[MOAB-dev] r2127 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Thu Oct 2 15:37:30 CDT 2008
Author: kraftche
Date: 2008-10-02 15:37:30 -0500 (Thu, 02 Oct 2008)
New Revision: 2127
Modified:
   MOAB/trunk/tools/iMesh/iMeshP.h
   MOAB/trunk/tools/iMesh/iMeshP_protos.h
Log:
 o Update iMeshP.h to latest version from RPI repo, with recent
   syntax corrections.
 o Update iMeshP_protos.h for new iMeshP.h
Modified: MOAB/trunk/tools/iMesh/iMeshP.h
--- MOAB/trunk/tools/iMesh/iMeshP.h	2008-10-02 19:48:09 UTC (rev 2126)
+++ MOAB/trunk/tools/iMesh/iMeshP.h	2008-10-02 20:37:30 UTC (rev 2127)
@@ -1,3 +1,13 @@
+#ifndef iMeshP_H
+#define iMeshP_H
+#include "iBase.h"
+#include "iMeshP_protos.h"
+#ifdef __cplusplus
+extern "C" {
+#endif
 Background and Terminology:
@@ -64,7 +74,7 @@
 Assumptions:
 -  Each part is wholly contained within a process.
--  A process may have multiple parts.
+-  A process may have zero, one or multiple parts.
 -  Many iMesh functions that accept EntitySet handles
    are also useful in the context of part handles.
    These functions will be reinterpreted so that they can accept either an
@@ -78,6 +88,11 @@
    and remote entity handle of all copies of the entity.
 -  All parts with copies of any entity know the part ID and
    entity handle corresponding to the owner of the entity.
+-  Functions that return entity information for a part, set or mesh
+   instance return the information for all entities (including copies and
+   ghosts) in that part, set or mesh instance.  Applications can check
+   whether an entity is owned or a ghost using iMeshP_isEntOwner or
+   iMeshP_getEntStatus.
@@ -86,49 +101,49 @@
-//  Create a partition handle:  Given a mesh instance to contain
-//  the partition and a communicator, return a partition
-//  handle.  May have different creation routines for different
-//  communication systems; once created, the application shouldn't have to
-//  worry about the communication system again.
-//  For serial use, *communicator may be MPI_COMM_SELF or communicator may
-//  be NULL.
-//  COMMUNICATION:  Collective.
+/**  Create a partition handle:  Given a mesh instance to contain
+ *  the partition and a communicator, return a partition
+ *  handle.  May have different creation routines for different
+ *  communication systems; once created, the application shouldn't have to
+ *  worry about the communication system again.
+ *  For serial use, *communicator may be MPI_COMM_SELF or communicator may
+ *  be NULL.
+ *  COMMUNICATION:  Collective.*/
 void iMeshP_createPartitionAll(iMesh_Instance instance,
                     /*in*/  MPI_Comm *communicator,
                     /*out*/ iMeshP_PartitionHandle *partition_handle,
                             int *err);
-//  Destroy a partition handle: Given a partition handle, destroy it and
-//  invalidate it.
+/**  Destroy a partition handle: Given a partition handle, destroy it and
+ *  invalidate it.
 void iMeshP_destroyPartitionAll(iMesh_Instance instance,
                     /*inout*/ iMeshP_PartitionHandle *partition_handle,
                               int *err);
-//  Given a partition handle, return its communicator.
-//  COMMUNICATION:  None
+/**  Given a partition handle, return its communicator.
+ *  COMMUNICATION:  None*/
 void iMeshP_getPartitionComm(iMesh_Instance instance,
                     /*in*/  iMeshP_PartitionHandle partition_handle,
                     /*out*/ MPI_Comm *communicator,
                             int *err);
-//  Update a partition after parts have been added.
-//  Gives the implementation an opportunity to locally store info
-//  about the partition so that queries on the partition can be
-//  performed without synchronous communication.
-//  Values that are precomputed by syncPartitionAll:
-//  +  The total number of parts in a partition.
-//  +  Mapping between part IDs and processes.
-//  +  Updated remote entity handle information.
+/**  Update a partition after parts have been added.
+ *  Gives the implementation an opportunity to locally store info
+ *  about the partition so that queries on the partition can be
+ *  performed without synchronous communication.
+ *  Values that are precomputed by syncPartitionAll:
+ *  +  The total number of parts in a partition.
+ *  +  Mapping between part IDs and processes.
+ *  +  Updated remote entity handle information.
 void iMeshP_syncPartitionAll(iMesh_Instance instance,
                        int *err);
-//  Given a mesh instance, return number of partition handles and
-//  all partition handles associated with the mesh instance.
-//  COMMUNICATION:  None.
+/**  Given a mesh instance, return number of partition handles and
+ *  all partition handles associated with the mesh instance.
+ *  COMMUNICATION:  None.*/
 void iMeshP_getNumPartitions(iMesh_Instance instance,
                     /*out*/ int *num_partitions,
                             int *err);
@@ -139,19 +154,37 @@
              /*out*/   int *partition_handle_size,
                        int *err);
-// Given a partition handle, return the total global number of parts
-// in the partition.
-//  COMMUNICATION:  None++.
-void iMeshP_getNumParts(iMesh_Instance instance,
+/** Given a partition handle, return the total global number of parts
+ * in the partition.
+ *  COMMUNICATION:  None++.*/
+void iMeshP_getNumGlobalParts(iMesh_Instance instance,
                           const iMeshP_PartitionHandle partition_handle,
                           int *num_global_part,
                           int *err);
-//  Map from parts to processes:
-//  Given a partition handle and a part ID, return the rank of the
-//  process that owns the part.
-//  The part may be local or remote.
+/** Given a partition handle, return the number of local (on-process) parts
+void iMeshP_getNumLocalParts(iMesh_Instance instance,
+                          const iMeshP_PartitionHandle partition_handle,
+                          int *num_local_part,
+                          int *err);
+/** Given a partition handle, return the number of local parts
+ * in the partition as well as the partition handles for the local parts.
+void iMeshP_getLocalParts(iMesh_Instance instance,
+                          iMeshP_PartHandle *part_handles,
+                          int part_handles_allocated,
+                          int *err);
+/**  Map from parts to processes:
+ *  Given a partition handle and a part ID, return the rank of the
+ *  process that owns the part.
+ *  The part may be local or remote.
 void iMeshP_getRankOfPart(iMesh_Instance instance,
              /*in*/    const iMeshP_Part part_id,
@@ -165,12 +198,12 @@
              /*inout*/ int *rank_allocated,
                        int *err);
-//  Provide global mesh information about a partition.
