[MOAB-dev] r2126 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Thu Oct 2 14:48:09 CDT 2008
Author: kraftche
Date: 2008-10-02 14:48:09 -0500 (Thu, 02 Oct 2008)
New Revision: 2126
Modified:
   MOAB/trunk/tools/iMesh/iMeshP.h
Log:
Draft interface sent ot itaps-parallel by K.Devine on July 24, 2008
Modified: MOAB/trunk/tools/iMesh/iMeshP.h
--- MOAB/trunk/tools/iMesh/iMeshP.h	2008-10-02 14:37:47 UTC (rev 2125)
+++ MOAB/trunk/tools/iMesh/iMeshP.h	2008-10-02 19:48:09 UTC (rev 2126)
@@ -1,161 +1,536 @@
-#ifndef IMESHP_H__
-#define IMESHP_H__
+Background and Terminology:
-  /** \mainpage The ITAPS Parallel Mesh Interface iMesh
+Terminology -- Abstract Data Model:
+-  The term "mesh" refers to an abstraction in the data model;
+   it does not imply a serial or parallel distribution.
+-  The term "partition" refers to an assignment of a set of entities to
+   subsets; like a "mesh," it does not imply a serial or parallel
+   implementation.
+-  An application may use one or more meshes.
+-  Parititions can create subsets of entities from one or more meshes.
+-  Meshes can be subdivided by one or more partitions.
+-  Partitions contain parts.  Parts contain the subsets of entities in the
+   partition.
-#ifndef ITAPS
-#define ITAPS
-#endif
+Terminology -- Parallelism
+-  A "process" can be thought of as an MPI process. The
+   number of processes can be considered to be the result of MPI_Comm_size.
+   The rank of a process can be thought of as the result of MPI_Comm_rank.
+   We will think in terms of processes rather than processors.  Initial
+   implementations of the parallel interface will likely use MPI terminology
+   directly; future implementations may accommodate other communication
+   paradigms and libraries.
+-  Partitions have communicators associated with them.  These communicators
+   can be thought of as MPI communicators.
+-  "Global" operations are operations performed with respect to a
+   partition's communicator.
+-  "Local" operations are operations performed with respect to a part or
+   a mesh instance within a process.
+-  Part A "neighbors" Part B if Part A has copies of entities owned by Part B
+   and/or if Part B has copies of entities owned by Part A.
+-  Each function description includes its communication requirements.  The
+   options are described here:
+   +  COMMUNICATION:  Collective -- the function must be called by all
+      processes in the partition's communicator.
+   +  COMMUNICATION:  Point-to-Point -- communication is used, but the
+      communication is from one process to only one other process.  The
+      receiving process must issue an appropriate receive call to receive
+      the message.
+   +  COMMUNICATION:  None -- the function does not use communication; only
+      local operations are performed.
+   +  COMMUNICATION:  None++ -- no communication is done; the values
+      are precomputed by iMeshP_syncPartitionAll or
+      iMeshP_completeParallelMeshPar.
+Terminology -- Interfaces
+-  Each process has one or more "mesh instances."  A mesh instance can be
+   thought of as a mesh database.  An implementation should support the
+   existence of more than one mesh instance per process (e.g., it should
+   always associate mesh data with a mesh instance).  However, we expect
+   applications would most often use only one mesh instance per process.
+-  There is one root set per mesh instance.
+-  Each process may have one or more partition handles.
+-  A partition partitions entities in one mesh instance.
+-  Entities in a mesh instance can be partitioned by one or more partitions.
+   Mesh instances know which partitions they contain.
+-  Parts are uniquely identified globally by part IDs of type iMeshP_Part.
+   Local parts can also be accessed by part handles.
+   Functions accepting part handles operate correctly on only local
+   parts (parts on the calling process); they will return an error
+   for remote (off-process) parts.
-#include "iMesh_extensions.h"
-#include "iMeshP_protos.h"
-#ifdef __cplusplus
-extern "C" {
-#endif
+Assumptions:
+-  Each part is wholly contained within a process.
+-  A process may have multiple parts.
+-  Many iMesh functions that accept EntitySet handles
+   are also useful in the context of part handles.
+   These functions will be reinterpreted so that they can accept either an
+   EntitySet handle, or a part handle.  See Carl's Oct 15 email for more detail.
+-  Generation and management of global IDs for entities
+   will be provided as a service above the parallel iMesh interface.
+   Uniqueness of global IDs is managed at the partition level.
+-  For each entity that is copied onto remote parts, the owning part knows
+   both the remote part ID and remote entity handle of all copies.
+-  All parts with copies of a boundary entity know the remote part ID
+   and remote entity handle of all copies of the entity.
+-  All parts with copies of any entity know the part ID and
+   entity handle corresponding to the owner of the entity.
-    /**\brief  Type used to store a part handle
-     * Type used to store a part handle
-  typedef void* iMeshP_PartHandle;
+/*                          Partition Functionality                       */
-    /**\brief  Type used to store a partition handle
-     * Type used to store a partition handle
-  typedef void* iMeshP_PartitionHandle;
+//  Create a partition handle:  Given a mesh instance to contain
+//  the partition and a communicator, return a partition
+//  handle.  May have different creation routines for different
+//  communication systems; once created, the application shouldn't have to
+//  worry about the communication system again.
+//  For serial use, *communicator may be MPI_COMM_SELF or communicator may
+//  be NULL.
+//  COMMUNICATION:  Collective.
+void iMeshP_createPartitionAll(iMesh_Instance instance,
+                    /*in*/  MPI_Comm *communicator,
+                    /*out*/ iMeshP_PartitionHandle *partition_handle,
+                            int *err);
+//  Destroy a partition handle: Given a partition handle, destroy it and
+//  invalidate it.
+void iMeshP_destroyPartitionAll(iMesh_Instance instance,
+                    /*inout*/ iMeshP_PartitionHandle *partition_handle,
+                              int *err);
-  const int iMeshP_INTERNAL = 0;
-  const int iMeshP_BOUNDARY = 1;
-  const int iMeshP_GHOST = 2;
+//  Given a partition handle, return its communicator.
