[MOAB-dev] errors during make check
de Almeida, Valmor F. dealmeidav at ornl.gov
Wed Oct 1 16:48:16 CDT 2008
> > FAIL: cub_file_test
> > 1 of 19 tests failed
> This, OTHO, is a problem.  What was the output from that test?  It
doesn't
> fail for me.
Jason,
This is what I get as screen output. Is there another place to look for
outputs?
[snip]
ALL TESTS PASSED
PASS: mesh_set_test
Running test_vertices ...
Running test_edges ...
Running test_quads ...
Running test_hexes ...
Running test_geometric_topology ...
Running test_geometric_sets ...
Running test_blocks ...
Running test_side_sets ...
Running test_node_sets ...
Running test_file_set ...
FAIL: cub_file_test
make[2]: *** [check-TESTS] Error 1
make[2]: Leaving directory
`/home/dealmeida/projects/scidac/itaps/moab-dev'
make[1]: *** [check-am] Error 2
make[1]: Leaving directory
make: *** [check-recursive] Error 1
Valmor
