[MOAB-dev] r1853 - MOAB/trunk
kraftche at mcs.anl.gov
Wed May 28 15:29:35 CDT 2008
Author: kraftche
Date: 2008-05-28 15:29:35 -0500 (Wed, 28 May 2008)
New Revision: 1853
Modified:
MOAB/trunk/MBGeomUtil.cpp
MOAB/trunk/MBGeomUtil.hpp
Log:
More optimizations for MBGeomUtil::box_linear_elem_overlap
- early check for vertex-in-box indicating overlap
- translate elem cordinates into local coordinate system of box
- unroll/reorder loops
Current box_linear_elem_overlap is at least. twice as fast as
MBGeomUtil::box_hex_overlap
Modified: MOAB/trunk/MBGeomUtil.cpp
--- MOAB/trunk/MBGeomUtil.cpp 2008-05-28 19:44:00 UTC (rev 1852)
+++ MOAB/trunk/MBGeomUtil.cpp 2008-05-28 20:29:35 UTC (rev 1853)
@@ -303,6 +303,19 @@
const MBCartVect& box_center,
const MBCartVect& box_halfdims )
+ MBCartVect corners[8];
+ const unsigned num_corner = MBCN::VerticesPerEntity( type );
+ assert( num_corner <= sizeof(corners)/sizeof(corners[0]) );
+ for (unsigned i = 0; i < num_corner; ++i)
+ corners[i] = elem_corners[i] - box_center;
+ return box_linear_elem_overlap( corners, type, box_halfdims );
+bool box_linear_elem_overlap( const MBCartVect *elem_corners,
+ MBEntityType type,
+ const MBCartVect& dims )
// Do Separating Axis Theorem:
// If the element and the box overlap, then the 1D projections
// onto at least one of the axes in the following three sets
@@ -312,76 +325,131 @@
// (crossproduct of each edge with each principal axis)
// 3) The normals of the faces of the element
- unsigned d, i, e, f; // loop counters
- bool all_less, all_greater; // track overlap (or lack thereof)
- double min, max, cross[2], tmp;
+ unsigned i, e, f; // loop counters
+ bool all_less, all_greater; // track overlap (or lack thereof)
+ double dot, cross[2], tmp;
MBCartVect norm;
int indices[4]; // element edge/face vertex indices
- // calculate minimum and maximum corners of extents box
- const MBCartVect box_min( box_center - box_halfdims );
- const MBCartVect box_max( box_center + box_halfdims );
- // get element topology information
- const unsigned num_corner = MBCN::VerticesPerEntity( type );
- const unsigned num_edge = MBCN::NumSubEntities( type, 1 );
- const unsigned num_face = MBCN::NumSubEntities( type, 2 );
// test box face normals (principal axes)
- for (d = 0; d < 3; ++d) { // for each principal axis
- all_less = all_greater = true;
- for (i = 0; i < num_corner; ++i) { // for each element corner
- if (elem_corners[i][d] > box_min[d])
- all_less = false;
- if (elem_corners[i][d] < box_max[d])
- all_greater = false;
- if (all_greater || all_less)
- return false;
- // test edge-edge crossproducts
- for (d = 0; d < 3; ++d) { // for each principal axis (box edge)
- // get indices of other two axes
- const int idx1 = (d+1)%3;
- const int idx2 = (d+2)%3;
+ int not_less[3] = { num_corner, num_corner, num_corner };
+ int not_greater[3] = { num_corner, num_corner, num_corner };
+ int not_inside;
+ for (i = 0; i < num_corner; ++i) { // for each element corner
+ not_inside = 3;
- for (e = 0; e < num_edge; ++e) { // for each element edge
- // get which element vertices bound the edge
- MBCN::SubEntityVertexIndices( type, 1, e, indices );
- // calculate crossproduct: axis x (v1 - v0),
- // where v1 and v0 are edge vertices.
- cross[0] = elem_corners[indices[0]][idx2] - elem_corners[indices[1]][idx2];
- cross[1] = elem_corners[indices[1]][idx1] - elem_corners[indices[0]][idx1];
- // skip if orthogonal
- if ((cross[0]*cross[0] + cross[1]*cross[1]) < std::numeric_limits<double>::epsilon())
- continue;
+ if (elem_corners[i][0] < -dims[0])
+ --not_less[0];
+ else if (elem_corners[i][0] > dims[0])
+ --not_greater[0];
+ else
+ --not_inside;
- // first box vertex
- min = max = cross[0] * box_min[idx1] + cross[1] * box_min[idx2];
- // second box vertex
- tmp = cross[0] * box_min[idx1] + cross[1] * box_max[idx2];
- if (tmp < min) min = tmp; else if (tmp > max) max = tmp;
- // third box vertex
- tmp = cross[0] * box_max[idx1] + cross[1] * box_max[idx2];
- // fourth box vertex
- tmp = cross[0] * box_max[idx1] + cross[1] * box_min[idx2];
+ if (elem_corners[i][1] < -dims[1])
+ --not_less[1];
+ else if (elem_corners[i][1] > dims[1])
+ --not_greater[1];
+ else
+ --not_inside;
+ if (elem_corners[i][2] < -dims[2])
+ --not_less[2];
+ else if (elem_corners[i][2] > dims[2])
+ --not_greater[2];
+ else
+ --not_inside;
+ if (!not_inside)
+ return true;
+ // If all points less than min_x of box, then
+ // not_less[0] == 0, and therfore
+ // the following product is zero.