-//  Note that these functions may require communication and, thus,
-//  would have to be called by all processes in the partition handle.
-//  Given a mesh instance and partition handle, return the
-//  total number of entities with given type or topology in the partition.
+/**  Provide global mesh information about a partition.
+ *  Note that these functions may require communication and, thus,
+ *  would have to be called by all processes in the partition handle.
+ *  Given a mesh instance and partition handle, return the
+ *  total number of entities with given type or topology in the partition.
 void iMeshP_getNumOfTypeAll(iMesh_Instance instance,
                        const iBase_EntitySetHandle entity_set_handle,
@@ -187,29 +220,29 @@
-//  Given a partition handle, create a part and add it to the
-//  partition on the process invoking the creation.  Return part handle.
+/**  Given a partition handle, create a part and add it to the
+ *  partition on the process invoking the creation.  Return part handle.
 void iMeshP_createPart(iMesh_Instance instance,
                    /*out*/ iMeshP_PartHandle *part_handle,
                            int *err);
-// Given a partition handle and a part handle, remove the part
-// from the partition, destroy the part, and invalidate the part handle.
-// If part_handle is remote, an error is returned.
+/** Given a partition handle and a part handle, remove the part
+ * from the partition, destroy the part, and invalidate the part handle.
+ * If part_handle is remote, an error is returned.
 void iMeshP_destroyPart(iMesh_Instance instance,
                  /*inout*/ iMeshP_PartHandle *part_handle,
                            int *err);
-// Map between part handles and part IDs.
-// Given a partition handle and a local part handle, return the part ID.
-// If the part handle is not a valid part handle for a local part,
-// return an error.
+ * Map between part handles and part IDs.
+ * Given a partition handle and a local part handle, return the part ID.
+ * If the part handle is not a valid part handle for a local part,
+ * return an error.
 void iMeshP_getPartFromPartHandle(iMesh_Instance instance,
@@ -225,9 +258,9 @@
              /*inout*/ int *part_ids_allocated,
                        int *err);
-// Given a partition handle and a part ID, return the part handle
-// if the part is local; otherwise, return error code.
+/** Given a partition handle and a part ID, return the part handle
+ * if the part is local; otherwise, return error code.
 void iMeshP_getPartHandleFromPart(iMesh_Instance instance,
@@ -243,29 +276,30 @@
              /*inout*/ int *part_handles_allocated,
                        int *err);
-//  Add/remove on-process entities to/from on-process part:  Given
-//  a partition handle, an entity handle, and a part handle, add/remove the
-//  entity to/from the part.
-//  On-process add/remove can be accomplished by functions
-//  that add/remove entities to/from EntitySets.
-//  The part handle is passed in the entity set argument of
-//  the appropriate entity set function.
-//  The part handle must be local.
-//  iMeshP_addEntToPart --> iMesh_addEntToSet
-//  iMeshP_rmvEntFromPart --> iMesh_rmvEntFromSet
-//  iMeshP_addEntArrToPart --> iMesh_addEntArrToSet
-//  iMeshP_rmvEntArrFromPart --> iMesh_rmvEntArrFromSet
+/**  Add/remove on-process entities to/from on-process part:  Given
+ *  a partition handle, an entity handle, and a part handle, add/remove the
+ *  entity to/from the part.
+ *  On-process add/remove can be accomplished by functions
+ *  that add/remove entities to/from EntitySets.
+ *  The part handle is passed in the entity set argument of
+ *  the appropriate entity set function.
+ *  The part handle must be local.
+ *  iMeshP_addEntToPart --> iMesh_addEntToSet
+ *  iMeshP_rmvEntFromPart --> iMesh_rmvEntFromSet
+ *  iMeshP_addEntArrToPart --> iMesh_addEntArrToSet
+ * iMeshP_rmvEntArrFromPart --> iMesh_rmvEntArrFromSet
-//  Identify parts that neighbor a given part.
-//  Given a partition handle, a part handle, and an entity type,
-//  return the number of parts in the partition that neighbor the given part
-//  (i.e., that (1) have copies of entities of the given entity type owned by
-//  the given part or (2) own entities of the given entity type that are
-//  copied on the given part).
-//  If the part_handle is invalid, an error is returned.
+/**  Identify parts that neighbor a given part.
+ *  Given a partition handle, a part handle, and an entity type,
+ *  return the number of parts in the partition that neighbor the given part
+ *  (i.e., that (1) have copies of entities of the given entity type owned by
+ *  the given part or (2) own entities of the given entity type that are
+ *  copied on the given part).
+ *  If the part_handle is invalid, an error is returned.
 void iMeshP_getNumPartNbors(iMesh_Instance instance,
              /*in*/    const iMeshP_PartHandle part_handle,
@@ -281,14 +315,14 @@
              /*inout*/ int *num_part_nbors_allocated,
                        int *err);
-//  return the number of neighbor part IDs and the part IDs of
-//  all parts in the partition that neighbor the given part
-//  If part_handle is invalid, an error is returned.
+/**  Given a partition handle, a part handle, and an entity type,
+ *  return the number of neighbor part IDs and the part IDs of
+ *  all parts in the partition that neighbor the given part
+ *  If part_handle is invalid, an error is returned.
 void iMeshP_getPartNbors(iMesh_Instance instance,
@@ -310,16 +344,17 @@
              /*out*/   int *nbor_part_ids_size,
                        int *err);
-//  Provide part boundary info:
-//  Note: Allow optional specification of desired entity types and
-//  topologies; allow target part handle = iMeshP_ALL_PARTS to
-//  count/include all qualifying boundary entities of part.
-//  Given a partition handle, a part handle, entity type and topology, and a
-//  target part ID, return the number of qualifying entities on
-//  the part boundary shared with the target part.
+/**  Provide part boundary info:
+ *  Note: Allow optional specification of desired entity types and
+ *  topologies; allow target part handle = iMeshP_ALL_PARTS to
+ *  count/include all qualifying boundary entities of part.
+ *  Given a partition handle, a part handle, entity type and topology, and a
+ *  target part ID, return the number of qualifying entities on
+ *  the part boundary shared with the target part.
 void iMeshP_getNumPartBdryEnts(iMesh_Instance instance,
+                      /*in*/  const iMeshP_PartitionHandle partition_handle,
                       /*in*/  const int entity_type,
                       /*in*/  const int entity_topology,
@@ -327,13 +362,14 @@
                       /*out*/ int *num_entities,
                               int *err);
-//  target part ID, return an array of entity handles for all
-//  qualifying entities along the part boundary shared with the target
-//  part.