+//  COMMUNICATION:  None
+void iMeshP_getPartitionComm(iMesh_Instance instance,
+                    /*in*/  iMeshP_PartitionHandle partition_handle,
+                    /*out*/ MPI_Comm *communicator,
+                            int *err);
+//  Update a partition after parts have been added.
+//  Gives the implementation an opportunity to locally store info
+//  about the partition so that queries on the partition can be
+//  performed without synchronous communication.
+//  Values that are precomputed by syncPartitionAll:
+//  +  The total number of parts in a partition.
+//  +  Mapping between part IDs and processes.
+//  +  Updated remote entity handle information.
+void iMeshP_syncPartitionAll(iMesh_Instance instance,
+                       iMeshP_PartitionHandle partition_handle,
+                       int *err);
+//  Given a mesh instance, return number of partition handles and
+//  all partition handles associated with the mesh instance.
+//  COMMUNICATION:  None.
+void iMeshP_getNumPartitions(iMesh_Instance instance,
+                    /*out*/ int *num_partitions,
+                            int *err);
+void iMeshP_getPartitions(iMesh_Instance instance,
+             /*inout*/ iMeshP_PartitionHandle **partition_handle,
+             /*inout*/ int *partition_handle_allocated,
+             /*out*/   int *partition_handle_size,
+                       int *err);
 // Given a partition handle, return the total global number of parts
 // in the partition.
 //  COMMUNICATION:  None++.
-  void iMeshP_getNumParts(iMesh_Instance instance,
+void iMeshP_getNumParts(iMesh_Instance instance,
                           const iMeshP_PartitionHandle partition_handle,
                           int *num_global_part,
                           int *err);
 //  Map from parts to processes:
-//  Given a partition handle and a part handle, return the rank of the
+//  Given a partition handle and a part ID, return the rank of the
 //  process that owns the part.
-//  The part_handle may be local or remote.
+//  The part may be local or remote.
-  void iMeshP_getRankOfPart(iMesh_Instance instance,
-                            const iMeshP_PartitionHandle partition_handle,
-                            /*in*/    const iMeshP_PartHandle part_handle,
-                            /*out*/   int *rank,
-                            int *err);
-  void iMeshP_getRankOfPartArr(iMesh_Instance instance,
-                               /*in*/    const iMeshP_PartHandle *part_handle,
-                               /*in*/    const int part_handle_size,
-                               /*inout*/ int **rank,
-                               /*inout*/ int *rank_allocated,
-                               int *err);
+void iMeshP_getRankOfPart(iMesh_Instance instance,
+                       const iMeshP_PartitionHandle partition_handle,
+             /*in*/    const iMeshP_Part part_id,
+             /*out*/   int *rank,
+                       int *err);
+void iMeshP_getRankOfPartArr(iMesh_Instance instance,
+             /*in*/    const iMeshP_Part *part_ids,
+             /*in*/    const int part_ids_size,
+             /*inout*/ int **rank,
+             /*inout*/ int *rank_allocated,
+                       int *err);
-//  Map from processes to parts:
-//  Given a partition handle and a process rank,
-//  return the part handles owned by the process.
-//  COMMUNICATION:  None++.
-  void iMeshP_getPartsOnRank(iMesh_Instance instance,
-                             /*in*/    const int rank,
-                             /*inout*/ iMeshP_PartHandle **part_handles,
-                             /*inout*/ int *part_handles_allocated,
-                             /*out*/   int *part_handles_size,
-                             int *err);
-  void iMeshP_getPartsArrOnRank(iMesh_Instance instance,
-                                /*in*/    const int *rank,
-                                /*in*/    const int rank_size,
-                                int *err);
 //  Provide global mesh information about a partition.
 //  Note that these functions may require communication and, thus,
 //  would have to be called by all processes in the partition handle.
 //  Given a mesh instance and partition handle, return the
 //  total number of entities with given type or topology in the partition.
-  void iMeshP_getNumOfTypeAll(iMesh_Instance instance,
-                              const iBase_EntitySetHandle entity_set_handle,
-                              const int entity_type, int *num_type, int *err);
-  void iMeshP_getNumOfTopoAll(iMesh_Instance instance,
-                              const int entity_topology, int *num_topo, int *err);
+void iMeshP_getNumOfTypeAll(iMesh_Instance instance,
+                       const iBase_EntitySetHandle entity_set_handle,
+                       const int entity_type, int *num_type, int *err);
+void iMeshP_getNumOfTopoAll(iMesh_Instance instance,
+                       const int entity_topology, int *num_topo, int *err);
-// Given a partition handle and a part handle, test whether the part
-// handle refers to a local or remote part, and whether it is valid.
-  void iMeshP_testPart(iMesh_Instance instance,
-                       /* in */ iMeshP_PartitionHandle partition_handle,
-                       /* in */ iMeshP_PartHandle part_handle,
-                       /* out */ int *part_status, /* LOCAL, REMOTE, INVALID */
+/*                        Part Functionality                              */
+//  Given a partition handle, create a part and add it to the
+//  partition on the process invoking the creation.  Return part handle.
+void iMeshP_createPart(iMesh_Instance instance,
+                   /*out*/ iMeshP_PartHandle *part_handle,
+                           int *err);
+// Given a partition handle and a part handle, remove the part
+// from the partition, destroy the part, and invalidate the part handle.
+// If part_handle is remote, an error is returned.
+void iMeshP_destroyPart(iMesh_Instance instance,
+                 /*inout*/ iMeshP_PartHandle *part_handle,
+                           int *err);
+// Map between part handles and part IDs.
+// Given a partition handle and a local part handle, return the part ID.
+// If the part handle is not a valid part handle for a local part,
+// return an error.
