[MOAB-dev] r2237 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov
Thu Nov 13 13:27:16 CST 2008
Author: kraftche
Date: 2008-11-13 13:27:16 -0600 (Thu, 13 Nov 2008)
New Revision: 2237
Modified:
MOAB/trunk/tools/iMesh/iMeshP.h
MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp
Log:
sync with latest iMeshP.h
Modified: MOAB/trunk/tools/iMesh/iMeshP.h
--- MOAB/trunk/tools/iMesh/iMeshP.h 2008-11-13 18:35:34 UTC (rev 2236)
+++ MOAB/trunk/tools/iMesh/iMeshP.h 2008-11-13 19:27:16 UTC (rev 2237)
@@ -15,7 +15,6 @@
ITAPS_DECLARE_HANDLE( iMeshP_PartitionHandle );
ITAPS_DECLARE_HANDLE( iMeshP_RequestHandle );
-ITAPS_DECLARE_HANDLE( iMeshP_Status );
/* Since we allow overloading of iMesh functions' entity set handles with
* part handles, iMeshP_PartHandle must be defined the same as
@@ -70,18 +69,6 @@
a mesh instance within a process.
- Part A "neighbors" Part B if Part A has copies of entities owned by Part B
and/or if Part B has copies of entities owned by Part A.
-- Each function description includes its communication requirements. The
- options are described here:
- - COMMUNICATION: Collective -- the function must be called by all
- processes in the partition's communicator.
- - COMMUNICATION: Point-to-Point -- communication is used, but the
- communication is from one process to only one other process. The
- receiving process must issue an appropriate receive call to receive
- the message.
- - COMMUNICATION: None -- the function does not use communication; only
- local operations are performed.
- - COMMUNICATION: None++ -- no communication is done; the values
- are precomputed by iMeshP_syncPartitionAll or iMeshP_syncMeshAll.
\section INT Interfaces
- Each process has one or more "mesh instances." A mesh instance can be
@@ -132,6 +119,27 @@
- Remove entity from part --> iMesh_rmvEntFromSet
- Add array of entities to part --> iMesh_addEntArrToSet
- Remove array of entities from part --> iMesh_rmvEntArrFromSet
+\section CMM Communication
+- Each function description includes its communication requirements. The
+ options are described here:
+ - COMMUNICATION: Collective -- the function must be called by all
+ processes in the partition's communicator. (These functions have the
+ suffix "All" to indicate collective communication is done.)
+ - COMMUNICATION: Point-to-Point -- communication is used, but the
+ communication is from one process to only one other process. The
+ receiving process must issue an appropriate receive call to receive
+ the message.
+ - COMMUNICATION: None -- the function does not use communication; only
+ local operations are performed.
+ - COMMUNICATION: None++ -- no communication is done; the values
+ are precomputed by iMeshP_syncPartitionAll or iMeshP_syncMeshAll.
+- Non-blocking calls for off-processor mesh-modification return a request
+ that indicates whether or not the operation has completed. The request
+ is more than an MPI request; it encapsulates both the MPI information and
+ the mesh operations that were requested. If non-blocking calls are used,
+ appropriate calls to iMeshP "wait" or "poll" functions must be used to
+ handle and satisfy requests.
@@ -157,14 +165,13 @@
* \param instance (In) Mesh instance to contain the partition.
* \param communicator (In) Communicator to be used for parallel
* communication.
- * \param partition_handle (Out) Partition handle for the newly
- * created partition.
+ * \param partition (Out) The newly created partition.
* \param err (Out) Error code.
void iMeshP_createPartitionAll(
iMesh_Instance instance,
MPI_Comm communicator,
- iMeshP_PartitionHandle *partition_handle,
+ iMeshP_PartitionHandle *partition,
int *err);
@@ -178,13 +185,12 @@
* COMMUNICATION: Collective.
* \param instance (In) Mesh instance containing the partition.
- * \param partition_handle (In) Partition handle for the partition
- * to be destroyed.
+ * \param partition (In) The partition to be destroyed.
void iMeshP_destroyPartitionAll(
- iMeshP_PartitionHandle partition_handle,
+ iMeshP_PartitionHandle partition,
int *err);
@@ -197,14 +203,13 @@
* COMMUNICATION: None
- * \param partition_handle (In) Partition handle for the partition being
- * queried.
+ * \param partition (In) The partition being queried.
* \param communicator (Out) Communicator associated with the partition.
void iMeshP_getPartitionComm(
MPI_Comm *communicator,
int *err);
@@ -225,13 +230,12 @@
- * updated.
+ * \param partition (In) The partition being updated.
void iMeshP_syncPartitionAll(
int *err);
@@ -264,20 +268,20 @@
* partitions.
- * \param partition_handles (In/Out) Array of partition handles
+ * \param partitions (In/Out) Array of partition handles
* associated with the mesh
* instance.
- * \param partition_handles_allocated (In/Out) Allocated size of
- * partition_handles array.
- * \param partition_handles_size (Out) Occupied size of
+ * \param partitions_allocated (In/Out) Allocated size of
+ * partitions array.
+ * \param partitions_size (Out) Occupied size of
void iMeshP_getPartitions(
- iMeshP_PartitionHandle **partition_handles,
- int *partition_handles_allocated,
- int *partition_handles_size,
+ iMeshP_PartitionHandle **partitions,
+ int *partitions_allocated,
+ int *partitions_size,
int *err);
@@ -290,14 +294,13 @@
* COMMUNICATION: None++.
- * queried.
* \param num_global_part (Out) Global number of parts in the partition.
void iMeshP_getNumGlobalParts(
- const iMeshP_PartitionHandle partition_handle,
+ const iMeshP_PartitionHandle partition,
int *num_global_part,
int *err);
@@ -311,15 +314,14 @@
* COMMUNICATION: None.
- * queried.
* \param num_local_part (Out) Local (on-process) number of parts in
* the partition.
void iMeshP_getNumLocalParts(
int *num_local_part,
int *err);
@@ -334,22 +336,21 @@
* partition.
- * being queried.
- * \param part_handles (In/Out) Array of part handles
+ * \param parts (In/Out) Array of part handles
* for local parts in the partition.
- * \param part_handles_allocated (In/Out) Allocated size of
- * part_handles array.
- * \param part_handles_size (Out) Occupied size of
+ * \param parts_allocated (In/Out) Allocated size of
+ * parts array.
+ * \param parts_size (Out) Occupied size of
+ * parts array.
void iMeshP_getLocalParts(
- iMeshP_PartHandle **part_handles,
- int *part_handles_allocated,
- int *part_handles_size,
+ iMeshP_PartHandle **parts,
+ int *parts_allocated,
+ int *parts_size,
int *err);
@@ -363,15 +364,14 @@
- * queried.
* \param part_id (In) Part ID for the part being queried.
* \param rank (Out) Process rank of part_id.
void iMeshP_getRankOfPart(
const iMeshP_Part part_id,
int *rank,
int *err);
@@ -387,8 +387,7 @@
- * queried.
* \param part_ids (In) Array of Part IDs for the parts being
* queried.
* \param part_ids_size (In) The number of Part IDs in part_ids.
@@ -400,7 +399,7 @@
void iMeshP_getRankOfPartArr(
const iMeshP_Part *part_ids,
const int part_ids_size,
int **ranks,
@@ -421,9 +420,8 @@
- * queried.
