[MOAB-dev] errors during make check
Jason Kraftcheck
kraftche at cae.wisc.edu
Wed Oct 1 14:54:29 CDT 2008
de Almeida, Valmor F. wrote:
> This is with revision 2117. Is it a problem?
> Thanks,
> Valmor
> 63 tests passed
> PASS: vtk_test
> PASS: adaptive_kd_tree_tests
> Running test_iterator ...
> Running test_box_iterator ...
> Running test_tree_create ...
> Running test_box_tree_create ...
> Running test_leaf_containing_point_bounded_tree ...
> Running test_leaf_containing_point_unbounded_tree ...
> Running test_merge_leaf ...
> PASS: bsp_tree_test
> PASS: file_options_test
> HDF5-DIAG: Error detected in HDF5 (1.8.1) thread 0:
> #000: H5D.c line 321 in H5Dopen2(): not found
> major: Dataset
> minor: Object not found
> #001: H5Gloc.c line 468 in H5G_loc_find(): can't find object
> major: Symbol table
> #002: H5Gtraverse.c line 861 in H5G_traverse(): internal path
> traversal failed
> major: Symbol table
> #003: H5Gtraverse.c line 691 in H5G_traverse_real(): traversal
> operator failed
> major: Symbol table
> minor: Callback failed
> #004: H5Gloc.c line 423 in H5G_loc_find_cb(): object doesn't exist
> major: Symbol table
> #005: H5Gobj.c line 1105 in H5G_obj_lookup(): can't locate object
> major: Symbol table
> #006: H5Gstab.c line 857 in H5G_stab_lookup(): not found
> major: Symbol table
> #007: H5Gnode.c line 971 in H5G_node_found(): not found
> major: Symbol table
> major: Dataset
> major: Symbol table
> traversal failed
> major: Symbol table
> operator failed
> major: Symbol table
> major: Symbol table
> major: Symbol table
> major: Symbol table
> major: Symbol table
This stuff is normal. The HDF5 library can be rather verbose about attempts
to open non-existent tables. However, the MOAB code correctly handles these
older files.
> [snip]
> FAIL: cub_file_test
> 1 of 19 tests failed
This, OTHO, is a problem. What was the output from that test? It doesn't
fail for me.
- jason