+void iMeshP_getPartFromPartHandle(iMesh_Instance instance,
+             /*in*/    const iMeshP_PartHandle part_handle,
+             /*out*/   iMeshP_Part *part_id,
                        int *err);
+void iMeshP_getPartFromPartHandlesArr(iMesh_Instance instance,
+             /*in*/    const iMeshP_PartHandle *part_handles,
+             /*in*/    const int part_handles_size,
+             /*inout*/ iMeshP_Part **part_ids,
+             /*inout*/ int *part_ids_allocated,
+                       int *err);
+// Given a partition handle and a part ID, return the part handle
+// if the part is local; otherwise, return error code.
+void iMeshP_getPartHandleFromPart(iMesh_Instance instance,
+             /*in*/    iMeshP_Part part_id,
+                       int *err);
+void iMeshP_getPartHandlesFromPartsArr(iMesh_Instance instance,
+             /*inout*/ iMeshP_PartHandle **part_handles,
+             /*inout*/ int *part_handles_allocated,
+                       int *err);
+//  Add/remove on-process entities to/from on-process part:  Given
+//  a partition handle, an entity handle, and a part handle, add/remove the
+//  entity to/from the part.
+//  On-process add/remove can be accomplished by functions
+//  that add/remove entities to/from EntitySets.
+//  The part handle is passed in the entity set argument of
+//  the appropriate entity set function.
+//  The part handle must be local.
+//  iMeshP_addEntToPart --> iMesh_addEntToSet
+//  iMeshP_rmvEntFromPart --> iMesh_rmvEntFromSet
+//  iMeshP_addEntArrToPart --> iMesh_addEntArrToSet
+//  iMeshP_rmvEntArrFromPart --> iMesh_rmvEntArrFromSet
+//  Identify parts that neighbor a given part.
+//  Given a partition handle, a part handle, and an entity type,
+//  return the number of parts in the partition that neighbor the given part
+//  (i.e., that (1) have copies of entities of the given entity type owned by
+//  the given part or (2) own entities of the given entity type that are
+//  copied on the given part).
+//  If the part_handle is invalid, an error is returned.
+//  COMMUNICATION:  None++.
+void iMeshP_getNumPartNbors(iMesh_Instance instance,
+             /*in*/    int entity_type,
+             /*out*/   int *num_part_nbors,
+                       int *err);
+void iMeshP_getNumPartNborsArr(iMesh_Instance instance,
+             /*inout*/ int **num_part_nbors,
+             /*inout*/ int *num_part_nbors_allocated,
+                       int *err);
+//  return the number of neighbor part IDs and the part IDs of
+//  all parts in the partition that neighbor the given part
+//  If part_handle is invalid, an error is returned.
+void iMeshP_getPartNbors(iMesh_Instance instance,
+             /*inout*/ iMeshP_Part **nbor_part_ids,
+             /*inout*/ int *nbor_part_ids_allocated,
+             /*out*/   int *nbor_part_ids_size,
+                       int *err);
+void iMeshP_getPartNborsArr(iMesh_Instance instance,
+                       int *err);
+//  Provide part boundary info:
+//  Note: Allow optional specification of desired entity types and
+//  topologies; allow target part handle = iMeshP_ALL_PARTS to
+//  count/include all qualifying boundary entities of part.
+//  Given a partition handle, a part handle, entity type and topology, and a
+//  target part ID, return the number of qualifying entities on
+//  the part boundary shared with the target part.
+void iMeshP_getNumPartBdryEnts(iMesh_Instance instance,
+                      /*in*/  const int entity_type,
+                      /*in*/  const int entity_topology,
+                      /*in*/  const iMeshP_Part target_part_id,
+                      /*out*/ int *num_entities,
+                              int *err);
+//  target part ID, return an array of entity handles for all
+//  qualifying entities along the part boundary shared with the target
+//  part.
+void iMeshP_getPartBdryEnts(iMesh_Instance instance,
+                   /*inout*/  iBase_EntityHandle **entity_handles,
+                   /*inout*/  int *entity_handles_allocated,
+                      /*out*/ int *entity_handles_size,
+                              int *err);
+//  Boundary iterators:  Given a partition handle, a part handle, and a
+//  target part ID, return an iterator over all entities along
+//  Functionality for getNext, reset, and end is
+//  provided through the regular iMesh iterator functions.
+void iMeshP_initPartBdryEntIter(iMesh_Instance instance,
+                      /*in*/  const iMeshP_Part nbor_part_id,
+                   /*inout*/  iMesh_EntityIterator* entity_iterator,
+                              int* err);
+void iMeshP_initPartBdryEntArrIter(iMesh_Instance instance,
+                      /*in*/  const int array_size,
+                              int* err);
+//  Provide entity information about a part and entity set.
+//  Given an entity set handle
+//  and a part handle, return the number of entities of given type/topo
+//  that are in both the part and the entity set.
+void iMeshP_getNumOfType(iMesh_Instance instance,
+                       const iMeshP_PartHandle part_handle,
+void iMeshP_getNumOfTopo(iMesh_Instance instance,
+//  and a part handle, return vertex information for vertices
+void iMeshP_getAllVtxCoords(iMesh_Instance instance,
+                             iMeshP_PartHandle part_handle,
+                             double** coordinates,
+                             int* coordinates_allocated,
+                             int* coordinates_size,
+                             int** in_entity_set,
+                             int* in_entity_set_allocated,
+                             int* in_entity_set_size,
+                             int* storage_order, int *err);
+void iMeshP_getVtxCoordIndex(iMesh_Instance instance,
+                             const int requested_entity_type,
+                             const int requested_entity_topology,
+                             const int entity_adjacency_type,
+                             int** offset,
+                             int* offset_allocated,
+                             int* offset_size,
+                             int** index,
+                             int* index_allocated,
+                             int* index_size,
+                             int** entity_topologies,
+                             int* entity_topologies_allocated,
+                             int* entity_topologies_size,
+                             int *err);
+//  and a part handle, return entity handles for entities
+void iMeshP_getEntities(iMesh_Instance instance,
+                        iBase_EntityHandle** entity_handles,
+                        int* entity_handles_allocated,
+                        int* entity_handles_size,
+                        int *err);
+//  and a part handle, return entity adjacencies for entities
+void iMeshP_getAdjEntities(iMesh_Instance instance,
+                           const iBase_EntityHandle entity_set_handle,
+                           const int entity_type_requestor,
+                           const int entity_topology_requestor,
+                           const int entity_type_requested,
+                           iBase_EntityHandle** adj_entity_handles,
+                           int* adj_entity_handles_allocated,
+                           int* adj_entity_handles_size,
+                           int** offset,
+                           int* offset_size,
+                           int *err);
+//  Provide entity and array iterators for entities within both a given part
+//  and a given entity set.
