[MOAB-dev] errors during make check
de Almeida, Valmor F.
dealmeidav at ornl.gov
Wed Oct 1 14:48:29 CDT 2008
This is with revision 2117. Is it a problem?
Valmor
63 tests passed
PASS: vtk_test
PASS: adaptive_kd_tree_tests
Running test_iterator ...
Running test_box_iterator ...
Running test_tree_create ...
Running test_box_tree_create ...
Running test_leaf_containing_point_bounded_tree ...
Running test_leaf_containing_point_unbounded_tree ...
Running test_merge_leaf ...
PASS: bsp_tree_test
PASS: file_options_test
HDF5-DIAG: Error detected in HDF5 (1.8.1) thread 0:
#000: H5D.c line 321 in H5Dopen2(): not found
major: Dataset
minor: Object not found
#001: H5Gloc.c line 468 in H5G_loc_find(): can't find object
major: Symbol table
#002: H5Gtraverse.c line 861 in H5G_traverse(): internal path
traversal failed
major: Symbol table
#003: H5Gtraverse.c line 691 in H5G_traverse_real(): traversal
operator failed
major: Symbol table
minor: Callback failed
#004: H5Gloc.c line 423 in H5G_loc_find_cb(): object doesn't exist
major: Symbol table
#005: H5Gobj.c line 1105 in H5G_obj_lookup(): can't locate object
major: Symbol table
#006: H5Gstab.c line 857 in H5G_stab_lookup(): not found
major: Symbol table
#007: H5Gnode.c line 971 in H5G_node_found(): not found
major: Symbol table
major: Dataset
major: Symbol table
traversal failed
major: Symbol table
operator failed
major: Symbol table
major: Symbol table
major: Symbol table
major: Symbol table
major: Symbol table
[snip]
FAIL: cub_file_test
1 of 19 tests failed
make[2]: *** [check-TESTS] Error 1
make[2]: Leaving directory
`/home/dealmeida/projects/scidac/itaps/moab-dev'
make[1]: *** [check-am] Error 2
make[1]: Leaving directory
make: *** [check-recursive] Error 1