- * \param entity_set_handle (In) Entity set handle for the entity set
+ * \param entity_set (In) Entity set handle for the entity set
* being queried.
* \param entity_type (In) Requested entity type;
* may be iBase_ALL_TYPES.
@@ -433,8 +431,8 @@
void iMeshP_getNumOfTypeAll(
- const iBase_EntitySetHandle entity_set_handle,
+ const iBase_EntitySetHandle entity_set,
int entity_type,
int *num_type,
int *err);
@@ -452,9 +450,8 @@
- * queried.
* being queried; may be the root set.
* \param entity_topology (In) Requested entity topology;
* may be iMesh_ALL_TOPOLOGIES.
@@ -464,8 +461,8 @@
void iMeshP_getNumOfTopoAll(
int entity_topology,
int *num_topo,
int *err);
@@ -486,15 +483,14 @@
- * updated.
- * \param part_handle (Out) Part handle for the newly created part.
+ * \param part (Out) The newly created part.
void iMeshP_createPart(
- iMeshP_PartHandle *part_handle,
+ iMeshP_PartHandle *part,
int *err);
@@ -508,15 +504,14 @@
- * updated.
- * \param part_handle (In) Part handle for the part to be removed.
+ * \param part (In) The part to be removed.
void iMeshP_destroyPart(
- iMeshP_PartHandle part_handle,
+ iMeshP_PartHandle part,
int *err);
@@ -530,16 +525,15 @@
- * queried.
- * \param part_handle (In) Part handle for the part being queried.
- * \param part_id (Out) Part ID for part_handle.
+ * \param part (In) The part being queried.
+ * \param part_id (Out) Part ID for part.
void iMeshP_getPartIdFromPartHandle(
- const iMeshP_PartHandle part_handle,
+ const iMeshP_PartHandle part,
iMeshP_Part *part_id,
int *err);
@@ -556,22 +550,21 @@
+ * \param parts (In) Array of part handles for the parts
* being queried.
- * \param part_handles (In) Array of part handles for the parts
- * being queried.
- * \param part_handles_size (In) Number of part handles being queried.
+ * \param parts_size (In) Number of part handles being queried.
* \param part_ids (In/Out) Array of part IDs associated with the
- * part_handles.
+ * parts.
* \param part_ids_allocated (In/Out) Allocated size of part_ids array.
* \param part_ids_size (Out) Occupied size of part_ids array.
void iMeshP_getPartIdsFromPartHandlesArr(
- const iMeshP_PartHandle *part_handles,
- const int part_handles_size,
+ const iMeshP_PartHandle *parts,
+ const int parts_size,
iMeshP_Part **part_ids,
int *part_ids_allocated,
int *part_ids_size,
@@ -588,17 +581,16 @@
- * queried.
- * \param part_handle (Out) Part handle associated with part_id.
+ * \param part (Out) Part handle associated with part_id.
void iMeshP_getPartHandleFromPartId(
int *err);
@@ -615,27 +607,26 @@
* partition.
- * being queried.
* \param part_ids (In) Array of part IDs for the parts
* being queried.
* \param part_ids_size (In) Number of part IDs being queried.
- * \param part_handles (In/Out) Array of part handles associated
+ * \param parts (In/Out) Array of part handles associated
* with the part_ids.
- * \param part_handles_allocated (In/Out) Allocated size of part_handles
+ * \param parts_allocated (In/Out) Allocated size of parts
* array.
- * \param part_handles_size (Out) Occupied size of part_handles
+ * \param parts_size (Out) Occupied size of parts
* array.
void iMeshP_getPartHandlesFromPartsIdsArr(
+ int *parts_size,
int *err);
@@ -652,14 +643,12 @@
* (i.e., that (1) have copies of entities of the given entity type owned by
* the given part or (2) own entities of the given entity type that are
* copied on the given part).
- * If the part_handle is invalid, an error is returned.
- * queried.
* \param entity_type (In) Entity type of the copied entities;
* \param num_part_nbors (Out) Number of parts neighboring the given part.
@@ -667,8 +656,8 @@
void iMeshP_getNumPartNbors(
int entity_type,
int *num_part_nbors,
int *err);
@@ -683,24 +672,22 @@
- * If any part_handle is invalid, an error is returned.
* partition.
- * partition being queried.
* parts being queried.
- * \param part_handles_size (In) Number of part handles in
- * part_handles.
+ * \param parts_size (In) Number of part handles in
+ * parts.
* entities;
* \param num_part_nbors (In/Out) Array of values specifying the
* number of part neighbors for
- * each part in part_handles.
+ * each part in parts.
* \param num_part_nbors_allocated (In/Out) Allocated size of num_part_nbors
* array.
* \param num_part_nbors_size (Out) Occupied size of num_part_nbors
@@ -709,9 +696,9 @@
void iMeshP_getNumPartNborsArr(
- int part_handles_size,
+ int parts_size,
int entity_type,
int **num_part_nbors,
int *num_part_nbors_allocated,
@@ -727,23 +714,20 @@
* partition.
- * part being queried.
* entities;
* the given part.
* \param nbor_part_ids (In/Out) Array of part IDs for
- * part neighbors of part_handle.
+ * part neighbors of part.
* \param nbor_part_ids_allocated (In/Out) Allocated size of nbor_part_ids
* array.
* \param nbor_part_ids_size (Out) Occupied size of nbor_part_ids
@@ -752,8 +736,8 @@
void iMeshP_getPartNbors(
int entity_type,
iMeshP_Part **nbor_part_ids,
@@ -770,28 +754,26 @@
* partition.
+ * \param parts (In) The parts being queried.
+ * \param parts_size (In) The number of parts being queried.
* entities;
* array.
* array.
* array.
@@ -800,9 +782,9 @@
void iMeshP_getPartNborsArr(
int entity_type,
@@ -819,29 +801,27 @@
* Given a partition handle, a part handle, an entity type and topology, and a
* target part ID, return the number of entities of the given type and/or
* topology on the part boundary shared with the target part.
- * If part_handle is invalid, an error is returned.
- * queried.
* \param entity_type (In) Entity type of the boundary entities;
* \param entity_topology (In) Entity topology of the boundary entities;
- * \param target_part_id (In) Part ID with which part_handle is sharing
+ * \param target_part_id (In) Part ID with which part is sharing
* the boundary entities; may be
* iMeshP_ALL_PARTS.
* \param num_entities (Out) Number of part boundary entities shared
- * by part_handle and target_part_id.
+ * by part and target_part_id.
void iMeshP_getNumPartBdryEnts(
int entity_type,
iMeshP_Part target_part_id,
@@ -855,45 +835,42 @@
* target part ID, return the entity handles of entities of the given type
* and/or topology on the part boundary shared with the target part.
* partition.
- * queried.
* entities;
* entities;
* is sharing the boundary entities;
* may be iMeshP_ALL_PARTS.
- * \param entity_handles (In/Out) Array of entity handles for
+ * \param entities (In/Out) Array of entity handles for
* entities on the part boundary
- * between part_handle and
+ * between part and
* target_part_id.
- * \param entity_handles_allocated (In/Out) Allocated size of entity_handles
+ * \param entities_allocated (In/Out) Allocated size of entities
* array.