+/**  Given a partition handle, a part handle, entity type and topology, and a
+ *  target part ID, return an array of entity handles for all
+ *  qualifying entities along the part boundary shared with the target
+ *  part.
 void iMeshP_getPartBdryEnts(iMesh_Instance instance,
@@ -343,14 +379,15 @@
                       /*out*/ int *entity_handles_size,
                               int *err);
-//  Boundary iterators:  Given a partition handle, a part handle, and a
-//  target part ID, return an iterator over all entities along
-//  Functionality for getNext, reset, and end is
-//  provided through the regular iMesh iterator functions.
+/**  Boundary iterators:  Given a partition handle, a part handle, and a
+ *  target part ID, return an iterator over all entities along
+ *  Functionality for getNext, reset, and end is
+ *  provided through the regular iMesh iterator functions.
 void iMeshP_initPartBdryEntIter(iMesh_Instance instance,
@@ -358,6 +395,7 @@
                    /*inout*/  iMesh_EntityIterator* entity_iterator,
                               int* err);
 void iMeshP_initPartBdryEntArrIter(iMesh_Instance instance,
@@ -367,28 +405,35 @@
                               int* err);
-//  Provide entity information about a part and entity set.
-//  Given an entity set handle
-//  and a part handle, return the number of entities of given type/topo
-//  that are in both the part and the entity set.
+/**  Provide entity information about a part and entity set.
+ *  Given an entity set handle
+ *  and a part handle, return the number of entities of given type/topo
+ *  that are in both the part and the entity set.
 void iMeshP_getNumOfType(iMesh_Instance instance,
-                       const int entity_type, int *num_type, int *err);
+                       const int entity_type,
+                       int *num_type,
+                       int *err);
 void iMeshP_getNumOfTopo(iMesh_Instance instance,
-                       const int entity_topology, int *num_topo, int *err);
+                       const int entity_topology,
+                       int *num_topo,
+                       int *err);
-//  and a part handle, return vertex information for vertices
+/**  Given an entity set handle
+ *  and a part handle, return vertex information for vertices
 void iMeshP_getAllVtxCoords(iMesh_Instance instance,
-                             iMeshP_PartHandle part_handle,
+                             const iMeshP_PartHandle part_handle,
                              double** coordinates,
                              int* coordinates_allocated,
@@ -396,9 +441,11 @@
                              int** in_entity_set,
                              int* in_entity_set_allocated,
                              int* in_entity_set_size,
-                             int* storage_order, int *err);
+                             int* storage_order,
+                             int *err);
 void iMeshP_getVtxCoordIndex(iMesh_Instance instance,
                              const int requested_entity_type,
                              const int requested_entity_topology,
@@ -414,13 +461,14 @@
                              int* entity_topologies_size,
                              int *err);
-//  and a part handle, return entity handles for entities
+ *  and a part handle, return entity handles for entities
 void iMeshP_getEntities(iMesh_Instance instance,
@@ -429,13 +477,14 @@
                         int* entity_handles_size,
                         int *err);
-//  and a part handle, return entity adjacencies for entities
+ *  and a part handle, return entity adjacencies for entities
 void iMeshP_getAdjEntities(iMesh_Instance instance,
                            const iBase_EntityHandle entity_set_handle,
                            const int entity_type_requestor,
                            const int entity_topology_requestor,
@@ -451,21 +500,23 @@
                            int *err);
-//  Provide entity and array iterators for entities within both a given part
-//  and a given entity set.
+/**  Provide entity and array iterators for entities within both a given part
+ *  and a given entity set.
 void iMeshP_initEntIter(iMesh_Instance instance,
                         int *err);
 void iMeshP_initEntArrIter(iMesh_Instance instance,
@@ -479,34 +530,36 @@
-//  Provide part information about an entity: Given an entity and a
-//  partition handle, return the part ID of the part that owns the entity.
-//  Return an error code if an entity is not in the partition.
+/**  Provide part information about an entity: Given an entity and a
+ *  partition handle, return the part ID of the part that owns the entity.
+ *  Return an error code if an entity is not in the partition.
 void iMeshP_getEntOwnerPart(iMesh_Instance instance,
-                      /*in*/  iBase_EntityHandle entity_handle,
+                      /*in*/  const iBase_EntityHandle entity_handle,
                      /*out*/  iMeshP_Part *part_id,
                               int* err);
 void iMeshP_getEntOwnerPartArr(iMesh_Instance instance,
-                      /*in*/  iBase_EntityHandle *entity_handles,
-                      /*in*/  int entity_handles_size,
+                      /*in*/  const iBase_EntityHandle *entity_handles,
+                      /*in*/  const int entity_handles_size,
                    /*inout*/  iMeshP_Part **part_ids,
                               int* err);
-//  Provide entity categorization within part.
-//  Given a partition handle, a part handle, and an entity handle, return a
-//  flag indicating whether the entity is owned by the part.
+/**  Provide entity categorization within part.
+ *  Given a partition handle, a part handle, and an entity handle, return a
+ *  flag indicating whether the entity is owned by the part.
 void iMeshP_isEntOwner(iMesh_Instance instance,
                    /*out*/ int* is_owner,
                            int *err);
 void iMeshP_isEntOwnerArr(iMesh_Instance instance,
@@ -514,17 +567,19 @@
                  /*inout*/ int* is_owner_allocated,
                            int *err);
-//  flag indicating whether the entity is strictly internal, on a
-//  boundary, or a ghost.
+/**  Given a partition handle, a part handle, and an entity handle, return a
+ *  flag indicating whether the entity is strictly internal, on a
+ *  boundary, or a ghost.
 void iMeshP_getEntStatus(iMesh_Instance instance,
                    /*out*/ int* par_status, // Values=INTERNAL,BOUNDARY,GHOST
                            int *err);
 void iMeshP_getEntStatusArr(iMesh_Instance instance,
@@ -532,22 +587,22 @@
                  /*inout*/ int* par_status_allocated,
                            int *err);
-//  Provide information about copies of entities.
-//  All these functions should work on the local process as well as
-//  remote processes; entity handles returned are likely but not
-//  necessarily remote.
-//  Given a partition handle and an entity handle, return the number
-//  of copies of the entity in the partition.
+/**  Provide information about copies of entities.
+ *  All these functions should work on the local process as well as
+ *  remote processes; entity handles returned are likely but not
+ *  necessarily remote.
+ *  Given a partition handle and an entity handle, return the number
+ *  of copies of the entity in the partition.
 void iMeshP_getNumCopies(iMesh_Instance instance,
                    /*out*/ int *num_copies_ent,
                            int *err);
-//  Given a partition handle and an entity handle, return the part IDs
-//  of copies of the entity in the partition. (Requested by Onkar.)