+void iMeshP_initEntIter(iMesh_Instance instance,
+                        iMesh_EntityIterator* entity_iterator,
+                        int *err);
+void iMeshP_initEntArrIter(iMesh_Instance instance,
+                           const int requested_array_size,
+                           iMesh_EntityArrIterator* entArr_iterator,
+                           int *err);
+/*                           Entity Functionality                         */
 //  Provide part information about an entity: Given an entity and a
-//  partition handle, return the part handle of the part that owns the entity.
+//  partition handle, return the part ID of the part that owns the entity.
 //  Return an error code if an entity is not in the partition.
-  void iMeshP_getEntOwnerPart(iMesh_Instance instance,
-                              /*in*/  const iMeshP_PartitionHandle partition_handle,
-                              /*in*/  iBase_EntityHandle entity_handle,
-                              /*out*/  iMeshP_PartHandle *part_handle,
+void iMeshP_getEntOwnerPart(iMesh_Instance instance,
+                      /*in*/  const iMeshP_PartitionHandle partition_handle,
+                      /*in*/  iBase_EntityHandle entity_handle,
                               int* err);
-  void iMeshP_getEntOwnerPartArr(iMesh_Instance instance,
-                                 /*in*/  iBase_EntityHandle *entity_handles,
-                                 /*in*/  int entity_handles_size,
-                                 int* err);
+void iMeshP_getEntOwnerPartArr(iMesh_Instance instance,
+                      /*in*/  iBase_EntityHandle *entity_handles,
+                      /*in*/  int entity_handles_size,
+                              int* err);
 //  Provide entity categorization within part.
 //  Given a partition handle, a part handle, and an entity handle, return a
 //  flag indicating whether the entity is owned by the part.
-//  If part_handle is remote, an error is returned.
-  void iMeshP_isEntOwner(iMesh_Instance instance,
-                         /*in*/ const iBase_EntityHandle entity_handle,
-                         /*out*/ int* is_owner,
-                         int *err);
-  void iMeshP_isEntOwnerArr(iMesh_Instance instance,
-                            /*in*/ const iBase_EntityHandle *entity_handles,
-                            /*in*/ const int entity_handles_size,
-                            /*inout*/ int** is_owner,
-                            /*inout*/ int* is_owner_allocated,
-                            /*inout*/ int* is_owner_size,
-                            int *err);
+void iMeshP_isEntOwner(iMesh_Instance instance,
+                    /*in*/ const iBase_EntityHandle entity_handle,
+                   /*out*/ int* is_owner,
+                           int *err);
+void iMeshP_isEntOwnerArr(iMesh_Instance instance,
+                    /*in*/ const iBase_EntityHandle *entity_handles,
+                    /*in*/ const int entity_handles_size,
+		 /*inout*/ int** is_owner,
+                 /*inout*/ int* is_owner_allocated,
+                           int *err);
 //  flag indicating whether the entity is strictly internal, on a
 //  boundary, or a ghost.
-  void iMeshP_getEntStatus(iMesh_Instance instance,
-                           /*out*/ int* par_status, // Values=INTERNAL,BOUNDARY,GHOST
+void iMeshP_getEntStatus(iMesh_Instance instance,
+                   /*out*/ int* par_status, // Values=INTERNAL,BOUNDARY,GHOST
                            int *err);
-  void iMeshP_getEntStatusArr(iMesh_Instance instance,
-                              /*inout*/ int** par_status, // Values=INTERNAL,BOUNDARY,GHOST
-                              /*inout*/ int* par_status_allocated,
-                              /*inout*/ int* par_status_size,
-                              int *err);
+void iMeshP_getEntStatusArr(iMesh_Instance instance,
+		 /*inout*/ int** par_status, // Values=INTERNAL,BOUNDARY,GHOST
+                 /*inout*/ int* par_status_allocated,
+                           int *err);
 //  Provide information about copies of entities.
 //  All these functions should work on the local process as well as
@@ -164,28 +539,728 @@
 //  Given a partition handle and an entity handle, return the number
 //  of copies of the entity in the partition.
-  void iMeshP_getNumCopies(iMesh_Instance instance,
-                           /*out*/ int *num_copies_ent,
+void iMeshP_getNumCopies(iMesh_Instance instance,
+                   /*out*/ int *num_copies_ent,
                            int *err);
+//  Given a partition handle and an entity handle, return the part IDs
+//  of copies of the entity in the partition. (Requested by Onkar.)
+void iMeshP_getCopyParts(iMesh_Instance instance,
+                   /*out*/ int *part_ids_size,
+                           int *err);
 //  Given a partition handle and an entity handle, return (remote) entity
-//  handles and part handles of all copies of the entity.
+//  handles and part IDs of all copies of the entity.
-  void iMeshP_getCopies(iMesh_Instance instance,
-                        /*inout*/ iBase_EntityHandle **copies_entity_handles,
-                        /*inout*/ int *copies_entity_handles_allocated,
-                        /*inout*/ int *copies_entity_handles_size,
-                        int *err);
+void iMeshP_getCopies(iMesh_Instance instance,
+                 /*inout*/ iBase_EntityHandle **copies_entity_handles,
+                 /*inout*/ int *copies_entity_handles_allocated,
+                           int *err);
-#ifdef __cplusplus
-#endif
+//  Given a partition handle, an entity handle and a part ID, return the
+//  (possibly remote) entity handle of the entity in the specified part.