- * \param entity_handles_size (Out) Occupied size of entity_handles
+ * \param entities_size (Out) Occupied size of entities
* array.
void iMeshP_getPartBdryEnts(
int entity_type,
- iBase_EntityHandle **entity_handles,
- int *entity_handles_allocated,
- int *entity_handles_size,
+ iBase_EntityHandle **entities,
+ int *entities_allocated,
+ int *entities_size,
int *err);
@@ -907,19 +884,18 @@
* Iterator functionality for getNext, reset, and end is
* provided through the regular iMesh iterator functions
* iMesh_getNextEntIter, iMesh_resetEntIter, and iMesh_endEntIter,
- * respectively. If part_handle is invalid, an error is returned.
+ * respectively.
- * queried.
* iMeshP_ALL_PARTS.
* \param entity_iterator (Out) Iterator returned by the function.
@@ -927,8 +903,8 @@
void iMeshP_initPartBdryEntIter(
int entity_type,
@@ -946,21 +922,20 @@
* iMesh_getNextEntArrIter, iMesh_resetEntArrIter, and iMesh_endEntArrIter,
+ * respectively.
- * queried.
* \param array_size (In) Size of chunks of handles returned for
* each value of the iterator.
* iMeshP_ALL_PARTS.
@@ -968,8 +943,8 @@
void iMeshP_initPartBdryEntArrIter(
int entity_type,
int array_size,
@@ -989,27 +964,25 @@
* part AND the given entity set.
* This function is similar to iMesh_getNumOfType, but it also restricts
* the returned data with respect to its existence in the given part.
- * queried.
* \param num_type (Out) Number of entities of entity_type in
- * both part_handle and entity_set_handle.
+ * both part and entity_set.
void iMeshP_getNumOfType(
int entity_type,
int *num_type,
int *err);
@@ -1023,27 +996,25 @@
* This function is similar to iMesh_getNumOfTopo, but it also restricts
- * queried.
* \param num_topo (Out) Number of entities of entity_topology in
void iMeshP_getNumOfTopo(
int *num_topo,
int *err);
@@ -1065,17 +1036,14 @@
* that storage order; otherwise the storage order is the implementation's
* native order. On return, storage order contains
* order of the returned coordinates.
* partition.
- * queried.
* entity set being queried;
* may be the root set.
* \param coordinates (In/Out) Array of coordinates for
@@ -1096,9 +1064,9 @@
void iMeshP_getAllVtxCoords(
double **coordinates,
int *coordinates_allocated,
int *coordinates_size,
@@ -1128,11 +1096,9 @@
* partition.
- * queried.
@@ -1158,9 +1124,9 @@
void iMeshP_getVtxCoordIndex(
int entity_type,
int entity_adjacency_type,
@@ -1182,17 +1148,14 @@
* that are in both the part and the entity set.
* This function is similar to iMesh_getEntities, but it also restricts
* partition.
- * queried.
@@ -1201,23 +1164,23 @@
* entities;
- * entities in both part_handle
- * and entity_set_handle.
- * \param entity_handles_allocated (In/Out) Allocated size of entity_handles.
- * \param entity_handles_size (Out) Occupied size of entity_handles.
+ * entities in both part
+ * and entity_set.
+ * \param entities_allocated (In/Out) Allocated size of entities.
+ * \param entities_size (Out) Occupied size of entities.
void iMeshP_getEntities(
int entity_type,
int *err);
@@ -1233,20 +1196,17 @@
* If a non-root entity set is specified, the function also returns
* flags indicating whether each adjacent entity
* is in the entity set; (*in_entity_set)[i]=1 indicates that adjacent entity
- * (*adj_entity_handles)[i] is in the specified entity set.
+ * (*adj_entities)[i] is in the specified entity set.
* Array entry offset[i] stores the index of first adjacent entity to
* entity i.
* partition.
- * queried.
* \param entity_type_requestor (In) Return entities adjacent to
@@ -1258,12 +1218,12 @@
* \param entity_type_requested (In) Return adjacent entities of
* this type;
- * \param adj_entity_handles (In/Out) Array of adjacent entity
+ * \param adj_entities (In/Out) Array of adjacent entity
* handles returned.
- * \param adj_entity_handles_allocated (In/Out) Allocated size of
- * adj_entity_handles.
- * \param adj_entity_handles_size (Out) Occupied size of
+ * \param adj_entities_allocated (In/Out) Allocated size of
+ * adj_entities.
+ * \param adj_entities_size (Out) Occupied size of
+ * adj_entities.
* \param offset (In/Out) Array of offsets returned.
* \param offset_allocated (In/Out) Allocated size of offset.
* \param offset_size (Out) Occupied size of offset.
@@ -1271,7 +1231,7 @@
* non-root entity set was input;
* (*in_entity_set)[i]=1
* indicates
* is in the entity set.
* \param in_entity_set_allocated (In/Out) Allocated size of
* in_entity_set.
@@ -1281,15 +1241,15 @@
void iMeshP_getAdjEntities(
- const iBase_EntityHandle entity_set_handle,
+ const iBase_EntityHandle entity_set,
int entity_type_requestor,
int entity_topology_requestor,
int entity_type_requested,
- iBase_EntityHandle **adj_entity_handles,
- int *adj_entity_handles_allocated,
- int *adj_entity_handles_size,
+ iBase_EntityHandle **adj_entities,
+ int *adj_entities_allocated,
+ int *adj_entities_size,
int **offset,
int *offset_allocated,
int *offset_size,
@@ -1312,11 +1272,9 @@
* partition.
- * queried.
* entity set being queried.
* \param requested_entity_type (In) Type of entities to include in
* the iterator.
@@ -1327,9 +1285,9 @@
void iMeshP_initEntIter(
const int requested_entity_type,
const int requested_entity_topology,
iMesh_EntityIterator* entity_iterator,
@@ -1351,11 +1309,9 @@
* partition.
- * queried.
* the iterator.
@@ -1368,9 +1324,9 @@
void iMeshP_initEntArrIter(
const int requested_array_size,
@@ -1396,9 +1352,8 @@
* partition.
- * \param entity_handle (In) Entity whose owning part is to be
+ * \param entity (In) Entity whose owning part is to be
* returned.
* \param part_id (Out) Part ID of the part owning
* the entity.
@@ -1406,8 +1361,8 @@
void iMeshP_getEntOwnerPart(
- const iBase_EntityHandle entity_handle,
+ const iBase_EntityHandle entity,
int *err);
@@ -1422,12 +1377,11 @@
* partition.
- * \param entity_handles (In) Entity whose owning part is to be
+ * \param entities (In) Entity whose owning part is to be
* returned.
- * \param entity_handles_size (In) Number of entities in
- * entity_handles array.
+ * \param entities_size (In) Number of entities in
+ * entities array.
* \param part_ids (Out) Part IDs of the parts owning
* the entities.
@@ -1436,9 +1390,9 @@
void iMeshP_getEntOwnerPartArr(
- const iBase_EntityHandle *entity_handles,
- const int entity_handles_size,
+ const iBase_EntityHandle *entities,
+ const int entities_size,
int *part_ids_size,
@@ -1454,20 +1408,18 @@
- * \param entity_handle (In) Entity handle for the
- * entity whose ownership is being tested.
+ * \param entity (In) Entity whose ownership is being tested.
* \param is_owner (Out) Flag indicating whether the given part
* is the owner of the given entity.
void iMeshP_isEntOwner(
int *is_owner,
int *err);
@@ -1482,15 +1434,12 @@
* partition.
- * \param entity_handles (In) Entity handles for the
- * entities whose ownership is
+ * \param entities (In) Entities whose ownership is
* being tested.