+/**  Given a partition handle and an entity handle, return the part IDs
+ *  of copies of the entity in the partition. (Requested by Onkar.)
 void iMeshP_getCopyParts(iMesh_Instance instance,
@@ -556,9 +611,9 @@
                    /*out*/ int *part_ids_size,
                            int *err);
-//  Given a partition handle and an entity handle, return (remote) entity
-//  handles and part IDs of all copies of the entity.
+/**  Given a partition handle and an entity handle, return (remote) entity
+ *  handles and part IDs of all copies of the entity.
 void iMeshP_getCopies(iMesh_Instance instance,
@@ -569,22 +624,22 @@
                  /*inout*/ int *copies_entity_handles_allocated,
                            int *err);
-//  Given a partition handle, an entity handle and a part ID, return the
-//  (possibly remote) entity handle of the entity in the specified part.
-//  Return an error if the entity does not exist in the specified part.
+/**  Given a partition handle, an entity handle and a part ID, return the
+ *  (possibly remote) entity handle of the entity in the specified part.
+ *  Return an error if the entity does not exist in the specified part.
 void iMeshP_getCopyOnPart(iMesh_Instance instance,
-                    /*in*/ iMeshP_Part* part_id,
+                    /*in*/ const iMeshP_Part* part_id,
                    /*out*/ iBase_EntityHandle* copy_entity_handle,
                            int *err);
-//  Given a partition handle and an entity handle, return the entity
-//  handle and part ID from the owner of the entity (e.g., the
-//  entity handle of the copy that has right-to-modify).
+/**  Given a partition handle and an entity handle, return the entity
+ *  handle and part ID from the owner of the entity (e.g., the
+ *  entity handle of the copy that has right-to-modify).
 void iMeshP_getOwnerCopy(iMesh_Instance instance,
@@ -595,10 +650,10 @@
  *******         COMMUNICATION          **********
-// Non-blocking calls for off-processor mesh-modification return a request
-// that indicates whether or not the operation has completed.
-// The following functions receive and process requests.
+ * Non-blocking calls for off-processor mesh-modification return a request
+ * that indicates whether or not the operation has completed.
+ * The following functions receive and process requests.*/
 /**\brief  Wait for specified request to complete
@@ -606,9 +661,9 @@
  * \param req Request object to wait on
  * \param stat Status of communication request
  * \param err Error returned from function
+ *  COMMUNICATION:  Blocking point-to-point.
-//  COMMUNICATION:  Blocking point-to-point.
-iMeshP_Wait(iMesh_Instance instance,
+void iMeshP_Wait(iMesh_Instance instance,
              /*in*/ iMeshP_RequestHandle req,
             /*out*/ iMeshP_Status stat,
@@ -622,8 +677,8 @@
  * \param index Index of request in req which was completed
 void iMeshP_WaitAny(iMesh_Instance instance,
                /*in*/ iMeshP_RequestHandle *req,
@@ -639,8 +694,8 @@
  * \param req_size Number of request objects
 void iMeshP_WaitAll(iMesh_Instance instance,
@@ -658,8 +713,8 @@
  * \param entities_alloc Allocated size of entities vector
  * \param entities_size Occupied size of entities vector
 void iMeshP_WaitEnt(iMesh_Instance instance,
@@ -675,8 +730,8 @@
  * \param flag Returned true if request completed
+ *  COMMUNICATION:  Point-to-point; non-blocking.
-//  COMMUNICATION:  Point-to-point; non-blocking.
 void iMeshP_Test(iMesh_Instance instance,
@@ -684,25 +739,26 @@
             /*out*/ iMeshP_Status *stat,
             /*out*/ int *err)
-// Poll for requests.  The internals of this function are going to have
-// to cover a lot of ground.  The array in the return is there as a
-// placeholder to tell the application that something interesting / useful
-// has been done to a handle.  This might indicate successful in-migration,
-// a recent change in vertex location, or successful completion of handle
-// matching.
-// Returns an array of requests that have been handled.  If
-// the array has a size allocated already, then the implementation stops
-// working when it has generated that many completed requests, even if there
-// are more messages waiting.  The syntax on this call should perhaps be
-// modified somewhat to make it more compatible with an analogous MPI call.
-// Should also perhaps have its name changed to handleMessages or some such
-// thing, since the function should not only poll for unexpected
-// messages, but also handle expected ones; these is no reason to
-// separately call two different functions to handle non-blocking receives
-// for different types of messages.
-// COMMUNICATION:  non-blocking; point-to-point.
+/** Poll for requests.  The internals of this function are going to have
+ * to cover a lot of ground.  The array in the return is there as a
+ * placeholder to tell the application that something interesting / useful
+ * has been done to a handle.  This might indicate successful in-migration,
+ * a recent change in vertex location, or successful completion of handle
+ * matching.
+ * Returns an array of requests that have been handled.  If
+ * the array has a size allocated already, then the implementation stops
+ * working when it has generated that many completed requests, even if there
+ * are more messages waiting.  The syntax on this call should perhaps be
+ * modified somewhat to make it more compatible with an analogous MPI call.
+ * Should also perhaps have its name changed to handleMessages or some such
+ * thing, since the function should not only poll for unexpected
+ * messages, but also handle expected ones; these is no reason to
+ * separately call two different functions to handle non-blocking receives
+ * for different types of messages.
+ * COMMUNICATION:  non-blocking; point-to-point.
 void iMeshP_pollForRequests(iMesh_Instance instance,
            iMeshP_RequestHandle **requests_completed,
@@ -714,14 +770,14 @@
  *******     Requests for off-processor mesh modification      ******
-//  Add entities to on-process and/or off-process parts:
-//  Collective-communication version:
-//  iMeshP_exchEntArrToPartsPar is a collective, non-blocking operation
-//  to be called by all processes in the partition's communicator.
-//  An iMeshP_RequestHandle is returned; any of the iMeshP_Wait functions can be
-//  used to block until the request is completed.
-//  COMMUNICATION:  Collective.  Non-blocking.
+ *  Add entities to on-process and/or off-process parts:
+ *  Collective-communication version:
+ *  iMeshP_exchEntArrToPartsPar is a collective, non-blocking operation
+ *  to be called by all processes in the partition's communicator.
+ *  An iMeshP_RequestHandle is returned; any of the iMeshP_Wait functions can be
+ *  used to block until the request is completed.
+ *  COMMUNICATION:  Collective.  Non-blocking.*/
 void iMeshP_exchEntArrToPartsAll(iMesh_Instance instance,
@@ -732,20 +788,20 @@
                       /*out*/  iMeshP_RequestHandle *request,
                                int *err);
-// Request in-migration to a given part of an entity and its upward adjacencies.