+//  Return an error if the entity does not exist in the specified part.
+void iMeshP_getCopyOnPart(iMesh_Instance instance,
+                    /*in*/ iMeshP_Part* part_id,
+                   /*out*/ iBase_EntityHandle* copy_entity_handle,
+                           int *err);
-#endif
+//  Given a partition handle and an entity handle, return the entity
+//  handle and part ID from the owner of the entity (e.g., the
+//  entity handle of the copy that has right-to-modify).
+void iMeshP_getOwnerCopy(iMesh_Instance instance,
+                   /*out*/ iMeshP_Part *owner_part_id,
+                   /*out*/ iBase_EntityHandle *owner_entity_handle,
+                           int *err);
+ *******         COMMUNICATION          **********
+// Non-blocking calls for off-processor mesh-modification return a request
+// that indicates whether or not the operation has completed.
+// The following functions receive and process requests.
+/**\brief  Wait for specified request to complete
+ * Wait for the specified request to complete.
+ * \param req Request object to wait on
+ * \param stat Status of communication request
+ * \param err Error returned from function
+//  COMMUNICATION:  Blocking point-to-point.
+iMeshP_Wait(iMesh_Instance instance,
+             /*in*/ iMeshP_RequestHandle req,
+            /*out*/ iMeshP_Status stat,
+            /*out*/ int *err)
+/**\brief  Wait for any of the specified requests to complete
+ * Wait for any of the specified requests to complete.
+ * \param req Request objects to wait on
+ * \param req_size Number of request objects
+ * \param index Index of request in req which was completed
+void iMeshP_WaitAny(iMesh_Instance instance,
+               /*in*/ iMeshP_RequestHandle *req,
+               /*in*/ int req_size,
+               /*out*/ int *index,
+               /*out*/ iMeshP_Status *stat,
+               /*out*/ int *err)
+/**\brief  Wait for all of the specified requests to complete
+ * Wait for all of the specified requests to complete.
+void iMeshP_WaitAll(iMesh_Instance instance,
+               /*out*/ int *err)
+ * Wait for the specified request to complete.  Returns entities
+ * for which information was \em received
+ * \param entities Entities for which information was received
+ * \param entities_alloc Allocated size of entities vector
+ * \param entities_size Occupied size of entities vector
+void iMeshP_WaitEnt(iMesh_Instance instance,
+               /*inout*/ iBase_EntityHandle **out_entities,
+               /*inout*/ int *out_entities_alloc,
+               /*inout*/ int *out_entities_size,
+               /*out*/ int *err)
+/**\brief Test for whether specified request has completed
+ * Test for whether specified request has completed
+ * \param flag Returned true if request completed
+//  COMMUNICATION:  Point-to-point; non-blocking.
+void iMeshP_Test(iMesh_Instance instance,
+            /*out*/ int *flag,
+            /*out*/ int *err)
+// Poll for requests.  The internals of this function are going to have
+// to cover a lot of ground.  The array in the return is there as a
+// placeholder to tell the application that something interesting / useful
+// has been done to a handle.  This might indicate successful in-migration,
+// a recent change in vertex location, or successful completion of handle
+// matching.
+// Returns an array of requests that have been handled.  If
+// the array has a size allocated already, then the implementation stops
+// working when it has generated that many completed requests, even if there
+// are more messages waiting.  The syntax on this call should perhaps be
+// modified somewhat to make it more compatible with an analogous MPI call.
+// Should also perhaps have its name changed to handleMessages or some such
+// thing, since the function should not only poll for unexpected
+// messages, but also handle expected ones; these is no reason to
+// separately call two different functions to handle non-blocking receives
+// for different types of messages.
+// COMMUNICATION:  non-blocking; point-to-point.
+void iMeshP_pollForRequests(iMesh_Instance instance,
+           iMeshP_RequestHandle **requests_completed,
+			    int *requests_allocated,
+			    int *requests_size,
+			    int *err);
+ *******     Requests for off-processor mesh modification      ******
+//  Add entities to on-process and/or off-process parts:
+//  Collective-communication version:
+//  iMeshP_exchEntArrToPartsPar is a collective, non-blocking operation
+//  to be called by all processes in the partition's communicator.
+//  An iMeshP_RequestHandle is returned; any of the iMeshP_Wait functions can be
+//  used to block until the request is completed.
+//  COMMUNICATION:  Collective.  Non-blocking.
+void iMeshP_exchEntArrToPartsAll(iMesh_Instance instance,
+                       /*in*/  const iMeshP_Part *target_part_ids,
+                       /*in*/  int command_code,  // e.g., MIGRATE,COPY
+                       /*in*/  int update_ghost,  // e.g., YES,NO
+                      /*out*/  iMeshP_RequestHandle *request,
+                               int *err);
+// Request in-migration to a given part of an entity and its upward adjacencies.
+// This is a pull migration.  The
+// entity must be on the part bdry and is identified by local handle, and
+// the implementation handles the rest.  This operation will require multiple
+// rounds of communication, and at some times certain entities may be
+// locked (unavailable for local modification) while info about their
+// remote copies is still in question.
+// It's worth mentioning that implementations will have to take care to
+// migrate tags and parallel set membership as well as adjacency info.
+// CHANGES: Returns a request handle.  Assumes you wouldn't be asking if
+// you didn't need the upward adjacencies as well.
+// COMMUNICATION:  point-to-point, non-blocking, pull.
+void iMeshP_migrateEntity(iMesh_Instance instance,
+		          const iBase_EntityHandle local_entity_handle,
+			  iMeshP_RequestHandle *request,
+		          int *err);
+// Update vertex coordinates.  One could argue that we could overload
+// the setVtxCoords function to do this, and maybe we should.  But that
+// obfuscates when communication could occur.  The communication here is
+// push-and-forget.
+// Because this is push-and-forget, no request handle -should- be generated.
+// COMMUNICATION:  point-to-point, non-blocking, push-and-forget.