- * \param entity_handles_size (In) Number of entity handles in
- * entity_handles.
+ * \param entities_size (In) Number of entity handles in
+ * entities.
* \param is_owner (Out) Flag for each entity indicating
* whether the given part is the
* owner of the given entity.
@@ -1500,10 +1449,10 @@
void iMeshP_isEntOwnerArr(
int **is_owner,
int *is_owner_allocated,
int *is_owner_size,
@@ -1521,20 +1470,18 @@
- * entity whose status is being tested.
+ * \param entity (In) Entity whose status is being tested.
* \param par_status (Out) Value indicating the status of the
* is the entity with respect to the part.
void iMeshP_getEntStatus(
int *par_status,
int *err);
@@ -1552,15 +1499,12 @@
* partition.
- * entities whose status is
+ * \param entities (In) Entities whose status is
* being tested.
- * entity_handles.
+ * entities.
* \param par_status (Out) Value for each entity indicating
* the status of the entity with
* respect to the part.
@@ -1571,16 +1515,17 @@
void iMeshP_getEntStatusArr(
int **par_status, /* enum iMeshP_EntStatus */
int *par_status_allocated,
int *par_status_size,
int *err);
/** \brief Return the number of copies of an entity that exist in the partition.
* Given a partition handle and an entity handle, return the number
@@ -1593,18 +1538,16 @@
- * entity whose copy info is requested.
+ * \param entity (In) Entity whose copy info is requested.
* \param num_copies_ent (Out) Number of copies of the entity that
* exist in the partition.
void iMeshP_getNumCopies(
int *num_copies_ent,
int *err);
@@ -1623,9 +1566,8 @@
* partition.
- * \param entity_handle (In) Entity handle whose copy info
* is requested.
* \param part_ids (Out) Part IDs of parts having copies
* of the given entity.
@@ -1635,8 +1577,8 @@
void iMeshP_getCopyParts(
int *part_ids_size,
@@ -1657,499 +1599,722 @@
* partition.
* is requested.
- * \param copy_handles (Out) (Remote) entity handles of the
+ * \param copies (Out) (Remote) entity handles of the
* entity copies.
- * \param copy_handles_allocated (In/Out) Allocated size of copy_handles.
- * \param copy_handles_size (Out) Occupied size of copy_handles.
+ * \param copies_allocated (In/Out) Allocated size of copies.
+ * \param copies_size (Out) Occupied size of copies.
void iMeshP_getCopies(
int *part_ids_size,
- iBase_EntityHandle **copy_handles,
- int *copy_handles_allocated,
- int *copy_handles_size,
+ iBase_EntityHandle **copies,
+ int *copies_allocated,
+ int *copies_size,
int *err);
-/** Given a partition handle, an entity handle and a part ID, return the
- * (possibly remote) entity handle of the entity in the specified part.
+/** \brief Get the entity handle of a copy of a given entity in a given part.
+ * Given a partition handle, an entity handle and a part ID,
+ * return the (remote) entity handle of the copy of the entity in that part.
* Return an error if the entity does not exist in the specified part.
- * COMMUNICATION: None++.*/
+ * COMMUNICATION: None++.
+ * \param instance (In) Mesh instance containing the
+ * partition.
+ * is requested.
+ * \param part_id (In) Part ID of part whose copy
+ * of the given entity is requested.
+ * \param copy_entity (Out) (Remote) entity handle of the
+ * entity copy from the given part.
+ * \param err (Out) Error code.
void iMeshP_getCopyOnPart(
- /*in*/ const iMeshP_PartitionHandle partition_handle,
- /*in*/ const iBase_EntityHandle entity_handle,
- /*in*/ const iMeshP_Part part_id,
- /*out*/ iBase_EntityHandle *copy_entity_handle,
- int *err);
+ const iMeshP_Part part_id,
+ iBase_EntityHandle *copy_entity,
+ int *err);
-/** Given a partition handle and an entity handle, return the entity
- * handle and part ID from the owner of the entity (e.g., the
- * entity handle of the copy that has right-to-modify).
+/** \brief Get the entity handle of a copy of a given entity in its owner part.
+ * Given a partition handle and an entity handle, return the (remote)
+ * entity handle of the copy of the entity in its owner part.
+ * partition.
+ * is requested.
+ * \param owner_part_id (Out) Part ID of the entity's owner part.
+ * \param owner_entity (Out) (Remote) entity handle of the
+ * entity copy from the owner part.
void iMeshP_getOwnerCopy(
- /*out*/ iMeshP_Part *owner_part_id,
- /*out*/ iBase_EntityHandle *owner_entity_handle,
- int *err);
+ iMeshP_Part *owner_part_id,
+ iBase_EntityHandle *owner_entity,
+ int *err);
- ------- COMMUNICATION ----------
- * Non-blocking calls for off-processor mesh-modification return a request
- * that indicates whether or not the operation has completed.
- * The following functions receive and process requests.*/
-/**\brief Wait for specified request to complete
+/*------- COMMUNICATION ----------*/
+/**\brief Wait for a specific iMeshP request to complete.
- * Wait for the specified request to complete.
- * \param req Request object to wait on
- * \param stat Status of communication request
- * \param err Error returned from function
+ * Given an iMeshP_RequestHandle, wait for the request to complete.
* COMMUNICATION: Blocking point-to-point.
+ * partition.
+ * \param request (In) iMeshP request for whose completion
+ * we should wait.
-void iMeshP_Wait(
+void iMeshP_waitForRequest(
- /*in*/ iMeshP_RequestHandle req,
- /*out*/ iMeshP_Status *stat,
- /*out*/ int *err);
+ iMeshP_RequestHandle request,
+ int *err);
-/**\brief Wait for any of the specified requests to complete
+/**\brief Wait for any of the specified iMeshP requests to complete.
- * Wait for any of the specified requests to complete.
- * \param req Request objects to wait on
- * \param req_size Number of request objects
- * \param index Index of request in req which was completed
+ * Given an array of iMeshP_RequestHandles, wait for any one of the requests
+ * to complete.
+ * partition.
+ * \param requests (In) iMeshP requests for which we wait
+ * until one request completes.
+ * \param requests_size (In) Number of requests in requests.
+ * \param index (Out) Index of the request that completed.
-void iMeshP_WaitAny(
+void iMeshP_waitForAnyRequest(
- /*in*/ iMeshP_RequestHandle *req,
- /*in*/ int req_size,
- /*out*/ int *index,
+ iMeshP_RequestHandle *requests,
+ int requests_size,
+ int *index,
+ int *err);
-/**\brief Wait for all of the specified requests to complete
+/**\brief Wait for all of the specified iMeshP requests to complete.
- * Wait for all of the specified requests to complete.
+ * Given an array of iMeshP_RequestHandles, wait for all of the requests
+ * to complete.
+ * partition.
+ * until completion.
-void iMeshP_WaitAll(
+void iMeshP_waitForAllRequests(
+ int *err);
+/**\brief Wait for a specific request to complete; return entities received.
- * Wait for the specified request to complete. Returns entities
- * for which information was \em received
- * \param entities Entities for which information was received
- * \param entities_alloc Allocated size of entities vector
- * \param entities_size Occupied size of entities vector
+ * Given an iMeshP_RequestHandle, wait for the request to complete. Return
+ * entities for which information was received.
+ * partition.
+ * we should wait.
+ * \param out_entities (Out) Entities for which information was
+ * received.