-// This is a pull migration.  The
-// entity must be on the part bdry and is identified by local handle, and
-// the implementation handles the rest.  This operation will require multiple
-// rounds of communication, and at some times certain entities may be
-// locked (unavailable for local modification) while info about their
-// remote copies is still in question.
-// It's worth mentioning that implementations will have to take care to
-// migrate tags and parallel set membership as well as adjacency info.
-// CHANGES: Returns a request handle.  Assumes you wouldn't be asking if
-// you didn't need the upward adjacencies as well.
-// COMMUNICATION:  point-to-point, non-blocking, pull.
+/** Request in-migration to a given part of an entity and its upward adjacencies.
+ * This is a pull migration.  The
+ * entity must be on the part bdry and is identified by local handle, and
+ * the implementation handles the rest.  This operation will require multiple
+ * rounds of communication, and at some times certain entities may be
+ * locked (unavailable for local modification) while info about their
+ * remote copies is still in question.
+ * It's worth mentioning that implementations will have to take care to
+ * migrate tags and parallel set membership as well as adjacency info.
+ * CHANGES: Returns a request handle.  Assumes you wouldn't be asking if
+ * you didn't need the upward adjacencies as well.
+ * COMMUNICATION:  point-to-point, non-blocking, pull. */
 void iMeshP_migrateEntity(iMesh_Instance instance,
@@ -753,27 +809,27 @@
 		          int *err);
-// Update vertex coordinates.  One could argue that we could overload
-// the setVtxCoords function to do this, and maybe we should.  But that
-// obfuscates when communication could occur.  The communication here is
-// push-and-forget.
-// Because this is push-and-forget, no request handle -should- be generated.
-// COMMUNICATION:  point-to-point, non-blocking, push-and-forget.
+/** Update vertex coordinates.  One could argue that we could overload
+ * the setVtxCoords function to do this, and maybe we should.  But that
+ * obfuscates when communication could occur.  The communication here is
+ * push-and-forget.
+ * Because this is push-and-forget, no request handle -should- be generated.
+ * COMMUNICATION:  point-to-point, non-blocking, push-and-forget.*/
 void iMeshP_updateVtxCoords(iMesh_Instance instance,
 		            const iBase_EntityHandle local_vertex_handle,
 			    int *err);
-// Replace entities.  This refers to changes on the part bdry where the
-// application/service is responsible for ensuring that things are done
-// identically on both sides and that the args are passed in an order that
-// can be matched.  (Specifically, matching new entities should appear in
-// the same order in the call array.)  Communication here could be a
-// two-way push-and-forget, or some variant on push-and-confirm.
-// CHANGES: At Onkar's suggestion, added an offset array (similar to array
-// adjacency requests) so that a single call can easily handle coordination
-// with multiple entities on part-boundary.
+/** Replace entities.  This refers to changes on the part bdry where the
+ * application/service is responsible for ensuring that things are done
+ * identically on both sides and that the args are passed in an order that
+ * can be matched.  (Specifically, matching new entities should appear in
+ * the same order in the call array.)  Communication here could be a
+ * two-way push-and-forget, or some variant on push-and-confirm.
+ * CHANGES: At Onkar's suggestion, added an offset array (similar to array
+ * adjacency requests) so that a single call can easily handle coordination
+ * with multiple entities on part-boundary.
+ * COMMUNICATION:  point-to-point, non-blocking, push-and-forget. */
 void iMeshP_replaceOnPartBdry(iMesh_Instance instance,
 		       const iBase_EntityHandle *old_entities,
@@ -785,18 +841,18 @@
 		       int *err);
-// The ability to create and delete copies is likely
-// to be useful, even though for common topologically-based cases, copies
-// maintainance can (and IMO should) be done automagically, either at
-// migration time or during iMeshP_syncMeshAll.
-// Communication here is
-// push-and-confirm for creation (so that the original knows ID's of the
-// ghosts), push-and-forget for deletion (in the latter case, no request
-// handle is needed).  I'm assuming here that the closure of a new ghost
-// will be pushed automatically as part of the underlying communication,
-// and that the remote part will clean up the closure as appropriate during
-// deletion.
-// COMMUNICATION:  point-to-point, non-blocking, push.
+/** The ability to create and delete copies is likely
+ * to be useful, even though for common topologically-based cases, copies
+ * maintainance can (and IMO should) be done automagically, either at
+ * migration time or during iMeshP_syncMeshAll.
+ * Communication here is
+ * push-and-confirm for creation (so that the original knows ID's of the
+ * ghosts), push-and-forget for deletion (in the latter case, no request
+ * handle is needed).  I'm assuming here that the closure of a new ghost
+ * will be pushed automatically as part of the underlying communication,
+ * and that the remote part will clean up the closure as appropriate during
+ * deletion.
+ * COMMUNICATION:  point-to-point, non-blocking, push.*/
 void iMeshP_addGhostOf(iMesh_Instance instance,
 	/* in */       const iMeshP_PartitionHandle partition_handle,
 	/* in */       const iMeshP_Part target_part_id,
@@ -810,22 +866,25 @@
 	/* in */       const iBase_EntityHandle copy_to_purge,
 		       int *err);
-// Done with mesh modification.  This is a blocking call, to get
-// everything up-to-date and back in synch.  Essentially, waits for all
-// message traffic to clear, as well as (possibly) rebuilding a bunch of
-// ghost info that was allowed to go obsolete.
+/** Done with mesh modification.  This is a blocking call, to get
+ * everything up-to-date and back in synch.  Essentially, waits for all
+ * message traffic to clear, as well as (possibly) rebuilding a bunch of
+ * ghost info that was allowed to go obsolete.*/
 void iMeshP_syncMeshAll(iMesh_Instance instance,
 		       int *err);
-// Functions to exchange Tag data.
+/* Functions to send Tag data from owning entities to copies.*/
-/**\brief  Synchronously exchange tag data for entity type/topo
+/**\brief  Synchronously send tag data for entity type/topo
  * and part
- * Exchange tag information for shared entities of specified type/
- * topology to specified part.  This version operates on all
+ * Send tag information for shared entities of specified type/
+ * topology to specified part.
+ * The tag data is "pushed" from the
+ * owner entities to all copies.