+void iMeshP_updateVtxCoords(iMesh_Instance instance,
+		            const iBase_EntityHandle local_vertex_handle,
+			    int *err);
+// Replace entities.  This refers to changes on the part bdry where the
+// application/service is responsible for ensuring that things are done
+// identically on both sides and that the args are passed in an order that
+// can be matched.  (Specifically, matching new entities should appear in
+// the same order in the call array.)  Communication here could be a
+// two-way push-and-forget, or some variant on push-and-confirm.
+// CHANGES: At Onkar's suggestion, added an offset array (similar to array
+// adjacency requests) so that a single call can easily handle coordination
+// with multiple entities on part-boundary.
+void iMeshP_replaceOnPartBdry(iMesh_Instance instance,
+		       const iBase_EntityHandle *old_entities,
+		       const int old_entities_size,
+		       const iBase_EntityHandle *new_entities,
+		       const int new_entities_size,
+		       const int *offset,
+		       const int offset_size,
+		       int *err);
+// The ability to create and delete copies is likely
+// to be useful, even though for common topologically-based cases, copies
+// maintainance can (and IMO should) be done automagically, either at
+// migration time or during iMeshP_syncMeshAll.
+// Communication here is
+// push-and-confirm for creation (so that the original knows ID's of the
+// ghosts), push-and-forget for deletion (in the latter case, no request
+// handle is needed).  I'm assuming here that the closure of a new ghost
+// will be pushed automatically as part of the underlying communication,
+// and that the remote part will clean up the closure as appropriate during
+// deletion.
+// COMMUNICATION:  point-to-point, non-blocking, push.
+void iMeshP_addGhostOf(iMesh_Instance instance,
+	/* in */       const iMeshP_PartitionHandle partition_handle,
+	/* in */       const iMeshP_Part target_part_id,
+	/* in */       const iBase_EntityHandle entity_to_copy,
+	/* out */      iMeshP_RequestHandle *request,
+		       int *err);
+void iMeshP_rmvGhostOf(iMesh_Instance instance,
+	/* in */       const iBase_EntityHandle copy_to_purge,
+		       int *err);
+// Done with mesh modification.  This is a blocking call, to get
+// everything up-to-date and back in synch.  Essentially, waits for all
+// message traffic to clear, as well as (possibly) rebuilding a bunch of
+// ghost info that was allowed to go obsolete.
+void iMeshP_syncMeshAll(iMesh_Instance instance,
+		       int *err);
+// Functions to exchange Tag data.
+/**\brief  Synchronously exchange tag data for entity type/topo
+ * and part
+ * Exchange tag information for shared entities of specified type/
+ * topology to specified part.  This version operates on all
+ * shared entities of specified type/topology (or all
+ * types/topologies if iMesh_ALL_TYPE or iMesh_ALL_TOPOLOGIES are
+ * given).  This function assumes tag handles given on various
+ * calling parts are consistent, i.e. they have the same name,
+ * data type, size, etc.  This call blocks until communication is
+ * completed
+ * \param tag Tag handle to exchange
+ * \param entity_type Tag data exchanged only for this entity type
+ * \param entity_topo Tag data exchanged only for this entity topology
+ * \param with_part Tag info exchanged only with this part
+void iMeshP_ExchTags(iMesh_Instance instance,
+                /*in*/ iBase_TagHandle tag,
+                /*in*/ int entity_topo,
+                /*in*/ iMeshP_Part with_part_id,
+                /*out*/ int *err)
+/**\brief  Synchronously exchange tag data for entities and part
+ * Exchange tag information for specified entities, which must
+ * already be shared.  This function assumes tag handles given on various
+ * completed
+ * \param entities Entities for which to exchange data
+ * \param entities_size Number of entities
+void iMeshP_ExchTagsEnt(iMesh_Instance instance,
+                   /*in*/ iBase_EntityHandle *entities,
+                   /*in*/ int entities_size,
+                   /*out*/ int *err)
+/**\brief  Asynchronously exchange tag data for entity type/topo
+ * and part
+ * data type, size, etc.  Applications can call iMeshP_Wait or
+ * iMeshP_WaitEnt to block until associated call completes
+ * \param iMeshP_RequestHandle Request object used in call to
+ *    iMeshP_Wait or iMeshP_WaitEnt
+void iMeshP_IExchTags(iMesh_Instance instance,
+                /*out*/ iMeshP_RequestHandle *req,
+                /*out*/ int *err)
+/**\brief  Asynchronously exchange tag data for entities and part
+void iMeshP_IExchTagsEnt(iMesh_Instance instance,
+                   /*out*/ int *err)
+/*  GHOST ENTITY SUPPORT */
+The triplet describing a ghosting "rule" (ghost dim, bridge dim, #
+layers) will be stored in the partition and re-established by the end
+of iMeshP_syncPartitionAll and iMeshP_syncMeshAll.  Implementations can
+choose to keep ghosting consistent throughout mesh modification, but ghosts
+are not required to be consistent until the end of these two functions.
+The number of layers specified is with respect to the global mesh;
+that is, ghosting may extend beyond a single neighboring processor if the
+number of layers is high.
+iMeshP_createGhostEntities is a preprocessing function.  It is
+cumulative; that is, multiple calls may add more ghosts, not eliminate
+previous ghosts.
+/* \brief Create ghost entities between parts/processors.
+  * Ghost entities are specified similar to 2nd-order adjacencies, i.e.
+  * through a "bridge" dimension.  Number of layers is measured from
+  * the inter-processor interfaces.  For example, to get 2 layers of hex
+  * entities in the ghost layer, measured from faces on the interface,
+  * use ghost_dim=3, bridge_dim=2, and num_layers=2.
+  * Ghost information is cached on the partition.
+  * \param instance iMesh instance
+  * \param partition_handle Partition on which to create ghosts
+  * \param ghost_dim Dimension of entities ghosted
+  * \param bridge_dim Dimension through which bridge adjacencies are found
+  * \param num_layers Number of layers of ghost entities
+  * COMMUNICATION:  Collective.  Blocking.