+ * \param out_entities_allocated (In/Out) Allocated size of out_entities.
+ * \param out_entities_size (Out) Occupied size of out_entities.
-void iMeshP_WaitEnt(
+void iMeshP_waitForRequestEnt(
- /*inout*/ iBase_EntityHandle **out_entities,
- /*inout*/ int *out_entities_alloc,
- /*inout*/ int *out_entities_size,
+ iBase_EntityHandle **out_entities,
+ int *out_entities_allocated,
+ int *out_entities_size,
+ int *err);
-/**\brief Test for whether specified request has completed
+/**\brief Test whether a specific request has completed.
- * Test for whether specified request has completed
- * \param flag Returned true if request completed
- * COMMUNICATION: Point-to-point; non-blocking.
+ * Given an iMeshP_RequestHandle, test whether the request has completed.
+ * This function will not wait until the request completes; it will only
+ * return the completion status (complete = 1 or 0).
+ * COMMUNICATION: None.
+ * partition.
+ * we should test.
+ * \param completed (Out) Flag indicating whether (1) or
+ * not (0) the given request has
+ * completed.
-void iMeshP_Test(
+void iMeshP_testRequest(
- /*out*/ int *flag,
+ int *completed,
+ int *err);
-/** Poll for requests. The internals of this function are going to have
- * to cover a lot of ground. The array in the return is there as a
- * placeholder to tell the application that something interesting / useful
- * has been done to a handle. This might indicate successful in-migration,
- * a recent change in vertex location, or successful completion of handle
- * matching.
- * Returns an array of requests that have been handled. If
- * the array has a size allocated already, then the implementation stops
- * working when it has generated that many completed requests, even if there
- * are more messages waiting. The syntax on this call should perhaps be
- * modified somewhat to make it more compatible with an analogous MPI call.
- * Should also perhaps have its name changed to handleMessages or some such
- * thing, since the function should not only poll for unexpected
- * messages, but also handle expected ones; these is no reason to
- * separately call two different functions to handle non-blocking receives
- * for different types of messages.
- * COMMUNICATION: non-blocking; point-to-point.
+/** \brief Poll for outstanding requests.
+ * Check for outstanding requests from other parts, handle any requests
+ * found, and return an array of requests that have been handled. If
+ * the array has a size allocated already, then the implementation stops
+ * working when it has generated that many completed requests, even if there
+ * are more requests waiting.
+ * COMMUNICATION: non-blocking; point-to-point.
+ * partition.
+ * \param requests_completed (Out) Requests that were completed.
+ * \param requests_completed_allocated (In/Out) Allocated size of
+ * requests_completed.
+ * \param requests_completed_size (Out) Occupied size of
void iMeshP_pollForRequests(
- iMeshP_RequestHandle **requests_completed,
- int *requests_allocated,
- int *requests_size,
- int *err);
+ iMeshP_RequestHandle **requests_completed,
+ int *requests_completed_allocated,
+ int *requests_completed_size,
+ int *err);
------- Requests for off-processor mesh modification -------
- * Add entities to on-process and/or off-process parts:
- * Collective-communication version:
- * iMeshP_exchEntArrToPartsPar is a collective, non-blocking operation
+/** \brief Add entities to on-process and/or off-process parts.
+ * Given a partition and a list of entities, add those entities to the
+ * target parts. The entities can be added as copies or migrated entirely
+ * (i.e., change ownership of the entities)
+ * to the parts. The entities' downward adjacencies are also copied and/or
+ * migrated as appropriate to support the entities.
+ * This function is a collective, non-blocking operation
* to be called by all processes in the partition's communicator.
- * An iMeshP_RequestHandle is returned; any of the iMeshP_Wait functions can be
- * used to block until the request is completed.
- * COMMUNICATION: Collective. Non-blocking.*/
+ * An iMeshP_RequestHandle is returned; any of the
+ * iMeshP_wait* functions can be used to block until the request is completed.
+ * COMMUNICATION: Collective. Non-blocking.
+ * \param instance (In) Mesh instance containing the partition.
+ * \param partition (In) Handle for the partition being queried.
+ * \param entities (In) Entities to be sent.
+ * \param entities_size (In) Number of entities to be sent.
+ * \param target_part_ids (In) Array of size entities_size listing
+ * the parts to which the entities should
+ * be sent.
+ * \param command_code (In) Flag indicating whether to migrate
+ * the entities or only make copies.
+ * \param update_ghost (In) Flag indicating whether (1) or not (0)
+ * ghost copies of the entities should be
+ * updated with new owner information.
+ * \param request (Out) iMeshP RequestHandle returned; can be used
+ * for blocking until this send is complete.
void iMeshP_exchEntArrToPartsAll(
- /*in*/ const iBase_EntityHandle *entity_handles,
- /*in*/ const int entity_handles_size,
- /*in*/ const iMeshP_Part *target_part_ids,
- /*in*/ int command_code, /* e.g., MIGRATE,COPY */
- /*in*/ int update_ghost, /* e.g., YES,NO */
- /*out*/ iMeshP_RequestHandle *request,
- int *err);
+ const iMeshP_Part *target_part_ids,
+ int command_code,
+ int update_ghost,
+ iMeshP_RequestHandle *request,
+ int *err);
-/** Request in-migration to a given part of an entity and its upward adjacencies.
- * This is a pull migration. The
- * entity must be on the part bdry and is identified by local handle, and
- * the implementation handles the rest. This operation will require multiple
- * rounds of communication, and at some times certain entities may be
- * locked (unavailable for local modification) while info about their
- * remote copies is still in question.
- * It's worth mentioning that implementations will have to take care to
- * migrate tags and parallel set membership as well as adjacency info.
- * CHANGES: Returns a request handle. Assumes you wouldn't be asking if
- * you didn't need the upward adjacencies as well.
- * COMMUNICATION: point-to-point, non-blocking, pull. */
+/** \brief Request in-migration of an entity and its upward adjacencies.
+ * This function is a "pull" migration, where a part requests to become the
+ * owner of an entity that is owned by another part (so that the part has
+ * the right to modify the entity). The requested
+ * entity must be on the part boundary and is identified by a local handle
+ * (i.e., an entity part-boundary copy). This operation may require multiple
+ * rounds of communication, and at some times, certain entities may be
+ * locked (unavailable for local modification) while info about their
+ * remote copies is still in question. Tags and parallel set membership
+ * are migrated as well as the appropriate adjacency info.
+ * An iMeshP request handle is returned.
+ * COMMUNICATION: point-to-point, non-blocking, pull.
+ * \param part (In) The part to which the entity is migrated.
+ * \param local_entity (In) The local entity copy for the entity to be
+ * migrated.
+ * \param request (Out) The iMeshP request handle returned.
void iMeshP_migrateEntity(
- const iBase_EntityHandle local_entity_handle,
- iMeshP_RequestHandle *request,
- int *err);
+ iBase_EntityHandle local_entity,
+ int *err);
-/** Update vertex coordinates. One could argue that we could overload
- * the setVtxCoords function to do this, and maybe we should. But that
- * obfuscates when communication could occur. The communication here is
- * push-and-forget.
- * Because this is push-and-forget, no request handle -should- be generated.
- * COMMUNICATION: point-to-point, non-blocking, push-and-forget.*/
+/** \brief Update vertex coordinates for vertex copies.
+ * For a given vertex, update its copies with the vertex's coordinates.