+ * This version operates on all
  * shared entities of specified type/topology (or all
  * types/topologies if iMesh_ALL_TYPE or iMesh_ALL_TOPOLOGIES are
  * given).  This function assumes tag handles given on various
@@ -835,44 +894,46 @@
  * \param tag Tag handle to exchange
  * \param entity_type Tag data exchanged only for this entity type
  * \param entity_topo Tag data exchanged only for this entity topology
- * \param with_part Tag info exchanged only with this part
-void iMeshP_ExchTags(iMesh_Instance instance,
+void iMeshP_pushTags(iMesh_Instance instance,
                 /*in*/ iBase_TagHandle tag,
                 /*in*/ int entity_type,
                 /*in*/ int entity_topo,
-                /*in*/ iMeshP_Part with_part_id,
                 /*out*/ int *err)
-/**\brief  Synchronously exchange tag data for entities and part
+/**\brief  Synchronously send tag data for entities and part
- * Exchange tag information for specified entities, which must
- * already be shared.  This function assumes tag handles given on various
+ * Send tag information for specified entities, which must
+ * already be shared.
+ * This function assumes tag handles given on various
  * calling parts are consistent, i.e. they have the same name,
  * data type, size, etc.  This call blocks until communication is
  * completed
  * \param entities Entities for which to exchange data
  * \param entities_size Number of entities
-void iMeshP_ExchTagsEnt(iMesh_Instance instance,
+void iMeshP_pushTagsEnt(iMesh_Instance instance,
                    /*in*/ iBase_EntityHandle *entities,
                    /*in*/ int entities_size,
                    /*out*/ int *err)
-/**\brief  Asynchronously exchange tag data for entity type/topo
+/**\brief  Asynchronously send tag data for entity type/topo
  * and part
@@ -882,45 +943,43 @@
  * \param iMeshP_RequestHandle Request object used in call to
  *    iMeshP_Wait or iMeshP_WaitEnt
-void iMeshP_IExchTags(iMesh_Instance instance,
+void iMeshP_iPushTags(iMesh_Instance instance,
                 /*out*/ iMeshP_RequestHandle *req,
                 /*out*/ int *err)
-/**\brief  Asynchronously exchange tag data for entities and part
+/**\brief  Asynchronously send tag data for entities and part
+ * Sedn tag information for specified entities, which must
  * data type, size, etc.  Applications can call iMeshP_Wait or
  * iMeshP_WaitEnt to block until associated call completes
-void iMeshP_IExchTagsEnt(iMesh_Instance instance,
+void iMeshP_iPushTagsEnt(iMesh_Instance instance,
                    /*out*/ int *err)
 /*  GHOST ENTITY SUPPORT */
 The triplet describing a ghosting "rule" (ghost dim, bridge dim, #
@@ -953,13 +1012,16 @@
   * \param bridge_dim Dimension through which bridge adjacencies are found
   * \param num_layers Number of layers of ghost entities
+  * \param include_copies  Create ghosts of non-owned part boundary entities?
+  *         (1/0)
   * COMMUNICATION:  Collective.  Blocking.
-iMeshP_createGhostEnts(/*in*/ iMesh_Instance instance,
+void iMeshP_createGhostEnts(/*in*/ iMesh_Instance instance,
                        /*in*/ int ghost_dim,
                        /*in*/ int bridge_dim,
                        /*in*/ int num_layers,
+                       /*in*/ int include_copies,
                        /*out*/ int *err);
 /* \brief Delete all ghost entities between parts/processors.
@@ -968,7 +1030,7 @@
-iMeshP_deleteGhostEnts(/*in*/ iMesh_Instance instance,
+void iMeshP_deleteGhostEnts(/*in*/ iMesh_Instance instance,
                        /*out*/ int *err);
@@ -982,7 +1044,7 @@
-iMeshP_ghostEntInfo(/*in*/ iMesh_Instance instance,
+void iMeshP_ghostEntInfo(/*in*/ iMesh_Instance instance,
                     /*out*/ int num_ghost_rules,
                     /*inout*/ int *ghost_rules_allocated,
@@ -992,6 +1054,53 @@
                     /*out*/ int **num_layers,
                     /*out*/ int *err);
+ *******    FILE I/O                                           ******
+/* \brief iMeshP file I/O closely aligns with iMesh file I/O.  The major
+ * change is the addition of a iMeshP_PartitionHandle argument to both
+ * iMeshP_load and iMeshP_save, enabling I/O from parallel processes.
+ * For now, individual implementations will support different sets of
+ * options; Tim and Ken will work to unify the options by SC08.
+/* \brief iMeshP_load: function to populate a mesh instance and
+ * a partition by reading data from files.
+ * The application creates both the mesh instance and the partition
+ * handle before calling iMeshP_load.  iMeshP_load then reads the
+ * specified file, inserts entities into the mesh instance, constructs
+ * parts within the partition, and inserts entities into the parts.
+ * Optional capabilities of iMeshP_load include computing an initial
+ * partition (e.g., if a serial mesh file without part assignments is read)
+ * and creating ghost entities as requested by the application.
+ * Options allow n>=1 files on p processes.
+void iMeshP_load(iMesh_Instance instance,
+                 const iMeshP_PartitionHandle partition,
+                 const iBase_EntitySetHandle entity_set_handle,
+                 const char *name,
+                 const char *options,
+                 int *err,
+                 int name_len,
+                 int options_len);
+/* \brief iMeshP_save: function to write data from a mesh instance and
+ * a partition to files.
+ * iMeshP_save writes mesh and partition data to the
+ * specified file.
+void iMeshP_save(iMesh_Instance instance,
+                 const char *name,
+                 int *err,
+                 const int name_len,
+                 int options_len);
 Major Items left to do:
@@ -1004,6 +1113,7 @@
    same time.  Designating one partition as "active" would store data
    with respect to only one partition.
 -  File I/O support.
+   Need common set of options to allow interoperability.
    Support single files, N << P files on P processes, and P files.
    Support reading and writing partition information.
    Support initial parallel partitioning of serial file data.
@@ -1027,6 +1137,10 @@
 -  iMeshP_getOwnerCopy could be achieved by calling iMeshP_getOwnerPart
    followed by iMeshP_getCopyOnPart.  Do we want to keep iMeshP_getOwnerCopy?
+-  Need function to receive tag data from part-boundary entities in owner.
+   Possible options:  return the tag data values received directly, or
+   include a mathematical operation (similar to MPI_SUM). 9/15/08
 Comments and resolved questions:
@@ -1223,10 +1337,10 @@
 will return only itself and its owner in getCopies; part-boundary
 entities will return copies on other parts as well.
 -  Tim envisions applications (e.g., FETI methods) updating tag data
-in their ghosts that they would like to accumulate back to the
+in their copies that they would like to accumulate back to the
 owner.  Xiaolin said that he writes in his ghosts, but doesn't send
-those values back to the owner.  Currently, we have the ability only
-to send tag data from owners to ghosts.  Tim will look at this issue
+those values back to the owner.  Currently, we have the ability
+to send tag data only from owners to ghosts.  Tim will look at this issue
 and propose a solution.
