[MOAB-dev] r2238 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov
Thu Nov 13 13:28:26 CST 2008
Author: kraftche
Date: 2008-11-13 13:28:26 -0600 (Thu, 13 Nov 2008)
New Revision: 2238
Modified:
MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp
Log:
add some utility code for attaching a debugger to only one proc and fix bugs in a test
Modified: MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp
--- MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp 2008-11-13 19:27:16 UTC (rev 2237)
+++ MOAB/trunk/tools/iMesh/iMeshP_unit_tests.cpp 2008-11-13 19:28:26 UTC (rev 2238)
@@ -8,6 +8,10 @@
#include <math.h>
#include <map>
+#ifndef _MSC_VER
+#include <unistd.h>
+#endif
#define STRINGIFY_(X) #X
#define STRINGIFY(X) STRINGIFY_(X)
const char* const FILENAME = "iMeshP_test_file";
@@ -322,6 +326,21 @@
MPI_Comm_rank( MPI_COMM_WORLD, &rank );
MPI_Comm_size( MPI_COMM_WORLD, &size );
+ if (argc > 2 && !strcmp(argv[1], "-p")) {
+#ifndef _MSC_VER
+ std::cout << "Processor " << rank << " of " << size << " with PID " << getpid() << std::endl;
+ std::cout.flush();
+#endif
+ // loop forever on requested processor, giving the user time
+ // to attach a debugger. Once the debugger in attached, user
+ // can change 'stop'. E.g. on gdb do "set var stop = 1"
+ if (atoi(argv[2]) == rank) {
+ volatile int stop = 0;
+ while (!stop);
+ MPI_Barrier(MPI_COMM_WORLD);
if (rank == 0) {
ierr = create_mesh( FILENAME, size );
@@ -1213,9 +1232,9 @@
// get vertices in quads
iBase_EntityHandle conn[16];
- int offsets[4], *off_ptr = offsets, junk3 = 4, junk4;
+ int offsets[5], *off_ptr = offsets, junk3 = 5, junk4;
ptr = conn;
- junk1 = 4;
+ junk1 = 16;
iMesh_getEntArrAdj( imesh, quads, 4, iBase_VERTEX,
&ptr, &junk1, &junk2,
&off_ptr, &junk3, &junk4,
@@ -1225,10 +1244,10 @@
assert( junk1 == 16 );
assert( junk2 == 16 );
assert( off_ptr == offsets );
- assert( junk3 == 4 );
- assert( junk4 == 4 );
+ assert( junk3 == 5 );
+ assert( junk4 == 5 );
- // make unique vertex li8st
+ // make unique vertex list
std::sort( conn, conn + 16 );
const int num_vtx = std::unique( conn, conn+16 ) - conn;
assert(9 == num_vtx);
