[MOAB-dev] r2236 - MOAB/trunk/tools/iMesh
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Thu Nov 13 12:35:34 CST 2008
Author: kraftche
Date: 2008-11-13 12:35:34 -0600 (Thu, 13 Nov 2008)
New Revision: 2236
Modified:
   MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
Log:
o Fix an earlier checkin of mine that completely broke iMesh iterators
  (current position was being initialized to some other, empty MBRange.)
o Fix iMesh_getNextEntArrIter: has_data must be set to false during the
  last successful query.  It previously only did so if the size of the
  range was not a multiple of the iterator size such that it reached the
  end of the range before completely filling the input array.  This almost
  always worked for array iterators, but resulting in single-entity
  iterators being broken (as they share the same step code and the range
  size is always a multple of one.)
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2008-11-13 15:32:25 UTC (rev 2235)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp	2008-11-13 18:35:34 UTC (rev 2236)
@@ -188,7 +188,7 @@
   RangeIterator* iter = new RangeIterator;
   if (iter) {
     iter->iteratorRange.swap(range);
-    iter->currentPos = range.begin();
+    iter->currentPos = iter->iteratorRange.begin();
     iter->requestedSize = array_size;
   return iter;
@@ -879,7 +879,7 @@
                                 /*inout*/ iBase_EntityHandle** entity_handles,
                                 /*inout*/ int* entity_handles_allocated,
                                 /*out*/ int* entity_handles_size,
-                                int *is_end, int *err)
+                                int *has_data, int *err)
     RangeIterator *this_it = RANGE_ITERATOR(entArr_iterator);
@@ -889,21 +889,16 @@
     CHECK_SIZE(*entity_handles, *entity_handles_allocated, expected_size,
                iBase_EntityHandle, false);
-    int j = 0, i;
-    for (i = 0; i < this_it->requestedSize; ++i, ++this_it->currentPos)
+    int i = 0;
+    while (i < this_it->requestedSize && this_it->currentPos != this_it->iteratorRange.end())
-      if (this_it->currentPos == this_it->iteratorRange.end()) {
-        *is_end = false;
-        *entity_handles_size = j;
-        RETURN(iBase_SUCCESS);
       if (MBimesh->is_valid(*this_it->currentPos))
-        (*entity_handles)[j++] = (iBase_EntityHandle)*this_it->currentPos;
+        (*entity_handles)[i++] = (iBase_EntityHandle)*(this_it->currentPos);
+      ++(this_it->currentPos);
-    *is_end = true;
+    *has_data = (this_it->currentPos != this_it->iteratorRange.end());
+    *entity_handles_size = i;