 Communication:
@@ -1260,7 +1374,14 @@
 CVS File Information
    $RCSfile: DraftInterface.h,v $
    $Author: kddevin $
-   $Date: 2008/07/24 20:08:12 $
-   $Revision: 1.27 $
+   $Date: 2008/09/15 17:50:05 $
+   $Revision: 1.31 $
+#ifdef __cplusplus
+} // extern "C"
+#endif
+#endif /* defined(iMeshP_h) */
Modified: MOAB/trunk/tools/iMesh/iMeshP_protos.h
--- MOAB/trunk/tools/iMesh/iMeshP_protos.h	2008-10-02 19:48:09 UTC (rev 2126)
+++ MOAB/trunk/tools/iMesh/iMeshP_protos.h	2008-10-02 20:37:30 UTC (rev 2127)
@@ -1,25 +1,71 @@
 #include "MBCN_FCDefs.h"
 #ifdef FC_FUNC_
-#define iMesh_getErrorType FC_FUNC_(imesh_geterrortype, IMESH_GETERRORTYPE)
-#define iMeshP_getNumParts FC_FUNC_(imeshp_getnumparts, IMESHP_GETNUMPARTS)
-#define iMeshP_getRankOfPart FC_FUNC_(imeshp_getrankofpart, IMESHP_GETRANKOFPART)
-#define iMeshP_getRankOfPartArr FC_FUNC_(imeshp_getrankofpartarr, IMESHP_GETRANKOFPARTARR)
-#define iMeshP_getPartsOnRank FC_FUNC_(imeshp_getpartsonrank, IMESHP_GETPARTSONRANK)
-#define iMeshP_getPartsArrOnRank FC_FUNC_(imeshp_getpartsarronrank, IMESHP_GETPARTSARRONRANK)
-#define iMeshP_getNumOfTypeAll FC_FUNC_(imeshp_getnumoftypeall, IMESHP_GETNUMOFTYPEALL)
-#define iMeshP_getNumOfTopoAll FC_FUNC_(imeshp_getnumoftopoall, IMESHP_GETNUMOFTOPOALL)
-#define iMeshP_testPart FC_FUNC_(imeshp_testpart, IMESHP_TESTPART)
-#define iMeshP_getEntOwnerPart FC_FUNC_(imeshp_getentownerpart, IMESHP_GETENTOWNERPART)
-#define iMeshP_getEntOwnerPartArr FC_FUNC_(imeshp_getentownerpartarr, IMESHP_GETENTOWNERPARTARR)
-#define iMeshP_isEntOwner FC_FUNC_(imeshp_isentowner, IMESHP_ISENTOWNER)
-#define iMeshP_isEntOwnerArr FC_FUNC_(imeshp_isentownerarr, IMESHP_ISENTOWNERARR)
-#define iMeshP_getEntStatus FC_FUNC_(imeshp_getentstatus, IMESHP_GETENTSTATUS)
-#define iMeshP_getEntStatusArr FC_FUNC_(imeshp_getentstatusarr, IMESHP_GETENTSTATUSARR)
-#define iMeshP_getNumCopies FC_FUNC_(imeshp_getnumcopies, IMESHP_GETNUMCOPIES)
-#define iMeshP_getCopies FC_FUNC_(imeshp_getcopies, IMESHP_GETCOPIES)
+#define iMeshP_createPartitionAll	FC_FUNC_(imeshp_createpartitionall,	IMESHP_CREATEPARTITIONALL)
+#define iMeshP_destroyPartitionAll	FC_FUNC_(imeshp_destroypartitionall,	IMESHP_DESTROYPARTITIONALL)
+#define iMeshP_getPartitionComm		FC_FUNC_(imeshp_getpartitioncomm,	IMESHP_GETPARTITIONCOMM)
+#define iMeshP_syncPartitionAll		FC_FUNC_(imeshp_syncpartitionall,	IMESHP_SYNCPARTITIONALL)
+#define iMeshP_getNumPartitions		FC_FUNC_(imeshp_getnumpartitions,	IMESHP_GETNUMPARTITIONS)
+#define iMeshP_getPartitions		FC_FUNC_(imeshp_getpartitions,		IMESHP_GETPARTITIONS)
+#define iMeshP_getNumGlobalParts	FC_FUNC_(imeshp_getnumglobalparts,	IMESHP_GETNUMGLOBALPARTS)
+#define iMeshP_getNumLocalParts		FC_FUNC_(imeshp_getnumlocalparts,	IMESHP_GETNUMLOCALPARTS)
+#define iMeshP_getLocalParts		FC_FUNC_(imeshp_getlocalparts,		IMESHP_GETLOCALPARTS)
+#define iMeshP_getRankOfPart		FC_FUNC_(imeshp_getrankofpart,		IMESHP_GETRANKOFPART)
+#define iMeshP_getRankOfPartArr		FC_FUNC_(imeshp_getrankofpartarr,	IMESHP_GETRANKOFPARTARR)
+#define iMeshP_getNumOfTypeAll		FC_FUNC_(imeshp_getnumoftypeall,	IMESHP_GETNUMOFTYPEALL)
+#define iMeshP_getNumOfTopoAll		FC_FUNC_(imeshp_getnumoftopoall,	IMESHP_GETNUMOFTOPOALL)
+#define iMeshP_createPart		FC_FUNC_(imeshp_createpart,		IMESHP_CREATEPART)
+#define iMeshP_destroyPart		FC_FUNC_(imeshp_destroypart,		IMESHP_DESTROYPART)
+#define iMeshP_getPartFromPartHandle	FC_FUNC_(imeshp_getpartfromparthandle,	IMESHP_GETPARTFROMPARTHANDLE)
+#define iMeshP_getPartFromPartHandlesArr FC_FUNC_(imeshp_getpartfromparthandlesarr,	IMESHP_GETPARTFROMPARTHANDLESARR)
+#define iMeshP_getPartHandleFromPart	FC_FUNC_(imeshp_getparthandlefrompart,	IMESHP_GETPARTHANDLEFROMPART)
+#define iMeshP_getPartHandlesFromPartsArr FC_FUNC_(imeshp_getparthandlesfrompartsarr,	IMESHP_GETPARTHANDLESFROMPARTSARR)
+#define iMeshP_getNumPartNbors		FC_FUNC_(imeshp_getnumpartnbors,	IMESHP_GETNUMPARTNBORS)
+#define iMeshP_getNumPartNborsArr	FC_FUNC_(imeshp_getnumpartnborsarr,	IMESHP_GETNUMPARTNBORSARR)