+ * This function assumes that a local vertex's coordinates were updated
+ * through a call to iMesh_setVtxCoords. This function then updates all
+ * copies of the vertex with the updated coordinates.
+ * The communication here is push-and-forget; as such,
+ * no request handle needs to be returned.
+ * COMMUNICATION: point-to-point, non-blocking, push-and-forget.
+ * \param local_vertex (In) The vertex whose copies should be updated.
void iMeshP_updateVtxCoords(
- const iBase_EntityHandle local_vertex_handle,
- int *err);
+ const iBase_EntityHandle local_vertex,
+ int *err);
-/** Replace entities. This refers to changes on the part bdry where the
- * application/service is responsible for ensuring that things are done
- * identically on both sides and that the args are passed in an order that
- * can be matched. (Specifically, matching new entities should appear in
- * the same order in the call array.) Communication here could be a
- * two-way push-and-forget, or some variant on push-and-confirm.
- * CHANGES: At Onkar's suggestion, added an offset array (similar to array
- * adjacency requests) so that a single call can easily handle coordination
- * with multiple entities on part-boundary.
- * COMMUNICATION: point-to-point, non-blocking, push-and-forget. */
+/** \brief Replace entities on the part boundary.
+ * This function performs changes on the part boundary where the
+ * calling application can ensure that things are done
+ * identically on both sides and that the arguments are passed in an order
+ * that can be matched. (Specifically, matching new entities should appear in
+ * the same order in the call array.) An example is creation of new
+ * boundary edges during edge splitting.
+ * Communication here could be a
+ * two-way push-and-forget, or some variant on push-and-confirm.
+ * CHANGES: At Onkar's suggestion, added an offset array (similar to array
+ * adjacency requests) so that a single call can easily handle coordination
+ * with multiple entities on part-boundary.
+ * \param old_entities (In) The entities to be replaced.
+ * \param old_entities_size (In) The number of entities to be replaced.
+ * \param new_entities (In) The entities that replace the old entities.
+ * \param new_entities_size (In) The number of entities in new_entities.
+ * \param offset (In) Index into new_entities; old_entities[i]
+ * is replaced by new_entities[offset[i]] to
+ * new_entities[offset[i+1]-1].
+ * \param offset_size (In) The number of entries in offset.
void iMeshP_replaceOnPartBdry(
- const iBase_EntityHandle *old_entities,
- const int old_entities_size,
- const iBase_EntityHandle *new_entities,
- const int new_entities_size,
- const int *offset,
- const int offset_size,
- int *err);
+ const iBase_EntityHandle *old_entities,
+ const int old_entities_size,
+ const iBase_EntityHandle *new_entities,
+ const int new_entities_size,
+ const int *offset,
+ const int offset_size,
+ int *err);
-/** The ability to create and delete copies is likely
- * to be useful, even though for common topologically-based cases, copies
- * maintainance can (and IMO should) be done automagically, either at
- * migration time or during iMeshP_syncMeshAll.
- * Communication here is
- * push-and-confirm for creation (so that the original knows ID's of the
- * ghosts), push-and-forget for deletion (in the latter case, no request
- * handle is needed). I'm assuming here that the closure of a new ghost
- * will be pushed automatically as part of the underlying communication,
- * and that the remote part will clean up the closure as appropriate during
- * deletion.
- * COMMUNICATION: point-to-point, non-blocking, push.*/
+/** \brief Push ghost copies of individual entities onto other parts.
+ * Given an entity and a target part, create a ghost copy of the entity on
+ * the target part.
+ * Communication here is push-and-confirm (so that the original knows remote
+ * entity handle of the created ghosts). The closure of a new ghost is pushed
+ * automatically as part of the underlying communication.
+ * COMMUNICATION: point-to-point, non-blocking, push.
+ * \param target_part_id (In) The part to receive the new ghost.
+ * \param entity_to_copy (In) The entity to be copied in target_part_id.
void iMeshP_addGhostOf(
- /* in */ const iMeshP_PartitionHandle partition_handle,
- /* in */ const iMeshP_Part target_part_id,
- /* in */ const iBase_EntityHandle entity_to_copy,
- /* out */ iMeshP_RequestHandle *request,
- int *err);
+ const iMeshP_Part target_part_id,
+ iBase_EntityHandle entity_to_copy,
+ int *err);
+/** \brief Remove ghost copies of individual entities from other parts.
+ * Given an entity and a target part, remove the ghost copy of the entity on
+ * Communication is push-and-forget; as such, no request handle is needed.
+ * The remote part will clean up the closure of the removed ghost
+ * as appropriate during deletion.
+ * \param target_part_id (In) The part to lose the ghost.
+ * \param copy_to_purge (In) The entity whose ghost is removed from
+ * target_part_id.
void iMeshP_rmvGhostOf(
- /* in */ const iBase_EntityHandle copy_to_purge,
- int *err);
+ iBase_EntityHandle copy_to_purge,
+ int *err);
-/** Done with mesh modification. This is a blocking call, to get
- * everything up-to-date and back in synch. Essentially, waits for all
- * message traffic to clear, as well as (possibly) rebuilding a bunch of
- * ghost info that was allowed to go obsolete.*/
+/** \brief Indicate completion of mesh modification.
+ * Calling this function indicates that the user is finished with mesh
+ * modification for now. With mesh modification complete, the implementation
+ * can update ghost, partition, boundary, and other information to
+ * re-establish a valid distributed mesh. This function waits for all
+ * message traffic to clear and rebuilds ghost information that was
+ * allowed to go obsolete during mesh modification.
+ * COMMUNICATION: collective.
void iMeshP_syncMeshAll(
- int *err);
+ int *err);
-/* Functions to send Tag data from owning entities to copies.*/
+/* Functions to send Tag data from owning entities to copies. */
-/**\brief Synchronously send tag data for entity type/topo
- * and part
+/**\brief Synchronously send tag data for given entity types and topologies.
- * Send tag information for shared entities of specified type/
- * topology to specified part.
- * The tag data is "pushed" from the
- * owner entities to all copies.
- * This version operates on all
- * shared entities of specified type/topology (or all
- * types/topologies if iMesh_ALL_TYPE or iMesh_ALL_TOPOLOGIES are
- * given). This function assumes tag handles given on various
- * calling parts are consistent, i.e. they have the same name,
- * data type, size, etc. This call blocks until communication is
- * completed
- * \param tag Tag handle to exchange
- * \param entity_type Tag data exchanged only for this entity type
- * \param entity_topo Tag data exchanged only for this entity topology
+ * Send tag information for shared entities of specified type and
+ * topology. The tag data is "pushed" from the owner entities to all copies.
+ * This version operates on all shared entities of specified type and topology
+ * (or all types/topologies if iBase_ALL_TYPES/iMesh_ALL_TOPOLOGIES are
+ * given). This function assumes tag handles given on various
+ * calling parts are consistent; i.e. they have the same name,
+ * data type, size, etc. This call blocks until communication is
+ * completed.
+ * COMMUNICATION: point-to-point, blocking.
+ * \param source_tag (In) Tag handle for the sending entities.
+ * \param dest_tag (In) Tag handle for the receiving entities.
+ * \param entity_type (In) Tag data is exchanged only for this
+ * entity type.