+iMeshP_createGhostEnts(/*in*/ iMesh_Instance instance,
+                       /*in*/ int ghost_dim,
+                       /*in*/ int bridge_dim,
+                       /*in*/ int num_layers,
+                       /*out*/ int *err);
+/* \brief Delete all ghost entities between parts/processors.
+  * \param partition_handle Partition on which ghost entities are deleted
+  * COMMUNICATION:  None.
+iMeshP_deleteGhostEnts(/*in*/ iMesh_Instance instance,
+/* \brief Return information about all ghosting on a partition.
+  * \param ghost_dim Dimension of ghost entities
+  * \param bridge_dim Dimension of bridge entities
+iMeshP_ghostEntInfo(/*in*/ iMesh_Instance instance,
+                    /*out*/ int num_ghost_rules,
+                    /*inout*/ int *ghost_rules_allocated,
+                    /*inout*/ int *ghost_rules_size,
+                    /*out*/ int **ghost_dim,
+                    /*out*/ int **bridge_dim,
+                    /*out*/ int **num_layers,
+Major Items left to do:
+-  Support for multiple partitions.
+   We discussed designating a given partition as
+   the "active" partition; i.e., the partition that is actually used in
+   the distribution of mesh data in distributed memory.  We were concerned
+   that when multiple partitions were used, multiple copies of mesh
+   entities would be needed to fully support multiple partitions at the
+   same time.  Designating one partition as "active" would store data
+   with respect to only one partition.
+-  File I/O support.
+   Support single files, N << P files on P processes, and P files.
+   Support reading and writing partition information.
+   Support initial parallel partitioning of serial file data.
+   Support storing mapping of parts to processes in files.
+Minor Items left to do:
+-  Determine which capabilities need both "getNumX" and "getX" functions.
+   That is, when would an application need "getNumX" to allocate memory
+   for "getX" or separately from "getX".  When could we use only "getX"
+   and return numX as a byproduct.
+-  Determine with functions need "Ent" and "EntArr" versions, or whether
+   we should adopt only the more general "EntArr" version.
+-  Determine whether to revise iMeshP_createPartition to make it less MPI
+   specific.  We don't want to require applications to link with MPI if the
+   implementation doesn't require it.  We may define an ITAPS_Comm name
+   typedef'ed appropriately.
+-  iMeshP_getOwnerCopy could be achieved by calling iMeshP_getOwnerPart
+   followed by iMeshP_getCopyOnPart.  Do we want to keep iMeshP_getOwnerCopy?
+Comments and resolved questions:
+- Applications will build partitions by (1) creating a partition handle
+  on each process to be included in the partition; (2) adding parts to
+  the partition handle within the process; (3) populating the parts with
+  entities, and (4) calling iMeshP_syncPartitionAll to allow the
+  implementation to compute global data for the partition.
+- For now, we will not include an iterator over local (to a
+  process) parts within a partition.  If it is needed, it can be added
+  later.
+- We will not provide capability to move entire parts to new
+  processes;  instead, the new process must create the part in its
+  partition handle and then receive (perhaps in bulk) the entities to
+  populate the part.  In other words, parts can be added to only a local
+  partition handle.
+- Currently, iMesh doesn't have the functionality to get entities or
+  entity sets by type and tag in serial.  Should it?
+  Many people said it would be useful; others said it could be costly
+  (in parallel) or numerically difficult (for floating point values).
+  This issue is an iMesh issue, not a parallel interface issue, so
+  for this document, the issue is resolved.  The resolution:  If
+  iMesh adopts this capability, we will add it to the
+  parallel interface.
+- We will not include functions that return all entities with
+  given characteristics within a partition; the memory use of these
+  functions can be large.  Instead, we will return entity information
+  with respect to parts and/or mesh instances.  If the user wants such
+  info, he should go through the mechanics of gathering it himself so
+  that he is painfully aware of how much memory he is allocating.
+  Removed the following global queries:
+  + All tag names over the partition;
+  + All entities in this partition having a given type, tag and/or
+    tag name.
+  + All entity sets in this partition having a given
+    type, tag and/or tag name.
+- We will not include functions that return information about each
+  part and/or process in a partition.  Such functions limit memory
+  scalability for large numbers of parts.  If the user wants such
+  + The number of entities in each part of the partition;
+  + The number of entity sets in each part of the partition;
+  + The number of entities with given type, tag, and/or
+    tag name in each part of the partition;
+  + The number of entity sets with given type, tag,
+    and/or tag name in each part of the partition;
+  + All tag names in each part of the partition;
+- For functions that replace a set handle with a part handle, return
+  all appropriate entities in a part, whether they are owned or are
+  copies.  The application can test for ownership if needed.
+- Part assignments computed with respect to a set of
+  entities induce part assignments to adjacent entities in an
+  implementation-dependent fashion.  That is, if a partition is computed
+  with respect to regions, queries about ownership of faces and vertices
+  are valid.
+Discussed but unresolved questions:
+- We discussed adding functions that give
+  hints to an implementation about which data mappings the application
+  will use, allowing the implementation to pre-compute them if it chooses
+  to.  The example discussed was mapping between entities and parts, but
+  other examples in iMesh may also exist.
+- We discussed adding an iterator over entities
+  with given type/topology in a set or part.  We have non-iterator
+  functionality, but not an iterator.
+  KDD:  Is this true?  What is iMesh_initEntIter (and its analogous
+  KDD:  iMeshP_initEntIter)?
+- We discussed storing in a partition
+  information about which "objects" were used in computing the partition.
+  These objects can be single entities or groups of entities.
+  KDD:  Perhaps this capability should be part of the load-balancing service.
+- We discussed designating a given partition as
+Not-yet-discussed, unresolved questions
+Entity questions:
+- From Carl:  "getTag*Operate: Again, we haven't got this in serial.  Does
+  the existence of such operations imply that we expect to implement
+  fields as tags? (Because that wasn't what I was assuming about field
+  implementations at all, personally...)  Note that I'm not opposed to
+  this sort of global reduction operation, I just wonder whether it'll see
+  use outside of field-like situations.  If not, then it should be in
+  parallel fields, not parallel mesh, and usage for
+  fields-implemented-as-tags should be handled there."