+ if (not_greater[0] * not_greater[1] * not_greater[2] *
+ not_less[0] * not_less[1] * not_less[2] == 0)
+ return false;
+ // Test edge-edge crossproducts
+ // Edge directions for box are principal axis, so
+ // for each element edge, check along the cross-product
+ // of that edge with each of the tree principal axes.
+ const unsigned num_edge = MBCN::NumSubEntities( type, 1 );
+ for (e = 0; e < num_edge; ++e) { // for each element edge
+ // get which element vertices bound the edge
+ MBCN::SubEntityVertexIndices( type, 1, e, indices );
+ // X-Axis
+ // calculate crossproduct: axis x (v1 - v0),
+ // where v1 and v0 are edge vertices.
+ cross[0] = elem_corners[indices[0]][2] - elem_corners[indices[1]][2];
+ cross[1] = elem_corners[indices[1]][1] - elem_corners[indices[0]][1];
+ // skip if orthogonal
+ if ((cross[0]*cross[0] + cross[1]*cross[1]) >= std::numeric_limits<double>::epsilon()) {
+ dot = fabs(cross[0] * dims[1]) + fabs(cross[1] * dims[2]);
for (i = (unsigned)(indices[0]+1)%num_corner; i != (unsigned)indices[0]; i = (i+1)%num_corner) { // for each element corner
- tmp = cross[0] * elem_corners[i][idx1] + cross[1] * elem_corners[i][idx2];
- if (tmp > min)
+ tmp = cross[0] * elem_corners[i][1] + cross[1] * elem_corners[i][2];
+ if (tmp > -dot)
all_less = false;
- if (tmp < max)
+ if (tmp < dot)
if (all_less || all_greater)
return false;
+ // Y-Axis
+ cross[0] = elem_corners[indices[0]][0] - elem_corners[indices[1]][0];
+ cross[1] = elem_corners[indices[1]][2] - elem_corners[indices[0]][2];
+ dot = fabs(cross[0] * dims[2]) + fabs(cross[1] * dims[0]);
+ all_less = all_greater = true;
+ for (i = (unsigned)(indices[0]+1)%num_corner; i != (unsigned)indices[0]; i = (i+1)%num_corner) { // for each element corner
+ tmp = cross[0] * elem_corners[i][2] + cross[1] * elem_corners[i][0];
+ if (tmp > -dot)
+ all_less = false;
+ if (tmp < dot)
+ all_greater = false;
+ if (all_less || all_greater)
+ return false;
+ // Z-Axis
+ cross[0] = elem_corners[indices[0]][1] - elem_corners[indices[1]][1];
+ cross[1] = elem_corners[indices[1]][0] - elem_corners[indices[0]][0];
+ dot = fabs(cross[0] * dims[0]) + fabs(cross[1] * dims[1]);
+ tmp = cross[0] * elem_corners[i][0] + cross[1] * elem_corners[i][1];
+ if (tmp > -dot)
+ all_less = false;
+ if (tmp < dot)
+ return false;
// test element face normals
+ const unsigned num_face = MBCN::NumSubEntities( type, 2 );
for (f = 0; f < num_face; ++f) {
MBCN::SubEntityVertexIndices( type, 2, f, indices );
switch (MBCN::SubEntityType( type, 2, f )) {
@@ -400,49 +468,26 @@
assert(false);
continue;
- // first box corner
- min = max = norm % box_min;
- // second corner
- tmp = norm % MBCartVect( box_max[0], box_min[1], box_min[2] );
- // third corner
- tmp = norm % MBCartVect( box_max[0], box_max[1], box_min[2] );
- // fourth corner
- tmp = norm % MBCartVect( box_min[0], box_max[1], box_min[2] );
- // fifth corner
- tmp = norm % MBCartVect( box_min[0], box_min[1], box_max[2] );
- // sixth corner
- tmp = norm % MBCartVect( box_max[0], box_min[1], box_max[2] );
- // seventh corner
- tmp = norm % box_max;
- // eighth corner
- tmp = norm % MBCartVect( box_min[0], box_max[1], box_max[2] );
+ dot = fabs(norm[0] * dims[0]) + fabs(norm[1] * dims[1]) + fabs(norm[2] * dims[2]);
// for each element vertex
tmp = norm % elem_corners[i];
- if (tmp > min)
+ if (tmp > -dot)
all_less = false;
- if (tmp < max)
+ if (tmp < dot)
return false;
// Overlap on all tested axes.
return true;
Modified: MOAB/trunk/MBGeomUtil.hpp
--- MOAB/trunk/MBGeomUtil.hpp 2008-05-28 19:44:00 UTC (rev 1852)
+++ MOAB/trunk/MBGeomUtil.hpp 2008-05-28 20:29:35 UTC (rev 1853)
@@ -179,6 +179,22 @@
const MBCartVect& box_half_dims );
+/**\brief Test if the specified element intersects an axis-aligned box.
+ * Uses MBCN and separating axis theorem for general algorithm that
+ * works for all fixed-size elements (not poly*). Box and element
+ * vertices must be translated such that box center is at origin.
+ *\param elem_corners The coordinates of the element vertices, in
+ * local coordinate system of box.
+ *\param elem_type The toplogy of the element.
+ *\param box_half_dims Half of the width of the box in each axial
+ * direction.
+ MBEntityType elem_type,
+ const MBCartVect& box_half_dims );
void closest_location_on_box( const MBCartVect& box_min_corner,
const MBCartVect& box_max_corner,
const MBCartVect& point,