+ * \param entity_topo (In) Tag data is exchanged only for this
+ * entity topology.
void iMeshP_pushTags(
- /*in*/ iBase_TagHandle tag,
- /*in*/ int entity_type,
- /*in*/ int entity_topo,
+ iBase_TagHandle source_tag,
+ iBase_TagHandle dest_tag,
+ int entity_type,
+ int entity_topo,
+ int *err);
-/**\brief Synchronously send tag data for entities and part
+/**\brief Synchronously send tag data for individual entities.
- * Send tag information for specified entities, which must
- * already be shared.
- * This function assumes tag handles given on various
- * completed
- * \param entities Owned entities for which to send data
- * \param entities_size Number of entities
+ * Send tag information for the specified entities.
+ * The tag data is "pushed" from the owner entities to all copies.
+ * This function assumes tag handles given on various
+ * completed.
+ * \param entities (In) Owned entities for which to send data.
+ * \param entities_size (In) The number of entities for which to send data.
void iMeshP_pushTagsEnt(
- /*in*/ const iBase_EntityHandle *entities,
- /*in*/ int entities_size,
+ int entities_size,
+ int *err);
-/**\brief Asynchronously send tag data for entity type/topo
- * and part
+/**\brief Asynchronously send tag data for given entity types and topologies.
- * data type, size, etc. Applications can call iMeshP_Wait or
- * iMeshP_WaitEnt to block until associated call completes
- * \param iMeshP_RequestHandle Request object used in call to
- * iMeshP_Wait or iMeshP_WaitEnt
+ * This call does not block; applications should call
+ * iMeshP_waitForRequest (or a similar wait function)
+ * to block until this push is completed.
+ * COMMUNICATION: point-to-point, non-blocking.
+ * entity type.
void iMeshP_iPushTags(
- /*out*/ iMeshP_RequestHandle *req,
+ int entity_type,
+ int entity_topo,
+ int *err);
-/**\brief Asynchronously send tag data for entities and part
+/**\brief Asynchronously send tag data for individual entities.
- * Sedn tag information for specified entities, which must
void iMeshP_iPushTagsEnt(
+ int *err);
-/* GHOST ENTITY SUPPORT */
-The triplet describing a ghosting "rule" (ghost dim, bridge dim, #
-layers) will be stored in the partition and re-established by the end
-of iMeshP_syncPartitionAll and iMeshP_syncMeshAll. Implementations can
-choose to keep ghosting consistent throughout mesh modification, but ghosts
-are not required to be consistent until the end of these two functions.
-The number of layers specified is with respect to the global mesh;
-that is, ghosting may extend beyond a single neighboring processor if the
-number of layers is high.
+ * GHOSTING *
-iMeshP_createGhostEntities is a preprocessing function. It is
-cumulative; that is, multiple calls may add more ghosts, not eliminate
-previous ghosts.
+/* \brief Create ghost entities between parts.
+ * Ghost entities are specified similar to 2nd-order adjacencies, i.e.,
+ * through a "bridge" dimension. The number of layers is measured from
+ * the inter-part interfaces. For example, to get two layers of region
+ * entities in the ghost layer, measured from faces on the interface,
+ * use ghost_dim=3, bridge_dim=2, and num_layers=2.
+ * The number of layers specified is with respect to the global mesh;
+ * that is, ghosting may extend beyond a single neighboring processor if the
+ * number of layers is high.
+ * Ghost information is cached in the partition.
+ * The triplet describing a ghosting "rule" (ghost dim, bridge dim, #
+ * layers) is stored in the partition; ghosting that became incorrect
+ * due to mesh modification or redistribution of mesh entities is
+ * re-established using these rules by the end
+ * of iMeshP_syncPartitionAll and iMeshP_syncMeshAll.
+ * Implementations can choose to keep ghosting consistent throughout
+ * mesh modification, but ghosts are not required to be consistent until
+ * the end of these two functions.
-/* \brief Create ghost entities between parts/processors.
- * Ghost entities are specified similar to 2nd-order adjacencies, i.e.
- * through a "bridge" dimension. Number of layers is measured from
- * the inter-processor interfaces. For example, to get 2 layers of hex
- * entities in the ghost layer, measured from faces on the interface,
- * use ghost_dim=3, bridge_dim=2, and num_layers=2.
- * Ghost information is cached on the partition.
- * \param instance iMesh instance
- * \param partition_handle Partition on which to create ghosts
- * \param ghost_type Entity type of entities ghosted
- * \param bridge_type Entity type through which bridge adjacencies are found
- * \param num_layers Number of layers of ghost entities
- * \param include_copies Create ghosts of non-owned part boundary entities?
- * (1/0)
- * COMMUNICATION: Collective. Blocking.
-void iMeshP_createGhostEnts(/*in*/ iMesh_Instance instance,
- /*in*/ iMeshP_PartitionHandle partition_handle,
- /*in*/ int ghost_type,
- /*in*/ int bridge_type,
- /*in*/ int num_layers,
- /*in*/ int include_copies,
+ * iMeshP_createGhostEntsAll is cumulative; that is, multiple calls can only
+ * add more ghosts, not eliminate previous ghosts.
+ * COMMUNICATION: Collective. Blocking.
+ * \param partition (In) The partition in which to create ghosts.
+ * \param ghost_type (In) Entity type of entities to be ghosted.
+ * \param bridge_type (In) Entity type through which bridge
+ * adjacencies are found.
+ * \param num_layers (In) Number of layers of ghost entities.
+ * \param include_copies (In) Flag indicating whether to create ghosts
+ * of non-owned part boundary entities
+ * (YES=1, NO=0).
+void iMeshP_createGhostEntsAll(
+ iMesh_Instance instance,
+ int ghost_type,
+ int bridge_type,
+ int num_layers,
+ int include_copies,
+ int *err);
-/* \brief Delete all ghost entities between parts/processors.
- * \param partition_handle Partition on which ghost entities are deleted
- * COMMUNICATION: None.
-void iMeshP_deleteGhostEnts(/*in*/ iMesh_Instance instance,
-/* \brief Return information about all ghosting on a partition.
- * \param num_ghost_rules Number of ghosting rules currently registered
- * \param ghost_type Entity type of ghost entities
- * \param bridge_type Entity type of bridge entities
-void iMeshP_ghostEntInfo(/*in*/ iMesh_Instance instance,
- /*out*/ int *num_ghost_rules,
- /*inout*/ int *ghost_rules_allocated,
- /*inout*/ int *ghost_rules_size,
- /*out*/ int **ghost_type,
- /*out*/ int **bridge_type,
- /*out*/ int **num_layers,
+/* \brief Delete all ghost entities between parts.
+ * Given a partition, delete all ghost entities in that partition of the mesh.
+ * \param partition (In) The partition from which to delete ghosts.
+void iMeshP_deleteGhostEntsAll(
+ int *err);
+/** \brief Return information about all ghosting on a partition.
+ * Return the ghosting rules established through calls to
+ * iMeshP_createGhostEntsAll.
+ * partition.
+ * \param partition (In) The partition to be queried.
+ * \param ghost_rules_allocated (In/Out) Allocated size of ghost_type,
+ * bridge_type and num_layers.
+ * \param ghost_rules_size (Out) Occupied size of ghost_type,
+ * bridge_type and num_layers;
+ * equal to the number of ghosting
+ * rules currently registered in
+ * the partition.
+ * \param ghost_type (Out) Entity type of ghost entities
+ * for each rule.
+ * \param bridge_type (Out) Entity type of bridge entities
+ * for each rule.
+ * \param num_layers (Out) Number of layers of ghosts in each
+ * rule.