+/* NOTES FROM BOOTCAMP MARCH 2008 */
+-  Changed getPartRank to getRankOfPart.  (Carl)
+-  Made sure iMeshP_getNumOfTypeAll and iMeshP_getNumOfTopoAll were
+documented as collective operations.  (Carl)
+-  Changed suffix "Par" to "All".  (Lori)
+-  Added iMeshP_testPart() to test status of part handle, returning
+LOCAL, REMOTE, or INVALID.  (Mark M, Lori).
+6/25/08:  Removed this function since part handles can no longer be remote.
+If an application wants to test the validity of a part handle, it can try
+to compute its Part ID.
+-  Changed iMeshP_addCopyOf and iMeshP_rmvCopyOf back to
+iMeshP_addGhostOf and iMeshP_rmvGhostOf.  If we wanted to use these
+functions for adding boundary copies, we'd have to include a list of
+already existing remote copies in the arguments, as well as
+communicate with parts already owning copies to let them know a ghost
+copy has been made.  Actually, this raises an interesting question:
+does a boundary copy need to know about all ghost copies of it?
+-  Change getEntParStatus to getEntStatus.  (Lori)
+-  Changed sendEntArrToPartsPar to exchEntArrToPartsAll.  (Lori,Tim)
+Parts and Processes:
+-  Martin argued for consecutive unique Part IDs in addition to or
+instead of Part handles.  He will send use cases.   If we decide to
+add them back to the interface, we could compute them in
+iMeshP_syncPartitionAll rather than in iMeshP_createPart.  That is, an
+application couldn't access them until after iMeshP_syncPartitionAll.
+6/25/08:  On follow-up, Martin couldn't recall why having consecutive
+PartIDs was necessary.  While we all agree they are conceptually nice,
+they are difficult to implement and not really necessary.  Part IDs will
+be globally unique but not necessarily consecutive.
+-  Are part handles globally unique?  They probably need to be
+globally unique in order for them to be useful as remote part
+handles.  Also, does the process rank need to be encoded in the part
+handle in order to map from parts to processes for communication?
+6/25/08:  DECIDED:  We will have globally unique part IDs.  Part handles
+will be valid for only local parts.  Accessing remote parts must be done
+via Part IDs.
+-  If in iMeshP_syncPartitionAll, we computed a mapping from part
+handles to integers 0,..., k-1, we could store only ranges of
+integers to achieve the part-to-process and process-to-parts mappings;
+this would require O(P) storage per process for P processes.
+6/5/08:  DECIDED:  Do not need getPartOnRank or getNumPartOnRank.  These
+functions were troublesome due to their storage or communication requirements.
+We decided to remove them.
+-  Alternatively, the mapping of all parts to processes can be stored
+in O(k) total memory, distributed across processors (e.g., a
+distributed data directory) but interrogating the directory requires
+communication.
+6/5/08:  See note above.
+-  iMeshP_getPartsOnRank created discussion and needs to be resolved.
+IMeshP_getPartsOnRank would likely require either O(k) storage per
+process for k parts or communication.  For other points, please see
+Mark M's 3/12/08 email.
+CreateEnt:
+-  Carl asked if we should have a version of createEnt that accepts a
+part handle.  Should this function be used only for creating owned
+entities?   How do you envision creating part boundary entities when a
+parallel mesh is initially loaded?
+Ghost entities:
+-  We currently have a mechanism only for pushing ghosts onto other
+parts.  Will we want a mechanism for pulling them, too?  (E.g., a
+part says, "I want ghosts for this entity.")
+PartNbor functions:
+-  Did we agree to remove the entity type from these functions?  That
+is, do we want to return the part IDs for all parts that have
+any copies?  The entity type was intended to allow us to get the part
+IDs for all parts that have copies of a given type (perhaps
+ALL_TYPES).
+Functions handling both Parts and Entity Sets:
+-  Tim said these function names (e.g., iMeshP_getNumOfType,
+iMeshP_getAllVtxCoord) are too close to existing iMesh function
+names, even though the argument lists would be different.  He agreed
+to email suggestions for better names.
+Copies:
+-  Functions getNumCopies, getCopies, getCopyParts, and getCopyOnPart
+have different behavior for ghost and part-boundary copies.  Ghosts
+will return only itself and its owner in getCopies; part-boundary
+entities will return copies on other parts as well.
+-  Tim envisions applications (e.g., FETI methods) updating tag data
+in their ghosts that they would like to accumulate back to the
+owner.  Xiaolin said that he writes in his ghosts, but doesn't send
+those values back to the owner.  Currently, we have the ability only
+to send tag data from owners to ghosts.  Tim will look at this issue
+and propose a solution.
+Communication:
+-  Although we should think in terms of parts, communication really
+occurs with respect to processes.  We need to make sure all our
+communication routines make sense with respect to both processes and
+parts, and perhaps, revise their descriptions.  Also, if we send to
+parts, the implementation really does need the mapping of parts to
+processes.
+Entity Owner/Status Queries:
+-  Should we combine functions getEntOwnerPart and getEntStatus into
+one function?  Or should we combine functions getOwnerCopy and
+getEntOwner into one function?  Or should we remove getOwnerCopy and
+make applications call getOwnerPart followed by getCopyOnPart?
+Reducing storage:
+-  Mark Miller proposed allowing the user to specify the amount of
+copying done by the implementation, depending on applications' needs.
+For example, for a static viz application, every boundary entity may not
+need to know where all its copies are, so the implementation would not
+have to store them.  Can the implementations accept a flag advising them how
+much copying is needed?  If so, the implementations could choose to
+optimize storage or ignore the flag.
+CVS File Information
+   $RCSfile: DraftInterface.h,v $
+   $Author: kddevin $
+   $Date: 2008/07/24 20:08:12 $
+   $Revision: 1.27 $
