deps/skin.Po
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -lm -o mbskin skin.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o mbskin skin.o ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/skin'
Making all in tagprop
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/tagprop'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/tagprop -I../.. -I../../../src -I../.. -DVALGRIND -Wall -pipe -pedantic -g -MT parse.o -MD -MP -MF .deps/parse.Tpo -c -o parse.o ../../../src/tools/tagprop/parse.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/tagprop -I../.. -I../../../src -I../.. -DVALGRIND -Wall -pipe -pedantic -g -MT propagate_tags.o -MD -MP -MF .deps/propagate_tags.Tpo -c -o propagate_tags.o ../../../src/tools/tagprop/propagate_tags.cpp
mv -f .deps/parse.Tpo .deps/parse.Po
mv -f .deps/propagate_tags.Tpo .deps/propagate_tags.Po
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -lm -o mbtagprop parse.o propagate_tags.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o mbtagprop parse.o propagate_tags.o ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/tagprop'
Making all in spheredecomp
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/spheredecomp'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/spheredecomp -I../.. -I../../../src -I../.. -DVALGRIND -Wall -pipe -pedantic -g -MT SphereDecomp.o -MD -MP -MF .deps/SphereDecomp.Tpo -c -o SphereDecomp.o ../../../src/tools/spheredecomp/SphereDecomp.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/spheredecomp -I../.. -I../../../src -I../.. -DVALGRIND -Wall -pipe -pedantic -g -MT main.o -MD -MP -MF .deps/main.Tpo -c -o main.o ../../../src/tools/spheredecomp/main.cpp
mv -f .deps/main.Tpo .deps/main.Po
mv -f .deps/SphereDecomp.Tpo .deps/SphereDecomp.Po
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -lm -o spheredecomp SphereDecomp.o main.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o spheredecomp SphereDecomp.o main.o ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/spheredecomp'
Making all in surfplot
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/surfplot'
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/surfplot -I../.. -I../../../src -I../.. -DVALGRIND -Wall -pipe -pedantic -g -MT surfplot.o -MD -MP -MF .deps/surfplot.Tpo -c -o surfplot.o ../../../src/tools/surfplot/surfplot.cpp
mv -f .deps/surfplot.Tpo .deps/surfplot.Po
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -lm -o mbsurfplot surfplot.o ../../libMOAB.la -lm
c++ -Wall -pipe -pedantic -g -o mbsurfplot surfplot.o ../../.libs/libMOAB.a -lnetcdf_c++ -lnetcdf /usr/lib/libhdf5.so -lpthread -lz -lm
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/surfplot'
Making all in dagmc
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/dagmc'
/bin/sh ../../libtool --tag=CXX --mode=compile c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/dagmc -I../.. -I../../../src -I../.. -DVALGRIND -Wall -pipe -pedantic -g -MT DagMC.lo -MD -MP -MF .deps/DagMC.Tpo -c -o DagMC.lo ../../../src/tools/dagmc/DagMC.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -I. -I../../../src/tools/dagmc -I../.. -I../../../src -I../.. -DVALGRIND -Wall -pipe -pedantic -g -MT DagMC.lo -MD -MP -MF .deps/DagMC.Tpo -c ../../../src/tools/dagmc/DagMC.cpp -o DagMC.o
mv -f .deps/DagMC.Tpo .deps/DagMC.Plo
/bin/sh ../../libtool --tag=CXX --mode=link c++ -Wall -pipe -pedantic -g -lm -o libdagmc.la -rpath /usr/local/lib DagMC.lo -lm
rm -fr .libs/libdagmc.a .libs/libdagmc.la .libs/libdagmc.lai
ar cru .libs/libdagmc.a DagMC.o
ranlib .libs/libdagmc.a
creating libdagmc.la
(cd .libs && rm -f libdagmc.la && ln -s ../libdagmc.la libdagmc.la)
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/dagmc'
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/tools'
Making all in doc
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/doc'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/doc'
Making all in doxygen
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/doxygen'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/doxygen'
make[1]: Leaving directory `/home/jason/moab/test/AMD64-32'
Making check in mhdf
make[1]: Entering directory `/home/jason/moab/test/AMD64-32/mhdf'
make[1]: Nothing to be done for `check'.
make[1]: Leaving directory `/home/jason/moab/test/AMD64-32/mhdf'
Making check in .
make moab_test homxform_test scdseq_test tqdcfr test_adj seq_man_test geom_util_test xform_test obb_test vtk_test adaptive_kd_tree_tests bsp_tree_test file_options_test kd_tree_test var_len_test var_len_test_no_template tag_test mesh_set_test cub_file_test kd_tree_tool kd_tree_time
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT scdseq_test.o -MD -MP -MF .deps/scdseq_test.Tpo -c -o scdseq_test.o ../src/scdseq_test.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -DTEST_TQDCFR -Wall -pipe -pedantic -g -Wall -pipe -pedantic -g -MT tqdcfr-Tqdcfr.o -MD -MP -MF .deps/tqdcfr-Tqdcfr.Tpo -c -o tqdcfr-Tqdcfr.o `test -f 'Tqdcfr.cpp' || echo '../src/'`Tqdcfr.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT test_adj.o -MD -MP -MF .deps/test_adj.Tpo -c -o test_adj.o ../src/test_adj.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT TestTypeSequenceManager.o -MD -MP -MF .deps/TestTypeSequenceManager.Tpo -c -o TestTypeSequenceManager.o ../src/TestTypeSequenceManager.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT GeomUtilTests.o -MD -MP -MF .deps/GeomUtilTests.Tpo -c -o GeomUtilTests.o ../src/GeomUtilTests.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -DTEST -Wall -pipe -pedantic -g -Wall -pipe -pedantic -g -MT xform_test-MBAffineXform.o -MD -MP -MF .deps/xform_test-MBAffineXform.Tpo -c -o xform_test-MBAffineXform.o `test -f 'MBAffineXform.cpp' || echo '../src/'`MBAffineXform.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT OBBTest.o -MD -MP -MF .deps/OBBTest.Tpo -c -o OBBTest.o ../src/OBBTest.cpp
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT VtkTest.o -MD -MP -MF .deps/VtkTest.Tpo -c -o VtkTest.o ../src/VtkTest.cpp
mv -f .deps/test_adj.Tpo .deps/test_adj.Po
c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../src -I. -I../src/mhdf/include -DVALGRIND -DSRCDIR=../src -Wall -pipe -pedantic -g -MT adaptive_kd_tree_tests.o -MD -MP -MF .deps/adaptive_kd_tree_tests.Tpo -c -o adaptive_kd_tree_tests.o ../src/adaptive_kd_tree_tests.cpp
mv -f .deps/xform_test-MBAffineXform.Tpo .deps/xform_test-MBAffineXform.Po
mv -f .deps/TestTypeSequenceManager.Tpo .deps/TestTypeSequenceManager.Po
mv -f .deps/GeomUtilTests.Tpo .deps/GeomUtilTests.Po
mv -f .deps/OBBTest.Tpo .deps/OBBTest.Po
mv -f .deps/scdseq_test.Tpo .deps/scdseq_test.Po
mv -f .deps/adaptive_kd_tree_tests.Tpo .deps/adaptive_kd_tree_tests.Po
mv -f .deps/tqdcfr-Tqdcfr.Tpo .deps/tqdcfr-Tqdcfr.Po