+#define iMeshP_getPartNbors		FC_FUNC_(imeshp_getpartnbors,		IMESHP_GETPARTNBORS)
+#define iMeshP_getPartNborsArr		FC_FUNC_(imeshp_getpartnborsarr,	IMESHP_GETPARTNBORSARR)
+#define iMeshP_getNumPartBdryEnts	FC_FUNC_(imeshp_getnumpartbdryents,	IMESHP_GETNUMPARTBDRYENTS)
+#define iMeshP_getPartBdryEnts		FC_FUNC_(imeshp_getpartbdryents,	IMESHP_GETPARTBDRYENTS)
+#define iMeshP_initPartBdryEntIter	FC_FUNC_(imeshp_initpartbdryentiter,	IMESHP_INITPARTBDRYENTITER)
+#define iMeshP_initPartBdryEntArrIter	FC_FUNC_(imeshp_initpartbdryentarriter,	IMESHP_INITPARTBDRYENTARRITER)
+#define iMeshP_getNumOfType		FC_FUNC_(imeshp_getnumoftype,		IMESHP_GETNUMOFTYPE)
+#define iMeshP_getNumOfTopo		FC_FUNC_(imeshp_getnumoftopo,		IMESHP_GETNUMOFTOPO)
+#define iMeshP_getAllVtxCoords		FC_FUNC_(imeshp_getallvtxcoords,	IMESHP_GETALLVTXCOORDS)
+#define iMeshP_getVtxCoordIndex		FC_FUNC_(imeshp_getvtxcoordindex,	IMESHP_GETVTXCOORDINDEX)
+#define iMeshP_getEntities		FC_FUNC_(imeshp_getentities,		IMESHP_GETENTITIES)
+#define iMeshP_getAdjEntities		FC_FUNC_(imeshp_getadjentities,		IMESHP_GETADJENTITIES)
+#define iMeshP_initEntIter		FC_FUNC_(imeshp_initentiter,		IMESHP_INITENTITER)
+#define iMeshP_initEntArrIter		FC_FUNC_(imeshp_initentarriter,		IMESHP_INITENTARRITER)
+#define iMeshP_getEntOwnerPart		FC_FUNC_(imeshp_getentownerpart,	IMESHP_GETENTOWNERPART)
+#define iMeshP_getEntOwnerPartArr	FC_FUNC_(imeshp_getentownerpartarr,	IMESHP_GETENTOWNERPARTARR)
+#define iMeshP_isEntOwner		FC_FUNC_(imeshp_isentowner,		IMESHP_ISENTOWNER)
+#define iMeshP_isEntOwnerArr		FC_FUNC_(imeshp_isentownerarr,		IMESHP_ISENTOWNERARR)
+#define iMeshP_getEntStatus		FC_FUNC_(imeshp_getentstatus,		IMESHP_GETENTSTATUS)
+#define iMeshP_getEntStatusArr		FC_FUNC_(imeshp_getentstatusarr,	IMESHP_GETENTSTATUSARR)
+#define iMeshP_getNumCopies		FC_FUNC_(imeshp_getnumcopies,		IMESHP_GETNUMCOPIES)
+#define iMeshP_getCopyParts		FC_FUNC_(imeshp_getcopyparts,		IMESHP_GETCOPYPARTS)
+#define iMeshP_getCopies		FC_FUNC_(imeshp_getcopies,		IMESHP_GETCOPIES)
+#define iMeshP_getCopyOnPart		FC_FUNC_(imeshp_getcopyonpart,		IMESHP_GETCOPYONPART)
+#define iMeshP_getOwnerCopy		FC_FUNC_(imeshp_getownercopy,		IMESHP_GETOWNERCOPY)
+#define iMeshP_Wait			FC_FUNC_(imeshp_wait,			IMESHP_WAIT)
+#define iMeshP_WaitAny			FC_FUNC_(imeshp_waitany,		IMESHP_WAITANY)
+#define iMeshP_WaitAll			FC_FUNC_(imeshp_waitall,		IMESHP_WAITALL)
+#define iMeshP_WaitEnt			FC_FUNC_(imeshp_waitent,		IMESHP_WAITENT)
+#define iMeshP_Test			FC_FUNC_(imeshp_test,			IMESHP_TEST)
+#define iMeshP_pollForRequests		FC_FUNC_(imeshp_pollforrequests,	IMESHP_POLLFORREQUESTS)
+#define iMeshP_exchEntArrToPartsAll	FC_FUNC_(imeshp_exchentarrtopartsall,	IMESHP_EXCHENTARRTOPARTSALL)
+#define iMeshP_migrateEntity		FC_FUNC_(imeshp_migrateentity,		IMESHP_MIGRATEENTITY)
+#define iMeshP_updateVtxCoords		FC_FUNC_(imeshp_updatevtxcoords,	IMESHP_UPDATEVTXCOORDS)
+#define iMeshP_replaceOnPartBdry	FC_FUNC_(imeshp_replaceonpartbdry,	IMESHP_REPLACEONPARTBDRY)
+#define iMeshP_addGhostOf		FC_FUNC_(imeshp_addghostof,		IMESHP_ADDGHOSTOF)
+#define iMeshP_rmvGhostOf		FC_FUNC_(imeshp_rmvghostof,		IMESHP_RMVGHOSTOF)
+#define iMeshP_syncMeshAll		FC_FUNC_(imeshp_syncmeshall,		IMESHP_SYNCMESHALL)
+#define iMeshP_pushTags			FC_FUNC_(imeshp_pushtags,		IMESHP_PUSHTAGS)
+#define iMeshP_pushTagsEnt		FC_FUNC_(imeshp_pushtagsent,		IMESHP_PUSHTAGSENT)
+#define iMeshP_iPushTags		FC_FUNC_(imeshp_ipushtags,		IMESHP_IPUSHTAGS)
+#define iMeshP_iPushTagsEnt		FC_FUNC_(imeshp_ipushtagsent,		IMESHP_IPUSHTAGSENT)
+#define iMeshP_createGhostEnts		FC_FUNC_(imeshp_createghostents,	IMESHP_CREATEGHOSTENTS)
+#define iMeshP_deleteGhostEnts		FC_FUNC_(imeshp_deleteghostents,	IMESHP_DELETEGHOSTENTS)
+#define iMeshP_ghostEntInfo		FC_FUNC_(imeshp_ghostentinfo,		IMESHP_GHOSTENTINFO)
+#define iMeshP_load			FC_FUNC_(imeshp_load,			IMESHP_LOAD)
+#define iMeshP_save			FC_FUNC_(imeshp_save,			IMESHP_SAVE)
 #endif