+void iMeshP_ghostEntInfo(
+ const iMesh_Instance instance,
+ int *ghost_rules_allocated,
+ int *ghost_rules_size,
+ int **ghost_type,
+ int **bridge_type,
+ int **num_layers,
+ int *err);
FILE I/O
/* iMeshP file I/O closely aligns with iMesh file I/O. The major
* change is the addition of a iMeshP_PartitionHandle argument to both
- * iMeshP_load and iMeshP_save, enabling I/O from parallel processes.
+ * iMeshP_loadAll and iMeshP_saveAll, enabling I/O from parallel processes.
* For now, individual implementations will support different sets of
* options; Tim and Ken will work to unify the options by SC08.
/** \brief Populate a mesh instance and a partition by reading data from files.
- * Before calling iMeshP_load, the application creates both a mesh
- * instance and a partition handle. iMeshP_load then reads the
+ * Before calling iMeshP_loadAll, the application creates both a mesh
+ * instance and a partition handle. iMeshP_loadAll then reads the
* specified file, inserts entities into the mesh instance, constructs
* parts within the partition, and inserts entities into the parts.
* Options allow n>=1 files on p processes.
- * Optional capabilities of iMeshP_load include computing an initial
+ * Optional capabilities of iMeshP_loadAll include computing an initial
* partition (e.g., if a serial mesh file without part assignments is read)
* and creating ghost entities as requested by the application; the
* availability of these options is implementation dependent.
@@ -2157,19 +2322,18 @@
* \param instance (In) Mesh instance to contain the data.
- * \param partition_handle (In) Partition handle for the newly
- * populated partition.
- * \param entity_set_handle (In) Set to which the mesh will be added.
+ * \param partition (In) The newly populated partition.
+ * \param entity_set (In) Set to which the mesh will be added.
* \param name (in) File name from which mesh data is read.
* \param options (In) Implementation-specific options string.
* \param name_len (In) Length of the file name character string.
* \param options_len (In) Length of the options character string.
-void iMeshP_load(
+void iMeshP_loadAll(
const char *name,
const char *options,
int *err,
@@ -2178,25 +2342,24 @@
/** \brief Write data from a mesh instance and a partition to files.
- * iMeshP_save writes mesh and partition data to the specified file.
+ * iMeshP_saveAll writes mesh and partition data to the specified file.
- * saved.
- * \param entity_set_handle (In) Set from which data will be saved.
+ * \param partition (In) The partition being saved.
+ * \param entity_set (In) Set from which data will be saved.
* \param name (in) File name to which mesh data is written.
-void iMeshP_save(
+void iMeshP_saveAll(
const char *name,
int *err,
@@ -2487,4 +2650,3 @@
#endif
#endif /* defined(iMeshP_h) */
Modified: MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp 2008-11-13 18:35:34 UTC (rev 2236)
+++ MOAB/trunk/tools/iMesh/iMeshP_MOAB.cpp 2008-11-13 19:27:16 UTC (rev 2237)
@@ -700,7 +700,7 @@
int adj_part_id,
MBRange& entities_out)
- int* adj_part_id_ptr = ((unsigned)adj_part_id == iMeshP_ALL_PARTS) ? 0 : &adj_part_id;
+ int* adj_part_id_ptr = (adj_part_id == iMeshP_ALL_PARTS) ? 0 : &adj_part_id;
MBRange iface_sets;
MBErrorCode rval = pcomm->get_interface_sets(
@@ -1348,44 +1348,35 @@
MBRTN(rval);
-void iMeshP_Wait( iMesh_Instance instance,
- iMeshP_RequestHandle req,
- iMeshP_Status *stat,
- int *err )
+void iMeshP_waitForAnyRequest( iMesh_Instance instance,
+ iMeshP_PartitionHandle partition_handle,
+ int request_size,
+ int* index,
+ int* err )
{ FIXME; RETURN(iBase_NOT_SUPPORTED); }
-void iMeshP_WaitAny( iMesh_Instance instance,
- iMeshP_RequestHandle *req,
- int req_size,
- int *index,
- int *err )
+void iMeshP_waitForAllRequests( iMesh_Instance instance,
+ int *err )
-void iMeshP_WaitAll( iMesh_Instance instance,
- int req_size,
- int *err )
+ int *err)
-void iMeshP_WaitEnt( iMesh_Instance instance,
- iBase_EntityHandle **out_entities,
- int *out_entities_alloc,
- int *out_entities_size,
- int *err )
-{ FIXME; RETURN(iBase_NOT_SUPPORTED); }
-void iMeshP_Test( iMesh_Instance instance,
+void iMeshP_testRequest( iMesh_Instance instance,
- int *flag,
+ int *complete,
int *err )
@@ -1463,11 +1454,16 @@
void iMeshP_pushTags( iMesh_Instance instance,
- iBase_TagHandle tag,
int entity_type,
int entity_topo,
int *err )
+ if (source_tag != dest_tag)
+ RETURN (iBase_NOT_SUPPORTED);
+ iBase_TagHandle tag = source_tag;
MBParallelComm* pcomm = PCOMM;
MBDimensionPair types;
if (entity_topo != iMesh_ALL_TOPOLOGIES)
@@ -1495,11 +1491,16 @@
void iMeshP_pushTagsEnt( iMesh_Instance instance,
int entities_size,
int *err )
MBRange range;
const MBEntityHandle* ents = itaps_cast<const MBEntityHandle*>(entities);
std::copy( ents, ents+entities_size, mb_range_inserter(range) );
@@ -1512,7 +1513,8 @@
void iMeshP_iPushTags( iMesh_Instance instance,
int entity_type,
int entity_topo,
@@ -1521,7 +1523,8 @@
void iMeshP_iPushTagsEnt( iMesh_Instance instance,
int entities_size,
@@ -1552,9 +1555,8 @@
int *err )
-void iMeshP_ghostEntInfo( iMesh_Instance instance,
- int *num_ghost_rules,
+void iMeshP_ghostEntInfo( const iMesh_Instance instance,
+ const iMeshP_PartitionHandle partition_handle,
int **ghost_dim,
@@ -1616,7 +1618,7 @@
-void iMeshP_load( iMesh_Instance instance,
+void iMeshP_loadAll( iMesh_Instance instance,
const char *name,
@@ -1661,7 +1663,7 @@
MBRTN(rval);
-void iMeshP_save( iMesh_Instance instance,
+void iMeshP_saveAll( iMesh_Instance instance,
const char *name,
Modified: MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp 2008-11-13 18:35:34 UTC (rev 2236)
+++ MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp 2008-11-13 19:27:16 UTC (rev 2237)
@@ -531,7 +531,7 @@
// write file
iBase_EntitySetHandle root_set;
iMesh_getRootSet( imesh, &root_set, &ierr );
- iMeshP_save( imesh, partition, root_set, filename, 0, &ierr, strlen(filename), 0 );
+ iMeshP_saveAll( imesh, partition, root_set, filename, 0, &ierr, strlen(filename), 0 );
CHKERR;
iMesh_dtor( imesh, &ierr ); CHKERR;
@@ -551,7 +551,7 @@
- iMeshP_load( imesh, prtn, root_set, FILENAME, 0, &ierr, strlen(FILENAME), 0 );
+ iMeshP_loadAll( imesh, prtn, root_set, FILENAME, 0, &ierr, strlen(FILENAME), 0 );
PCHECK;
